So I went to a deep dark place with my Truma in the past because I always had condensate dripping down the curbside of my trailer and none down the street side, or from either condensate lines under the trailer. The condensate lines cross so that meant I was not getting any drainage from the curb side condensate tray. There is a second outlet on each side of the condensate tray that is supposed to allow water to drain down the side of the trailer if the condensate line is occluded. To make a long story short, the condensate line that drains to the street side was occluded somewhere in between the inner and outer hull, and I could not access this area. I remedied the problem by getting a y fitting and splicing the tubing coming from the street side into the tubing coming from the curbside. I never had any drainage inside the trailer. I should also mention that when my trailer is absolutely level, the ac lists to the curbside. Giving my experience, I would first remove the inner shroud and see if you can identify where the leak is originating. If you confirm it is condensate, I would then get one of these, https://a.co/d/0hkNDgD0, and pass the brush from the condensate drain tube as far as possible and see if it is visible from inside the trailer, since the inside shroud is removed. I would then do the same on the other side. If you determine one side is occluded, I used this fitting to splice the occluded side to the non occluded side, https://a.co/d/0d6K2v06. Maybe you will find a kink or other occlusion that can be fixed with out splicing. I had the outer cover off several times during this process, but found that the access and visibility is poor and I would not start there. I hope this helps, please feel free to reach out if I can help further.
High Pointe Convection Oven Tripping CGFI Breaker
I'm thinking you mean the GCFI 20A outlet you are plugged into had tripped. Your EMS readout displayed 12A which is the total input amperage from shore power, which would include the Xantrex charger if it was in fact charging at the time. Sounds like a temperamental GFCI to me and it's not the first time I've read this story on our Forum! Glad our home was built in 1980 when only bathrooms had GFCI outIets. If it was my garage or exterior outlet that I used for shore power, I would replace it with a standard 20A outlet, regardless of code. Or add a new 30A breaker to your service panel, run wire and a 30A dedicated outlet for shore power. This is what I did where we park our Oliver. Not running on the 2KW Xantrex? Check and lower your shut-off voltage setting which is often the case with Xantrex inverters (not Victron). Your oven pulling only 11A (12A - 1A) should run on any 15A household circuit, let alone 20A. And 11A on 120VAC is equivalent to 110A on 12VDC which translates to 1320W, which again should run on a 2000W inverter with a lot or room to spare! Could the oven be defective? Not likely, since it started up and pulled a measurement read by the EMS. You could think it's the oven since it blew on two power sources. But the microwave works. The oven must create a power spike the GCFI protection doesn't like. The only way to be sure is to connect to a shore power source that is not GFCI! The 30A shore power outlet at any campground are not GFCI outlets. Next time I need a GCFI outlet is the next time I take a shower with a live blow dryer in hand! 🤣 - Yesterday
Haoleboyk changed their profile photo
Steph and Dud B replied to 2008RN's topic in Mechanical & Technical Tips
Is it the circuit breaker in the breaker box under the dinette tripping or the GFCI in the outlet under the dinette tripping? They are different devices. -
Keep your tongue raised slightly. We have the Dometic AC and had this happen. The trailer was dead level. I raised the tongue and the issue went away immediately. I also checked the two condensate after our trip and they were open.
@strhomsen, Good catch, your right, although the year of my trailer is in my signature area, it is not emphasized greatly. Yes changes have been made to the trailer manufacturing over the years and this fix specifically pertains to very early models. However, when initially discussing this problem with the factory, they said the valves in the new LE1s also had limited clearance to access that bolt. If that is the case in anyone's trailer, this mod, or something akin to it may help in the future.
Here’s an example, Potawatomi State Park WI Individual sites offer a mix of non-electric and electric pedestals (40 sites with electricity), but lack individual water or sewer hookups. There are communal water spigots in the park. And another park Devils Lake has Water on pedestals but not each campsite. We carry an extra 7 gallon blue water carrier and refill our tank Using the rear siphon port. Search result: No, there are no Wisconsin State Park campgrounds that offer water hookups at every individual campsite. [1] The Wisconsin Department of Natural Resources (DNR) deliberately designs its state park campgrounds to offer a more rustic experience. While many parks provide electrical hookups at select sites, none of them feature individual water or sewer connections at every campsite. [1, 2, 3, 4]
RV Travel.com resale value top 5 travel trailers
BigTexas replied to srthomsen's topic in General Discussion
I have to admit. I swallowed pretty hard when I wrote the check for my new Oliver back in 2018. However, it's been relatively trouble free in the eight years I've owned it. Can't say that for most brands. I think the low production run also adds to the desirability. If Hohenwald was stamping trailers out as fast as Casita, it would lower the exclusivity of owning an Oliver. I was happy when Oliver went back to factory only sales. -
Jody joined the community
I am looking for a city water connection at the campsite. Are you saying WI does not offer city water connections at the campsite?
2008RN started following High Pointe Convection Oven Tripping CGFI Breaker
Since I had never used the Convection Oven side of the Microwave, I thought I would give it a try before we head out on the next adventure. I Place the metal rack in the oven, and put a bowl of water in the oven. I know it is not food, but at least I thought it would work for a test. I started the Convection Oven at 350 degrees for 10 minutes. I had also set the Xantrex Charger to 5amps charging, since I was using a dedicated 20AMP circuit in the RV port. Before starting the test the readout in the rear upper cabinet showed 1 Amp at 122 Volts. After starting the test I was drawing 12Amps At 119Volts. After 1 minute, the GFCI Breaker tripped. I tried resetting the breaker a couple of times and it continued to trip. I thought maybe something shorted out. After About 5 minutes I was able to reset the breaker. I tried the same test only at 300 degrees, and the same thing happened. I decided to try the Xantrex Freedom 2000 inverter and give my new Epoch batteries a small workout. Again after one minute the 120V 20Amp GFCI in the Xantrex tripped. Waited 10 minutes and was able to reset it. At this point I wanted to make sure the Microwave part of the oven still worked. I removeI the metal rack and placed the bowl of water on the glass tray and ran the microwave for 3 minutes and was able to heat up the water. I know I wasn't pulling over 13Amps total in the trailer, so it couldn't have been from a high load. Since it took some time for the breakers to be reset, I think there is dome type of switch automatically reseting in the Convection side of the oven. The previous owners back in 2020 stated that they never used the microwave side, but had used the Convection side on the few trips they had taken. It is not a show stopper, but it would have nice to cook one of my recipes in the the convection oven for the egg rally. Any Ideas?
- Last week
Water? Define. Recommendations of great WI public parks is easy and many exist...but if you want to city water connection AND a great WI public park that's unlikely. WI Oliver Owner here.
Hot Water Heater (Truma) Bypass Valve Issue
Galileo replied to Frank C's topic in Mechanical & Technical Tips
Since the existing bypass valve has had issues for at least a few owners already, I’d be very leery about replacing it with another of the same valve. Amazon has at least three 1/2” three-way ball valves - all with more substantial handles and likely better guts. Not sure if THIS is the right configuration - but if not - there’s two others: https://a.co/d/0gG3fFr3 -
Thanks to all responses. 😀
HDRider replied to srthomsen's topic in General Discussion
Gotta love it -
#1 Oliver Travel Trailers Oliver Travel Trailers builds about 100 units per year in Hohenwald, Tennessee. Each trailer uses a double-hull fiberglass shell, foam-core insulation, and an aluminum chassis. There is no wood in the walls to rot or absorb moisture. Two 250-point inspections and limited production add to the appeal, while used inventory remains scarce. The video reports that 5-year-old Olivers can sell near their original purchase price, with 10-year-old examples retaining 70% to 80%. -
Thanks Olive2 Roam for your input. I have not climbed on top due to physical limitations but looked from a ladder at Truma without seeing any debris. We are on the phone with OTT tech support as I write this hopefully for a solution.
We thought we might escape the heat and go to Wisconsin, especially The Driftless area. Does anyone have a recommendation? I haven't found one with water.
That happened to me once. I blew out the drip hoses.
Hello. I have a 2021 LE2 with a Truma Aventa retrofitted by the Florida Truma service center. I had a similar slow drip that developed from the air distributor. To repair it I removed air distributor from the ceiling. I found the Aventa condensation hose was spliced to the original Oliver condensation drain hose and secured with a radiator style hose clamp. That clamp was loose and leaking. A few turns of the screwdriver tighten the clamp and the leak stopped. I made note that if this leak reoccurs I'll find a more robust (maybe spring style) clamp to use. Regards, Steve
Interesting problem, but it sounds like you are on the right track. The volume of condensate coming from the hose at the rear of our trailer during hot/humid weather is high and starts almost immediately when starting up the AC. According to Truma it should be possible to clear a blocked condensate drain by getting up on the roof and clearing any debris (like leaves) blocking traps and the gap underneath the outdoor unit. Have you gotten up there to check things out? https://support.truma.com/s/article/Clean-Aventa-condensate-traps?language=en_US
Dreaded LE1 Black Tank dump valve replacement FIX!
srthomsen replied to bugeyedriver's topic in Mechanical & Technical Tips
That was the reason I asked for some clarification and additional photos. -
ScubaRx replied to bugeyedriver's topic in Mechanical & Technical Tips
Very cool underbody lighting system. -
Your 2023 is very different from a 2008. -
Joy Queen changed their profile photo
Joy Queen joined the community
Cool! I see it. whats the piece closer to the WH? Just a coupler? -
Galileo started following Questions on Convection Oven use.
Agree wholeheartedly with everything @Galway Girl says above! No issues with the glass turntable or the rubber (silicone I’m guessing) tips on the rack. Yes. DO use it when baking - just like your oven at home has racks. We use the Convection oven quite a bit. We’re not big fans of microwaves. We’ve use the microwave setting for popcorn and reheating something that we’re too lazy (or dirty dish frugal) to put into a regular pan. Two caveats for the convection oven: This ain’t your mamma’s full-size home convection oven. It simply doesn’t have the oomph of a 240v electric oven. I find that even using recommended temperatures, things seem to come out undercooked. Conventional wisdom is lower the temp 25F when using a recipe that gives you setting for a conventional, non-convection oven. I haven’t actually put an oven thermometer in there to check - but I guess one of these days I will. (“They” say you should do this with your home oven as well - thermostats aren’t always accurate!) My bigger concern - when cooking something for a long time - like a cake for 35 or 40 minutes OR when cooking at high temps - like 350 and above (heaven forbid a pizza at 400F!) - the oven puts a LOT of heat onto the shallow counter/shelf above the fridge. Hot enough to burn you. I worry that it could discolor, soften, or blister the surface. I’ve taken to sponging it down every few minutes Those points mentioned - using the oven on warm months WILL add a lot of heat to the inside of your trailer. That’s great in January in Wisconsin - but definitely not great in July in Texas. It would have been GREAT if the folks at OTT had thought of this and either vented the oven outside - or even more cleverly - set it up so you could vent the heat outside during the summer - and inside in the winter. (Another mod for our prototypers?)
Snackchaser replied to Frank C's topic in Mechanical & Technical Tips
The check valve is the second brass piece from the water heater, with two hex ends. If you magnify the photos, you can just see the directional arrow on the top side between the hex ends.
