Got my tire pressure monitors installed today at a family run local shop, here’s how the pros do it. Just outside the picture are two stands on either side, not touching the trailer but ‘just in case’ as he said Pretty awesome having all this info now
It’s mainly the height for me. Completely agree with the benefit of a narrow body. My truck doesn’t have a towing mirror option but these work just fine. I’m 6’4, my son is 6’5+, the bed length was a major concern sight unseen. But oddly it’s not at all a problem. The bed is super comfortable and I have enough room, I never think about it. Well occasionally I’ll scootch down the bed a bit and notice my feet are hitting, but that’s an easy recenter. Can’t figure it, this isn’t suppose to work 🤷♂️
rideandfly started following Furrion Stereo Upgrade: A Sound Choice
rideandfly replied to Snackchaser's topic in Ollie Modifications
Geoff, Nice looking job! Our Ollie came with a Furrion DV 1200 unit. The DVD player and remote control operates erratically. Will look at iRV units to replace our old Furrion unit. Thanks for posting! -
John, my setup is pretty simple. I run a hose from the camp water outlet to a simple Culligan filter or Camco blue filter, then a short hose to connect to a small water softener, then into the city water port. On Amazon: Water Softener Mike
@Steve and MA and @Mike and Carol, Would you explain your setups a little more please? I'm currently researching water filtration and softening systems and would like more info about the TV setup, how your systems work with the Oliver water system, and any challenges such as cold weather or boondocking. I have a F-150 Powerboost so I have power in my TV. I like the UV faucet idea at the sink for drinking water but would benefit from some photos of the electrical hookup.
I have a 2020 with the V8 and have never had any problems with power or going down grades. I do all my towing in "S" and "Tow Haul" modes which makes a big difference, as does having the larger drums with the 5.2k axles. Getting the trailer controller dialed in correctly makes a big difference, too... When it comes to braking, you don't have the larger margin of safety that 3/4 ton trucks do so everything has to be dialed in. I'm with you on a diesel option and would buy one the second it hit the market. Not a fan of *any* of the modern big 3 diesel options and wouldn't even consider one.
Tow hitch/ weight distribution advice needed.
rideandfly replied to Mroth's topic in Towing an Oliver
Beautiful State Park! Like the Diamondback cover on your Tremor, too! We also have a Diamondback on our F-350. Hope y'all have a Great adventure! -
Made it down to the beach. The difference in towing was night and day. Literally no comparison. It’s almost like the Oliver wasn’t behind us. Exceeded my expectations.
Yes, this truck came with the 11000 GVWR package. That gives you the same rear axle and springs as the F350
@mossemi @NCeagle and others: Those of you that have done this modification, how did you caulk the side behind the hinge? I’ve got 2 layers of butyl tape on the vertical sides to offset the curvature of the cabinet. I can caulk 3 sides but not the side behind the hinge. Bill
- 2
@Mroth Do you have the original manufacdtures springs on it?
Thanks Geoff, we have been carrying a non-op "Dometic Type 9500E (120 VAC) Power Cassette Awning model 202(LL)(CC).003(#)", around for about 3 1/2 tears hoping to find a service center on a trip, that would have a replacement motor. I will reach out to them as well. B~Out,
Thanks ! I checked the settings and mine were at 11.5. Running fine now but if we experience the issue again I'll bump the setting to 12.1.
Dometic toilet 311 valve leakig
SNY SD UP replied to Nick and Linda Stratigakis's topic in General Discussion
Do not buy a "Lippert" replacement part. Sales ppl will say it is a match, but it is not. Tech will say put in the 2nd screw and it will stop that leak. maybe-maybe not. As the ppl at carnivals (not to disparage any OTT owner who has done that) would tell this 10-year-old who just spent his $5 on basketball, ring toss and water pistols, in the midway, "Close, but no cigar, Son"... The upside, I may have found an authorized Dometic dealer to work on our awning... just not before we head-out. B~Out -
Hi Bill (et al) - Thanks for the suggestions, I will open a case. To answer your question, for the same reason Ollie owners replace their trailer's springs when they might otherwise appear to be in good shape 😀 Or maybe I'm just paranoid with too much time on my hands? Anyway, I'd like to keep them out of the trash for the time being, at least. It seems to me like they might make a good 'just in case' spare to have. They are small and don't weigh much. Thanks, best Tim
Getting ready to head out to San Clemente state beach. The trailer barely made the truck squat. This truck has some stout leaf springs.I’ll keep you posted about my drive.
Thanks; I'll call 'em.
This is my thought as well. I have really liked having a TT that fits exactly where my TV is and does not hangout wider.
This was discussed in the Escape forum, someone linked a replacement from Panther RV https://pantherrvproducts.com/3314013-026p/ You should give them a call.
Hello Looking for help to source a replacement Dometic 9500E awning motor. A local RV service center (Big Country RV, Redmond OR) investigated my malfunctioning awning (wouldn't extend) and said it needs a new motor assembly. However, they said awning is discontinued (so can't find a replacement motor) and quoted $4,400 for a new awning replacement. I'm hoping to source a replacement motor and I've found motors for the Dometic 9100 awning but none that specify for the 9500 awning. Perhaps they are the same motors but I'm not sure. In addition, if I can find a replacement motor it seems I might need a special Dometic hex key tool to adjust it. Would anyone know where to buy that tool? If I can't find a replacement motor then I'd like to install a manual awning and have it use the same mounting system my 9500 has so I can avoid new holes in the roof. Any recommendations on a manual awning? Thank you, Craig 2020 Hull 612
Galway Girl replied to Mroth's topic in Towing an Oliver
We upgraded from 1/2ton F150 with eco boost 6 for that same reason. The downhill compression breaking in the diesel engine makes a world of difference and no need for an Anderson hitch as the new truck has antiseay brake controls. -
Tom and Doreen replied to Mroth's topic in Towing an Oliver
For most of the country the Tundra is fine. I've never had any issues with sway at all and as you say the torque and HP are more than adequate especially with the twin turbos. Colorado however can get a little challenging on the down grades, the 6 cyl engine just doesn't have the engine braking capability that the bigger trucks have. It's too bad that Toyota doesn't offer a diesel version in the States as they do in other parts of the world, political reasons most likely. -
I vaguely remember needing to reset a parameter within the settings of the Xantrex to avoid that problem. The battteries blink When charging so that’s normal. I n our case the LOW Battery Cutoff Voltage setting was not set properly after an update to our system....and it would do the beeping thing. The settings are easily changed in a data table on your xantrex phone app. Your settings would be the column to the left of the red column below: LCBO Voltage can be set from 11.5-12.1 FURTHER INFO: Here's some data from the web: A beeping sound from a Xantrex inverter charger is an audible alarm indicating low battery voltage, an electrical overload, or internal overheating. The system uses the beep to protect the internal components and the connected battery bank from permanent damage. [1, 2, 3] Most Common Causes Low Battery Voltage: The battery bank has dropped below the low-voltage cutoff threshold (typically around 10.5V for 12V systems). This can happen if the batteries are drained, a battery cell is dead, or the charger is disabled. AC Output Overload: The continuous power draw from connected appliances exceeds the total wattage capacity of your Xantrex unit. This triggers a warning beep before the system shuts down to protect its circuits. Overheating (Thermal Shutdown): Poor ventilation, blocked cooling fans, high ambient air temperatures, or heavy prolonged loads can cause internal temperatures to spike. High Battery Voltage: An external charging source like an un-regulated solar controller or high-output vehicle alternator is pushing voltage above the upper safety limit (usually >15.5V). Bad Cable Connections: Loose, corroded, or undersized DC cables cause a sudden voltage drop across the connection terminals under load. The inverter reads this localized drop as a dead battery and triggers an alarm. [1, 2, 3, 4, 5, 6, 7, 8, 9, 10] Troubleshooting Action Steps Check the Digital Display: Look for error codes like E01/E05 (Low Voltage), E03/E06(Overload), or E04/E07 (Over-temperature) to pinpoint the exact failure type. Verify Voltage with a Multimeter: Test direct DC current across the battery terminals. If it reads under 12V, plug into shore power or run a generator to engage the battery charger. Shed Electrical Loads: Unplug high-draw appliances like microwaves, coffee makers, or hair dryers to see if the beeping stops. Inspect Physical Connections: Tighten all cable terminals. Clean off any green or white corrosion crust with a wire brush. Ensure the cooling fan spin freely and the air vents are completely clear. Perform a Hard Reset: Turn off the unit. Completely disconnect all sources of AC shore power and DC battery power for 5 to 10 minutes to reboot the internal microprocessors. [1, 2, 3, 4, 5, 6, 7, 8, 10, 11]
2024 Elite II #1541 Good morning, Oliver owners. I’m reaching out to see if anyone has experienced something similar or might have an idea what caused the “beeping” issue we dealt with last night. Setup: Lithium Pro Package – 390AH Lithionics batteries 3000W Pro Inverter Batteries fully charged Connected to 30A shore power Progressive external surge protector plus the internal Oliver surge protection Around 11:30 PM, we woke up to a beeping sound but couldn’t immediately determine where it was coming from. We checked the CO2 detector, MaxxAir fan, and propane monitor — all appeared normal. The beeping would stop for 10–15 minutes and then start again. During one of the episodes, the Xantrex wall control showed a red light and was also beeping. Unfortunately, I didn’t catch the exact readings before the light went out and the beeping stopped again. The Xantrex app on my phone briefly displayed an alert, but it disappeared within seconds. I think it may have said something about high battery voltage, but I’m not certain. Here’s what I tried: Disconnected the external surge protector at the pedestal, thinking it might be the issue. Same results. Switched from the 30A connection to the 50A adapter connection. Beeping continued. Tried turning the batteries off, at which point I noticed the blue lights on the batteries were blinking. After that, the trailer power started cycling — lights, AC, and radio turning on and off intermittently?? I had assumed the trailer could still run directly from shore power with the batteries off, but that didn’t seem to be the case. Finally, I turned the batteries back on, left the trailer plugged into 50A shore power, and since then everything has been operating normally with no additional beeping. I’ll also post this on the Oliver forum for those not on Facebook, and I may give Oliver Service a call today. Any thoughts, similar experiences, or troubleshooting suggestions would be greatly appreciated. Thanks in advance.
