  1. Today
  2. Sorry, I do not have any pics.
  3. While gathering information for this project, I also discovered that Victron has introduced a new Orion XS 12/12-70A model. It has the same footprint and mounting pattern as the 50A version but adds integrated cooling fans. Victron also slightly increased the terminal size, which should make it much easier to terminate 4 AWG wire. Getting 4 AWG wire into the terminals of the 50A version can be a challenge, so that is a welcome improvement for higher-current installations. It is pricey and I just recently purchased my 50 amp version, so not for me at this time.
  4. Accidental duplication.
  5. Thanks, Geoff. I appreciate all the information you've shared. I'm in the process of installing my DC-to-DC charger now, but I haven't begun working on the tow vehicle portion of the project. Your comments about the cabling requirements and the tow vehicle current sensor gave me some useful information to consider before I get started on that part of the install. I agree that the 50A Orion XS is significantly more efficient than the 30A version. Even with the improved efficiency and reduced heat output, I plan to mount my Victron Orion XS 12/12-50A DC-DC charger on top of Mobile Solar Consulting’s Orion Fan Module, which features temperature-controlled cooling. If you’re not familiar with this option, there are several YouTube videos that demonstrate the noticeable reduction in operating temperatures when using the fan module. For me, the added cooling is inexpensive insurance for a component that will often be operating under heavy load. Dean
  6. Gj, the short answer is probably not, at least not directly. The smart alternator issues I described above tend to make the Orion cut in and out. A steady maximum of 22 A from a 30 A charger likely has a different cause. However, if your charger’s negative cable goes straight to the battery post and bypasses the current sensor, then it’s worth correcting. Without a record of the current over time, it’s hard to know what your charger is doing at any given moment. I’m assuming that the wiring is properly sized for minimum voltage drop, and that the battery was low enough to accept full charge. A nearly full battery won’t draw as much current and excessive voltage drop can cause other problems with the settings that I touched upon above. So even without knowing your exact conditions, it sounds like a heat issue. The Orion reduces its output when it gets hot. I had this with mine. Even with two cooling fans, my old 30 A ran scary hot at full load (running the trailer air conditioner while driving). That’s why I upgraded to the 50 A Orion XS, which is far more efficient and makes much less heat. Here’s the math. Your 30 A Orion is a 360-watt charger at a nominal 12.2 V output But a lithium battery charges at about 14.2 V. So 360 W ÷ 14.2 V is only about 25 amps (at 104°F). Above that temperature, Victron derates it 3% per degree C. So with the air around the charger at 113°F, you’re down to about 22 A. See what I mean? Of course, this is all conjecture. First, I’d recommend swapping the 30 A for a 50 A and turning its output down to match your cable size and length. I sold mine on Craigslist to a guy with an Explorer van, where it was better suited. Second, if you want to see what’s really going on, run a load with engine running above idle, such as a small heater on low through the inverter. That keeps the Orion working at full output even if the battery is nearly full. Then put an inexpensive clamp-on DC ammeter on the Orion’s output cable to see the real output. The shunt only shows the net current in and out of the battery. It can’t separate the charger’s output from trailer loads or solar. Hope that helps! Geoff
  7. RB, just catching up on this. Looks like your’e waiting for a new hull. So this may not be a reasonable request. Do you happen to have any photos of this set up? Particularly the aluminum hangers?
  8. Geoff: Could this be the reason that I don't see a charge rate at via the Ollie's Victron shunt more than 22 amps despite having a 30 amp Orion in play? GJ
  9. As have we. Not sure I could blame their demise on our winterization using Super Tech though.....
  10. Yesterday
  11. 😉
  12. remember story game
  13. Going through what few pics that I took at this year's Owner's Rally, I was reminded of a visitor that was there each morning as I drank my hot chocolate.
  14. that hopefully will
  15. Bob, as you already figured out, conventional alternator voltages can’t be applied to a smart alternator. They use a current sensor on the battery’s negative cable that signals the engine computer, which throttles the alternator down once the TV battery is charged. That saves fuel, and 12.4 V while driving can be perfectly normal. Based on what you’ve described, there are several possible causes for your problem. First, I’d verify that the DC-DC charger’s negative cable isn’t connected directly to the TV battery post. If it is, the Orion’s current bypasses the current sensor, the computer never sees the extra load, and it never raises the alternator voltage… unless for other reasons such as a low TV battery. Some manufactures specifically say to ground accessories to the body for this reason. Many vehicles have a ground stud on the far side of the sensor for accessories, otherwise use the chassis ground point where the battery’s negative cable attaches. Even if it worked before, it could be because the current sensor was seeing other TV loads that caused the alternator to increase voltage, and it wasn’t noticed when it stopped charging. If the truck can see the charger’s load independently from the truck loads, then the alternator should keep the voltage raised well above all of the thresholds. So it could have been charging when the truck called higher alternator voltage, but not otherwise. Second, the Orion’s engine shutdown detection works on voltage. My abridged explanation is that with the default “smart alternator” settings, it starts charging at 14.0 V. A smart alternator idling at 12.4 V never gets there, so the Orion thinks the engine is off. There’s also a separate input voltage lockout setting (default 12.5 V) below which charging stops. At 12.2 to 12.4 V, you’re under that too. These thresholds are adjustable in VictronConnect, but there’s a limit. Set them too low and the Orion can stay on and drain the truck battery when parked. Every vehicle is different, so some trial and error may be needed. It sounds like the Nissan system might have some unique quirks, but disabling the voltage control might be extreme. If fine-tuning doesn’t work, an “engine-running” signal on the Orions Remote L Terminal will force the Orion on. It’s there for this very reason. You must leave engine shutdown detection enabled when you do this, so it still turns the charger off when the engine stops. Victron describes several signal sources and recommends a true engine-running signal over a plain ignition wire. For your situation, a wire that goes dead with the key off is the best approach. In a trailer setup, this gets more complicated because it needs a third wire between the truck and trailer. Fortunately, the +12 V wire in the tow harness should work in most cases. Check it with a meter. It must be dead with the key off, and must not be live from the trailer battery with the truck off. Oliver doesn’t connect this wire on lithium systems so you should be okay. Ideally, it would also be off with the key on and the engine not running. Otherwise it could drain the TV battery if key is left on. This wire is usually capped off near the inverter and it’s typically a #10 or #12 wire. Also be aware that undersized cables, poor terminations, and corroded Anderson connectors can cause “additive” voltage drops that only show up when the charger is pulling heavy current. Corrosion builds over time, which could explain why it worked for a year and then stopped. This is where the “Input Voltage Lockout” setting comes into play. It’s set it so that Vlock-out ≤ Vshutdown − Vcable. The Vcable is the voltage drop in the wiring at full current. Victron’s manual provides an example voltage drop at 50 amps over a specific length of heavy cable. It’s a surprisingly high voltage drop, so if you add any additional resistance from undersized wire, corrosion or poor connections, you can add tenths of volts more, and that can push you under the set point where charging stops. You or your installer can measure your actual Vcable with the Orion running at full current (Turn on Oliver’s air conditioner and use a temporary +12V signal on the remote L trigger). Confirm its running full amps on the App. Vcable is the truck battery voltage minus the Orion’s input voltage. Many people wing this and get lucky, but it can become a latent problem especially with marginal wire sizing. Another way to get around this it is to de-tune the Orions maximum output amperage. For example: I have wiring sized for an old 30 amp charger based on the length of the run. When I upgraded to a new 50 amp charger, I reduced it’s power output to 30 amps to match wire size, otherwise Vcable could be too high. Mine actually worked at higher amps, but the wire was getting warm which meant the efficiency was suffering and I was burning more fuel. Finally, it’s worth load-testing the alternator. Turn on all the big loads (headlights, rear defrost, blower on high) and check that voltage climbs to around 14 V and holds. An alternator shop can do a more definitive carbon pile test. Also do a ripple test, which detects a burned diode that would reduce output. You can check it yourself with a meter on AC volts, with the loads on. There are YouTube videos showing how. If the voltage won’t rise even under heavy load, a Nissan dealer can scan for codes to tell whether the problem is the alternator or the current sensor. Again, it might be true that the Orion has never worked to full capacity and it was just not noticed. It probably worked periodically over long drives enough to charge a partially drained battery. The Victron has a history function where you can verify its performance over time. It's a good tool for problems like this. Anyway, it’s been fun trying to write this out in layman terms. I hope it helps, Geoff
  16. Let me guess..... The person you spoke to has the initials MS...
  17. According to the product page, Supertech RV Antifreeze contains Glycerin (Glycerol): An additive that helps lubricate and protect plumbing seals. Also Propylene Glycol: A non-toxic (to humans when used as directed) organic compound that lowers the freezing point. So, it's not all ethanol. Never had an issue ourselves in the past 27 years. On the other hand, we have had a CO/gas detector become overly sensitive and need to be replaced.
  18. Last week
  19. At the very worst, you temp use two bolts in each end. Available almost anywhere fine bolts are sold.
  20. similar problem during our 2023 Alaska trip documented below:
  21. There is some concern that the steel rod threads will "eat" the aluminum slot. A smooth rod of steel with collars or washers and cotter pins would likely serve you best. GJ
  22. Good observation. Any chance that the pipe and faucet had been hard frozen? That could account for both issues.
  23. Interesting change. Makes sense to have 2 vs. 3 inlets given the valving can provide the same 3-way functionality. What seems odd to me is the newly-chosen location of the City Water inlet. Water inlets should both be on the service side, the street side of the trailer. I often use our 10 ft hose to connect to City Water when a campsite has a water hookup. With this configuration I’d need to get out the 25 ft hose. Too bad they didn’t keep the two inlets together as they’ve always been and deleted the rear inlet. I'm also thankful to have all 3 jack switches in one location up front. It would be painful to level the trailer activating switches from 2 locations. A lot of walking back and forth, and the second location being behind the rear basement door is not at all helpful. Some changes are not deemed “improvements” by all! 😎
  24. Great post and thank you Cindy! Below is a long version with a couple of alternate RV products than the Super Walment Center Super Tech version that many of us have been using. Owners: If there are other less expensive sources please advise all. Have we seen any long term damage in our OTT's? (I have used it for 9 winters and have not experiencned any). If none by others then maybe the topic is over-blown. GJ RV ANTIFREEZE (Keep).docx
  25. Did they remove the pressure regulator from new units?
  26. Wow I'll need to digest your post a bit. By chance will our Pre-2020 trailers best use Sharkbite fittings and Pex - B pipe? With zero plumbing leaks in 9 seasons, I'm think for our 2027 season that it is for sure time to get to the Big Box store to acquire a small stock pile of the proper fittings. Here is a starting point for discussion: (Assuming all are 1/2" sized.) Half Stick of Pex-B pipe (One Each) Female Swivel adaptor (See above, Two Each) Coupling 90 and 45 degree elbows (2 Each) Support fixture for fixing the Pex-B pipe (See above, One Each) Stainless Steel Hose Clamps? (Needed? Number?) What above is not needed or is not listed? thanks, GJ
