JD we have Truma on demand hot water. Turned off. No change. Inverter I only turned off for a short time. Can try shutting off for longer period tomorrow. No custom fridge cooling fans. I do think Norcold fan has gotten louder. I turned off fridge and still see draw. No special DC accessories. i will try jack fuses in AM.
Lithionics large phantom draw
jd1923 replied to DaveAndBecky_NorthernMI's topic in Mechanical & Technical Tips
You should be getting +A from your solar. So 2-3 amps/battery, is say -8A total with everything off? You should be getting approx. +12A from your solar, given the fridge on LP. That means during the day your about net -20A. That's a large draw! The one time this happened to us, I had the hot water heater on AC (electric). Are you certain no change with all the breakers OFF? You wrote you restarted the inverter. Did you leave the inverter OFF for a period of time to measure draw with it off? Do that to be sure it is not anything 120VAC provided by the inverter. Hard to imagine anything DC taking that much power. Do you have any special DC accessories? Also, pull your 30A jack fuses, one at a time. A jack could perhaps be shorted in a way where it's drawing power to ground through the motor. Do you have a fridge cooling fan or other fans? Battery heaters ON? I cannot think of anything else DC that could draw so much amperage. Hope the best for you two! Bummer to have this worry when you're in such a beautiful place. - Today
As to your first point - portable panels check this out. https://solartrackpro.com/ This is a product that was conceived by one of our owners. It has been under development for about 5 years and is now ready for sale. There are several owners that have one of the earlier models, myself included.
2008RN started following Knee replacement surgery, anyone gone through this?
2008RN replied to routlaw's topic in General Discussion
Been there and done that x2 (ten years apart.. Both times I used a stationary training bike during rehab. It few weeks after surgery before I could get the knee joint loose enough to get all the way around the top of the pedal stroke. it was probably 2 months before I could get a above 40 rpm still without force. By 3 months I was walking 5 miles a day and standing on my feet 8 hours a day before I went back to work as a cardiac RN. Both times I did each knee during the summer. It wasn't until spring that I got out on a real bicycle. Even at 9 months I still had to Ice the knee after bike rides. As mentioned above it was about 1 year the I forgot that I had a knee surgery. Also as stated above rehab is tough and painful. Do what PT tells you. The important thing is getting full mobility back. Then getting muscle stronger. This takes months. I still have a minor problem with my left leg (Dominate) with standing on one leg and balancing long enough to put my pants on easily standing up. I still do it, but I am clumsy. I did have an exterior tendon release a few years before the surgery because the tracking on my patella to the knee joint, which might has cause the slight balance issues. Things I have never done again. I love sports and always pushed my self hard. Down hill skiing, If I could not do the double diamonds, and push myself it wasn't worth skiing. Jumping down off of anything: The truck tailgate, large logs and rocks when hiking, Anything that required cutting side to side, soccer, racket ball, etc. As far as trailer maintenance, 3-6 months for some of the easy stuff. The hard stuff like repacking bearings 9+months. You learn about getting down on the ground and getting back up. I still can not squat down to the ground like a mechanic would to work on things. Only do what is comfortable and you feel safe. Remember baby steps. If you have to repack bearings or such coming up soon you should have someone else do it. I do all of my maintenance on my Oli it just means modifying how you do things. I know little old ladies that still garden that have had knee replacement. You should be back in the camp grounds in around 6 months or so. Remember Ice and Stretching during the next 9 months. I spent my lunch breaks Icing the knee on my lunch breaks. I was the best surgeries I have done. Hang in there and don't give up. -
We have Elite II Pro package with 3 Lithionics batteries. Currently boondocking near Capital Reef Utah. I checked batteries mid-morning with good sun and saw 2-3 amp draw on each battery. I came back after a good day of sun to same draw and batteries down 15% in a day with no usage. Inverter off. Norcold refrigerator on propane. Here’s what I’ve done Restarted inverter Reset inverter breaker (red switch streetside bed) Power cycled batteries Reset all AC breakers while watching amp load - nothing changed pulled each DC fuse one at a time - no change checked all wire connections in dinette by pantry. No loose wires Batteries are taking charge from generator but show same loss as soon as generator turned off. Any ideas where to check next? Thanks in advance Oliver crew!
tallmandan replied to routlaw's topic in General Discussion
@routlaw Your're only 5 weeks out...give it some time and stay on track with the recommended activities. I have two total hip replacements and the hardest part was being patient and allowing time for my body to recover. I know knees replacement is tougher than hip replacement, but I think you may be plesantly suprised how much mobility and function you have in 3, 6 and 12 months. Modern total joint technology is truly amazing but there is still the brutal trauma to your body that needs time to heal. Don't sell your camper yet! Wish you the best for health and healing! -
mossemi started following Knee replacement surgery, anyone gone through this?
mossemi replied to routlaw's topic in General Discussion
@routlaw I had a total knee replacement in 2016, 46 years after ACL and cartilage tears in my right knee were repaired. That amounted to about 20 years of limited activity due to pain and discomfort. I stopped all racket sports and was content saving my knee for walking and used 2 poles while hiking. The 3 different knee doctors I saw in those years all wanted to wait until I was on my deathbed before replacing my knee. After having knee replacement surgery, it was about a year before I really didn’t think about it anymore. I really regretted not doing it sooner and I recommend it to anyone who has asked. I do believe that as we age, we should probably pick and choose some things we have always done. I gave up blowing pine needles and oak leaves off our house roof and gutter this year and pay someone to do that job, but my wife had to talk me into it. There are OTT maintenance jobs that you might have to give up and unless it is a financial decision, I would suggest giving up some maintenance jobs and keeping your Ollie, you can always sell it in the future if you find the maintenance issues to much to deal with. Mossey -
Rolind replied to routlaw's topic in General Discussion
I would recommend you fight tooth and nail to preserve your mobility and ability to continue what you love. Recovery from knee surgery is really tough. I’ve not had it but am an MD and many of my patients have. Once you give things up they will never come back. The body and people in general have a remarkable ability to adapt and overcome limitations. Good luck on your recovery! I hope this helps! - Yesterday
What microwave do you have that allows it to run on batteries? I have never managed to get mine to work without tripping the inverter. I own the Hightouch Convection Microwave.
AmyV joined the community
I have a 2022 Elite II. I ran three lines of heat tracing on the water lines including bathroom, outside shower lines, water intake lines, over the water pump, etc. I also added a heat duct to carry heat through the streetside basement. This gives me two lines of defense from freezing temperatures. Monitoring my bluetooth thermometers tell me that the furnace does a fantastic job of keeping the basement above freezing. The furnace actually runs more efficiently and quieter with the added duct. When plugged into shorepower I use a small AC space heater and open the little garage door and face the heater toward the garage. When driving I turn on the inverter to run the heat tracing which comes on at 40 degrees. I have three thermometers placed around the basement and they have confirmed when the heat tracing comes on. So far we have driven and camped through 20 degree weather. Yes, all of this required me to stand on my head and squeeze into small places but the peace of mind is well worth the struggles. I have yet to test not winterizing for next winter, but think I might try it. Input?
Made in USA leaf springs
Mike and Carol replied to Mountainman198's topic in Mechanical & Technical Tips
The service was good, too. -
Same place for us. Great breakfast. John -
Jls started following Heat tracing on water lines
Has anyone contemplated placing heat tracing on water lines? I see two reasons...1. eliminate worry while on the road during springtime cold snap after dewinterizing and 2. possibly eliminating the need to winterize at all.
- 1
jd1923 replied to routlaw's topic in General Discussion
Knee replacement was suggested for me by a local surgeon. I had fallen hard on my right knee as a teenager which caused bone spurs/arthritis over the years, first tore my meniscus playing tennis mid-90's and years of tennis and pickleball. I'm less of a biker and hiker, though I understand since mountain biking is so big here that it is very hard on the knees. The surgeon I met was only about replacement and not trusting him, I keep nursing my old knees. My knee locks up and I get jarring pain on occasion when playing which thankfully goes away as I walk it off and keep playing! PT videos from Dr Adam Fields on YouTube are very helpful. He has 100 videos on almost every body part and condition. This is the first I'm hearing that a full knee replacement has movement limitations! Perhaps you also had considerable ligament damage that needs PT correction. Chris and I know almost every senior in Prescott that plays pickleball (there are 100s), we also know a good 10 players that have knee replacements, some have both knees replaced and are playing pickleball again like having young knees. I hear from some that the pain after surgery is severe for 2 weeks. But there is certainly more knee movement in mountain biking than playing a racquet sport. Rob, I wish you the best and hope you store your Oliver just ONE season, get back to it next season when you work more PT and get back to full movement! My right shoulder is about as bad as my right knee. I was under the truck again, installing an A/C compressor yesterday. With maintenance you can take your time. You'll be able to work Oliver maintenance soon and I also hope you will enjoy your sports to the max asap! -
After a life time of running, hiking, biking and walking finally wore out my left knee and just went through this myself 5 weeks ago today. I am healing up pretty well and walking over a mile each day and on some days up to 2.5 to 3 miles. It's much slower than my normal pace of course but even that is improving. Cycling currently is out of the question. My physical therapist have been awesome and very encouraging stating I am ahead of schedule by a long shot. What I am really concerned about is ongoing maintenance of the Oliver, climbing on ladders or scaffolds to wash and wax, crawling under for wheel bearing maintenance and the list goes on. Then there are long drives with knee in the same position which for me to this point can be quite problematic. So my question to the group for those who have gone through this how long before you were fully operable in terms of using your camper, Oliver or not? At this point I am actually considering the sale of ours and either downsizing or abandoning camping altogether due to the diminished mobility. My therapist said it's unlikely I would ever be able to get 140-150º of flex or range of motion which eliminates being down on your knees and completely bending over for many of the task and maintenance chores of RV'ing. Thanks for taking the time and look forward to any insight from the folks here. Rob
We went to Dream Cafe on Main Street in Grand Junction. It was good. -
rideandfly started following Springs, DC-DC, window upgrades
Very nice upgrades. We’re planning the Alcan upgrade, too!
SERVAL owners have done the same thing. We also have the first appointment of the day and will follow the lead. Where's breakfast there that seems to be a hit? - Last week
Agree. They are pretty quick. I don’t know which fridge you have, we left ours on propane. Probably should have switched to 12v, but the ALCAN guys didn’t seem to care. It was an open bay and they were done in a couple of hours. We drove over from James Robb State Park, dropped off at about 7:50, went to breakfast, walked around Bass Pro Shop and got a text just before 10:00 that they were done. We then drove down to Ridgway State Park near Ouray for a relaxing stay before heading down Highway 550 to Durango. Mike -
Both Home Depot and Lowes carry Reflextic in fairly small rolls. For the battery door - I used foam board that I had laying around the shop. p.s. Foil tape can be used to secure the Reflextic to the door and/or to virtually anywhere inside between the hulls if you want to put your excess in there.
I used carpet tape and just some honeycomb insulation that came as packing in something we purchased.
Amazon carries it, but theirs is sometimes low quality and thin. I got some from an HVAC contractor/supplier for free. It is used for duct insulation and was much better quality.
Where to buy a small quantity of reflectix insulation? What type of adhesive should I use to keep it in place on the battery door and the cellar door?
From all the posts about Alcan, I don't recall any of their installs taking more than two hours. Likely your two additional food storage boxes will not warm up all that much if you just keep them in the shade. GJ
