  2. You will need to install a dedicated transfer switch to be able to run the a/c off the batteries and still be able to operate it when on shore power via the inverter. No need to upgrade the inverter just to be able to run the unit in this manner. You will also need to install a shunt and fuse with the battery upgrade.
  3. Today
  4. Could be a coincidence. But there was once an old hull with an Air Fryer upgrade. 🤣
  5. Yeah after I wrote that I thought “nah, it’ll be an upgraded I”. But $2M?? I knew those molds are expensive but that is nuts. Well $500k per mold I guess makes more sense. You make a fiberglass one-off model (the ‘plug’ I think?), then build the fiberglass mold off that. Still seems high but what do I know … Edit: easier bet; first reveal will be at the Rally
  6. Yesterday
  7. Hi. Read through this forum. Use Google search: "Oliver trailers forum <insert your question here>." Tons of good information available.
  8. As @topgun2 suggests, I hope you come to the rally -- you will meet many happy Oliver owners, see personalized trailers, and OTT usually includes informational seminars by the Oliver team as well as some of the component manufacturers.
  9. The OTT website has been updated since I last looked and has a nice comparison of the different current models. I notice that OTT has picked up on some of the Oliver Owner's personal upgrades, which is neat (such as offering an air fryer in lieu of a microwave).
  10. If possible - try to attend the Oliver Owner's Rally. It's too late to register as a full participant, but, there is no reason that you can't attend many of the functions of the Rally to include visiting with current owners in the campground and touring the vendor area. Any of the Sales staff at Oliver will be happy to give you all the details. Bill
  11. I'd bet - the same size as the current Elite I. Simply put - with each of the four molds that it take to make any Oliver costing in excess of $2,000,000 (i.e. total cost would be in excess of $8,000,000) the cost of introducing a third size of travel trailer is simply too high. I'd also bet that similar to what has been done with the Elite II, a different model and/or trim level for the existing Elite I is behind that cover in the pic. Bill
  12. Hi guys, the 4 AGM’s on my 2018 Oliver are kaput. I am installing a new Vatrer 460ah and was wondering how hard it would be to run the A/C off of it. I know I would need a 3000 watt inverter. Would I just take the A/C wires off the charger/converter and make a plug that plugs into the new inverter? Thanks
  13. Getting closer to the rally. Lake Manawa SP in Council Bluffs Iowa. Clear view across lake to the Mutual of Omaha building.
  14. My guess is an Apex version of the single axle
  15. From their Twitter/X feed. Single axel, I’ll guess larger than the I but smaller than the II
  16. We are Anna and Steve from Staten Island New York. We've been arving since 2009. We camped in a camp in tear drop trailer from 2009 to 2014 and then we purchased a casita Fiboglass trailer in 2014 that we sold and we never should have We now own a grand design. Imagine,2026 which is our third RV that we are extremely unhappy with. We are looking forward to purchasing an Oliver 2027 Elite. We have just completed a 13,000 mile trip from Staten Island New York to Fairbanks. Alaska and back.
  17. Email sent. Mike wrote on Where's Ollie something like, this one is "good enough to frame!"
  18. YES - same on my Hull #117 Bill
  19. This is exactly what we have. Was OTT installing these back when our hulls were made? I assumed it was OEM but maybe previous owner upgraded. I realize many newer ones look like what Bill showed above. The shut-off on ours was tight but works well after a CLR soak. In shower head mode, pressure not so great but good enough.
  20. We have a crew cab long bed. The long bed is good for storage, especially if you have a large Clam screen room. The downside is maneuverability. Our truck and trailer combined are about 45' long. Makes it harder to back into some campsites with narrow roads and trees.
  21. "Red sky at night - Sailor's ...." Pretty.
  22. Daisy Barn campground just outside of Niagara Falls
  23. Really apreciate all your informative posts. And it looks like I opened up a can of worms on OEM DC-DC with the ENs in the comunity. OBTW the CA in GregCA are my initails. I am actully in Navarre Fl close to Pensacola
  24. Was going to just do a cover, but like the cap and bed slide idea. May have to consider something like this to make life easier. Yes please send me some pictures
  25. Thanks for the input. Didn't even consider payload and assumed a 3/4 ton would be plenty. Just based on numbers from what I know now, I should have about 2,500 lbs. of payload left after people, pets, and Oliver with 2 e-bikes are accounted for. Hopefully will be enough. Thinking back, I must have been a disaster waiting to happen back in my Casita/Ridgeline towing days. Was looking at a cap but probably leaning towards a bed cover to keep things locked up and dry.
  26. Ironically, I just went through this when our awning began to jam because of a piece of debris. I was really annoyed that the bottom end cap screw was inaccessible and went hunting for a right angle screw driver. But even with that the screws were pretty locked up and took an effort to remove. I ended up replacing the bottom end cap screw with a hex cap screw so I could (next time) remove it with a wrench or socket. You won't realize how good @Tom and Doreen tips above are until you need them. 🙂
  27. Jd, If driving with an open truck bed will make me feel like a kid again, I'm all in🤸‍♀️
