  2. We use the built-in audio quite a bit. When we stream video to the TV we use the ARC channel to put the audio on the speakers. We also like to find local FM stations, especially the little independent ones, that have things like farm reports and swap meets. If Steph sleeps in, I use the A/B speaker selector to choose only the front speakers. I have music on a flash drive in the Furrion head as well and, once in a while, we'll break out a DVD.
  3. @johnwen, my apologies, I thought I had included the details on the Ethernet cable running from the RJ45 through jack utilizing the Furrion external shell. All of the Ethernet cables I purchased are Cable Matters products. All are shielded Cat 6A. In addition to the 20 ft. cable used inside the trailer, I purchased a 50 ft, and 2x 25 ft. cables and a single 1ft cable. I also purchased VCE CAT6A Waterproof RJ45 Coupler IP68, 10Gbps CAT6A/CAT6/CAT5E/CAT5 Female-to-Female Outdoor Ethernet Connector Shielded, Network Cable Extender for Outdoor Use 2-Pack, 5.3 in. To connect the Ethernet cable to the PoE splitter, I had to slightly trim the black plastic anti-snag protector on the 1 foot long Cat 6A able. This was necessary because of the tight fit through the watertight connector on the PoE splitter. You may have run across mentions of this issue by others online who are using this PoE Injector and Splitter. Once I trimmed the soft plastic cover over the cable release tab I was able to fit the RJ45 connector through the watertight connector on the Splitter. I chose to use the 1 foot long cable so that I could leave the splitter and the 1 foot cable connected to Starlink Mini. I find the connectors going to the Mini from the Splitter to be difficult to remove due to the watertight seals. I don't like the idea of pulling on the cables to release the Splitter from the Mini. I anticipate repeated removal of the Splitter from the Mini will result in damage to the cables on the Splitter. Replacement Splitters appear to cost about $65. At the other end of the 1 foot cable I attached one half of the VCE RJ45 couplers listed above. This way it is much easier to disconnect the Ethernet cable from the Mini without messing with the watertight connector on the Splitter again. I also installed the VCE couplers on the ends of the 50 foot and 2x 25 foot cables. This way they are like extension cords which are easily connected/dis-connected. I am impressed with the VCE couplers. They are excellent and easy to use. I bought the three longer length cables to be able to easily connect 25, 50, 75 and 100 foot long cables, as needed. I specifically want to avoid having to deal with a single 100 foot cable, which I find to be a PITA. I have not yet had a chance to use the Starlink Mini on a trip, but have only tested it with our LEII parked in our driveway. Due to tree coverage, I needed to connect at least 75 feet of Ethernet cable to position the Mini for a reasonably unobstructed view of the sky. The Mini still had some obstructions, but I was able to measure Ethernet speeds inside the trailer >100 Mbps. I sometimes saw speeds drop to the 50-75 Mbps and rise as high as 200+ Mbps. I suspect the variable is at least partially attributable to the position of Starlink satellites at the time of the speed tests. The satellites are each only in view 8-9 minutes, without obstructions. In any case, I connected my laptop to Starlink WiFi inside the trailer and was able to browse comfortably. I did not notice the occasional losses of service which I noticed in the performance data on the Starlink app. I don't recall any RV park or state park where the provided WiFi was anywhere close to the minimum speeds I have observed in our driveway. BTW, in our residence we have AT&T wired gigabit Ethernet throughout, so I have a low tolerance for poor WiFi service. I have high expectations for using the Starlink service, based on reports by others and my experience so far. At this point, I have not used any adhesive to attach the PoE Injector to the top of the frame member on which it sits. I have a small zip tie connecting it to a PEX cold water line. With the Ethernet cables attached it cannot really go anywhere. I did not want to use a more permanent method to secure the PoE Injector, until field testing on a road trip. We have our next trip scheduled in late August, so I will observe it over a 400+ mile trip. I will likely use a small strip of 3M VHB tape to fasten to the hard rubber frame covering. Good luck with your installation. If you have any questions, feel free to send me a Personal Message and I will be happy to answer.
  4. They just changed the Promo Code to 20% OFF! The Turbro Greenland is now $1,200 plus tax.
  5. Today
  6. We use these speakers on occasion, only when Chris connects music on her phone by Bluetooth. I don't like the speaker right on top of my head in front dinette seat. We use a high quality soundbar for TV and can stream or play DVD/Blu-Ray/CD music there with a player installed in the attic (better than cut into the walls)! The interior hull would be better without the 4 large speaker holes, 16 screw holes. I'd go without the Furrion head too! But there are not many of us who would sell our Oliver to buy a new one for a few features, plus or minus! Heck, if we got a new Oliver I go without any factory options and then I'd have to rework all the mods I've worked over the last 2 years. Life is not long enough! 🤣
  7. Don, I'll be tackling this project this weekend. Did you attach with glue?
  8. That sign was just on a short NF road off AZ Hwy 260 descending into the canyon to Tonto Natural Bridge near Payson. They had a parking lot there for the sole purpose of detaching trailers before descending! Generally 8% is the steepest I’ve seen marked on US Interstates and highways, some state highways are steeper. Good you have a special towing setup. I added 3rd Gen Dodge 2500 front rotors designed for the newer heavier model. Also just now adding oversized rear drum slave cylinders. Trailer brakes from 10” to 12” and these upgrades all help. FedEx Freight just called, axles coming tomorrow! I wanted to add a Pacbrake exhaust brake. Was $1800 two years ago, now $2300 and toooo much money!
  9. Wow, what a beautiful campsite with a beautiful Ollie Rig!!!!
  10. Facebook marketplace Done!😊
  11. Okay thanks for letting me know. Did you sell it through the Oliver Travel Trailers for sale FB page? Don't forget to inform Oliver if the new Owners name. I believe there is a transfer ownership form on Oliver's website too Best of luck to you guys.
  12. We scored a wonderful spot at a Corps of Engineers park today (August 11,2025). Site 25 at Left Tailrace Campground near Fort Thompson, SD. The weather has been much better than Tennessee when we left for the west. Looking forward to some great boondocking in a few days as we head to higher elevation.
  13. Wow! thats quite the road and story on that thread @jd1923 . All this talk about brakes, controllers et al has me wanting to go through my trailer brakes again to make sure they are in good shape. I do feel better with this new truck and its Max Tow Package. Looking at the front and rear rotors they truly look much larger than my older truck which only had the basic tow package. Still some of these roads out west are formidable descents, not to be taken lightly. Regarding Teton Pass, the drop down into Idaho is quite doable which I have also done. As long as your TV can make the climb up the steep ascent from Jackson without overheating the westward descent is not a big deal. The one time I towed going from Jackson to Driggs I had to stop at the pass to allow my F150 to cool down, both engine and transmission. They were getting pretty close to their limits. Grades of 14-18% is off the hook though, never saw that.
  14. I’d read in another post here or on Facebook that the speakers are gone, replaced y Bluetooth speakers. I don’t know if that is an option or standard equipment. I’ve never used the inbuilt audio system. We don’t use DVDs, and we have a Sonos Move for streaming audio inside or out.
  15. Thank you! Great information and I look forward to hear how it works on your trip.
  16. @Snackchasergreat idea!
  17. @Donna and Scott Donna, FYI...Thea and I will not attend the rally anymore, we sold our Ollie! I have emailed Texas State Parks, so site# 54 will be up from grabs.
  18. You took the words right out of my mouth! 🤣 Our Oliver has been parked in the sun the 2+ years we've owned it and who knows how much in its 10 years. It had a bit of a shine in 2023, not so much today. We hand wash it when we return from trips. It doesn't really get clean and I'm not going to be one that gets up there with power tools! I was also never one to paint over things, always preferring natural vs. painted finishes. But paint may be an answer for our hull at some point. I've got a local auto painter who painted our Lexus GX470 at a reasonable cost. Painting the Oliver might cost about what CGI charges for their work. I had a thought to match the colors to our tow vehicle. They look good together as is, with Oliver logo and pinstriping matching the TV colors, but what if the Oliver was the same light gray on the lower hull and the same bright white on the upper. Dull egg to bright white may be a bit of a shock to the eyes. Bring back the two-tone look of the great cars of the 60s! 🤣
  19. I'm with you on this Rob (thanks for the heads up on Teton Pass)! If doing the Million Dollar Highway, I'd choose the direction to be on the hill side vs. the cliff side of the road! 🤣 CO 145 drops 2500 feet, from Telluride down to Delores. A little rugged before Rico CO, then heading south from there it follows the beautiful Delores River and was mainly a good road. We have a trip planned camping along CO 145 late Sept to mid Oct. Starting at Delores we will get up to Sunshine Campground again close to Telluride, maybe as far north as Ridgway CO. Having 3-4 weeks we should be able to find some good campsites without rushing through there like the end of our last trip. Maybe put AZ Hwy 78 on the same list. Grades are not listed but certainly > 10% in some parts. Not a well known road but this was our story. Months later, I found out our brake controller was going bad. Replaced it for much better braking! We're getting new axles which should arrive this week. Going to the D52 trailer axles with 12" brakes should increase stopping power. Our Ram is an older model when the diesel exhaust brake was not an option in pickup trucks.
  20. Follow-up re this thread. This spring I worked brake service on our Oliver. I wanted to be certain the self-adjusters on the Oliver were dialed in. The front axle was close and the rears were a bit looser. This is likely normal. In doing so, Chris was applying the brake in the tow vehicle. At times there was nothing. I asked, "Are you pushing the brakes?" She said "Yes" but the brakes did not stop the spinning wheels. Increased the gain and tried again, the brakes would stop the wheels but 3-4 seconds later. My next comment was, "We need a new brake controller!" Purchased and installed a Tekonsha P3 Prodigy Brake Controller and ran the same test. On the default 6.0 gain when Chris hit the pedal the brakes (all 4) banged abruptly to a stop when spinning in the air. I now believe that when our brakes were over-heating last October, some of it had to do with the weak controller not applying enough power to the TT brakes which caused the brakes on the TV to overheat!
  21. Steve, Sorry to hear of your poor experience with the Haloview MC7108. I am not familiar with this model, which apparently dates to 2019, based on the dates of YouTube reviews. The BT7 Touch, which I purchased, apparently dates to 2024. My experience with the BT7 Touch is limited to my 35 mile drive on Saturday and driveway testing following installation. In no case did I observe any flicker, dropouts or lag when viewing the monitor mounted to the windshield using the suction cup mount. The image was quite stable. As I mentioned, I folded the two antennas to rest horizontally on top to the monitor, which had no discernible effect on the performance of the monitor. If I recall correctly, the on screen signal strength meter dropped from 5 bars to 4. Also, on my short test drive, I was frequently looking back and forth from the TV mirrors to the BT7 Touch Monitor to compare the views to the rear and sides. The images on the BT7 Touch Monitor seemed to be real time images, with no delay, based on what I was seeing in the TV mirrors. We tow with a 2014 BMW X5 35d, using the standard door mounted side mirrors, plus a pair of Milenco MIL-2912 Grand Aero 3 Towing Mirrors. I have used these for 3-½ years, the entire time we have owned our LEII. I am very familiar with the view to the rear and sides provided by the mirrors, and I was comparing the increased visibility using the Haloview camera/monitor. We have a 200+ mile trip scheduled beginning August 27 (coincidentally 4 days prior to the closure of our Amazon return window). This will give me 3-4 hours driving time each way to observe the performance of the BT7 Touch camera/monitor. I will be happy to post an update following a trip of 400+ miles. Also, a minor clarification- The Haloview MC7108 Monitor resolution is apparently 1024x600, 720P high definition, not 4K. For reference, my Furrion, Model F0S43TADS, had resolution of 480x272. The Haloview BT7 Touch Monitor is 1920 x 1080, the resolution of 1080p (Full HD). Regards, Don
  22. I think it would like much nicer if the grey was on the bottom and of a much lighter shade.
  23. Hard to be sure, but it looks like the overhead speakers are gone. We like the old sound system for music and videos. I'm glad the swing out windows are here, but they usually have integrated shades/screens in other RVs. Those bulgy shades look sketchy.
  24. Don, how persistent is the connection between the camera and the display? Are you seeing dropouts and/or lag? After seeing Mike Urbancic (@Boilermake Chemist) using a Haloview MC7108 at this year's rally, I ordered one, too, along with this adaptor plate with furring to Haloview connectors. https://a.co/d/iMfzTgw The setup worked beautifully in the driveway! But a couple of weeks later when we took our trip to Adirondack Park was the first time I used it on the road. As soon as I got up over 30 or so MPH, I started getting a lot of dropouts. And when there was a signal, a lot of the time there was significant delay. I'd see cars beside me that were just coming into view on the backup camera screen. We moved the receiver all over the dash, against the sunroof, Deb holding it next to the window, all while adjusting the antenna to get best signal. Nothing helped. We were on a 10 day trip, and my return window was 4 days away, so I'm stuck with it. Worse, the Fusion camera and monitor were at home in the garage. I don't really use the camera for backing up, instead preferring it for lane changes and keeping an eye on traffic approaching from behind. I've got it on Facebook Marketplace now, describing how it would be good for something shorter like a truck camper or back of a truck cap. But no interest so far. Haloview Customerservice was useless, answering there first email with generic tips, and never answering the next three or four I sent... So, I'm curious to see how yours works with two antenna on the monitor. The only thing I can think of to cause my unit (and many others after reading more reviews) to lose signal at speed is due to 4K bandwidth of the new camera compared to whatever low resolution is on the original Furrion. But it can't just be interference from engine noise, because I manually kept the truck in first gear to test it at low speeds but high RPM, and no loss of signal or delay. I'm perplexed.
  25. The old Pullman Sleeper Cars had nicer looking blinds. They were nice and tight, not like a pillow🙃
  26. It was delivered 2-tone by Oliver. I can't find the original announcements. They were off Oliver website. UPDATE: Hull # 1000 was all white upon delivery
  27. I saw that on Facebook and commented. Definitely not a fan of the new blinds! They look cheap compared to the current version, and that spot where it rests on the window handle looks like a wear/puncture point, as well as just plain ugly. The TV looks smaller, and the cable entry for the TV swapped sides. Chrome belly band seems to break up the interior better to my eyes. Overall, *I* think it is a step backwards in quality appearance.
