Chukarhunter
Everything posted by Chukarhunter
  1. Those that might be contemplating getting a Levelmate should know that a newer model was released last year called the Levelmate Max. I had never gone for a Levelmate before but decided to try the Max version and have been extremely satisfied. There is absolutely no need to hardwire it because it runs on three AAA batteries that last over a year and can be replaced in under a minute. As far as technology upgrades over the Pro and Pro+, the Max adds a gyroscope in addition to the accelerometer. This enables one to observe continuous instant changes in level (side to side and front to back) with the trailer hitched and vehicle moving (called leveling on the go). This feature can be useful in finding the best spot to stop and unhitch when boondocking on uneven ground. Another feature is that it can remember the preferred tongue height when it is time to hitch up without having to back the vehicle up to the tongue first. Levelmate recommendz permanently mounting it with screws but I used 2 inch wide heavy duty velcro to mount it just inside the door under the rocker switch panel. No holes drilled.
  2. I may do a bathroom hatch some day but for expediency, I experimented with a quick and simple (and reversible) hack designed to achieve greater heating of the area under the sink while also adding a return vent from the bathroom into the basement to improve heating in the bathroom (My 2020 didn't have a return vent in the bathroom like the newer models). I had also concluded, as have most, that the heat supply vent under the TP was essentially useless because of the long flex-duct run to the bathroom. It never did supply much heat. What I did was temporarily removed the towel bar rack, disconnected the flex duct from the heat vent under the TP holder, dropped the flex duct to the floor (where it heats the area under the sink) and replaced the towel bar rack. That gave me a return vent in the bathroom (without cutting a new hole) that pulls heated air from the cabin into the bathroom and then into the space under the sink, while the loose flex duct also supplies additional heat to the area under the sink. You can tell it is pulling a measurable amount of air through the bathroom into the sink cavity by looking at the dangling TP moving when the furnace is running. I now have two cold weather seasons of experience with this setup and I will never go back. As long as I keep the bathroom door slightly open against the closed twist lock, the bathroom stays warmer than it ever did with the flex duct attached to the vent under the TP. Also, I have noticed that the bathroom feels a little bit warmer when a late night visit to the bathroom is called for, likely due to less radiant heat loss from my (un-shirted) body, due to the warmer surface of the fiberglass surrounding the sink cavity. The additional heat under the sink cavity also improves the heating under the kitchen sink area as the heat from the sink cavity circulates rearward to be recirculated through the furnace.
  3. I also store my Oliver remotely outdoors through the winter but do not winterize. All above advice is solid. I use remote temperature sensors and have found that the coldest spot in the basement is in the lower rear of the trailer (storage area) where the water lines run. If that location stays above freezing, I am confident that nothing will freeze. The one additional thing I did was change out my thermostat to one with remote monitoring and control. I chose a Micro-air Easy Touch RV thermostat. It has both remote wifi monitoring and blutooth. https://www.micro-air.com/products_easytouch_rv_thermostat_touchscreen.cfm When temperatures are forecast to stay well above freezing, I can either turn the furnace off (remotely) or set it low (42-45 degrees). When the forecast is for below freezing temps, I turn it up to around 50. My remote sensor will send an alert to my phone if the rear basement approaches freezing temps and I can then turn the thermostat up even more from home. When daytime temps rise above freezing again, I turn the thermostat down to save propane.
  4. I apologize for chiming in late but just got home last night from a 10 day round trip from Oregon to Saddlestring, Wyoming towing our LE II. The discussion above omitted a very relevant specification when determining safe towing weight limits which is Gross Combined Weight Rating (GCWR). I believe the GCWR for your Tundra is 11,800 lbs. If you were to pull the the maximum trailer weight of 6,700 lbs, that would leave 5,200 lbs of remaining GCWR to work with for tow vehicle plus cargo weight. I believe the curb weight of your Tundra is about 4,800 lbs so if you tried to tow an LE II at 6,700 lbs, you would only have about 400 lbs of cargo capacity. If you were to keep the weight of the LE II at or below 5,700 lbs with full water and propane tanks, it would leave you with about 1,400 lbs of cargo capacity. In my opinion, this would allow you the flexibility to tow an LE II safely with your Tundra until you find (or can afford) the tow vehicle you really want. You would just need to be very disciplined in traveling light in terms of passengers/cargo until you do. I have pulled our LE II for 5 years now with the 4.7 liter engine. I find it to be marginal but adequate for my needs, but then I am a minimalist, the kids are grown up and gone, and we typically depart with the LE II at 5,600 lbs or less with a full water tank. That said, I do want a more capable tow vehicle but am waiting for the next evolution of EV batteries (e.g., solid state) to arrive.
  5. One strip is enough to cover all four porch lights with enough left over to cover the bottom outside lights as well
  6. I did the same thing adding the film to my exterior porch lights shortly after I brought my Ollie new in 2020. Many owners have done the same thing. It is one of the easiest, lowest cost, and most satisfying mods I have made. It only takes a few minutes to apply the film to the lights and the film is durable. The lights still look as good as new after four years. The porch lights also attract fewer flying insects now.
  7. A Honda 2200 EUi has a continuous rating of 2,000 kW which means it is capable of putting at most 2 kilowatt hours (kWh) of energy into an EV battery if it runs for an hour. An EV pickup like the F150 lightening will travel from 2-2.5 miles on a kWh of battery power in normal driving. That means if you wanted to add driving range using an Honda 2200 EUi, you would need to run the generator for a full hour for every 2 miles of additional range you wanted. Level one chargers at home (120 volts) are limited to about the same charging rate as a 2200 EUi; a rate of about 2 kW (15 amps x 120 volts equals 1.8 kW charging rate). Level 2 home (240 volt) chargers can charge a vehicle up to a 16 kW rate (i.e., the F150 Lightening) depending on the specific vehicle. The charging rate using AC power from home is limited by the charging circuitry in the vehicle that converts AC power from the home plug to DC power into the batteries. These internal vehicle electronics limit the charging current (whether 120 volts or 240 volts) so charging the vehicle will not trip the circuit breaker in the home panel. The charging stations being built along freeways, et. are DC fast chargers. They supply DC power directly into the vehicle batteries and typically are capable of charging the vehicle at a rate of 150-250 kW rate which is why they can charge a vehicle like an F 150 lightening from zero to 80% charge in way under an hour. It would take a 2200 EUi over 50 hours of continuous charging to do the same. The good news is if you had an EV like the F150 lightening that is capable of bi-directional power flow, you wouldn't need much if any battery storage in the Oliver itself. When you set up camp, you plug the trailer into the F150 (with 130 kWh of battery), you have over 100 kWh hours of battery reserve for over a month of camping assuming you arrive at camp with close to a full charge in the vehicle. My son is a rural large animal veterinarian and has an F150 Lightening (11,000 lbs towing capacity) as his work vehicle. It gives him several hundred miles of range which is more than enough for a day of ranch calls and he can recharge it from empty to full overnight at home with his 16 kW level 2 charger. Last summer his batteries in his travel trailer were nearly shot but he didn't replace them. He just took his family camping and plugged in to the F150 when they got to their campsite. My son did keep his gas powered F150 for now for the rare times he needs to travel out of state or go on hunting trips more than several hundred miles from home.
  8. I have lived in Oregon my whole life. You have planned an awesome trip. I second the recommendation to visit the Olympic National Park in Washington with a day trip to Victoria (and Butchart gardens) via passenger ferry. As for the Oregon coast, I would seriously consider the incredibly scenic Southern Oregon Coast instead of the much more crowded central Oregon coast. Since you are planning to visit the redwoods, afterwords you can just continue north on Highway 101 from Crescent City California through Brookings, OR and north to Reedsport where you could loop back east to interstate 5 if you wanted to. Some of the nicest coastal State Parks in Oregon are in the remote south coast stretch and there is less tourist pressure. The other thing I would share is that if you only see the western part of Oregon and Crater Lake, you will miss some of the best of the state. Over half of Oregon lies east of Crater Lake and is high dessert and canyonland country. Much of it is very remote with few lodging opportunities and only the lucky folks with a good trailer can easily take advantage of it. If you have time, one of the most remote and spectacular places in Oregon is Steens Mountain. Should you decide to make just one stop in Eastern Oregon along the way, I would suggest making it Steens Mountain and surroundings. (Steens Mountain is the first place I went after I brought my Ollie home from Hohenwald). You can reach Steens Mountain by traveling west from Interstate 84 at Ontario, OR, or west on Interstate 80 out of Salt Lake City and cutting north at Winnemucca on highway 140 to Steens Mountain (Frenchglen, OR). There is a wonderful BLM campground outside tiny Frenchglen called Page Springs, and it is close to the start of a gravel road that allows you to drive to the top of spectacular Steens Mountain itself at over 9.000 feet. Your timing will be good for a visit to Steens Mountain as it is only accessible a few months out of the year due to late snow melt (July) and closure when the first snow falls in late September or October. (bring insect repellent) The surrounding area is rich in history, much of which dates back to the mid-1800's, the Oregon Trail, Cattle Barons and gold and silver mining. From Steens Mountain, you can continue on to Crater Lake via Bend, OR and then south down to Lassen and then west over to the Redwoods. Something to consider if you have the time.
  9. I am old as well and we both have memories of our roadster days. I once wore a new set of tires bald in 12,000 miles with my 68 Datsun 1600. Anyway, I live in the inner city (Portland OR.) and have a low height garage so a truck is just not practical for me and on street parking in my neighborhood is a challenge. My plan when I first purchased #657 was to limp along with the 4Runner just long enough until a tow capable EV SUV became available. The Rivian would work but according to my wife I can't afford one. And actually, the 4Runner is working out much better than I could have hoped. Of course, having driven nothing but manual transmission cars most of my life (like you probably), I am very comfortable manually shifting the automatic when towing to enhance performance and the transmission in my 4Runner is designed for maximum engine braking when descending. I am comfortable driving in the mountains and rarely have to use the brakes much to control speed, even on 6% downhill grades. I have found that the vehicle struggles with an OEM air filter but performance excels with a K&N air filter. I do have to be careful in loading my TV and have become accustomed to traveling light. If I travel with both my wife and dog, I have used up my cargo capacity and most everything else goes in the Ollie. I always keep the Ollie below 6,000 lbs. My 4Runner is a rare version called the V8 Limited that was factory set up for towing and was made in a Lexus factory in Japan. I am the original owner. I think it is almost identical to your GX470 but mine has the x-reas schocks and a self-leveling rear end which yours may not have. It is also factory rated to tow 7,000 lbs which I believe is a bit more than the GX470. Anyway, right before I drove 2,400 miles to pick up my new Ollie, I replaced the x-reas shocks and air springs at a cost of $5,600 and had a complete brake replacement with all OEM parts at a cost of $2,600. I now have over 20,00 miles of towing my Ollie and quite a bit of it has been on interstates in the mountains of Oregon, Washington and Utah. The car does struggle somewhat at high altitudes going uphill on windy two lane roads, but downhill is never a problem and I have never experienced any sway. That said I sure hope to upgrade to a more capable TV soon. Then we can start bringing a few toys along with us🤪
  10. My choice of propane tanks goes to (minimizing) weight being the highest priority. My tow vehicle (TV) has very little cargo capacity so minimizing tongue weight is very important to me. I am an outlier in that regard on this forum. To minimize weight I switched to composite propane tanks shortly after I acquired my LEII. When empty, they weigh about 1/2 of what a common steel tank weighs although the capacities are reduced somewhat. The 20 lb equivalent holds 17 lbs and the 30 lb equivalent holds 22 lbs of propane. Most people couldn't justify the cost because they are much more expensive than steel tanks. However, if lowering tongue weight is important for you as it is for me, you might want to check them out. They are way less expensive then a new TV🤑 I am pretty sure there are a few of you out there that would really appreciate the light weight and don't do extensive cold weather camping. Even if I get a new tow vehicle, I will probably continue to use the composite tanks because they are so much nicer for everyday use. In addition to being much lighter when full, they have a wide base and are extremely stable in the back of the vehicle without tie-downs. Also, they have no sharp edges whatsoever so it is much easier to carry around and pack in the Ollie when carrying a spare tank as I do for cold weather camping. I have never had any problems getting them refilled. They are made in Europe and imported by Viking Cylinders. https://www.vikingcylinders.com/online-shop/ Since they have a much larger diameter base, if you switch to them you will need to switch out your 2 tank mounting tray inside of the doghouse. Viking Cylinders sells a custom fit replacement tray for $40 and the old tray is easy to swap out for the new one and back again if necessary.
  11. The maxxair vent and bathroom vent don't seal real tight so a fair amount of warm cabin air can leave through those vents when closed IF and ONLY IF there is a window open or as you appear to have discovered, a source of outside air entering your basement. I have never experienced condensation under the hatch cover above the furnace like you are so it seems plausible the cold outside air is coming into the basement in that area. Could it be possible that the outside air intake tube for the furnace has cracked or separated from the combustion chamber inside the furnace housing? That would allow outside air to flow freely into the furnace housing and then into the basement through the fan intake vents when the furnace is not running but the furnace would probably still work. It doesn't seem at all likely but that could possibly explain it. Just a WAG.
  12. After four years of towing my LE II and reading countless threads on the Anderson and cargo capacities in general, I have come to the following conclusions. The Anderson improves the towing experience and aids in control of the vehicle in emergency maneuvers. The additional time to hook up the Anderson is negligible compared to the increased safety and driveability it provides If your manual states that a weight distributing hitch is required when towing over 5,000 lbs, it is because it is probably not possible to take advantage of the entire cargo capacity of the TV without using a weight distributing hitch. This is because cargo capacity as stated on the doorjamb sticker is always a product of the maximum front axle loading capacity plus the maximum rear axle loading capacity. It is often overlooked, but you can be driving down the highway with your Gross Vehicle weight 300 lbs UNDER the rated GVWR, but if the rear axle is loaded over the maximum rear axle weight, then you are overloaded. When a vehicle manufacturer states that a weight distributing hitch is required when towing over 5,000 lbs, they have assumed that when towing a trailer with a 500 lb tor higher tongue weight, it is not possible to load the vehicle to its rated cargo capacity (i.e., loaded to maximum GVWR) without overloading the rear axle axle. If you weigh at a scale, it is important that you weigh the front axle and the rear axle. If one is over its rating, the maximum rated cargo capacity of your TV is irrelevant. I am no expert and I hope others will correct me or provide the appropriate caveats to my description above if advisable.
  13. Does your water pump cycle on from time to time even when not using water? If so, that probably indicates a slow leak somewhere in your plumbing system. When you first turn your water pump on, it will pressurize the tank and then turn off. It will not come on again unless you turn on a faucet or flush the toilet. However, if there is a very slow leak, it will come on again after a few minutes or longer because the leak will gradually lower the pressure in the water system. This happened to me last time out after traveling about 30 miles on washboard roads. I traced the problem to a slow leak in one of the push-in compression fittings by the Truma on demand water heater. Even though the leak was in the rear of the Ollie, the leaking water was dripping out one of the forward weep holes.
  14. The only settings I had to change in my 2000W inverter/charger was to change the charge setting from flooded batteries to a LFPO4 charging profile. Our early versions of the 2,000 watt model did not have a LFPO4 setting to switch to so I selected the "custom" battery option. I then set the custom absorption voltage to 14.6 volts (as recommended by the battery manufacturer) and I was done. The main reason you need to adjust the absorption voltage to a 14.4-14.6 volt level (consult your battery manufacturer for their preferred setting) is that the LFPO4 batteries require a higher voltage than flooded batteries to reach full charge, compared to the flooded or AGM batteries. To be confident how to do this with your model of converter/charger, you really need to consult the "Optional Equipment" manual that came with your Oliver. I just looked on the Oliver University and the factory manual they have posted is apparently a mid-2020 updated manual that appears to reflect a firmware upgrade to the units we have, since the manual on the Oliver site displays a LFPO4 setting in the menu, which my 2020 version does not show in the menu and definitely did not have. I would post a picture of my settings table from my manual, but it is across town in storage. PM me if you want me to retrieve my manual and post a copy of the settings menu here. I would be happy to do so.
  15. The remote display I have is part of Xantrex inverter/charger model that I have, not the PD Charger/Converter. When I elected the 2000 watt inverter/charger option, the factory kept the PD Converter/charger in place to serve as the breaker/fuse panel, but disabled the converter/charger function and instead wired the 2000 watt inverter/charger into the PD circuit/fuse panel. You would not need to change any settings to use a 1,000 watt generator to charge your AGM batteries since your converter/charger is has its own built in charging limit of 45 or 60 amps depending on the model. A 1,000 watt generator should be capable of charging the batteries at 60 amps since this will effectively limit the draw on the generator to about 840 watts (14 volts x 60 amps = 840 watts.) I you upgrade to lithium batteries, then you have two choices. You can replace your existing PD converter/charger with a more up to date version of the same model that has a lithium ion charging profile option built in. This is the lowest cost option, but you will be limited to a maximum charging current of 60 amps split among all your batteries . A superior solution but more expensive solution would be to keep your current PD converter/charger but upgrade your inverter to a 3,000 watt inverter/charger. The 3,000 watt inverter charger that Oliver installs can charge your batteries at a rate as high as 150 amps, thereby charging your batteries 2 1/2 times as fast as a 60 amp charger when you are connected to shore power. To charge with a generator at the 150 amp rate, you would likely need a generator that outputs a minimum of 2200 MW continuous, more if you want to simultaneously use any 120 volt appliances at the same time. I hope this is helpful.
  16. Sorry that I may have added to the confusion. Apparently, the 2000 watt inverter installed in the 2018 Oliver was an inverter only without a battery charger built in. The 2000 watt inverter installed in my 2020 LE II is an inverter/charger. That is why I have a more sophisticated wall panel with led readout. In your 2018 Oliver, the batteries are charged by the Progressive Dynamics Converter/Charger under the dinette that also serves as the 12volt and 120 volt service panel (breakers and fuses). The PD Converter/Charger in your trailer has a fixed maximum charging rate of either 45 amps or 60 amps depending upon what model Oliver installed. The PD Converter/charger is perfectly adequate if you have lead/acid batteries or AGMs and charging at the maximum charging rate of 60 amps should not overtax a 1000 watt generator. If you ever upgraded to lithium ion batteries though, you would need to replace the PD converter/charger with a charger that offers a lithium ion charging profile built in. Progressive Dynamics makes one that is a drop in replacement for the one you have. Alternatively, you can install an updated combined converter/charger to charge your batteries and then bypass the charger in the PD Converter. That is what the factory did in my 2020 LE II. I do have a background in grid scale power and high voltage transmission, but the information above I learned the hard way when I switched out my lead acid batteries for LFP04 lithiums right after I picked up my 2020 LE II. Oliver started offering the lithium option in mid-model year about a month after I took delivery of mine so I had to figure it out myself. Information on this forum helped me out considerably.
  17. I have the Xantrex PROwatt 2000 inverter in my 2020 LE II. It has Charge Current setting just like the 3000 watt version. The max charge current in the 2000 watt inverter is 80 amps (as opposed to 150 amps in the 3,000 watt inverter.) To set the charge current limit to less than the factory default of 80 amps, you just need to go into the inverter panel on the wall of the Oliver, enter into configuration mode, scroll to setting # 24 Charge Current, and change the setting. It only takes a minute or two. It is certainly not as easy as using a bluetooth app and I often have to refer to the manual again because the exact sequence of button pushing is easy to forget. But it works just the same as in the 2000 watt inverter.
  18. With no offense intended, I believe there is some questionable advice in this thread. In particular, it is counterintuitive to me that reducing the input amperage to the inverter is the best way to limit the level of charging current that the inverter is delivering into the batteries, especially when the inverter has a setting (#24) designed specifically for that function. Wandering Sage Brush is apprehensive about using the smaller Honda 1000 to charge his house batteries while boondocking. There is nothing to be nervous about as many of us do it all the time. The only issue you need to be aware of is ensuring that the combination of trailer loads (120 volt loads and 12 volt charging load) is less than the maximum output of the generator. If you try to run higher loads (i.e., greater watts) than the generator can produce, the generator will overload and shut down. The table above showing inverter settings are for a 3,000 watt inverter. Setting 28 is factory defaulted to 25 amps because 25 amps * 120 volts = 3,000 watts. If you lower the amperage limit in Setting 28 down to lets say 15 amps, you are turning your 3,000 watt inverter into an 1800 watt inverter because 15 amps * 120 volts = 1800 watts. There is no need to do that. If you want to charge your batteries with a 1000 watt generator, then you need to limit the draw on the generator to less than 1,000 watts. If you want all the available 1,000 watts to go into your batteries, then there are two steps you need to take when you decide to charge. First is to turn off your inverter and any 120 volt loads if you want to all the generator output to go into your batteries. You don't want any 120 volt trailer loads drawing on the generator at the same time you are charging the batteries. Second, you need to reduce the amperage limit in Setting #24: Charger Current. The charger typically charges at about 14 volts when the batteries are getting close to full. Since volts x amps = watts, 1000 watts into the batteries is going to require 71 amps of Charge Current (14 volts * 71 amps = 1,000 watts) . Adjusting for losses and generator derating at altitude and in higher temperatures, you should probably limit the watts from the generator at no more than 900 watts which equates to 64 amps (900 watts / 14 volts = 64 amps). So whatever inverter/charger you have, set the max charging current at 60 amps and your Honda EU1000 will probably charge just fine without overloading. If you are running the Honda 1000 and you are also getting 20 amps from your solar panels at the same time, then you will be putting 80 amps into the batteries (60 amps from the generator and 20 amps from the solar). This is equal to 1,120 watts (80 amps x 14 volts = 1,120 watts) You can leave the Charge Current setting at 60 amps all the time if you want unless you want your batteries to charge faster when you are on shore power. If so, just increase the max charging amps in setting # 24 before you go back on shore power.
  19. I picked up one of these relatively inexpensive generator test kits a while back. It lets you verify both generator voltage and also how many watts and amps the generator is actually generating at site conditions (altitude and temperature) with the clamp meter. This can help you rule out generator issues. It comes with a test pigtail to make measurement easy. (see pictures below). You can find it at Microair .net
  20. I worry about Oliver owners with the Suburban furnace that close any heat vents (supply vents) in the trailer. This is almost always detrimental to the functioning a an HVAC system but in the case of my generation of the LE II it can be dangerous. According to my furnace manual, the furnace requires 25 square inches of unobstructed hot air venting to work properly. Even a few feet of lightweight flex duct will restrict airflow and any bends in the flex duct will restrict airflow even more. The two 4" round supply ducts in the Oliver total exactly 25 sq. inches at the furnace so technically, when the runs of flex duct are considered, Oliver has not ensured sufficient airflow for the furnace to operate at its best as it is. (An analogy would be someone that exceeds the GVWR of their tow vehicle). Closing one of the two cabin vents inevitably causes a sharp increase in back pressure against the furnace fan with the result that the fan cannot move as much air across the heat exchanger and into the cabin. The result is hotter air coming out of the remaining open vent but less Btu's in total flowing into the cabin, and the likely overheating of the heat exchanger resulting in the furnace shutting down prematurely (short cycling). In milder weather, this might not be noticeable but it is dangerous in colder weather because if the high temperature limit switch in the furnace ever fails, there is a serious risk of a fire. The only safe way to increase the flow of hot air into the Oliver's cabin is to increase the number or size of return vents, which will reduce cabin pressurization when the furnace is running and thereby enable the furnace to move more air (and Btu's) through and out of the supply ducts. In my experience, the key to comfort and balanced heating in the Oliver along with a warm bathroom is to ensure that all the hot air from the cabin must flow through the entire basement on its way back to the furnace, thereby heating the entire basement as well as the cabin. This requires additional return vents in the middle and front (bathroom) of the cabin.
  21. Your observations on the inferior design of the HVAC (furnace) "system" is spot on. I think Oliver has maybe not given this issue sufficient design attention because a large proportion of Oliver Owners probably winterize their trailers and don't care much about the furnace. I use my Oliver throughout the year, store outside, and do not winterize. My primary concern is the ability to keep the plumbing from freezing even when the cabin is warm. I have placed internet connected thermometers in the basement by the outside shower hoses and other spots, and found that the basement temperatures can fall to 30 degrees or more below the cabin temperatures when outside air temps drop into the low 20's or teens. I found that if the outside temperatures go very much below freezing, I have to keep the cabin at least 65 degrees to keep most of the basement areas (except for right around the furnace itself) above freezing. I determined the problem is insufficient warm air circulation through the basement (i.e., no return air vents in the front of the trailer (bathroom). Oliver did add a small return air vent in the bathroom in more recent models. I have resisted running new ductwork or cutting holes in the trailer to address this while I studied the issue in the field. Finally, and just recently, I tried a non-invasive hack that appears upon initial testing to work quite well. The outside temperatures last week dipped into the mid-teens for several days, yet my basement temps stayed within 15 degrees of the cabin temps (the Oliver was in outside storage). I am heading out next week and will test the cabin and bathroom comfort in temperatures expected to be just below freezing, and I expect to find a much warmer bathroom and more comfortable trailer, as well as the warmer basement temps. What I finally did was easy. I removed the "front bottle plate" from the bathroom vanity and disconnected the flex duct from the bathroom vent, creating a 3'' (or 4") return air vent in the bathroom. I then left the disconnected air duct loose under the sink to put extra heat into the front of the basement. Combined with the new return air vent in the bathroom, the warm cabin air flows forward into the bathroom and the warm air bathroom air is pulled under the bathroom and shower to be slowly circulated from front of the basement to the back of the basement when the furnace fan is running, more effectively heating all the plumbing and battery box. I do need to keep the bathroom door cracked (but not open) for this to work, unless or until I install a vent between the bathroom and main cabin. I am not sure if a functional return vent like this would cause problems in Olivers with the composting toilet. I have the standard toilet.
  22. Humor notwithstanding, I believe this is the correct answer. It is not complicated. First, lets look at what happens when you connect to shore power 30 amp receptacle. In this normal situation, the 30 amp shore power outlet will pass a maximum of 3,600 watts continuous power to your Ollie (30 amps x 120 volts = 3,600 watts). If you turn on too many appliances in the Ollie (including battery charger and air conditioner, fridge, etc.) such that you are consuming more than 3.600 watts, then the 30 amp breaker on the shore power receptacle will likely trip. It is difficult but not impossible to to draw more than 3,600 watts in the Ollie but could happen if the batteries were charging at a 150 amp rate consuming 2,100 watts (150 amps x 14 volts =2,100), and you turned on the microwave at 1,000 watt setting, and turned on the air conditioner all at the same time, you would be trying to draw more than 4,000 watts from the 30 amp shore power outlet and the 30 amp breaker in the shore power post will trip. The only thing different when you connect to a 20 amp shore power outlet is the shore power outlet will only pass a maximum of 2,400 watts before the 20 amp breaker protecting the shore power outlet will trip. In this case, you need to be diligent to keep your continuous consumption in the Ollie to less than 2,400 watts. This is easy to do if you change the charger setting to something lower than 150 amp maximum charging rate. I almost always choose to connect to the 20 amp shore power outlet when I am just stopping for the night somewhere and not unhitching. It is less work than to having to dig into the back of the basement to retrieve the heavy 30 amp cord and put it away later. Instead, I quickly plug in using a 25 foot lightweight 12 AWG extension cord with a 20 amp to 30 amp adapter. It allows me to simultaneously charge the batteries at 80 amps (1,120 watts, the maximum my 2,000 watt inverter will do) run the air conditioner or microwave at reduced power, and watch the 120 volt TV all simultaneously without drawing more than 20 amps of shore power. I can also run all 12 volt loads (e.g., furnace, lights, water pump, etc.) that I want without increasing the draw on shore power since all 12 volt loads draw their power from the batteries. The next morning, it takes me only two minutes to disconnect and stow the 12 AWG extension cord in the back of the TV. As Rolind said above, you will probably need to back down the maximum charge rate limit setting on your charger if you connect to only 20 amps, depending on what other 120 volt loads you want to run simultaneously in the Ollie.
  23. ICE engines will fade from vehicles, but hopefully ground based ICE generators will expand in rural areas to support grid-independent DC fast charging facilities. Using technology available today, these hybrid renewable EV fueling complexes can be built with a combination of on-site solar and/or wind power, some flow battery storage, and ICE generators with on-site fuel storage. The ICE generators would burn locally produced renewable diesel (not biodiesel) made with agricultural or forest biomass. All at lower cost than today’s grid-connected fast chargers that rely on expensive, increasingly unreliable grid supplied energy. And unlike every charging station in place today, these chargers would continue to work when the grid goes down. Rural economies would be the big winners.
  24. Looks like my Gold 4Runner pulling the LE II. Gonna have to try that!
  25. I would be concerned if the GFCI on a house outlet tripped when connecting the Ollie, period. The inverter/charger by itself will not cause a GFCI outlet to trip at the house. A properly functioning GFCI will only trip if it detects a current leakage to ground, a situation that is not wise to ignore. Your problem may be with the GFCI receptacle you are otherwise using. You mentioned that your GFCI is only rated to pass 15 amps of current. Your GFCI is not rated to pass a 20 amp current to the Ollie. I would suggest you install a 20 amp WR (outdoor rated) GFCI and see if that solves the problem. It worked for me. This is the 20 amp WR GFCI that I installed to connect house power to my Ollie. https://www.amazon.com/Leviton-GFWT2-W-SmartlockPro-Weather-Resistant-Tamper-Resistant/dp/B013OVCTBO/ref=sr_1_1?crid=21PT35NK7I73G&keywords=outdoor%2Brated%2B20%2Bamp%2Bgfci%2Boutlet&qid=1699985721&sprefix=outdoor%2Brated%2B20%2Bamp%2Bgfci%2Boutlet%2Caps%2C124&sr=8-1&th=1
