KenB Posted May 26, 2024 Posted May 26, 2024 Hello All, I've been reading the forum regularly since 2017 and don't remember anybody mentioning this. The chromed taillight bezels on our 2018 tail lights were turning a gross matte green from winter road chemicals used in Minnesota and maybe a Colorado trip over I70 on my way to Moab in March a few years back. I found that etrailer.com sells just the chrome bezel separately and that I didn't need to buy the whole tail light if I wanted the taillights to look nice again. The replacement bezels are only $4 each, so I bought a set of six. Since they fit and are inexpensive, I may just buy another set and put them away for a rainy day. They are held in place by four tabs on the back of the bezel and old bezel just pops off. I've attached a photo of where the bezel tabs lock in on the light housing. There are four bezel tabs, two on the top and two on the bottom. I used a few thin screwdrivers and an old fillet knife to get them to pop loose. After learning where the tabs are on the first one it made removing the next five much easier. There are many other items on my trailer that are ugly due to unrepairable road chemical corrosion, but at least this one is fixed. Hope this helps someone else with their northern winter use trailer too. Ken 6 1 2013 Toyota Land Cruiser 200 2018 Twin Bed Elite II #351
Patriot Posted May 26, 2024 Posted May 26, 2024 A good reminder Ken and good scoop on the bezels. Sodium Chloride used on roads in the winter is just brutal on mostly all metals, and as you have pointed out some plastics. For this exact reason I avoid towing our Oliver anywhere in the winter where I know the roads are going to be treated. Those shiney new bezels will look great! 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
MAX Burner Posted May 26, 2024 Posted May 26, 2024 6 hours ago, Patriot said: Those shiney new bezels will look great! Ditto! We like shiny!!! HA! 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Corvus Posted May 26, 2024 Posted May 26, 2024 Thank you, this is very timely. I was trying to figure out how to remove mine yesterday because they are taking on that corroded look too. 2 Jerry & Kathy 2019 LEII Standard #539 + 2019 Tundra Limited 4X4
Moderators Mike and Carol Posted May 26, 2024 Moderators Posted May 26, 2024 I replaced mine before the rally and it does make a big visual difference. Mike 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
jd1923 Posted May 26, 2024 Posted May 26, 2024 9 hours ago, Patriot said: Sodium Chloride used on roads in the winter is just brutal... Brought up in Chicago and TG we left there 25 years ago! Also thank goodness when we get snow up here in the Bradshaw Mountains of the Prescott NF, Yavapai county uses a sand mixture without salt. And in the spring, they run the street sweepers right down our street. Nice! And thanks @KenB. I had seen these on Amazon for $6 and when I need another item on eTrailer I'll get a set of these to combine shipping. Ours are pretty good, but #113 is 8 years old now in the AZ sun. Not as shiny as once was When I get around to a professional de-oxidization (is that a word?) and gelcoat of the outer hull, it will be nice to first remove most trim items and do the job right. Other items I will replace at that time: Furrion RV Outdoor Receptacle Cover - 15 Amp - White Furrion Accessories and Parts F15RCSPSAM (etrailer.com) (not sure this is the correct part#) Amazon.com: Sea Dog 337150-1 Screw Out Deck Plate, 5-7/16" / White : Sports & Outdoors (could not find on eTrailer) 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators topgun2 Posted May 26, 2024 Moderators Posted May 26, 2024 1 hour ago, jd1923 said: Other items I will replace at that time: Furrion RV Outdoor Receptacle Cover - 15 Amp - White Furrion Accessories and Parts F15RCSPSAM (etrailer.com) (not sure this is the correct part#) Instead of replacing this cover and then a few years down the road when it "yellows" again, I took mine off hull #117, cleaned it up (very well) and used Krylon gloss white rattle can paint. It still looks new after three years. Bill p.s. of course with the cost of a single rattle can these days and the work involved in cleaning the cover up ....... 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
KenB Posted May 26, 2024 Author Posted May 26, 2024 1 hour ago, jd1923 said: Other items I will replace at that time: Furrion RV Outdoor Receptacle Cover - 15 Amp - White Furrion Accessories and Parts F15RCSPSAM (etrailer.com) (not sure this is the correct part#) Amazon.com: Sea Dog 337150-1 Screw Out Deck Plate, 5-7/16" / White : Sports & Outdoors (could not find on eTrailer) If you're going to replace all of those, you might as well replace the handles on the propane cover too. It's just chromed pot metal and while it works fine indoors in the Oliver kitchen, it's very susceptible to corrosion outdoors due to getting blasted by winter road brine if towing during fall or winter. I bought mine from Oliver, but if you type the part number off of the back of the pull into a search engine you'll get a few options for purchase. They are very easy to replace. Just unbolt and bolt the new one on. No sealant or anything. A photo is attached to show how bad my handles had corroded. 3 2013 Toyota Land Cruiser 200 2018 Twin Bed Elite II #351
jd1923 Posted May 26, 2024 Posted May 26, 2024 (edited) 1 hour ago, topgun2 said: Instead of replacing this cover and then a few years down the road when it "yellows" again, I took mine off hull #117, cleaned it up (very well) and used Krylon gloss white rattle can paint. It still looks new after three years. Bill p.s. of course with the cost of a single rattle can these days and the work involved in cleaning the cover up ....... And if this is the correct cover, again it looks a little different, it's only $10 with tax. BUT, if I had the can of paint on hand, paid for, I would do the same and save the $10! Edited May 26, 2024 by jd1923 Added second sentence 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted May 26, 2024 Posted May 26, 2024 39 minutes ago, KenB said: If you're going to replace all of those, you might as well replace the handles on the propane cover too. OMG Ken, wow! I see you are from the beautiful land of 10,000 lakes, frigid temps half the year and a whole lotta street salt! (This is one reason why I started the thread, re listing your location.) Good addition though. I would not think that part to be so easy to source. When I used to restore old cars, before working on the paint (which I jobbed out), I would remove EVERY piece of trim. Now it appears I am in the restoration hobby again with an old Oliver! The 2nd pic is the rear of my '59 300E (owned it 1992-2010). All trim, all stainless, all chrome, everything was removed. Then it only cost me $200 (1996 dollars) to get the paint buffed/detailed, on a 10-year-old lacquer repaint. It did cost 1000s more to rework the stainless, chrome the bumpers, purchase NOS lenses, etc. and likely 1000 hours of sweat equity (don't have that energy anymore, half-day labor now vs. a 10-hour day was normal back then). When I get around to paying $$$$ to get the exterior fiberglass redone professionally, I will remove many trim pieces like this, so they can hit the whole panel with a buffing wheel. Until that day, ours will get duller as I collect parts like these, prioritizing jobs like a new AC unit. Check out the doghouse handle on your hull a 2018 vs. ours a 2016 life in the southwest! I will remove these handles for the finish work, use a light polishing wax and remount them. 2 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Corvus Posted May 26, 2024 Posted May 26, 2024 (edited) Thought I would post this in case anyone else was reluctant to remove the bezel with metal tools and risk buggering up the light or gelcoat. This involves using an old credit card, or hotel key. First slide the card between the light and bezel in the center. Next slide the card from side to side to release the clips. Sometimes there’s a click. Now the bezel can be gently pulled off. I didn’t find it necessary to release the clips on both sides but that could be the case at times. Edited May 26, 2024 by Corvus 4 5 Jerry & Kathy 2019 LEII Standard #539 + 2019 Tundra Limited 4X4
Geronimo John Posted June 3, 2024 Posted June 3, 2024 That's a lot of corrosion. Salt is bad. If replacing would some clear coat or gel coat help extend their life span? GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Rolind Posted June 3, 2024 Posted June 3, 2024 We have had a significant amount of corrosion on out light bezels and a lesser amount on the propane handles. Our trailer is just a year old. The offending trip was to Bahia Honda. There was some chemical treatment on the roads through Tennessee but we washed the trailer immediately in arriving to Florida. any advice on the best way to protect plastic chrome pieces. Our 3m marine wax didn’t do the trick. Thanks Robert and Cheryl, Louisville, KY, Legacy Elite II 2023 Hull #1390 Oliphino, TV F250 Tremor
Moderators Wayfinder Posted January 25, 2025 Moderators Posted January 25, 2025 Thanks @KenB. Your info on the Bezel replacement lead me straight to the entire light replacement part on my 2016 Elite-II. I think I will order two lights, and three extra Bezels in order to replace all the bezels and have one spare light on-hand. There's other great hints in this thread for removing the Bezel. Thanks @Corvus Ordering from E-Trailer: Piranha LED Trailer Tail Light w/ Chrome Bezel - Stop, Tail, Turn - Red Lens https://www.etrailer.com/Trailer-Lights/Peterson/PE76XV.html Part Number: PE76XV $34.02 (as of January 2025) Peterson Trailer Lights - PE76XV Tail Lights Oval LED Light 7-1/2L x 3-1/4W Inch Surface Mount Stop/Turn/Tail Non-Submersible Lights Peterson Specs: Overall dimensions: 7-1/2" wide x 3-1/4" tall Light dimensions: 7" wide x 2-3/4" tall Diodes: 10 Operating range: 9V - 32V Limited lifetime warranty 2 Chris 2016 Legacy Elite II o-o Hull #110 o-o "Rock'in 110" o-o Twin Bed (sometimes converted) o-o 5-leaf Alcan Springs (installed Feb 2026) 2020 RAM 1500 Limited 5.7L Augusta, Georgia
Moderators Wayfinder Posted January 27, 2025 Moderators Posted January 27, 2025 Dang it, I had not ordered the lights yet, and refreshed the page this morning and they went up in price a bit. Now $35.66. Ordering now. LOL Chris 2016 Legacy Elite II o-o Hull #110 o-o "Rock'in 110" o-o Twin Bed (sometimes converted) o-o 5-leaf Alcan Springs (installed Feb 2026) 2020 RAM 1500 Limited 5.7L Augusta, Georgia
Geronimo John Posted February 2, 2025 Posted February 2, 2025 On 5/26/2024 at 9:54 AM, jd1923 said: When I get around to paying $$$$ to get the exterior fiberglass redone professionally, I will remove many trim pieces like this, so they can hit the whole panel with a buffing wheel Spoken like a true Professional! 2 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
jamesgang Posted February 12, 2025 Posted February 12, 2025 On 5/26/2024 at 2:32 PM, KenB said: If you're going to replace all of those, you might as well replace the handles on the propane cover too. It's just chromed pot metal and while it works fine indoors in the Oliver kitchen, it's very susceptible to corrosion outdoors due to getting blasted by winter road brine if towing during fall or winter. I bought mine from Oliver, but if you type the part number off of the back of the pull into a search engine you'll get a few options for purchase. They are very easy to replace. Just unbolt and bolt the new one on. No sealant or anything. A photo is attached to show how bad my handles had corroded. latest link on where to find these: https://www.outwater.com/SD-160 1 2017 F250 Platinum D6.7L 2016 LE2 #157 with all options // Upgrades: Truma CP Plus and A/C, D52 Axles, Windows, Bath Fan, 4xTrojan AGM AES (-40F)
jd1923 Posted November 7, 2025 Posted November 7, 2025 (edited) On 5/26/2024 at 4:10 PM, Corvus said: Thought I would post this in case anyone else was reluctant to remove the bezel... Thank you, Jerry. I will try a credit card tomorrow, I should have saved some hotel keycards from when I traveled for business! Maybe I have one or two somewhere. I pulled on a few edges today and thought, I better look into this. And thank you @KenB for the good info in your posts! 😂 Edited November 7, 2025 by jd1923 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
