Guest Posted May 31, 2024 Posted May 31, 2024 (edited) I saw yesterday that Toyota has finally issued a Safety Recall for 2022 & 2023 Tundras and Sequoias. I’ve read that 2024’s are continuing to have the same main bearing failures. I’m a huge Toyota fan and you will have to pry my 2011 CrewMax out of my cold dead hands - but the new ones look really nice. Very disappointed in Toyota for these failures and hope they find the root cause soon. Not really buying the “debris from engine manufacturing” as the cause, since that would be easy to remedy and I think they would have taken care of that early on when these failures started to occur. Anyone here with a third gen Tundra had an engine failure yet? https://pressroom.toyota.com/toyota-recalls-certain-model-year-2022-2023-toyota-tundra-and-lexus-lx-vehicles/ Edited May 31, 2024 by katanapilot
rideandfly Posted May 31, 2024 Posted May 31, 2024 No failures with 30,000 miles so far on our 2022 Tundra. Changed the engine oil at 1,000 miles, then 5,000, and 10,000 miles trying to get rid of debris from engine manufacture. Also changed the differential oil at 1,000 miles and found metal shavings on the drain plug/magnet that was larger than expected. 😐 1 Bill 2015 LE2 #75 2024 F350 6.8L
MAX Burner Posted May 31, 2024 Posted May 31, 2024 No indication of engine issues after 35,000 miles (knock on wood) - getting engine oil changed next week and will inquire at the Toyo service center regarding the recall. 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Patriot Posted May 31, 2024 Posted May 31, 2024 (edited) Was so disappointed Toyota dropped the bullet proof 5.7 V8. We loved our 14 Platinum CrewMax it was a great truck. We just needed a lot more cargo capacity when loaded up to travel safely and ready to camp. The negative press and stop sale stickers on the new 22/23 YM Tundras sitting on dealers lots impacted by this recall is not good. Only time will tell how this works out. Edited May 31, 2024 by Patriot 4 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
CRM Posted May 31, 2024 Posted May 31, 2024 3 hours ago, Patriot said: Was so disappointed Toyota dropped the bullet proof 5.7 V8. We loved our 14 Platinum CrewMax it was a great truck. We just needed a lot more cargo capacity when loaded up to travel safely and ready to camp. The negative press and stop sale stickers on the new 22/23 YM Tundras sitting on dealers lots impacted by this recall is not good. Only time will tell how this works out. This has the potential to be a disaster for Toyota, even worse than the 1st gen Tundra frame recalls. I know they'll make it right no matter what it takes but I see no other option than to drop the oil pan and pull the main bearing caps and inspect the bearings. Pretty sure the motor has to be pulled on these trucks to do this too.. Agree with you on the 5.7 V8. One of the best engines ever built, but even it had it's issues (valve springs) for the first couple of years it was out. I was planning on buying a new Tundra once the kinks were worked out, but looks like I'll have to wait a little longer than expected.. 4 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
rideandfly Posted June 1, 2024 Posted June 1, 2024 (edited) Deleted link. Edited June 11, 2024 by rideandfly 1 2 1 Bill 2015 LE2 #75 2024 F350 6.8L
rideandfly Posted June 1, 2024 Posted June 1, 2024 (edited) Since Toyota plans to have a solution by late July, we still want to continue towing Ollie on local Blue Ridge Parkway trips while waiting for Toyota's solution. From my information gathered so far, failure rate is much less than 1% of 102,000 Toyota and Lexus vehicles. Edited June 8, 2024 by rideandfly 1 2 Bill 2015 LE2 #75 2024 F350 6.8L
Geronimo John Posted June 2, 2024 Posted June 2, 2024 (edited) Bill: I would press on if your are under 29K. But would for have towing on both TV and Ollie! Would also not go boondocking where the two insurance would not cover. GJ Edited June 2, 2024 by Geronimo John 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
rideandfly Posted June 2, 2024 Posted June 2, 2024 (edited) Just returned from a trip to Michigan (not towing) through West Virginia and Ohio with over 1400 miles and the pickup got over 24MPG. Read every post I could find on a Tundra forum today, confident Toyota will solve the issue. Edited June 8, 2024 by rideandfly 4 1 Bill 2015 LE2 #75 2024 F350 6.8L
MAX Burner Posted June 2, 2024 Posted June 2, 2024 Our Tundra experience is the same as @rideandfly's. (Thanks for posting the spreadsheet, BTW, Bill!). We've had no engine indications such as those listed on the Tundra Forums spreadsheet. I'm planning to get our oil analyzed at our local FBO at ABQ Sunport next week to set a baseline. We've put north of 3,500 miles on the TV in the past 6 weeks - it tows Casablanca famously with over 35k miles. The only mods we've made are the AirLift 5000 pneumatics for the rear suspension. Planning 1,500-miler to WY in two weeks... Oh, well. 2 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
rideandfly Posted June 2, 2024 Posted June 2, 2024 (edited) Added some Toyota items after purchase (mud flaps, bed mat, side-rails, Tonneau cover) but only aftermarket item was Timbren Load Enhancement System on the rear differential. The more I look at this, going to change oil/filter every 5000 miles (required when towing) but will do this towing or not. Each oil change, will take an oil sample for analysis and monitor engine oil condition until Toyota resolves this recall. There are some folks with over 100,000 miles on their 2022 Tundras without any issues. Edited June 2, 2024 by rideandfly 3 Bill 2015 LE2 #75 2024 F350 6.8L
MAX Burner Posted June 2, 2024 Posted June 2, 2024 Good call, Bill - I'm thinking we'll be doing the same. Do you use the TOW+ mode when dragging the OTT? Just curious... 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
ChrisMI Posted June 2, 2024 Posted June 2, 2024 Didn’t Toyota had early turbo failures on this engine? I know turbos are not very tolerant of contaminants in the oil. 2
rideandfly Posted June 2, 2024 Posted June 2, 2024 (edited) 1 hour ago, MAX Burner said: Good call, Bill - I'm thinking we'll be doing the same. Do you use the TOW+ mode when dragging the OTT? Just curious... Yes, use tow mode with Ollie and normally tow in 7 & 8 gears in NC & TN 18 minutes ago, ChrisMI said: Didn’t Toyota had early turbo failures on this engine? I know turbos are not very tolerant of contaminants in the oil. Yes, there were some early turbo failures, too. These engines were in some Lexus vehicles for a few years first, but different turbos were selected for the Tundra Edited June 2, 2024 by rideandfly 1 Bill 2015 LE2 #75 2024 F350 6.8L
mountainoliver Posted June 2, 2024 Posted June 2, 2024 “Also changed the differential oil at 1,000 miles and found metal shavings on the drain plug/magnet that was larger than expected. 😐“ I owned a 2017 Tundra for a short while and also found machining shavings in the rear differential so I guess that nothing has changed in 7 years. 2 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
rideandfly Posted June 2, 2024 Posted June 2, 2024 4 minutes ago, mountainoliver said: “Also changed the differential oil at 1,000 miles and found metal shavings on the drain plug/magnet that was larger than expected. 😐“ I owned a 2017 Tundra for a short while and also found machining shavings in the rear differential so I guess that nothing has changed in 7 years. Found one nice size curly shaving from machining or drilling in the first differential drain. Hard to see how it was missed during assembly. 2 Bill 2015 LE2 #75 2024 F350 6.8L
Patriot Posted June 3, 2024 Posted June 3, 2024 4 hours ago, rideandfly said: Found one nice size curly shaving from machining or drilling in the first differential drain. Hard to see how it was missed during assembly. Bill, With the type of meticulous care you take of ALL your vehicles, I don’t think you will encounter any ongoing issues with your Tundra. 👍🏻 4 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
rideandfly Posted June 3, 2024 Posted June 3, 2024 (edited) David, You are very kind! Looking forward to camping with Ollie later this month! Edited June 3, 2024 by rideandfly 3 Bill 2015 LE2 #75 2024 F350 6.8L
Patriot Posted June 3, 2024 Posted June 3, 2024 (edited) 9 hours ago, rideandfly said: David, You are very kind! Looking forward to camping with Ollie later this month! Bill, We gotta get our 🫐berries picked and then we’ll be on the road again. So far things are looking really good. We’ll see.👍🏻 David Edited June 3, 2024 by Patriot 2 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
rideandfly Posted June 3, 2024 Posted June 3, 2024 (edited) Edit: Changed video about 3.4 Engine Edited June 8, 2024 by rideandfly 1 Bill 2015 LE2 #75 2024 F350 6.8L
Moderators topgun2 Posted June 3, 2024 Moderators Posted June 3, 2024 Very interesting video. And, this guy's point of view just may be correct. However, not being a engineer, I trust that these companies (Ford, Chevy, Dodge, Toyota) all have a bevy of engineers whose job it is to design products that live up to the required specs. I purchased one of the first generation 3.5 twin turbos when I got my 2011 Ford F-150. I was "nervous" about this decision because I've always shyed away from buying the first generation of any new automotive product - "wait until they get the bugs worked out" was the standard mantra. I took the "risk" because of all the testing that Ford claimed had been done on this new engine. As it turned out - I never had a problem with that truck and this led me to purchase another 3.5 ecoboost in 2017 and yet another in 2023. Yes, I may have been very lucky in that Ford has had issues with their trucks resulting in a number of recalls over the years. These recalls include engine recalls such that Ford actually totally redesigned the turbo truck engines. Perhaps I dodged those recalls because I tend to not keep my vehicles beyond 6 years and, therefore, never get anywhere near 100,000 miles on them prior to the purchase of a new one. When I started looking at new trucks in late 2021, the Tundra was high on my list given that the "best" truck I've ever owned was a Tacoma. Unfortunately, the overall specs of the Tundra just didn't measure up to the F-150 (payload being the main issue). I was told that these numbers should not get in my way because Toyota always is very conservative in calculating and reporting these kinds of specs. And, while I actually believe that the probability of this statement is most true, I decided to stay with the devil I knew versus the devil I didn't know. Certainly Toyota "tested" this engine that is causing "problems" and (I assume) that it met or exceeded the design specs. But, perhaps, as with the situation that caused Ford to redesign their engine, Toyota has run into an unforeseen issue that only started to show up during "real world" testing on engines that had been driven a fair amount of miles. Hopefully Toyota will get to the bottom of the issue quickly. And, I have little doubt that when they do Toyota will do the right thing and get it fixed. Bill 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
rideandfly Posted June 3, 2024 Posted June 3, 2024 Here's notice a Tundra owner received this morning from Toyota Canada: "We would like to confirm that Toyota Canada initiated Safety Recall Campaign SRC RH0 (XH0) to resolve an issue related to the engine may stall. We would like to take this opportunity to advise at this time Toyota Canada is currently in the process of manufacturing the efficient amount of parts for this recall. We do apologize, however we do not have a time frame when they remedy will be available. Please be assured that we will notify you by first class mail as soon as the campaign remedy parts are available. At which time you can make an appointment with your dealership to have the recall completed at no cost to you. As we previously advised should you have concerns regarding this recall, please reach out to your dealership. We trust this information is helpful and thank you again for taking the time to contact us." 1 Bill 2015 LE2 #75 2024 F350 6.8L
rideandfly Posted June 3, 2024 Posted June 3, 2024 (edited) On 6/3/2024 at 9:40 AM, topgun2 said: Hopefully Toyota will get to the bottom of the issue quickly. And, I have little doubt that when they do Toyota will do the right thing and get it fixed. Bill Agree, hope they resolve this quickly. I'm not getting into manufacturer's names, but during 2021 purchased a new pickup and it stayed in the dealership shop during 2021 over 30 days during one time waiting to be fixed correctly. Next vehicle purchased was this 2022 Tundra. Had 4 recalls on the Tundra so far. Edited June 8, 2024 by rideandfly 2 1 Bill 2015 LE2 #75 2024 F350 6.8L
Geronimo John Posted June 3, 2024 Posted June 3, 2024 Assuming the video is spot on, with main bearing assemblies cast into the block, the likely fix will be engine replacements. 100,000 replacement engines cost alone will be well over a billion dollars. That's based on 100,000 engines at $10K replacement cost. But to amass that number of engines and teams to replace them will not be a short term effort. I have very high regard for Toyota and the fact that they have "Rogered Up" to the problem. I also know that they will fix it, and when it is, the owners will be very happy with their TV's. GJ 4 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
MAX Burner Posted June 4, 2024 Posted June 4, 2024 We're north of 35k miles with zero issues - if we make it to 75k we might be good. The spread sheet showed very few failures in the higher mileage range. The engine/drivetrain warranty is 100k, it would be nice to get a new motor at about 99k! HA! 1 1 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
