On 7/16/2024 at 9:06 PM, rideandfly said:
If the axle label is missing, Dexter engraves the axle serial number on each axle. I gave Dexter the serial number off of one of Ollie's axles a few years ago and Dexter emailed this axle spec sheet back to me. With this information a Dexter dealer should be able to supply an axle built to original specifications.
It took awhile, but I finally found pictures of my axle label and although I had several pictures I wondered why they all had the same serial number.  I went under the Ollie and found that I only had 1 label and it was on the rear axle.  I then found the engraved SN for the front axle and it was the same as the rear, which I thought was weird.  So I emailed that information to Dexter asking for an as built sheet and if tandem axles should have the same SN.  Dexter sent back a single build sheet and never addressed my question about the same SN on both axles.
So the question that I now have is if anyone else has the same SN's on both axles and if that is Dexter's standard practice?
The attachment is for 2017 LE2 #193 which has the original suspension equipment
Mossey,
I only looked at one axle and assumed 🫤 they had two different SN's, never thought two axles would have same serial number. 😐 Will check my axle SN's during the first part of August, making one more modification to the F-150 before towing Ollie during the first part of August.
Updated:
2010 LE2 #45 SC 50.5" D52 Original axle capacity
2014 LE2 #50 SC 50.5" D52 Original axle capacity & Alcan spring & Disc Brake upgrades
2015 LE2 #75 SC 50” D52 Original axle capacity
2016 LE2 #110 SC 50” D35 Original axle capacity (Gathered from Wayfinder's posts)
2016 LE2 #113 SC 50 “ D35 Original axle capacity
2017 LE2 #193 SC 50.5" D35 Original axle capacity
2017 LE2 #208 SC 50.5" D35 Original axle capacity
2017 LE2 #226 SC 50.5” D52 Upgraded axle capacity & Alcan springs
2020 LE2 #579 SC 50.5" D35 Original axle capacity
2021 LE2 #898 SC 50.5" D35 Original axle capacity & Alcan springs upgrade
2023 LE2 #1386 SC 50.5" D52 Original axle capacity
Please me know if information needs to be added/changed for a hull # and can also add additional campers including LE1's.
Edited by rideandfly
Bill 2015 LE2 2024 F-350 6.8L
My axle labels are nearly destroyed by road & weather.  I'll see what numbers I can see engraved somewhere.
Chris
o-o  2016 Legacy Elite II (demo) - Hull #110 -"Rock'in 110"
o-o  2024 Ford F-250 Lariat, 7.3L Godzilla gasser
o-o  Augusta, Georgia
I found the SN engraved on the rear side of the axle near the center.  Take a damp rag and a flashlight with you and wipe the axle down, it should be visible.  Mine was close to where the label used to be.
On 7/27/2024 at 8:48 AM, rideandfly said:
Mossey,
Updated:
This is my trailer but I went out and measured the spring centers as 50.0"
Updated:
2014 LE2 #50 SC 50" D52 Original axle capacity & Alcan spring & Disc Brake upgrades
  • Thanks 4
@jd1923 has shown me the trees beyond the forest.  I was not "getting it".  Now I think I do.  So maybe OTT can special order the size of axles for my trailer and install them getting all the upgrades I want at once.  Hmmm.
I will get my serial numbers off my axles soonest.
Chris
That would be very convenient if Oliver will order your axles!
Please post your axle build sheet when you get it! I can update the list, if needed.
  • 6 months later...
On 7/29/2024 at 8:53 AM, rideandfly said:
Updated:
looks like mid 2016 LE2 was a changeover time for the hanger width - mine was born in July 2016 and is 50.5" - so you need to measure to make sure
oliver was able to upgrade my LE2 hull #157 to all new running gear (D52s etc)
side note - my original truma was also compliant with the recall / had all the tabs bent over!
Edited by jamesgang
2017 F250 Platinum D6.7L
2016 LE2 #157 with all options // Upgrades:  Truma CP Plus and A/C, D52 Axles, Windows, Bath Fan, 4xTrojan AGM AES (-40F)
Jamesgang, Thanks!
Updated:
2016 LE2 #159 SC 50.5” D52 Upgraded axle capacity
Anybody know the actual differences between the D35 and D52 axles?
John,
Here's how I understand it:
D52 is 5200 pound axle and D35 is 3500 pound axle. The D52 has larger brakes and larger spindle that requires larger bearings and probably other different parts.
Believe when an axle label says "D52 capacity: 3500 pounds"  meaning the axle assembly came with a 5200 pound axle with 3500 pound springs, 4 leaf, the assembly is rated at 3500 pounds.
Our LE2 came with axle labels "D52 capacity: 5200 pounds" meaning the axle assembly came with a 5200 pound axle with 5200 pound, possibly higher rated capacity springs, 5 leaf, the assembly is rated at 5200 pounds.
Believe Mountainman198 posted about this in another thread, too.
Would love to have been one of the luck owners to benefit from the 3500 pound axle shortage and got the super duty 5200 pounders.  I believe I remember that they can be upgraded to disk brakes which is an option that OTT really should consider for new trailers.
Thanks for the low down Bill!
Edited by Geronimo John
I wish I needed new axles.  So I could dream about getting 5200 axles with disk brakes and springs of my choice (written so as not to kick the sleeping Spring Bear topic).  Bullet Proof!   But then I would need to ask Crazy Horse to rob a bank to pay for it..........
  • Haha 3
Yep, they ran out of 3500 pounds axles when building our LE2 is my understanding, so they installed 5200 pound axle assemblies with 5 leaf springs.
Steve installed disc brakes on his LE2 5200lb axles and Pete installed disc brakes on his LE1.
The larger drum brakes on the D52 5200 pound axles are very effective and durable. When I need to rebuild the axle assemblies, disc brakes would be nice.
100% concur, @Geronimo John, John!
We've got the disk brake upgrade on our radar and will likely drop the hammer on them when our current 12" drums need replacement...FYI
  • (SOLD) 2022 TUNDRA
  • 3 months later...
Well, I know I dropped off for a year.  It's been busy. I can't wait to retire.
I just opened a ticket with OTT to see if they can custom order the axles with the SC=50" measurement.  I will triple check tomorrow as I'll get under the trailer again.
We'll see what they say.
Thanks to all for all the great information.  Priceless.
Chris
Chris
Chris:  I have CONFIRMED that Dexter does make the D60 5200's with the SC of 50".  They have been in use at OTT in some hulls under #100.
On 7/16/2024 at 1:27 AM, Wayfinder said:
23I asked Jason about that very thing, moving the hangers. He was not keen on that idea at all in fear it would not, or could not easily, be done well enough.
I suspect that he is concerned about needing to do an absolute clean off of the HDG material for a critical structural weld.
The threshold for "Well Enough" in this case needs to be very very high.
Axle Info:
2018 LE2 #342 SC 50.5, D35 Original axle capacity
According to the list above, it appears that only Chris' hull #110 and our hull #113 have 3500 lb axles measuring 50". As soon we get on pavement, off the dirt and gravel in our travels, I'm going to measure again to be certain. Though I'll likely just confirm what I measured when this thread started months ago.
I talked to Alcan yesterday and they only stock the 50.5" 5200 lb axles for their Oliver customers. The rep was not aware of the 50" since they had not run across it in all the many Oliver customers they have served and most customers have purchased/installed leaf springs only.
GJ, hulls under 100 where built 10+ years ago. Did you confirm Dexter still makes/stocks these? Do you have a part number?
Another Q: Would it be that much of an issue mounting the 50.5" axle to replace the 50"? Tires would be 1/4" further out on each side. Is there anything else? It looks like an extra 1/4" width would fit well enough under the fiberglass wheel well. From the beginning of this thread, I was surprised the manufacture would actually build two axel models only a 1/2 difference. Who made that business decision? Not good planning.
Maybe this has been answered already, If the hull sizes are the same for all EII no matter the year, what would be the issue to go from the 50 to 50.5” axles?
**Sold😞**
I believe OTT welded the axles saddles (not sure of correct term?) +/- 1/4 to the steel subframe (welded to inside or outside edge of the frame). It's just as crazy that OTT did this as the fact that Dexter would have both 50" and 50.5" axles in their catalog!
Huh, I submitted a ticket to OTT service but never heard anything back. I’ll need to give them a call about the 50” axles.
Chris
Wow, it's been almost a year, right?!
Chris in another thread, I wrote that I just placed a special order with Alcan Spring for Dexter D52 50.00 axles. They are an authorized Dexter distributor. Soon I should get confirmation and a part number for the correct axles for our hulls.
If you are going to install yourself or in your home town, you could do the same given it works out for me. But perhaps you'd be going to back Hohenwald which is out of the question for me.
Let us know what OTT says now and I will post here when I hear something.
What's interesting on the above list 2010 #45 LE2 has 50.5" axles.
