Well, as some of you know I've been posting a "ton" of stuff on the FB group.  I'm trying to share and received some good suggestions for troubleshooting all my brake issues.
I was inspecting the brake wire bundles on the street-side wheel well when one of the very hard plastic sealed connectors broke off. I discovered even more corrosion (pictured).  No wonder these newer trucks think there's an issue with the brakes, cuz there is.  The voltage drop / resistance must be the issue.  I'll get someone to press on the brake peddle while I have a multimeter on these.  I'll compare the rear wire bundle to the front bundle, which I've not touched yet.  To see if I can see a difference. If I do the test correctly.
I placed new temporary connectors on the rear bundle at a harvest host in a very wet grassy field, after a huge downpour.  Fun times.  But the truck did not gripe about breaks for 2.5 hours going home, until the very end of the trip, after going through a HORRIBLE rainstorm on I-20.
There seems to also be wire "extenders" on the green wire on the front bundle, and I don't like the look of the NON-sealed connectors. I cannot wait to see what they look like.  I have shrink-wrap sealed connectors on-hand I will use.
Any suggestions are welcome, especially as it comes to testing the voltage from the 7-pin to the bundles.  Just things I've not yet done before. Kind of fun though.
Thanks,
Edited by Wayfinder
Chris
o-o  2016 Legacy Elite II (demo) - Hull #110 -"Rock'in 110"
o-o  2024 Ford F-250 Lariat, 7.3L Godzilla gasser
o-o  Augusta, Georgia
When I serviced my bearings, I cut back all the wires to clean copper and replaced all those old crimps. It's easy enough to run new wire if needed. I would suggest using the old wire to fish new 14 AWG wire, interior to the axles, not exterior using wire ties to the axles as John E Davies showed in an old post.
I was curious, when the truck is running, or in run mode, why do the brakes assemblies tick?  Is this the communication signal from the newer trucks to check for voltage and ground?
Thanks.
Chris
JD:
One of the reasons that JD suggested the exterior routing acrosss the axle is that the wires were being damaged at the entry and exit points.
I totally agree that the wires should be 14 ga as you suggested.
24 minutes ago, Geronimo John said:
JD:
When we pulled the wires from the axle there were wear spots in the middle of the wires too in several places.  Mine are now zip tied to the outside of the axle.  I had service check when they replaced my brakes in May and they left the wires on the outside.  Mike
  • Love 3
I remember removing excess wire. Voltage varies and is controlled by your trailer brake controller. I get Chris to apply the TV brakes,  on and off as I check the brake action and adjustment.
i would still run the wires through the axles. You just need high-quality, better insulated wire and you can add grommets.
Edited by jd1923
Those butt splice connectors on the green extender wires were too large AND whoever put them on did not bother to shrink wrap the ends, and they were quite large open ended connectors.  Water traps for sure.
Everything is reconnected and heat shrink wrapped ends are done too.  No truck errors in the drive way, but I never did get those.
Will test drive soonest.  Finger's crossed.
Edited by Wayfinder
Chris
Google led me to the 2018 forum discussion about wire size, right after I found this eTrailer article. https://www.etrailer.com/question-83165.html
I'm thinking of getting eTrailers 12 Gauge Black Primary Wire to replace what's in the axles, and likely going exterior too, but using medium-size black exterior zip ties. Suggestions welcome.
 https://www.etrailer.com/Wiring/Deka/12-1-1.html
I agree, what's in the Dexter axles are very thin, albeit double jacketed.
Edited by Wayfinder
Chris
Thanks @jd1923 for your suggestions, and everyone's.  I have a new DC clamp multimeter in the mail.  I only had an AC clamp meter before.  Before I finish up my brake wiring job I'm curious to see the voltages before and after, especially at the farthest distance to passenger side brakes.
I'm torn between going internal and external wires.  I'm thinking someone can at least see any issues if exterior.  And with a ton of perfectly spaced exterior tie wraps, it should look "pro" - with the wire on rear, and slip above center-plane of the axle.  Still thinking about it.  I can be swayed.  I'm malleable.  😉
Chris
First, I would say it was designed to be internal. When I saw the pictures on the John E Davies post, I thought it didn't look so good and why get under there with so many wire ties. Good thing not much in way of UV rays down there since zip ties will get weak over time and will break. What if you run over something that grabs the wire? Behind the axle has some protection, in the axle has more.
I always go internal. On our Bigfoot RV an F450 frame, when installing a completely new battery/solar/inverter system, I ran two lengths of 10-3 AC cabling from the front where the house batteries and inverter were, through the truck frame, back almost 15 FT and then up to the AC panel. I would have spent hours tying these cables down to the frame but when I realized there was an open internal path the run was made in minutes, fully protected with no wire ties. Then I needed a 14 AWG from the battery monitor to the truck starter battery, again through the frame as much as possible.
Recently I installed a new fuel pump in the fuel tank of our Dodge Ram TV. The HP pump came with oversized 1/2" fuel line. I ran it completely though the frame, no better protection for a rubber fuel line. I watched 3-4 YouTube videos, and nobody had this simple idea. I often get installation kits with so many zip ties I do not use and save them for something else. I install things my way and you'll find what's best for you!
Like to read re the voltage readings you get. I believe OEM is 14 AWG wire. If you are concerned about voltage drop to the far side of the axle, you could run new 12 AWG on those legs for more durability and negligible voltage drop.
@jd1923 any idea about the brake assemblies "ticking" when the truck is in run mode?  Was guessing communication/testing of the brakes so the truck always knows the status.  It tickets about the same rhythm that the errors might occur on the dash, when the brakes get disabled due to ground issues.
Thanks!
Edited by Wayfinder
Chris
I've not heard any brake ticking in the many trailers I've owned. It does not sound right. However, I have never owned a newer truck with a built-in brake controller, so have no experience there.
I've always installed Tekonsha aftermarket brake controllers in every truck I've owned, except a for Redarc model installed in our GX470.
I would consider an alternate route for exterior runs of wire, the L-shaped aluminum crossbeams. From looking at their positioning in relation to respective axles, it seems more practical to utilize them rather than the axle themselves. Wires further protected with a loom could easily be fastened on the rearward side of these crossbeams at their juncture with the fiberglass hull, and most importantly out of harms ways. Just a thought!
@jd1923 the Google interwebs revealed that at least going back to 2018 RAM owners reported their trailers clicking. And yes I am a RAM owner. eTrailer explains that this is the truck ensuring the magnets are working and could use the brakes if needed.
And as I learned, if the trailer has some questionable grounds or connections, the truck thinks there are no brakes, and gives up trying after a while, sometimes in the disable state. I'm not sure that's good logic or bad to disable the brake altogether. I rather just have the message remind me to check my brakes instead of completely turning them off.
This could be my last RAM.
Edited by Wayfinder
Chris
A common sentiment on the Cummins Forum, is that we only own Rams to house our Cummins. Last gasser Ram I owned was an 80s model with a carbureted 360 CI.
No idea on your internal brake control system. You could always disable it and install a Tekonsha. I have this one and it works great. It has a test piston that I push often to see how the trailer brakes are working without applying the truck brakes. Depending on the feel you just dial in more or less, resulting in a voltage adjustment at the trailer wheels. You know exactly how they are working.
Tekonsha Primus IQ Trailer Brake Controller - 1 to 3 Axles - Proportional Tekonsha Trailer Brake Controller TK90160 (etrailer.com)
Well, I finished putting on new connectors on all the brake assemblies. Much like @John E Davies article in 2018, I also saw a marked voltage improvement at each assembly, at least 100 mV or better. I have gone for two 20 mile test runs with the rig and no errors from the RAM and I've been able to reduce the brake controller gain from 8.5 to 6.0 or 6.5. Will continue to fine tune that in up coming travels.
Chris
There is a DIY video on Dexter YouTube channel that showed checking the magnets as a part of the bearing repack and shows how to check the face of the magnet where it activates on the wheel. If there is uneven wear the magnet won’t be as effective.  I don’t believe they explained why the wear would be uneven.
Hull 509 "The Swallow"
On 7/18/2024 at 7:59 AM, Geronimo John said:
JD:
To All,
Mine were abraded somewhere within the axle tube in the middle between the hubs.  There was about 12' of wire stuffed in the axle between the hubs.
Mike T. & I were in discussion, as we both had this issue at overlapping times.  I believe I was just further in the process when we discussed.
I will include pics (of both dbl. insulated wires) of where abrading exposed to the bare copper within the two insulations.  I did not remember to label front & rear.
It was explained to me that the during the forming of the axle tubes (and this may vary depending upon manufacturer) the inside of some may get a robotic welding,
as well as the outside.  the outside of course is smoothed off and painted.  The inside, depending on the process may get a smoothing, however most of them are left with weld spatter inside so the axle tube on the inside resembles a concave wood rasp... just what we do NOT want to house our brake wires.
Mine actually look like they were somehow pinched, or maybe during the shorting out process heated up enough to melt(?) the insulation near the abrasions.
So I went straight to a previously read article by Prof. JED, Emeritus, which dealt with replacing the brake wiring.
I ran my newly purchased (NAPA Shielded Brake Cable) wires outside the Axle Tubes, putting them thru a loom at about 9 o'clock (to the rear) to protect from rocks or other strikes.  Using butt-splice connectors from the Shielded Brake Cable wires to the leads going into the brakes, then buttered the connectors up with adhesive-sealant to further protect connectors from moisture.  I have some ZIP TIES (I've been told, like the ones 'LE' uses on your wrists...) which are 1/2" wide and abt 1/8" thick, and used those secure the loom to the axles.
At least that was my approach at the time, as I wanted to get back to camping.
The Brakes have worked as they should.
B~Out
Edited by SNY SD UP
My Visited North America Map
Yes, mine looked very similar to Bryan’s.  I replaced them in the same manner and all is well.  Mike
  • 1 year later...
Well, I cannot believe it took me this long to find the issue with my intermittent brakes after Oliver failed to put on new axles for me last year.  Since then I've been dealing with my RAM disabling the brakes periodically.  No rhyme or reason... (known to me).
At least three or four of you folks here would have found this sooner than me, I'm sure of it.  As suggested by some, I verified all ground wires going inside the trailer from the brake bundle on the drivers side (only for snugness). I have even replaced all brake bundle connectors, some I did twice just to be sure (today).
But the good thing is I learned a great deal, and I found a ton of wire connector corrosion along the way. Even the 7-pin connector (now replaced) was not looking good.
But what I DID NOT check was the actual copper wire condition going INTO the negative/ground bus-bar inside the trailer.  Well, after checking, re-checking, re-checking again all brake connectors today, and verified voltage to all brakes, I think I found what someone at Oliver had done.
See, when they initially removed my axles from #110 last year, in hopes that the new axles would fit my frame (that's another thread), they slapped my old axles back on, and hence re-ran the wires back into the trailer (creating the new issue).
Sure I checked for snug negative screws, but I never actually pulled out the wire from the bus-bar.  Look what I found today.
After fixing this "mess", and ensuring the sheathing was not inside the bus bar, my third test drive for the day was a success, but who knows, I've driven four hours in the past, before my truck was bitching about low voltage for the brakes. This had to be the issue, I hope.
I was also able to snug up the main nut to the chassis ground, although I know that was not the primary issue.
Sigh!
Edited by Wayfinder
Chris
On all my trailers I cut the ground wire and bolt it to the frame not far from the hitch. Makes it easy to test and repair when brake and/or lights issues arise.
the negative bus-bar inside the trailer.
Chris, you may want to do what I did to #113, now that our hulls are 10 years old! And your grounds look more corroded, seeing the color of the copper. I removed each and every one, trimmed the wires back 1/2” and stripped them for clean fresh copper, retighten good!
The intermittent brake disconnect issue drove me crazy for a couple of years.  I had my Ram checked and rechecked, I rewired the 7 pin connector, and had a couple of different technicians go over the trailer.  Finally pulled the brake wires out of the axle and there it was, bare wires from bouncing around inside the axles for 100k miles.  Frustration!
  • Wow 2
  • 4 weeks later...
Darn it. As others have had before, finding the intermittent voltage issue with trailer brakes and newer trucks can be frustrating. I still have a bit of an issue.
So, the only thing I have not checked or changed are the brake assemblies and the brake wires inside the axle tubes. I’m pulling them out this week before my Egg rally in live oak, FL.
I just received my new 12 AWG wire from eTrailer and new higher end crimpers, for non-solder connectors. Adding to my tool supply.
Also got some new toys. Solder seal wire connectors, just a few, (1100 count). With a mini heat gun with deflector.
I will find the voltage issue.
I did check, clean, and improve any and all grounds in the trailer this weekend. The test drive didn’t reveal any brake voltage issues, but I’m removing the axle wires anyways.
Edited by Chris Scarff
Chris
Well, it was a good day, I now have some new toys tools to help do all this type of work, and WoW, what a different they made.
I finally got a creeper, a set of ratcheting wrenches, and an off-road hydraulic roller jack which reaches 29 inches in hight. It's nearly 21 inches to the Oliver frame from the pavement.  Man, it was a breeze to do now.
I think putting the wheels on the creeper took half the time of the entire project.  LOL
The ratcheting wrenches were SUPER handy for the new Bulldog shocks - I've wanted a set for years.
My new high-end crimper made great crimps on the new brake wire now running along the rear axle.  I have not gotten to the front axle yet, got rained out.
My old shocks were all dead, which "someone" at Oliver said were "good" just two summers ago.  All four shocks would not open on their own and had to be pulled apart and were much easier to push closed than the new Bulldogs.
I'm now ready for next week's trip to Florida's Eggs & S'Mores Rally at the Suwannee Music ground in Live Oaks. Can't wait to see "the gang".  We'll have at least 4 or 5 Ollies in our group, along with Casitas.
My Alcan springs should arrive next week, but no time to put them on yet.
I used heavy duty exterior zip ties to secure the double insulated, 12-gauge, 2-wire brake wire to the axle.  The eTrailer part number from eTrailer is C46GJ.
My new mini heat-gun with wire shield did the trick nicely on the shrink tube butt-connectors.
I was also able to find the serial number to the rear axle for future replacement - thank goodness for the new creeper.
IMPORTANT: I did find a bad area on the wire I pulled out of the axle, which appeared to have been "calked" over, or something odd like that. Also found a break in the wire insulation of the brake assembly itself - it's getting brittle.  All brake assemblies will be replaced after Alcan spring installation, or best yet, just get the axles replaced with new brakes.  Then, the entire under carriage should be good-to-go.
Passenger-side voltage is now at 2.98v.  Very nice.
Here's a quick video of the new -vs- old shocks, a short race to the finish.
Chris
