Patriot Posted May 23, 2025 Author Posted May 23, 2025 (edited) 2 hours ago, Boudicca908 said: I'm frugal! But I still might be forced into the much more expensive Unlimited plan, once I'm really out in the boonies. Like you, we really gave the 50GB a month “frugal” try, and quickly realized it was a no go for us while on extended trips. The unlimited roaming plan works best for us now and then we pause service when we arrive back home. Edited May 23, 2025 by Patriot 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Boudicca908 Posted May 24, 2025 Posted May 24, 2025 22 hours ago, jd1923 said: In the picture you can see my fancy wired installation I'm using the KISS method; I plug it into an outlet on my Oliver and let the tiny cord go through a window, choosing the window that best fits for open skies (changes depending on where I am parked). I don't use it at all when I'm driving, but I DO carry it with me (even when Oliver stays in the cg) because if I get stuck somewhere with my truck, I can still reach out via cell phone using Starlink. All in all -- Starlink is a great service. 3 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
jd1923 Posted May 24, 2025 Posted May 24, 2025 24 minutes ago, Boudicca908 said: I'm using the KISS method; I plug it into an outlet on my Oliver and let the tiny cord go through a window, choosing the window that best fits for open skies (changes depending on where I am parked). I don't use it at all when I'm driving, but I DO carry it with me (even when Oliver stays in the cg) because if I get stuck somewhere with my truck, I can still reach out via cell phone using Starlink. All in all -- Starlink is a great service. I'm not much for out the window solutions in vehicles. Why not use the outdoor 110V outlet? We still have the included 50 ft wire and charger kit in the box. Over time and weather use of the long cord may become painful. It's nice to carry dish and battery and not worry about extending a cord and winding it up to leave. I just place the dish on an upside-down milk crate, always have a couple in the back of the truck. The battery solution can be expensive if purchasing outright, but we've had the DeWalt tools for years and I would not have had to buy more if one had not go bad last time out. Found an open-box 10 Ah 2-pack on eBay and these and a couple small ones will power up the Starlink and all the other tools we use. You also need the larger Ah for the leaf blower which cleans dirt-road dust of of the Oliver in seconds, clears debris from campsites and I use it every so often on outdoor rug. Nice to have! But I get it, the cable and 30V power adapter is in the kit, no additional expense, yes KISS! Best wishes, JD 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Boudicca908 Posted May 24, 2025 Posted May 24, 2025 1 hour ago, jd1923 said: Why not use the outdoor 110V outlet? Because then I would need to buy a box to keep the router dry... but to each his own. This method works well for me. :) 1 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
jd1923 Posted May 24, 2025 Posted May 24, 2025 2 hours ago, Boudicca908 said: Because then I would need to buy a box to keep the router dry... but to each his own. This method works well for me. 🙂 OK, I think I understand. You run power and Ethernet (or POE) cables to the Mini and connect to your internal router. Nice! Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Boudicca908 Posted May 25, 2025 Posted May 25, 2025 On 5/24/2025 at 5:33 PM, jd1923 said: You run power and Ethernet (or POE) cables to the Mini and connect to your internal router. Nice! Actually... I was thinking of the original Starlink (the big one with the separate router) and now I have the Mini with the built-in router (and I better read up on how much wet weather it can take) and I could just plug it in on the outdoor outlet! Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
jd1923 Posted May 26, 2025 Posted May 26, 2025 2 hours ago, Boudicca908 said: Actually... I was thinking of the original Starlink… It can take a pouring thunderstorm, also rated for 100 MPH winds to be roof mounted. Just as long as you use cables with the waterproof seals which they supply anyway, you’re good to plug in outdoors. 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Patriot Posted May 26, 2025 Author Posted May 26, 2025 (edited) 2 hours ago, Boudicca908 said: I better read up on how much wet weather it can take) and I could just plug it in on the outdoor outlet! It has water proof plugs. Our Mini has gone through a serious rain and even a hail storm had zero issues. The custom case adds a little weight to the Mini and does a good job of keeping in grounded during light wind conditions. With high winds I will use a bungee to secure it to a table or just place it on the ground. I run an extension cord from the Oliver exterior outlet into the bed of my TV. I have a camper shell so water is not a concern when I plug in the Mini and our Truma cooler in during bad weather. Just how we roll. 😊 Here is a pic of a chilly 28 degree morning while camped in Yellowstone at Fishing Bridge last fall. Our Mini was working great. It has a built in heating element (you must go into your IPhone app to turn it on) to keep ice or snow from collecting on the dish. We love cold weather camping! 🇺🇸🇺🇸 Edited May 26, 2025 by Patriot 4 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Jason Foster Posted May 26, 2025 Posted May 26, 2025 12 hours ago, Patriot said: It has water proof plugs. Our Mini has gone through a serious rain and even a hail storm had zero issues. The custom case adds a little weight to the Mini and does a good job of keeping in grounded during light wind conditions. With high winds I will use a bungee to secure it to a table or just place it on the ground. I run an extension cord from the Oliver exterior outlet into the bed of my TV. I have a camper shell so water is not a concern when I plug in the Mini and our Truma cooler in during bad weather. Just how we roll. 😊 Here is a pic of a chilly 28 degree morning while camped in Yellowstone at Fishing Bridge last fall. Our Mini was working great. It has a built in heating element (you must go into your IPhone app to turn it on) to keep ice or snow from collecting on the dish. We love cold weather camping! 🇺🇸🇺🇸 Seems such a tempting target for thieves. How do you secure it? 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Patriot Posted May 26, 2025 Author Posted May 26, 2025 (edited) 3 hours ago, Jason Foster said: Seems such a tempting target for thieves. How do you secure it? Great question. My SL Mini is tied to my account. If stolen it becomes a useless brick of no value. As the owner I can advise SL that it was stolen and they deactivate the account completely. After 48 days out west last fall, we never had a concern about our dish being stolen. When we leave our site to go XPLOR, we temporarily store it in our Oliver until we return and then redeploy. So far zero issues. The portability of the Mini is awesome, I will likely never permanently mount it for many reasons. If we are in a CG that I feel like I need to lock the Mini down with a cable, we have probably picked the wrong CG and will move on. We vet CG’s pretty hard when traveling and like gated SPs, and privately owned CG’s. Never had any issues with theft the entire time we have owned our Oliver. I always carry an extra cable lock, I find it much easier to just secure the dish in the Oliver if we leave. Edited May 26, 2025 by Patriot 1 3 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Jason Foster Posted May 26, 2025 Posted May 26, 2025 15 minutes ago, Patriot said: My SL Mini is tied to my account. If stolen it becomes a useless brick of no value. As the owner I can advise SL that it was stolen and they deactivate the account completely. After 48 days out west last fall, we never had a concern about our dish being stolen. When we leave our site to go XPLOR, we temporarily store it in our Oliver until we return and then redeploy. So far zero issues. The portability of the Mini is awesome, I will likely never permanently mount it for many reasons. If we are in a CG that I feel like I need to lock the Mini down with a cable, we have probably picked the wrong CG and will move on. We vet CG’s pretty hard when traveling and like gated SPs, and privately owned CG’s. Never had any issues with theft the entire time we have owned our Oliver. While I agree with everything you said and do, I have some campgrounds I love that occasionally have issues with some interesting people. It happens in almost every CG I have visited. That said, most thieves are not only stupid but opportunists. They see something of value, they grab it, not realizing it can’t be used because it is tied to your account. They grab, try to pawn for drug money or such, get nothing and do it again. It is ridiculous, makes no sense, but it is human nature in its most basic sense. I leave nothing to chance on valuable items. 2 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
jd1923 Posted May 26, 2025 Posted May 26, 2025 Last time out, we stayed one night... Let's call it a shady campground and I don't mean the fact that it was up in the woods! Too many homeless today living out of cars and vans! Last year we drove into a city park in central NM and as soon as we pulled down into it, we headed right back out! No way Chris and I would have spent a night there. It was like one of those refugee scenes from a disaster movie! I worried about the Mini since I had to place it a distance away from the Oliver to get clear sky. I fell asleep that night leaving it out there and in the morning I quickly looked out the dinette window to thankfully see it where I had left it. If they take our Mini, there goes the $450 plus tax we paid, $20 for the wiring kit and another $140 for my 10Ah DeWalt battery! All brand new stuff and they would probably even take the milk crate that I use to prop up the Mini above ground! The next loss is continuing the rest of your trip without satellite connection, and bummed re the loss. There is no way simple way to lock down a Mini. Lock it to what? Stretch out 50' of cable with a 50' chain? 🤣 We just have to be careful. 2 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Jason Foster Posted May 26, 2025 Posted May 26, 2025 2 hours ago, jd1923 said: Last time out, we stayed one night... Let's call it a shady campground and I don't mean the fact that it was up in the woods! Too many homeless today living out of cars and vans! Last year we drove into a city park in central NM and as soon as we pulled down into it, we headed right back out! No way Chris and I would have spent a night there. It was like one of those refugee scenes from a disaster movie! I worried about the Mini since I had to place it a distance away from the Oliver to get clear sky. I fell asleep that night leaving it out there and in the morning I quickly looked out the dinette window to thankfully see it where I had left it. If they take our Mini, there goes the $450 plus tax we paid, $20 for the wiring kit and another $140 for my 10Ah DeWalt battery! All brand new stuff and they would probably even take the milk crate that I use to prop up the Mini above ground! The next loss is continuing the rest of your trip without satellite connection, and bummed re the loss. There is no way simple way to lock down a Mini. Lock it to what? Stretch out 50' of cable with a 50' chain? 🤣 We just have to be careful. Wire it to this? https://fithops.com/products/fithops-camp-safe-12-gauge-perimeter-trip-rescue-alarm?variant=41448589459523&utm_campaign=1872547140&utm_source=google&utm_medium=cpc&utm_content=69485715785&gad_source=1&gad_campaignid=1872547140&gclid=Cj0KCQjwotDBBhCQARIsAG5pinN8D3_ApmbpWX1uKkqAQuYFJpSrlq0JsbLG3ESk-hcciu7hNo8Mn8gaAkd1EALw_wcB 1 2 1 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Jps190 Posted June 3, 2025 Posted June 3, 2025 (edited) For anyone with the harbor freight flagpole and the Starlink mini, a 1 1/4 inch PVC union works perfectly with the mount that comes with the starlink. You just need to drill new holes for the clear support ring a little lower down to make room for the PVC. Edited June 3, 2025 by Jps190 2 4 John and Kim 2021 GMC Sierra 2500 AT4 6.6L Duramax 11350 GVWR 3048lb Payload 2021 Oliver Elite II. Hull #887. 600 Watt Solar Mod
Moderators bugeyedriver Posted July 19, 2025 Moderators Posted July 19, 2025 (edited) I purchased my StarLink Mini in the spring during a great sale at Home Depot, and now,. Bosker and I have been on the road from San Antonio for about a month and a half. So far we've had decent broadband connectivity through Verizon utilizing our iPhone's hotspot or a Verizon Jetpack for our internet. We're now staying overnight at Clark Canyon Reservoir, in southwestern Montana, where nary a Verizon signal will reach. No problem. Attatched the 90° flagpole mount to the hitch receiver, snugged the Mini antenna / router onto a 12 ft pool cleaning rod and ran the connector cable to a 100W DC outlet on the curbside of the trailer --- And POOF! Bob's your Uncle, we are connected to the internet. Easy Peasy Love this gadget! Update: Downloadspeed - 242 mbps / Upload speed 4.97 mbps Edited July 20, 2025 by bugeyedriver 5 Pete & "Bosker". TV - '18 F150 Super-cab Fx4; RV - "The Wonder Egg"; '08 Elite, Hull Number 014. Travel blog of 1st 10 years' wanderings - http://www.peteandthewonderegg.blogspot.com
Ronbrink Posted July 20, 2025 Posted July 20, 2025 (edited) I purchased my SLM in May and since encased it in a Veritas Vans mount with an optional handle and magnets for securement on top of the Savana van when underway. I also bought a 12’ (three 4’ sections) pole with suction cup mounts from FlagPole Buddy for alternative use on the Oliver. Although these angled suction cup mounts are primarily marketed for Airstreams, they similarly fit the Oliver. Pole (two 4’ sections) shown mocked up in COW Barn. Edited July 20, 2025 by Ronbrink 5 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Patriot Posted July 20, 2025 Author Posted July 20, 2025 (edited) @Ronbrink Ron, I like everything about this SLM mod! It’s seamless, clean and neat it appears and easily deployed. I also like that you can locate it in different walls on your Oliver, vs the flag pole stationary flag pole mount on the front cargo box. Have you had any field experience with this yet? How well do the suction cups hold on? Do they have to be checked periodically? Well thought out and executed! Thanks! David Edited July 20, 2025 by Patriot 1 2 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Ronbrink Posted July 20, 2025 Posted July 20, 2025 (edited) 1 hour ago, Patriot said: Have you had any field experience with this yet? How well do the suction cups hold on? Do they have to be checked periodically? No experience with this SL pole setup, but years of using the same suction cup mounts on an actual 16’ fiberglass flagpole from the same company; a WeBoost antenna was also mounted at its top. I never had a suction cup loose grip. Yes, they do require a daily check and a couple strokes of the integral pump to maintain adequate suction; a visual indicator on the pump is used to ensure optimum suction. If there is too much obstruction at the Oliver, I like that the SLM can be mounted on the van with magnets while parked in close enough proximity to the campsite for Wi-Fi reception in the trailer. That said, I have parked at the COW Barn several times in like manner and been able to operate the Atmos via the Cielo and steam movies. Edited July 20, 2025 by Ronbrink 4 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Patriot Posted August 5, 2025 Author Posted August 5, 2025 (edited) Tech moving fast with beam switching. 👍🏻🇺🇸 https://www.dishytech.com/starlink-beam-switching-upgrade-improves-reliability-for-obstructed-dishes/ Edited August 5, 2025 by Patriot 2 4 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
johnwen Posted August 5, 2025 Posted August 5, 2025 I WAS going to break down and get a standard unit this week, but....in light of David's post on beam switching I may have to do a little more research. I had gravitated to the larger Gen3 because I would prefer the stronger reception and upgraded router. But the mini has the advantage in size and weight savings. And the DC power ability. And less equipment re the built in router. Does the larger unit actually receive any better with partial tree obstruction? We are not power users but we do stream a good movie occasionally. This beam switching seems like it could bring me back into the "mini" market. I finally talked Wendy into the Starlink technology so I want to make the smartest choice. We've boondocked 4 out of 7 months this year and have had really spotty connections with our Verizon unlimited plans. They work very well if within reach of their towers. How long of a cable can be used to move the mini dish to an unobstructed site? Is there anyone who switched from the larger unit to the mini who wishes they had stayed with the larger? Thanks for any help, John 3 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
CRM Posted August 5, 2025 Posted August 5, 2025 17 minutes ago, johnwen said: I WAS going to break down and get a standard unit this week, but....in light of David's post on beam switching I may have to do a little more research. I had gravitated to the larger Gen3 because I would prefer the stronger reception and upgraded router. But the mini has the advantage in size and weight savings. And the DC power ability. And less equipment re the built in router. Does the larger unit actually receive any better with partial tree obstruction? We went with the Gen3 for a couple of reasons- you can switch between residential and roaming plans with it, and the residential plan is less expensive with higher bandwidth. As of now you can't do that with the mini. The Gen3 is supposed to have better performance though I can't give an opinion on that since I've never had a mini to compare it to. Also, you can run the Gen3 off of 12v DC with a convertor though it will still use about 20-30 watts more than the mini does. When it comes to the residential vs roaming, *so far* we've been lucky and haven't had to switch to a roaming plan when we hit the road. We just change the service address from our home address to the campsite and it works within minutes. You can do this an unlimited amount of times but must be prepared to be denied access if the area you are in is not allowing any new residential connections. If this ever happens we would just change to a roaming plan until we got back home. 3 1 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
johnwen Posted August 5, 2025 Posted August 5, 2025 Thanks, CRM, We full time and our address is an UPS box back in SC so we would be totally "roaming". The 12v converter you mention would connect to A/C I suppose? so I have the choices of shore power, the trailer inverter (2000W) or an Anker 1056 WH Solix power bank to provide the A/C. Guess it's going to come down to performance differences. Thanks, John 1 1 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
CRM Posted August 6, 2025 Posted August 6, 2025 1 minute ago, johnwen said: Thanks, CRM, We full time and our address is an UPS box back in SC so we would be totally "roaming". The 12v converter you mention would connect to A/C I suppose? so I have the choices of shore power, the trailer inverter (2000W) or an Anker 1056 WH Solix power bank to provide the A/C. Guess it's going to come down to performance differences. Thanks, John The convertor converts your onboard 12v DC to 57v DC so no AC power needed at all. 2 1 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
Snackchaser Posted August 6, 2025 Posted August 6, 2025 1 hour ago, johnwen said: Is there anyone who switched from the larger unit to the mini who wishes they had stayed with the larger? Thanks for any help, John Hi John, We cut the cable years ago, and I’ve used the larger units, Gen-1 and Gen-3 for the Oliver. Now I use the Mini exclusively with no complaints and we still keep the Gen-3 active at home for security devices and guests while we're away. The Mini, with it’s built in Routrer, looses speed the farther away it is. This is due to the WiFi signal dropping off. So if you go with the Mini Dishy, then I recommend getting a Mini Mesh Node Router for $40 because there are times when you will need to move it farther away to find clear sky. See my post: The new Starlink Mini Router, for what ails you. Starlink Beam Switching keeps improving and there are increasing numbers satellites so reception keeps improving and the Mini seems to work as well as the Gen-3 in that regard. My Mini isn’t quite as fast as the Gen-3, but it’s still blistering fast, and way faster than most cable connections. There are a number of options to run the Mini from the trailers 12 volt system. You just can’t use the included 50’ cable because of voltage drop without boosting the voltage. You can do that with a voltage converter to increase voltage, or one of the available power supplies, or use a shorter cable. Hope that answers your questions! Cheers! Geoff 3
jd1923 Posted August 6, 2025 Posted August 6, 2025 Cut the cord! 🤣 (I also purchased the Mini Router per @Snackchaser post proving its use, but have not had the time to pull it out of its packaging.) 1 1 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
