There was a recent thread started by @Galileo where Val had a black tank waste valve beyond repair. OTT Service suggested replacing the valve with the Valterra motorized valve which would eliminate the need for the 12 ft pull cable replaced by an electric switch.
This got me thinking as we have a 10-year-old hull and ALL three (3) waste valves, including the 1 1/2" gray valve for the bathroom, are very difficult to pull the valves open and to push back to close. It's always better to work preventive maintenance than to get caught on the road with a stuck waste valve!
I wanted to install electric motorized valves in all 3 locations but we were made aware by OTT (through Val's service call) that replacing the gray valve would be difficult. From a picture I had taken of that area, I noted it was installed laying flat on the hull floor which would not allow for the considerably wider motorized valve.
I couldn't see a design with one manual valve with t-pull handle in the rear next to an electric switch for the other. So my plan morphed into restoring the main waste valves replacing OEM parts as needed. I kept the idea of a motorized 1 1/2" valve for the bathroom because this valve must be opened/closed often, every travel day. What a chronic pain it is getting into the bathroom, reaching down ankle height and pulling the valve open before pulling a muscle! Yep, we're getting older...
To start, I removed both valves under the front dinette seat. The 3" black and the 1 1/2" gray valves were originally installed angled towards and touching each other, with the gray valve jammed against the fiberglass wall. I sawed off the 1 1/2" ABS at the waste valve flange so that larger motorized valve could be installed. Purchase of a new flange and two couplings was all that was needed, as I was happy we had some ABS glue. With the plumbing out it was so easy to run wiring for our DC-DC charger from the hitch to rear dinette seat, an added bonus.
At first, I wanted to install the power switch near the entrance door so that it could be reached while standing outside. Thinking through the extra work and that it could be easily damaged or switched accidently, I installed it right there under the dinette seat. Here the provided wiring harness reached the buses under the rear dinette seat w/o modification. I cut a tight-fit rectangle opening for the switch alone, tossed the large faceplate and by-passed the odd fuse/reset button, adding a 5A fuse at the +bus. When the valve is open a thin red LED shows which can be seen from outside the entrance door. It is soooo great to merely press a button to work this valve!
A bench inspection of all 3 valves showed something quite interesting. With cables detached, the black waste valve opened and closed easily yet the seals were crusty and looked more worn. The seals on the gray valves looked to be in better condition yet the valve mechanisms on both gray valves were stuck, all gunk-ed up!
My thinking is soap and/or tank additives in the gray plumbing caused this and the black tank is certainly a different chemistry. I cannot be sure with 3 prior owners of our hull what was used through the years. I remember our good friend Steve @ScubaRx writing that he does not use additives, has not for years, and I believe we’re going with that plan going forward.
I was so hoping not to have to replace the gray waste valve since I had installed our Victron MP2 directly over it. Last week I reached down and around the inverter and with much pain and patience. I loosed the Allen key on the cable and the two Phillips screws to remove the sheath. With the cable detached I found the valve was near impossible to move by hand. What I feared came true, and today with much pain I removed this valve.
Was very happy to get the valve out and in only 2 hours, considering all. First of course, I removed the ground to the batteries and switched off the solar. I had to unstrap the inverter and pull the 42 LB beast up far enough out of the way to work below it. I used a steel bracket to hold it up. I feared I had taped the shelf down strong with the VHB tape, but it popped off with a strong pull due to the slick shelving material.
The waste valve was jammed so hard into the floor that the two bottom bolts were extremely difficult to remove (see impression of the waste valve in the floor insulation in 2nd picture). They were also rusty given their bottom location. You needed two open-ended 7/16” wrenches and the back bolt is extremely hard to reach being under the aisle floor. I spent 30 min on these two bolts alone! I’m really good at wrenching in tight spots from considerable experience. Most of you reading this, I strongly suggest getting OTT to replace this valve when you feel "it’s time." If they charge more than a hour labor, a good retort would be, “Well you put it there!”
There was a rubber mat installed under the gray tank which was halfway under the waste valve. I cut this rubber out in the area where the valve is bolted to make the reinstall a little easier. The gray valve was much worse than the picture reveals and the fact that this valve was installed horizontally makes all the residue collect on the lower side causing friction on one side adding to overall pull & push resistance.
I replaced entire valve assembly for the gray and just the seals on the black. The gray pull cable is about 4' short and looks fine with a slight curve. I will replace the 144” black cable when it arrives. Before we travel next week, I’ll get the garden hose in the Oliver, fill the black and gray tanks some, run water into the shower drain to test all 3 valves.
Tomorrow I should install the new gray valve. It will not be easy as the two flanges do not sit parallel. The two bottom bolts will be fun again! Then I need a plug and some fiberglass repair for the hole in the bathroom wall, and I'm sure I'll see other needs.
Sure hope to be good very soon... and for another 10+ years!
Edited by jd1923
You may well be getting older (glad it’s only you 😂 ) but it sounds like you’ve got a good amount of get-up-and-go left in you with that description of the work you did!
On valves -
We have the “Autovent” option for the gray water “fill” from the factory. Keeps the grey water out of the shower pan while moving.  Oliver installs the switch in the closet with a spring-loaded open/close rocker switch. We remember to open/close it -most- of the time. I suppose even it will need seals replaced eventually. Then again, unless it’s a dramatic failure, I don’t think it’s as critical as the dump valves.
Grey tank dump - that T handle moved quite easily. Short cable. Hopefully it will last us the ten years yours has. Maybe it will be the next owner’s problem. I have no plans to upgrade it to electric.
Blank tank dump - I think that horse is dead. I’m dismounting.
Tank Additives -
We usually use an odor-control additive in the black tank. Only occasionally in the grey tank. I really miss the good old Thetford blue stuff. It was quite effective and actually made the black tank dumping smell kinda good. I think it was the same stuff they use(d?) in commercial ports-potties. Pretty sure it had formaldehyde, so mere mortals prolly can’t obtain it.
My current favorites are Thetford Aqua Max “Summer Cypress Scent”. It smells nice. Downsides are I think they’re optimistic about one packet treating 40 gallons…. That, and it doesn’t dissolve completely. Leaves some grainy specsks behind. (I dissolved on in a clear container with plenty of warm water.) I’m also leery of the packets. I think they’re some kind of gelatin, and I’ve found they don’t dissolve completely either. That said, I probably won’t buy them again.
The Camco TST liquid seems the safest bet to me. Nothing to clog up or be left behind.
As for my least favorite, “Happy Camper” gets the nod. I can’t understand the raves on Amazon. The stuff doesn’t dissolve easily, and tends to harden like plaster! Looks like an invitation to gunked-up valves! That, and I find it has about zero odor control. I have half a bucket of it left that I’ll donate to a non-discerning RVer.
As for valve lubricants and treatments, I’ve tried the Thetford valve lubricant to try to help my black tank valve - and it did nothing. Probably because it was the cable, not the valve.
Anyway, I suppose you can get away with using no additives at all - but emptying the black tank (and even the grey tank) are gonna be a smelly adventure!
King Bed Floorplan
electronics package
Truma Aqua-Go
LOUD Dometic Penguin A/C
LevelMate Pro+
RealTruck hard tonneau cover
Rove R2-4K DashCams
12 hours ago, johnwen said:
:classic_wacko:
That reminds me that there are a few automotive designers that need to be slapped around a bit…..
Having to pull an engine to change a spark plug sounds like a good reason for capitol punishment.
One shouldn’t need to be double jointed and have eyes on one’s fingertips to do periodic maintenance on any device.
That said your suggestion of “well you put it there” is unlikely to phase anyone.
  • Haha 2
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
Thought this same thing soooo many times! Like changing the starter motor of a 4WD Gen2 Toyota 4Runner or pulling the PS pump (known for leaking) on my Lexus SC400.
Can I add replacing the fuel pump in our TV - pull the fuel tank or remove the truck bed? I went with the latter. These are jobs I've done in only the last two years and I cuss design engineers that only care of manufacturing process with no concern for maintenance.
Auto design engineers should be made to work an internship in service for 3 years before allowed to make one design decision! The 3" gray plumbing should have been installed 1/2" off the floor instead of pushing so hard on the floor to make an impression into the insulation! Also defeats the purpose of the insulation.
Edited by jd1923
Wanted to provide an update on this statement. Just yesterday, in another post on this subject, I learned of Drain Master waste valves. This product is flush on one side, so it can be installed directly on the floor in the gray tank waste valve location. Looks to be a very good option when anybody needs a new gray waste valve.
https://drainmaster.com/rv/product/pro-series-s3vt-kit-2-valves-6002
I haven't followed this thread totally and if someone has mentioned Molykote 111 compound by DuPont I apologize.  HERE is a video on the subject and I believe that it is available on Amazon HERE.
I've not personally tried it on my blade valves and seals nor on my toilet seal.
Was a long day getting the new gray waste valve installed.
But by 5PM today... it's done finally, yay! 😂
It's difficult to get the valve in place, in tight quarters, without the rubber seals slipping. The valves in the front have rubber couplings which can be removed giving so much room, but not down here. I applied a sealant on the back side of the rubber seals and set them on the flanges the day before hoping that would keep them in place. One slipped off but the other stayed which certainly helped.
The two flanges were on different angles, tied down by the weight of the 3" gray plumbing on one side and the gray tank on the other. Pulled a long crowbar to raise and shift the plumbing over, used a longer bolt to get one corner started. Installed one part at a time as the full valve assembly would not fit being crammed into the floor. Got everything torqued down, "good-n-tight" after another hour or more...
Removed the old cable to install the new one. You can only source 6 ft cables and must cut them down to fit. OTT installed a stock 3 ft cable. I found it to be jammed up in a corner for being too long. I cut the new cable sheath to 32" and the pull cable 4 3/4" longer. I also cut into the shelf that extends in the rear trunk area of the Oliver using a handheld coping saw, so that the pull cable would have a straight line to the valve (notice bottom left of picture).
So all was good, ya think, but the thin SS steel cable would not fit into the push rod of the valve, the fixture which holds the cable with an Allen key. I tried and tried and then I got a thin needle tool and found that the opening was defective, made in Mexico POS, and mostly closed. In the bottom of the basement, valve installed, I had to drill an opening into the cable receiver using a 90 degree extension powered by a 1/4" impact tool (whoa, make sure yours is good before installing)! 🤣
New waste valve, new pull cable nicely realigned and this valve now opens and closes like butter, so nice!
Tomorrow the 12' cable for the black valve should be delivered. I will also fill tanks to test all three valves tomorrow. Hopefully no leaks but given Murphy's Law, new plumbing often leaks somewhere on first try. I need a break on this project and hoping for the best! Hopefully we're done tomorrow so we can start the fridge, pack clothes and tools, hitch up and be ready for the next adventure! 😂
Though I’m sure this stuff is great for lubing the valve blades/gates, I’m convinced that the issue I experienced was because of the l-o-n-g cable and the two 90 degree bends, not the valve itself.
The valve I removed also showed zero signs of wear, buildup, deposits, scoring, etc - it looks new and the seals were fine.
My original symptoms were a black tank T handle that was VERY hard to pull out - to the point I was sure that the plastic T handle would break off. OTOH, it pushed in very smoothly and easily.
From past experience with cables of this kind, the cable “core” wears into the cable housing or sheath. This wear happens on the “pull” stroke to the inner radius of the cable bends. There are two 90 degree bends in the blank tank dump cable.
Anyway, since I wasn’t keen on temporary fixes like lubing a compromised cable, I opted for the fix OTT suggested: installing an electric valve.
Problem solved.
  • Care 1
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
Water test went well. I filled the black tank at least half full. Filled the bathroom sink until there was 3" on the floor. Ran several gallons down the kitchen sink. Let everything sit for a couple hours, not a drop anywhere and the height of water in the bathroom floor held without change.
All three valves are now renewed. New seals on the black. New valve, seals and pull cable on the gray. Motorized valve on the 1 1/2" gray line from the bathroom. Having an electric switch is amazing! Though I still had the batteries disconnected during the test, so I used the pull handle to manually open the drain. Reinstalled our inverter and connected the batteries and all is good!
Pulling the gray waste valve open is feather light with new valve and pull cable. The 144" cable for the black tank waste valve was delayed twice by the USPS, go figure. Leaving today, so this last part will have to wait. For the long black cable an easy way to run it is to first remove the old inner cable. Then cut the old cable sheath at the area under the streetside bed. Insert the new cable through the outside opening and feed it into the sheath and use electrical tape to keep them together. Then detach the old sheath from the waste valve and pull it through from there. This way it will run exactly where the old cable was with minimal effort and neck strain! Another 20-30 minutes of work for me when we return from our short trip.
I found that silicone grease on the cables did not help at all, in fact it added to the resistance, making it more difficult to pull and push. On the new cable, I greased the pistons on both ends but not the cable itself.
I don't imagine that any of you would be looking forward to doing this work! For me, I'm so happy this is in my past and with no worries for the next many years. 😂
Anyway, since I wasn’t keen on temporary fixes like lubing a compromised cable, I opted for the fix OTT suggested: installing an electric valve. Problem solved.
That makes sense about cable wear. The 90 by the pull handle is large radius which should not be an issue. Mine has an issue at the waste valve in that they mounted it vertically right near the wall of the dinette seat causing an 180 to 200 degree turn. I can’t yet see a way around this turn with a major plumbing change. Hope the new cable will improve the action,
Problem solved, yes. Like to see a pic off your switch installation Val. Thx
Worked this step yesterday. The new cable pulled into place as written above. See picture, taken under the streetside bed. On the left is the new cable. On the right is the cut-off sheath of the old cable. Then I pushed these two sides together, taped them together with electrical tape, and it pulled through nicely.
Don't forget to put the nut on the new cable before pulling this! Now the entire waste valve system is restored. The rebuilt gray is a feather-lite pull and push. The black still takes a little tug, due to the 144" cable and the 180 degree turn at the end, but it is much better than before. We should be good for many more years to come.
Edited by jd1923
typo
  • 2 months later...
We've had the same issues with our blackwater valve cable.  Impossible to pull out and when closing the valve, it never closed completely so I always had to go back into the trailer to push on the metal stop to ensure it was well-seated.  In the last few days, we installed a Barker AutoDrain. The switch is located along the upper edge just inside the basement. We placed it there because the switch is too large for the space created when we removed the black tank handle. We also located it where we felt the risk of damage would be reduced, but we still need to be careful when stowing supplies in the basement.
image.thumb.png.d328c1c727232fb682da10cf90d7cc6d.pngBarker valve in situ
As long as we are talking black tanks, I have been perpetually annoyed when, after dumping the black tank, having to go back into the trailer to turn on the water pump so I can wash my hands.  To address this minor annoyance, I added a marine-grade, water-pump switch that is mounted where the black tank valve handle was previously located, and I can now turn the water pump on and off from outside next to the shower. No more going in and out of the trailer at the dump station to wash my hands.
Water pump drain mounted where decommissioned where the black tank valve handle was.
2020 Ram 1500 Ecodiesel. LE2 hull# 344 with Grace and Maya Papaya - our 2 golden retrievers.
Awesome job, do you have a part# or link for this switch?
**Sold😞**
Both of my drain valves were extremely difficult to open and close as well. I used some silicone plumbers grease (the same stuff that I use on the toilet flush valve) and coated the metal rod that the cable connects to. The valves now operate very easily. Probably better than when new.
2017 Elite II, Hull #208
2019 Chevy HD 2500 Duramax
Here you go
Yeah Ken, I tried this when you first mentioned it to me. Didn't help on our valves. I found the reason when I got inside of the valves. The black cable was hard to pull due to 2 bends in the 12' cable. The gray valve had soooo much goo on the blade from past owners putting who knows what soaps and/or additives in the drains. I did silicone grease those rods per your advise during the install. A few trips and dumps later bother valves are still very smooth.
Seriously looking into upgrading the cable pull valves to electronic. Despite regular maintenance the black handle pull has always been terrible.
I have already ordered the cam lock waste connector and 20ft sewer hose that collapses to 6ft in length. They also sell an adapter if you need or want to use the old system. Love the built in features like 4:1 compression, see through terminal end with cutoff.
https://drainmaster.com/rv/product/waste-master-20-sewer-hose-system
https://www.youtube.com/channel/UCFtTb2fHr9X3xyOsqr6QIZw
I think from the above information and more research the drain master electronic valves could work on all three valves. But still investigating. If so, it would be a huge upgrade IMO. As my seven year old says emphatically.
Mike
They should fit on the main gray and black waste valves. I had supplied a link above for the electrically operated valves. If they have a 1 1/2” model, then all three! I found this product too late in my project and had already purchased all the other parts I needed.
They make an adapter to fit 1 1/2 in pipe. Thanks for original link.
@rideadeuce do you still use the bumper sewer hose compartment with your modified bike rack?  If so, please let us know how the 20' hose fits into it and if you can leave it connected all of the time.
You seem to understand why I am so interested in this setup. It is on back order, so I believe it will be 2-3 weeks before it ships. But I will report back when I get it installed. I hope that the cam lock handles clear okay and that I don’t have to change the pipe length at all.
Edited by rideadeuce
Ditched the bayonet style waste hose years ago, very pleased with this cam lock system. The hose keeps its shape, no snaking around when in use or while stowing away. The valve head has to be aligned at the curbside top notch of the rear opening for adequate clearance of the valve handle. Also made up a clear silicone hose with a terminal valve that cam locks onto the discharge pipe to primarily manage gray water, as needed. However, I generally keep it attached to the discharge pipe with the end valve closed; makes it easy to see if there is a valve leak from either holding tank, think no surprises!
That’s awesome. I don’t know how I miss these things! Happy to know it will work easily. Now if the electronic valves work, it will be even better. Thx!
