John and Debbie Posted April 25, 2025 Posted April 25, 2025 Hi all, we leave in about a month for a month long tour in Colorado, Utah, and Wyoming. Does anyone here use a dash cam and if so, which one do you use? Ideally I want one that doesn't need to be plugged into a cigarette lighter as I use that plug for the Oliver back up camera that is on while driving. Looking forward to getting out and seeing more of the country. First stop is Grand Junction, Colorado for the five leaf springs. John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
rich.dev Posted April 25, 2025 Posted April 25, 2025 I have the FITCAMX, it’s nicely integrated into my Silverado’s rear view mirror housing, and plug and play installation with the power wire hidden and connected to the rear view mirror wiring, and hidden inside the mirror housing. 1 5 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Patriot Posted April 25, 2025 Posted April 25, 2025 (edited) I have been running this D/C since 2022 and am really pleased how it works and how small and compact the camera is. Clear crisp photos or video. https://www.amazon.com/Garmin-140-degree-Monitor-Connected-Features/dp/B0931YZ82P/ref=sr Memory card -https://www.amazon.com/SanDisk-Extreme-microSDXC-Memory-Adapter/dp/B09X7CRKRZ/ref=sr I also recommend this polarized lens cover- https://www.amazon.com/Garmin-Polarized-Lens-Cover-010-12530-18/dp/B07LDCK7ZR/ref=sr_ Here is the Ford specific plug and play dongar.tech short connector which plugs into my review mirror and powers the camera. Install is a breeze. You can barely see the Garmin Mini 2 while in the cabin as it mounts up hidden discreetly forward of the review mirror. Note: you must have the auto dimming rear view mirror with the 16 pin connector for this plug’n play to work. 💯 happy with this dash cam set up and would buy again. You may want to call Dongar tech to determine which connector will work for your Expedition trim level. https://dongar.tech/products/16pin-ford-f150?srsltid=AfmBOookPpMlEZvtWy9Hi5SQfoIIYMJNOU0HJqtJewLLbWFu9zZgQjjS Edited April 25, 2025 by Patriot 1 4 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderators topgun2 Posted April 25, 2025 Moderators Posted April 25, 2025 I too have been using a dashcam for a number of years now - so many years that (as far as I know) they didn't produce a camera that used anything but the cig lighter for power unless you wired it to a hot and negative yourself. However, there are a couple of things to be on the lookout for. I got both the dash and rearview cameras and with this there is almost a 360 degree of the vehicle. Make sure that you get a fairly big memory card for your dashcam. Having a "parking mode" (this is when you are parked the camera still records) is very helpful for things like someone trying to break into the vehicle when you are not there or if you are hit in a parking lot. GPS integrated into the dashcam can be a blessing and/or a curse - it will show speed and location. Certainly this is helpful IF you are doing the speed limit at the time a problem is recorded. My camera does not have an interior view but I've read that this view can be helpful in the event you are the victim and have to go to court. Good luck choosing in that there are a ton of these cameras on the market. Bill p.s. mine is branded as Apeman for what its worth. 1 4 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
John Dorrer Posted April 25, 2025 Posted April 25, 2025 (edited) We have the ROVE Dashcam, front and back. I can connect to my phone Wi-Fi and there are very clear front and rear pictures. Extra safety, including preventing scams. Edited April 25, 2025 by John Dorrer Typo 1 3 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Rivernerd Posted April 26, 2025 Posted April 26, 2025 We have a CHORTAU dash cam purchased from Amazon in 2022. It can only be plugged into the truck cigarette lighter, but I believe CHORTAU makes a newer version that has a USB-C power connector. Our CHORTAU dash cam continues to work well, turning on each time we drive our 2019 Tundra. Fortunately, we have not yet needed to access video footage for evidence of an accident or vandalism, but we like having the dash cam installed for that purpose. 1 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
Zodd Posted April 28, 2025 Posted April 28, 2025 Plus one for the power adapter. It works great with rearview mirrors that have power. I have that in my truck and makes power and setup easy. I have a Rove as well. Hides behind the rearview. 1 Todd & Kat 2023 LE ll twin, hull # 1305, Truma AC & WH, Platinum solar, Natures Head 2024 Ford F250 Lariat 7.3L gasser / 3.75, FX4
Moderators Mike and Carol Posted April 29, 2025 Moderators Posted April 29, 2025 On 4/25/2025 at 3:09 PM, rich.dev said: I have the FITCAMX, it’s nicely integrated into my Silverado’s rear view mirror housing, and plug and play installation with the power wire hidden and connected to the rear view mirror wiring, and hidden inside the mirror housing. I’m looking at ordering a FITCAMX. I like the way it looks OEM, no wires, made model specific. My old dash cam is clunky, old and difficult to use. 4 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Rolind Posted April 30, 2025 Posted April 30, 2025 I have been very happy with my garmin mini 3. It is very basic and very small but does what I need. I also use the Dongar power adapter to connect it to the rear view mirrors power source. 2 Robert and Cheryl, Louisville, KY, Legacy Elite II Hull #1390 Oliphino, TV F250 Tremor
Ronbrink Posted April 30, 2025 Posted April 30, 2025 I need to check out the dash cam feature on my Garmin GPS RV785. Anybody have experience with their’s to share? 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Boudicca908 Posted April 30, 2025 Posted April 30, 2025 (edited) 14 hours ago, Rolind said: It is very basic and very small but does what I need. It's so small! The body is 2" x 2.5" -- the antenna makes it just under 4" tall. This is the Garmin InReach Mini2 - a Compact Satellite Communicator with GPS, and should really be on this OTHER thread HERE: Edited April 30, 2025 by Boudicca908 1 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
Moderators topgun2 Posted April 30, 2025 Moderators Posted April 30, 2025 And - It weighs next to nothing! Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators topgun2 Posted April 30, 2025 Moderators Posted April 30, 2025 1 hour ago, Ronbrink said: I need to check out the dash cam feature on my Garmin GPS RV785. Anybody have experience with their’s to share? I've got the Garmin 890 and tried the Garmin camera with it. After installing the camera on the back of the Oliver, I ran the transmitter as far forward (with an extension cable) as I could get it - to the cubbie above the microwave. I did this because Garmin states that the distance from the rear of the Oliver to the front of the cab of my F-150 is too far for the transmitter. While the camera did work - it tended to cut in and out while on the road. In turn, this causes the screen on the 890 to change from the road map to the rear camera view whenever it senses that the camera turns on/off (i.e. cuts in or out). To be fair here - note that these cameras operate on very low voltage. My use of an extension cable could have caused enough voltage drop such that this is what caused the "cutting in/out". Therefore, I dismantled the entire arrangement and now have a camera just sitting down in the workshop waiting for my next idea. Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Ronbrink Posted April 30, 2025 Posted April 30, 2025 35 minutes ago, topgun2 said: While the camera did work - it tended to cut in and out while on the road. In turn, this causes the screen on the 890 to change from the road map to the rear camera view whenever it senses that the camera turns on/off (i.e. cuts in or out). Okay thanks! I’m only concerned with the forward-facing dash cam capability and not trying to incorporate a rear camera. Was the “cut in and out” with the dash cam, rear camera or both? Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Moderators topgun2 Posted April 30, 2025 Moderators Posted April 30, 2025 2 hours ago, Ronbrink said: Was the “cut in and out” with the dash cam, rear camera or both? Sorry - this was not a dash camera. Basically it is just a add on camera mainly used (I think) for rear facing cameras. I just tried to extend its range (too far) and reduce the number of screens I had in the cockpit via having the signal feed into the Garmin. Patriot is the only person I know that has the Garmin dashcam. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
William SJT Posted May 12, 2025 Posted May 12, 2025 Beware ordering from https://fitcamx.com/collections/integrated-dash-cams . This is a Chinese company shipping their product from China. With the trade and tariff disputes, my shipment is stuck in customs in the US. Fitcam said that is my problem and refused to issue credit even though they cannot tell me when or if I will get the camera. I resolved the problem through my credit card company. 2 1 William & Janet, 2022 Elite II, twin bed, 2023 GMC Sierra 2500 People don't run out of dreams, they run out of time.
rich.dev Posted May 12, 2025 Posted May 12, 2025 7 minutes ago, William SJT said: Beware ordering from https://fitcamx.com/collections/integrated-dash-cams . This is a Chinese company shipping their product from China. With the trade and tariff disputes, my shipment is stuck in customs in the US. Fitcam said that is my problem and refused to issue credit even though they cannot tell me when or if I will get the camera. I resolved the problem through my credit card company. Sounds like the issue is with customs in the US, did you reach out to them? **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
William SJT Posted May 12, 2025 Posted May 12, 2025 22 minutes ago, rich.dev said: Sounds like the issue is with customs in the US, did you reach out to them? I would not know where to begin to contact US Customs. But, I do not believe it is my problem. Instead it is Fitcam’s problem. Fitcam should contact US Customs and pay any tariff or duty above the price they agreed to sell me the camera. Granted, the vendor and I found ourselves in the middle of an unusual situation. Caveat venditor. 1 William & Janet, 2022 Elite II, twin bed, 2023 GMC Sierra 2500 People don't run out of dreams, they run out of time.
Moderators Mike and Carol Posted May 15, 2025 Moderators Posted May 15, 2025 On 5/12/2025 at 5:21 AM, William SJT said: Beware ordering from https://fitcamx.com/collections/integrated-dash-cams . This is a Chinese company shipping their product from China. With the trade and tariff disputes, my shipment is stuck in customs in the US. Fitcam said that is my problem and refused to issue credit even though they cannot tell me when or if I will get the camera. I resolved the problem through my credit card company. I also ordered a Fitcam at the same time. It was hung up in customs for about 10 days but is now through customs and at the USPS facility in Chicago. I would guess it will be delivered sometime in the next week or so. Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Galileo Posted June 21, 2025 Posted June 21, 2025 We have a Rove R2-4K dashcam. Though by default, it plugs into a “cigarette lighter” outlet, our new TV doesn’t have one. Though the cable supplied with the unit will also plug into a USB-C receptacle - which our new TV has, I decided to buy the “hard wire” kit which lets you tap into your TV’s fuse block. I bought 2 additional units to add a rear-facing dashcam to the TV, and one for the rear window of the Ollie. A problem I have yet to solve is that the supplied mounts - both suction cup and adhesive mount - won’t work on a vertical window like the rear of a Pickup truck, or the Oliver. Has anybody found a way to mount a cam on a vertical glass?? I think I could just use a spacer of an inch or so, but curious if someone has already invented this wheel. (Apparently Rove hasn’t.) TIA, V 1 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Moderators topgun2 Posted June 21, 2025 Moderators Posted June 21, 2025 1 hour ago, Galileo said: Has anybody found a way to mount a cam on a vertical glass?? I took a small square of "clear" packing tape and placed it on the inside of the windshield. Then an appropriate size of double sided tape (3M) with one side of the tape applied to the camera and the other side to the tape. In case you're wondering what the packing tape is for - it is much easier to remove this packing tape than it is to remove the double sided 3M stuff. The camera has now been in the same place for two years without a hint of a problem. Bill p.s. from the "high" position on the windshield it was easy to route the hard wiring into the head liner, over to the "A" pillar and down to the interior fuse box. All that is visible is about 1 inch of the main power wire and about 1 inch of the wire back to the rear facing camera. 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Galileo Posted June 21, 2025 Posted June 21, 2025 I’d considered that - but with the Rove dashcam, the only surface on the camera would be the bezel around the lens. I’m not sure that’s enough contact area to assure it would stay in place. Especially since we tend to be in “hot” areas that cause even tough 3M “VHB” tape. That, and I’d have to create an open circle of tape to go around the lens. (in case I wasn’t being clear - I wanted to mount a cam to the rear window of the P/U facing to the rear, and one on the rear window if the Oliver. Being vertical, the mounts supplied with the camera don’t provide enough clearance to aim the camera level to the rear.) 1 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Moderators topgun2 Posted June 22, 2025 Moderators Posted June 22, 2025 12 hours ago, Galileo said: I’d considered that - but with the Rove dashcam, the only surface on the camera would be the bezel around the lens. I’m not sure that’s enough contact area to assure it would stay in place. Especially since we tend to be in “hot” areas that cause even tough 3M “VHB” tape. That, and I’d have to create an open circle of tape to go around the lens. Sorry about that - I missed the part about this being the rear camera. I too had an issue mounting the very small rear camera. I fashioned a piece of wood in a bit of an "L" shape. After spraying the wood flat black, I 3M'd the top of the wood to the metal frame around the window. Then I used the metal bracket included with the rear camera to attach it to the wood. Good luck! Bill p.s. the heat issue is another reason I used that heavy duty packing tape on the front camera just in case there would be an issue. But, as I mentioned, it has not moved even after being on the "hot side" of one of those heat reflectors used in the windshield to keep the sun off the dash while parked. 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Galileo Posted June 22, 2025 Posted June 22, 2025 Yep - the challenge was finding a piece of material the right size and shape - made out of a material that the tape would stick to. Since I don’t have any kind of “shop” to work in, I’ve been roaming the aisles at the hardware store hoping to find something. So far, the only one I’ve found was too “greasy” to hold the tape. The quest continues… 1 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
ScottyGS Posted June 28, 2025 Posted June 28, 2025 Speaking of Dash Cams.... this happened a couple years back. GRMN-2023-06-16_17-23-51-exportedVideo.MOV 5 Gregg & Donna Scott and Missy the Westie - The Flying Sea Turtle - 2016 Hull # 145 2024 Nissan Titan XD - Western NC
