T-Oliver Posted June 17, 2025 Posted June 17, 2025 Cover was removed to read the ANL fuse It’s certainly excellent advice to be aware of the potential hazards of grounding to the insulation 1
jd1923 Posted June 17, 2025 Posted June 17, 2025 12 hours ago, Geronimo John said: The Solar Disconnect (DISCO) only needs to handle the power of the solar panels. Likely 200 to 600 watts. The Battery disco needs to be able to handle 350 Amps at say 12.7V which is 4500 watts. For the main battery fuse, check your inverter spec. OTT had a 250A ANL fuse installed in our hull for the 2KW Xantrex that was our original system. When I upgraded to the Victron Multiplus II 3KVA Inverter-Charger the manual stated using a 400A fuse. Most applicable inverter specs will be in the range is 250-400A. When choosing a cut-off switch, it should be rated equal to or above the proper fuse rating. Most go with the available Blu Sea 300A or 350A rated switches. For your solar, use what is specified for the solar charger. Or if your MPPT Solar charger is rated for 30A, then a 35A or 40A breaker or fuse is appropriate. Our Blue Sky SC is rated for 25A and OTT installed a 30A breaker. When I added a Victron 30A MPPT SC, I believe the book said 35-40A and I installed a 35A breaker. So not to get shock while working with battery cables --- It is common practice when installing battery cables is to install the B+ side first since when the ground is not connected, the B+ side has no potential. When removing battery cables, use the reverse order, remove the B- side first. This is why in my battery installation, I positioned the main B- battery closest to the door. This way I can remove the ground (vs. having a switch) even without sliding the tray open and the closest B+ connection is 8" deeper into the battery bay, providing a very low chance of touching it by accident. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Geronimo John Posted June 17, 2025 Posted June 17, 2025 7 hours ago, T-Oliver said: Cover was removed to read the ANL fuse It’s certainly excellent advice to be aware of the potential hazards of grounding to the insulation 😊 😊 😊 GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Geronimo John Posted June 17, 2025 Posted June 17, 2025 3 hours ago, jd1923 said: For the main battery fuse, check your inverter spec. OTT had a 250A ANL fuse installed in our hull for the 2KW Xantrex that was our original system. When I upgraded to the Victron Multiplus II 3KVA Inverter-Charger the manual stated using a 400A fuse. Most applicable inverter specs will be in the range is 250-400A. Good safety tip JD. For our replacement 3,000 watt inverter I was able to reuse the OTT OEM 300 Amp for the protection of the 4/0 cables that feed the Inverter. In all three cases the fuse protects cables not attached loads. The inverters self protect if you overload them. But if your cables are too small they become a problem. Especially if your OEM cables were sized for 250 amps with a 400 amp fuse. So, in addition to checking the inverter manual for fuse size, VERIFY your cables are rated for the fuse size as well. 3 hours ago, jd1923 said: When choosing a cut-off switch, it should be rated equal to or above the proper fuse rating. Most go with the available Blu Sea 300A or 350A rated switches Ditto. I suggest that if you are installing such a safety switch, that for the minor cost difference, get the 350 amp Blue Sea switch. That way when you upgrade to the 3,000 watt inverter you don't also have to upgrade the switch too. Why? The switch must always be rated higher than the fuse protecting the wires. 3 hours ago, jd1923 said: This is why in my battery installation, I positioned the main B- battery closest to the door. This way I can remove the ground (vs. having a switch) even without sliding the tray open and the closest B+ connection is 8" deeper into the battery bay, providing a very low chance of touching it by accident. I wish that I had thought of that one two years ago! 3 hours ago, jd1923 said: So not to get shocked while working with battery cables --- It is common practice when installing battery cables is to install the B+ side first since when the ground is not connected, the B+ side has no potential. When removing battery cables, use the reverse order, remove the B- side first. Great reminder as well! GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Snackchaser Posted June 17, 2025 Posted June 17, 2025 19 hours ago, jdmmtx said: Can someone please educate us on why one would choose a solar disconnect versus a battery disconnect and why you wouldn't have both? Is the solar disconnect primarily a safety feature? We do understand a battery disconnect is used to eliminate parasitic draws during periods of storage. We currently have neither in our 2019 LEII and are wondering about having one or both installed. @jdmmtx, I'll try to explain it better if I can. First of all, I didn't install my solar switch as was suggested, it was installed by Oliver during manufacturing. There were NEC and local codes that required solar switches, but i don't know where that stands now or why Oliver apparently stopped installing them. Regardless, it’s still a reasonable safety feature, because with no sun the system can test completely dead. Then surprise when the sun comes out! The solar wire is not as obvious, or as easy to find and disconnect as the battery, so a switch is a good idea and easy to install. Also, it’s nice to be able to switch off the solar to avoid low voltage warnings such as @Tony and Rhonda were experiencing when they started this thread. But I wouldn't worry a second if I did't have one! The battery is more straight forward. A switch wasn't required by code, and the manufacture didn’t install one. A switch isn’t needed for modifications because it’s best to disconnect the battery. There are few credible or realistic scenarios where a battery switch would prevent disaster. The most persuasive reason is to disconnect the parasite loads during storage as you stated. But you can do that without a battery switch as I’ve previously explained, and you won’t be inadvertently de-energizing the emergency breakaway brakes… which is a code violation. Yet there is nothing wrong with adding a main battery switch if you want to. Just don’t be coerced into it by safety concerns, and make sure you maintain “un-switched” constant power to the breakaway brakes. Also understand and consider what safety features already exist in your trailer. For example; my Lithionics BMS has short circuit protection, overcurrent shutoff, high voltage, etc.. The batteries also have power switches that disconnect power to the terminals, and there is a 300 amp breaker already in the battery circuit. Adding a battery switch would be totally redundant and completely un-necessary! Oliver and their liability insurance obviously knew that too! I hope this will help folks be better informed to make the right decision for themselves. Cheers, Geoff 1
rich.dev Posted June 17, 2025 Posted June 17, 2025 1 hour ago, Snackchaser said: First of all, I didn't install my solar switch as was suggested, it was installed by Oliver during manufacturing. There were NEC and local codes that required solar switches, but i don't know where that stands now or why Oliver apparently stopped installing them. On our 2023 we have a solar disconnect switch in the cubby above the street side bed. 1 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
jd1923 Posted June 17, 2025 Posted June 17, 2025 11 minutes ago, rich.dev said: On our 2023 we have a solar disconnect switch in the cubby above the street side bed. Sorry, I assumed Geoff installed his since he suggested adding the switch with installation instructions. It read to me like he had added his, my mistake. So now we see Rich has the same on a much newer hull. Who knows why OTT stopped switching the SC on hull #251 and perhaps others of that era! ? Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted June 17, 2025 Posted June 17, 2025 2 hours ago, Geronimo John said: the fuse protects cables not attached loads. The inverters self protect if you overload them. True, but you need to size wire AWG and the fuse rating based on load requirements. The single largest load in a 12V RV system is the inverter, given you have one. And inverters have overload protection and so do modern LiFePO4 batteries and either can fail, so we use fuses or circuit breakers. From the examples I've seen, OTT installs 4/0 battery cables whenever they install an inverter. This is more cable than you need, over-engineered. There are so many wire gauge charts but I like this one since it covers short wire lengths. Although I do not know the source of this tables, the numbers seem to make sense. When I pulled the original 4/0 cables in our hull, cleaned them up and reused them for new batteries and the larger capacity Victron inverter, I noted each cable was less than 5 ft long. Based on this table, B+ plus B- lengths of 4/0 cable adding up to 10 ft can safely carry 600A. Victron specified a 400A fuse for their product which also has a built-in safety factor. They spec'd 400A,so that is what I installed. There is another conclusion you can make from reading the data in this table. If the 250A fuse was all that was required in the 2KW Xantrex inverter that was originally installed in our hull (and others as the example pictured above), OTT could have installed 1/0 wire which can handle 250A up to 12 ft long. 1 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Geronimo John Posted June 17, 2025 Posted June 17, 2025 (edited) On 6/16/2025 at 4:25 PM, Geronimo John said: Battery and Solar Disconnect Install Questions But be sure to know that they are two different things with two different purposes located in two different parts of the Ollie. The Solar Disconnect (DISCO) only needs to handle the power of the solar panels. Likely 200 to 600 watts. The Battery disco needs to be able to handle 350 Amps at say 12.7V which is 4500 watts. The Solar disco can be less easy to get to. Generally, it is used for maintenance and storage purposes. But the Battery disco needs to be where you or a first responder can get to it in a dire emergency fast. So why did I calculate the above power potentials? Certainly not to coerce anybody to do anything. But to inform of the power potentials that we need to be aware of. Yes, to me the primary purpose of having a battery AND a solar discos are (#1) maintenance and (#2) emergency use. #1 MAINTENANCE SAFETY & CONVENIENCE: When we are doing maintenance on our Ollies that in any way involve electrical it is important to disable ALL power sources that can bite us. Certainly 120V shore and Inverter power sources, as well as battery and solar. Why all? Because each trailer has systems that interconnect between them. Examples: Inverter, Converter, Refrigerators, computer power ports, etc. As stated above the are many ways that a simple mistake during a simple maintenance task can, and likely have occurred from not making safe all power sources. If you don't have the necessary disco's and don't have the background experience in such systems to safely disco hot circuits.... You really need to think about your situation. With the disco's you just need to: Turn off a 350 A battery switch Flip a solar breaker Physically verify your Ollie is not plugged into shore power (Generator, Power Pole, Outlet). Without disco's, we can manually make the job electrically safe by taking apart hot cables. This is a sweat producing moment for many and hazardous as well. But it takes a lot of time. I guarantee you that at some point in doing so, you will realize that the minor cost of installing those power Disco's is far more cost effective than your time to Disco and restore all sources of power when working on your electrical and mechanical systems. Finally on this point, I consider end of season parasitic loss elimination and power source isolations just another maintenance task that is a lot easier with such switches. #2 EMERGENCY USE: If you are handy and you smell a major electrical acrid burning smell, it is possible that you manually disco the various systems. In the 10 or 15 minutes it takes to get the tools and do so, the problem may have spread from a simple electrical issue to a major one. But it is possible that you can deal with it. But what if you are out fishing/hiking/or flying hang gliders; Are your guests capable of doing the above? Not likely for most owners. With no discos, for the vast majority of spouses or guests, they should exit the trailer and call 911 and summon help if there are knowledgeable campers around. Either way, they get to watch what happens next from a safe distance. Most important part is they are safe. On the other hand if you or they feel it is safe to do so: Turn off the Battery Master Switch and Solar breaker, and unplug the exterior power port. Air out the trailer and then figure what was burning..... IN SUMMARY: Our OTT electrical and mechanical systems are exceptionally well designed and carefully manufactured. Over time their systems age very well compared to the SOB's. As a result we don't see many of our OTT units burning to the ground. But fires do happen and to me, having basic measures in place make sense as the cost could be so very high if you don't. MANY owners, especially the Master Level Contributors, are fully capable of doing significant DIY efforts. Everything from A/C and Refrigerator replacements DC to DC chargers, transition to Lithium, adding solar, springs, axles. hitches, fans and other really great projects. We take great pride in helping other owners to join the DIY group. But first start with a DEEP dive in this forum on the topic. Take pictures of your system and download the posts and pictures of others who have done the effort. You than can intelligently talk to OTT or other qualified firms to have the mod done. Or, to start asking question and help on our forum if you want to DIY it. Our owners are scattered out all across the USA. Likely one will be in your location or willing to meet should the paths cross during the season. GJ Edited June 18, 2025 by Geronimo John 3 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
T-Oliver Posted June 19, 2025 Posted June 19, 2025 Any advice on how to bend on offset into a copper bar to connect to the disconnect switch. Also is 10mm x 25mm cu overkill vs 6mm x 25mm cu The ampacity calculations are not clear to me
rich.dev Posted June 19, 2025 Posted June 19, 2025 @Tony and Rhonda and @T-Oliver Some good advice from others on this thread, if you want to really expand your knowledge on anything solar (sizing fuses, wires, breakers, solar panels, batteries, charge controllers etc.), Nate from EXPLORIST Life is extremely knowledgeable on this subject and he follows code to a T. He even has sizing calculators and complete solar diagrams available on his website. Here’s a link to his YouTube channel. Will Prowse and Nate have been my go-to for anything solar/electrical for a long time now. **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Tony and Rhonda Posted June 19, 2025 Author Posted June 19, 2025 @rich.dev I watched the YouTube from Nate about installing a solar disconnect after reading the post by @mossemi above. Nate's video shows installing a double pole circuit breaker so both pos. and neg. wires are disconnected at the same time (per code). In my opinion, this would not be a very clean install for the upper cabinet. However, the two photos of disconnect switches posted here in this thread (by @Snackchaser and you @rich.dev) show BlueSea switches (assuming on the pos.) installed by Oliver. This is a clean install with no exposed wiring but may not meet code. I know you can't answer this but, if it doesn't meet code, why did Oliver install a pos. only switch??? Or no switch in our case? It seems the BlueSea switch is good enough, so that's what I'm planning to install. Also, I second @T-Oliver's question about bending copper busbars. I bought a 1/4"x1" busbar for my battery disconnect. From what I've read online, I can heat the bar almost red hot and bend it. I'm trying to find a way to make a smooth radius bend rather than clamping in a vise and whacking with a hammer. Any suggestions? But I can't work on it right now, the cat is sleeping on it. New to us 2017 Legacy Elite II Hull #251 (with updates) TV: 2023 Tundra Double Cab 4x4 TRD Sport (Now with Engine #2) Formerly 2004 Tundra with 2015 Four Wheel Camper Fleet
rich.dev Posted June 19, 2025 Posted June 19, 2025 57 minutes ago, Tony and Rhonda said: However, the two photos of disconnect switches posted here in this thread (by @Snackchaser and you @rich.dev) show BlueSea switches (assuming on the pos.) installed by Oliver. This is a clean install with no exposed wiring but may not meet code. I know you can't answer this but, if it doesn't meet code, why did Oliver install a pos. only switch??? Or no switch in our case? Yah I'm not sure, but I have seen many other "reputable" solar installers use that red bluesea switch as a solar and battery disconnect. The Oliver double hull fibreglass is best in class quality, but as far as I'm concerned they can do better with some of the electrical (and other) components. I believe in 2023 they dumped the zamp and went with Victron charge controllers and the BMV712 which I'm a huge fan off! Next I would like to see a Victron Multiplus II inverter, Cerbo GX, and to clean up all the buss bars and fuses a Victron Energy Lynx Distributor - and yes I understand it boils down to $$. **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Tony and Rhonda Posted June 20, 2025 Author Posted June 20, 2025 I have a Victron BMV712 that I bought for my FWC but never installed. Maybe it will make it into the Oliver, someday.... New to us 2017 Legacy Elite II Hull #251 (with updates) TV: 2023 Tundra Double Cab 4x4 TRD Sport (Now with Engine #2) Formerly 2004 Tundra with 2015 Four Wheel Camper Fleet
Moderators mossemi Posted June 20, 2025 Moderators Posted June 20, 2025 My solar circuit breaker is installed beneath the street side bed. Mossey 2 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Geronimo John Posted June 20, 2025 Posted June 20, 2025 On 6/17/2025 at 10:44 AM, rich.dev said: On our 2023 we have a solar disconnect switch in the cubby above the street side bed. Overkill, but highly effective! Hard to miss as well. Safety John Approved! LOL On 6/19/2025 at 6:36 AM, T-Oliver said: Any advice on how to bend on offset into a copper bar to connect to the disconnect switch. Several of us have used a vice, propane torch and machinist hammer. Suggest drilling the short leg hole first and make sure you have clearance over the switch and the door frame above. Mine is 1/8". I said good work. My wife said "Lucky". But then I tend to be the Clint Eastwood of this house..... GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators topgun2 Posted June 20, 2025 Moderators Posted June 20, 2025 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
jd1923 Posted June 21, 2025 Posted June 21, 2025 (edited) On 6/19/2025 at 10:36 AM, T-Oliver said: Any advice on how to bend on offset into a copper bar to connect to the disconnect switch. Also is 10mm x 25mm cu overkill vs 6mm x 25mm cu The ampacity calculations are not clear to me 6mm by +/- 1” is certainly enough. 10mm is crazy big! (and no way your bending a 10mm bar! On 6/19/2025 at 2:47 PM, Tony and Rhonda said: From what I've read online, I can heat the bar almost red hot and bend it. I'm trying to find a way to make a smooth radius bend rather than clamping in a vise and whacking with a hammer. Yep, just clamp it in a vise and hammer it! You better have a real HD vise though. If you want to add heat OK., but it may not help unless done right. It’s just copper, so it heats and bends nicely. Take a 5 lb hammer! 🤣 Allow me to add a thought re this subject. If you really need to account for a height difference in where you bolt the lugs, I made this cable to account for adding a shunt to my batteries in a previous install. Just an idea, but you cannot purchase cables like this. You cannot even buy cables less that 1 foot off-the-shelf except maybe from Powerwerx, love this company: https://powerwerx.com/ Edited June 21, 2025 by jd1923 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
T-Oliver Posted June 21, 2025 Posted June 21, 2025 I thought of that method, but I’d have to purchase lugs I’ll price it out The bussbar appealed to me, because I could over think the idea form the bar, tin the bar and then heat shrink The offset cable seems more practical 1
Tony and Rhonda Posted July 13, 2025 Author Posted July 13, 2025 I went to work on the solar disco switch this morning but didn't get very far. The circular marine hatch in my cabinet is 6" diameter so there is not room for the Bluesea 6006 switch next to the hatch. Based on @rich.dev's photo, it seems strange to me that newer Olivers have a smaller hatch than older models. I'm considering putting the switch inside the unfinished space behind the Zamp. I can epoxy some HDPE to the unfinished side of the pantry wall, then mount the Bluesea switch to the HDPE. This wouldn't be as convenient as having the switch in the over bed cabinet but 'may' be better than having it under the bench/bed. I'd have to reach in more or less blind to turn the switch but it's a big switch. Can anyone foresee other problems with this location? Is J.B. Weld the correct epoxy for gluing the HDPE to the fiberglass? Any advice on this? I'd like to confirm that the switch should go on the positive wire between the solar panels and the controller, correct? Thanks, Tony New to us 2017 Legacy Elite II Hull #251 (with updates) TV: 2023 Tundra Double Cab 4x4 TRD Sport (Now with Engine #2) Formerly 2004 Tundra with 2015 Four Wheel Camper Fleet
dewdev Posted July 14, 2025 Posted July 14, 2025 (edited) @Tony and Rhonda Tony: I am going to be installing a single circuit BlueSea System switch as my solar cutoff switch. Oliver installed a single pole switch in my friends 2021 Oliver, which he bought new. It is a BlueSea System model 6006 switch and is rated from 300 amps continous. (I can only assume that OTT is following code by only interupting the + wire, as they have been doing that for a few years now). Because your and my access hatches are larger than on the 2021+ trailers, we can not install the switch next to the hatch, as OTT did. Instead, I plan to install my BlueSea switch inside the pantry on the wall against the area where the wiring to the Zamp Solar Charge Controller is located. This location allows the + wire from the solar panels to the Zamp Controller to be moved off the Zamp and moved over to the BlueSea switch. Then only a new short cable is necessary to be installed from the BlueSea switch back to the Zamp Controller to complete the circuit. My research indicates that the Zamp Solar Charge Controller is using 8 AWG cable wiring. Yes, I will have to cut a circular hole in the pantry wall, but that is easier than trying to epoxy a HDPE backing plate inside that small area in back of the Zamp and the switch is than accessable without reaching into where all the wiring is. If anyone sees my approach to be a issue, please let me know. Edited July 14, 2025 by dewdev 1 Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 aH Lithonics batteries (390 total) and Xantrex Freedom XC 3000 Pro Inverter in 2025 2027 RAM 1500 Rebel, 4 x 4; 5.7L Gas V8 Hemi; 3.92 rear axle; 4 corner air suspension Maine
Tony and Rhonda Posted July 14, 2025 Author Posted July 14, 2025 @dewdev I considered moving the switch to a spot on one side or other of the the Zamp controller. but there still wasn't much room and the fiberglass on our 2017 is about 1/2" thick in that area. More than I want to drill though as a first time project. The solar wire in our 2017 is 6awg. 1 New to us 2017 Legacy Elite II Hull #251 (with updates) TV: 2023 Tundra Double Cab 4x4 TRD Sport (Now with Engine #2) Formerly 2004 Tundra with 2015 Four Wheel Camper Fleet
Snackchaser Posted July 15, 2025 Posted July 15, 2025 14 hours ago, dewdev said: @Tony and Rhonda Yes, I will have to cut a circular hole in the pantry wall, but that is easier than trying to epoxy a HDPE backing plate inside that small area in back of the Zamp and the switch is than accessable without reaching into where all the wiring is. If anyone sees my approach to be a issue, please let me know. Have you considered mounting it on the hatch cover? At least if you mess up, then you can just get a new one. Cheers, Geoff
Tony and Rhonda Posted July 16, 2025 Author Posted July 16, 2025 @Snackchaser Which hatch cover are you referring to? @dewdev I'm warming to your suggestion of installing in the pantry wall. While I don't have a problem sticking my arm behind the Zamp controller to turn the switch, my wife may not be able to reach it. High in the pantry wall is out of the way but still easily accessible. I don't think the fiberglass is very thick there either so drilling a hole 'should' be easier. Since the back is accessible, I can use #10 machine screws with washers and nuts instead of sheet metal screws for more secure mounting in the thinner fiberglass. This is more or less the same location as in the space behind the Zamp but facing the opposite direction. And no epoxy. Thanks for the suggestion! Tony New to us 2017 Legacy Elite II Hull #251 (with updates) TV: 2023 Tundra Double Cab 4x4 TRD Sport (Now with Engine #2) Formerly 2004 Tundra with 2015 Four Wheel Camper Fleet
Snackchaser Posted July 16, 2025 Posted July 16, 2025 On 7/13/2025 at 9:58 AM, Tony and Rhonda said: The circular marine hatch in my cabinet is 6" diameter so there is not room for the Bluesea 6006 switch next to the hatch. This is the hatch I'm referring to. Instead of mounting the switch next to it, mount it right on the hatch cover. It will make the drilling and wiring a breeze!
