Anyone here ever done this? Planning another trip to the SW and would like to explore more of CO and this road trip is on the bucket list but given the steep grades and descents not sure a half ton with 6 cylinder Ecoboost engine will provide enough engine braking compared to an 8 cylinder or diesel.
Curious to hear what others have to say or have experienced.
Thanks
Rob
Legacy Elite II #70
@Mike and Carol Mike wrote he towed the Million Dollar Highway with a half ton truck (when in another thread I wrote I was too chicken for that route)! We went to Ouray then back out to Ridgway, south to Telluride and took CO 145 down through Rico and to Delores.
We're heading back up there for a few weeks late Sept to mid Oct. Love the area! If you're ever in Delores go to the Delores Market. It's an amazing market with onsite butcher, fresh local produce and amazing baked goods! It will be our first stop on the way up and last stop on the way back! 😂
You are not the only ones who have opted for the alternate route via 145 for the same reason. I have been to Delores in the past but don't recall the market but will certainly look for it if there again. Have an old forest service friend who lives there too. I understand CO 145 is also very pretty as well.
Legacy Elite II #70
We have done 550 several times each way with our previous Ram 1500’s.  The grades up and down were not a big issue.  Traffic moves at a leisurely  pace and almost everyone drives cautiously and at a reasonable speed.  You have to respect the road.  We’ve also done the drive between Durango and Ridgway many times towing with our 2500, braking is mostly taken care of by the engine brake.  We’ve also done the trip west through Delores and Rico on 160 and 145 that takes you by Telluride.  It’s scenic in a different way, a little longer but a nice way to go.
We’re currently camping in Durango visiting our son and family on our way to the PNW.  He commuted up 550 weekly to Grand Junction for a year when he was working there.  He said it was closed a few times due to heavy snow, but other than that he never had an issue.  Mike
Thanks @Mike and Carol all helpful info. When I get down that way just might try both routes just to experience it all. Surprised CO actually plows this route in the winter. Our roughly equivalent Beartooth Highway up in this neck of the woods certainly doesn’t. It’s closed for over half the year. Love Durango, nice town.
Edited by routlaw
Legacy Elite II #70
2 hours ago, routlaw said:
Thanks @Mike and Carol all helpful info. When I get down that way just might try both routes just to experience it all. Surprised CO actually plows this route though in the winter though. Our roughly equivalent Beartooth Highway up in this neck of the woods certainly doesn’t. It’s closed for over half the year. Love Durango, nice town.
Rob, going north on 550 keeps you mostly in the inside lane against the mountain.  Going south you’re mostly on the outside lane which can seem more intimidating.  This is all between Silverton and Ouray.  The western route takes a little longer but we enjoy it too.  Ditto on Durango, we love it here.  Mike
2 years ago on our way back from Glacier we traveled the Million Dollar Highway in our 2019 1/2 ton Silverado, 8 cylinder 5.3 L, 8 speed automatic, with tow package.  A couple of stretches had me gear down to 2nd gear at 30mph to keep engine below 4000 rpm.  As we are full timers we were just below 7000 lbs on the trailer and about 100 lbs below max weight for the truck.  Didn't mind going uphill, but downhill we still needed the brakes more than I would have liked.  It was a beautiful drive but once is enough.  With 140,000 miles on the truck now I don't need to push my luck.  Back then we probably had 80,000 miles on the truck.  BTW we had our 1 and only flat tire on that highway and we didn't even know it.  Another motorist tried to get us to pull over for several miles.  I finally found a place to pull over and sure enough the tire was shredded...luckily no damage other than needing a new tire and rim.  The next week I installed a TPMS.
ALAKAZARCACOFLGAIDILINIAKSKYLAMEMDMAMIMN
Rob, just our 6.7 diesel 1 ton, and we absolutely loved the Million Dollar Highway. We let our diesel engine brake do all the work.
We would drive it again in a min.🤩
This is what I keep hearing from some YouTube videos. Might be a better route on my return trip vs on the way south.
Legacy Elite II #70
Ah the beauty of a big diesel engine when it comes to engine braking. All that compression truly becomes helpful on these steep descents. A definite disadvantage for gas engines especially the 6 cylinders, turbo boost or not. A couple of years ago I learned this lesson all too well while going over Teton Pass dropping down to Jackson. By the time I was halfway down my then 2013 Ecoboost and Ollie brakes were all smoking. Even 2nd gear was not much use on a 10% grade that runs for about 10 miles. Not something I would ever like to repeat.
We were not the only ones that day smoking brakes either. A fifth wheel just in front of us being pulled by a 3/4 ton truck was also in trouble and had to make an emergency pull over. Thus my caution on the Million Dollar Highway.
Legacy Elite II #70
Point well taken, and great info. I do run quite a bit lighter than you but still. Presumably the flat was on the Ollie and not your Silverado surely? Scary stuff. Likewise I keep a TPMS on ours too, monitors heat and pressure.
Legacy Elite II #70
Yes, on the Ollie.
I'm with you on this Rob (thanks for the heads up on Teton Pass)! If doing the Million Dollar Highway, I'd choose the direction to be on the hill side vs. the cliff side of the road! 🤣
CO 145 drops 2500 feet, from Telluride down to Delores. A little rugged before Rico CO, then heading south from there it follows the beautiful Delores River and was mainly a good road. We have a trip planned camping along CO 145 late Sept to mid Oct. Starting at Delores we will get up to Sunshine Campground again close to Telluride, maybe as far north as Ridgway CO. Having 3-4 weeks we should be able to find some good campsites without rushing through there like the end of our last trip.
Maybe put AZ Hwy 78 on the same list. Grades are not listed but certainly > 10% in some parts. Not a well known road but this was our story. Months later, I found out our brake controller was going bad. Replaced it for much better braking! We're getting new axles which should arrive this week. Going to the D52 trailer axles with 12" brakes should increase stopping power. Our Ram is an older model when the diesel exhaust brake was not an option in pickup trucks.
Edited by jd1923
Wow! thats quite the road and story on that thread @jd1923 . All this talk about brakes, controllers et al has me wanting to go through my trailer brakes again to make sure they are in good shape. I do feel better with this new truck and its Max Tow Package. Looking at the front and rear rotors they truly look much larger than my older truck which only had the basic tow package. Still some of these roads out west are formidable descents, not to be taken lightly.
Regarding Teton Pass, the drop down into Idaho is quite doable which I have also done. As long as your TV can make the climb up the steep ascent from Jackson without overheating the westward descent is not a big deal. The one time I towed going from Jackson to Driggs I had to stop at the pass to allow my F150 to cool down, both engine and transmission. They were getting pretty close to their limits.
Grades of 14-18% is off the hook though, never saw that.
Legacy Elite II #70
That sign was just on a short NF road off AZ Hwy 260 descending into the canyon to Tonto Natural Bridge near Payson. They had a parking lot there for the sole purpose of detaching trailers before descending!
Generally 8% is the steepest I’ve seen marked on US Interstates and highways, some state highways are steeper.
Good you have a special towing setup. I added 3rd Gen Dodge 2500 front rotors designed for the newer heavier model. Also just now adding oversized rear drum slave cylinders. Trailer brakes from 10” to 12” and these upgrades all help. FedEx Freight just called, axles coming tomorrow!
I wanted to add a Pacbrake exhaust brake. Was $1800 two years ago, now $2300 and toooo much money!
Having traversed Teton Pass at least on 5 different occasions in both directions, I am surprised that I did not see “hot” brake check stations. Having enough room to have brake checks on the pass is likely the issue. If I recall we only saw one runaway truck ramp. Wolf Creek Pass on the other hand has a 7% grade which requires commercial vehicles to maintain a 25 mph speed limit while descending the pass. The vistas are nothing short of amazing.
In Rocky Mountain NP they do have brake check pull offs. While visiting the park and not towing XPLOR, and were waived on through by the Park Police at the brake check station. The trucks we saw being pulled over for brake checks were mostly 1/2 ton gassers and many cars. @jd1923 I was surprised to read your diesel does not have an engine brake, interesting. Do you have tow/haul mode?
Edited by Patriot
Just guessing but doubt the state of Wyoming has ever invested in such technology (or ever will), it's also certainly not here in Montana.  The thing about Teton Pass as you know it is really steep, narrow and winding. Having gone over it several times myself, but only once towing, it hard to imagine how and where they would have built check stations. They barely have enough pullouts as it is and those are not very large.
It has become fairly obvious the state of Colorado is the King and champion of high mountain passes in the lower 48.
Legacy Elite II #70
Ours is an old 2001 2nd Gen Cummins 2500. For 18 years we had a 2003 3rd Gen Ram, neither had exhaust brake. I don't believe it was an option on pickups back then.
No tow mode either and only a 4-speed trans. It has an Over-Drive OFF button which keeps it in drive (3rd gear) and you can manually select 1st or 2nd. I used 2nd on very steep descents where 25-30 MPH is good. I use OD-OFF when climbing a steep incline where 55 MPH is a good speed to climb and it holds there nicely.
Y'all might find this article interesting. It appears Ford added the Exhaust Brake with the release of the 6.7L Power Stroke starting in 2011, with Dodge and GM +/- close in time.
https://www.ford-trucks.com/forums/1490785-2015-exhaust-brake.html
Ford guys online admitting the Ram having the better exhaust brake because the Cummins engine builds better back-pressure than the Power Stroke.
I found this article because there is a very clean/reasonable 2015 Ford F-250 Super Duty 6.7L Power Stroke listed 4-Sale locally (grandpa passed only 130K miles). It's white with Super Cab... Hmmm?
Anybody know what trans (and # gears) would be on the 2015 Power Stroke?
Edited by jd1923
Have not studied about the difference in manufacturer's engine brakes, but where you're located an engine brake would be nice! We used to install Cummins in several different industrial applications, nice engines. From what I understand the Ford 6.7L diesel works great towing an Ollie.
Bill 2015 LE2 2024 F-350 6.8L
@jd1923 Here is a link to what may help you with an answer on the used Super Duty you are looking at. You will likely need to register on the forum if you want to ask questions. Other than that lots of reading. I hope this helps!
https://www.ford-trucks.com/forums/forum30/
Open source says - The 2015 Ford Powerstroke is equipped with a 6.7L Powerstroke diesel engine and a 6R140 TorqShift heavy-duty 6-speed automatic transmission. As for the rear pumpkin, you would may want to call the owner and verify specs.
Edited by Patriot
We were in Ouray last fall and were heading to Great sand dunes after that so we had the same decision to make.  We had driven down to Silverton without the trailer and that was exciting enough.  Woke up the day of departure and it was raining so 550 was a no go for us.  Headed north back up through Montrose then 50 towards Gunnison.  If there is even the slightest chance of rain I would avoid it.
John and Kim
Will be in the Durango area in September; any camping location recommendations? Thanks
We usually stay at Durango Ranch RV Resort, it’s on highway 550 just south of town.  We’ll be there the end of September on our way back from the PNW.  We had friends who stayed at Alpen Rose RV park in Durango and were happy.  There’s also a nice RV Park in Bayfield, a little bit of a drive but a nice park.  We’ve stayed there a couple of times.  It used to be named Bayfield RV park now it’s Outdoorsy Bayfield.
  • 1 month later...
So as of yesterday, JD now has a Pacbrake PRXB Exhaust Brake!!! 🤣
The vendor swayed me with a 20% OFF Labor Day sale and Cummins Forum members convinced me of its product value! I got the work done and just yesterday went for a test drive. Wow I LOVE it! When I turn OD-OFF the exhaust brake consistently slows my Dodge-Cummins down to 25 MPH before releasing. There is also an engine warm-up feature that when ON pressurizes the valve partially to speed up warming (turned off when ECT hit 165F)!
I'm not going to add a build thread here since I'm the only oddball here towing with a truck now 25 years old! It was quite a build (about as much work as upgrading axles). Though I did create a build thread on the Cummins Forum, linked here for those interested:
https://www.cumminsforum.com/threads/pacbrake-on-the-dodge-47re-auto.2615212/?post_id=30091229/
An added bonus is the Pacbrake system comes with an onboard air compressor. So, I ran an air line to the rear bumper to air TV and TT tires or whatever.
We're leaving Sunday for SW Colorado. Can't wait to see the brake perform on the many mountain road descents we'll see over the next couple weeks! 😎
