Had a tricky time finding grommets that fit the hole for our burner bases on our Dometic PI 8022 2 burner in our Hull 505 EII
Added them to the outfitters guide here:
Oliver Outfitters Guide
Cheers,
Craig & Rose  Hull 505
Thanks! Sort of a rinky dink stove top compared to other offerings on the market now days. Have thought about buying and installing a different unit which would require copious amount of cutting into the FG countertop which is not appealing. Good to know these are replaceable.
Legacy Elite II #70
Perhaps THAT is just one of the reasons that Oliver has also upgraded the cooktop.
At the Oliver Rally I plan to put out various parts for free that may fit other Oliver setups as I’ve bought many replacement parts (like stove grommets) that aren’t for our version by mistake.
It's pretty easy to stub your toe like this when buying on Amazon.  It's not the same as a trip to local hardware store if you still have one!
When I called Dometic for a part number last year, the lady couldn't figure out the part number for the little grommets.  So she sent a bunch of parts including all the grommets, new knobs, new decal.  For free!  She was also very fun and cheerful to talk to.
Wow!  That's even better than a trip to the local hardware store, except you probably didn’t get popcorn like I do!
  • Care 1
I had a similar experience when I needed one of the four screws that hold the Dometic AC cover on.  I called and was told they would “take care of me”.  In a few days I had a bag of 6 screws.  No charge.  Mike
