Hey all, A quick search did not turn much up so maybe this is an unusual issue. The welded washer at the forward end of the steel rod that allows the entry steps to slide up for travel has broken off. See below. Oliver does not sell that part so the repair options and pros and cons that I can think of are below.
Option 1: I considered having a welder reattach the washer. Cons, fairly expensive, $65-100 depending on the welder, and the possibility of recurrence.
Option 2: Purchase a new steel rod, cut to length (24 1/2"), and drill holes for cotter pins to anchor. Cons, still expensive, and some machining required, but close to original.
Option3: I temporarily cut a half inch threaded aluminum rod to length and used 2 nuts at each end to secure without tightening to the frame. Pros, quick and inexpensive. Cons, threads may bugger up the track that the rod rides in (maybe). Aluminum is not as strong as the original steel rod, but this temporary fix is functional.
Option 4: Same as 3 but use a threaded steel rod for strength. This would almost surely wear grooves in the track as you pull out and store the steps.
Thoughts from any of the metal working gurus out there?
Bob
https://www.instagram.com/campbells_olive2roam
2024 Legacy Elite Platinum, Hull #1465
2024 Nissan Pathfinder, Rock Creek Edition
Lithium Batteries (260AH),
240 Watt Solar with Charge Controller, and a 2000 Watt Pro Inverter.
Victron Orion XS 50A DC-DC Battery Charger
ALAZARCTDEFLGAILINKYLAMEMDMAMIMNMSNHNJNM
IMG_3669.thumb.jpeg.c57a83fdc615cb97d38ebd0e4581c6e7.jpegOrder a 1/2 shaft collar from Amazon. Try to find a collar that is split and clamps on or one that uses a set screw for attachment. Buy one that is stainless steel. The collar should be clamped on the rod end that had the washer, the other end will still use the washer and cotter pin. These stainless collars are only a few dollars each and will make a good solid end.
Edited by mountainoliver
Added photo
2017 Elite II, Hull #208
2019 Chevy HD 2500 Duramax
40 minutes ago, Olive2Roam said:
Ah! Why didn't I think of that? Good call. 🙂
Or -
Give Service a call.
Can they ship you a replacement rod and what would the cost be.  Since your Ollie is relatively new - this breakage should not have happened.  Would they (could they) replace this under warranty?  You'll never know unless you ask (nicely).
3 hours ago, topgun2 said:
Or -
I did call service. Disappointingly, the response was, "we don't stock that part" and I may be better off finding a welder to spot weld it back on. I was happy to pay for a new part and have it shipped. I could have pressed the issue but I needed it quickly because we are heading out for 3-4 weeks next week. Like I said, disappointing response to say the least. I would have even been willing to drive to Hohenwald to pick up a part.
Darn!  Well, it was worth the call and at least you know.
However, I'm a bit surprised.
Excellent advice Ken (the metal working guru you asked for). I would choose the set screw kind and drill an indentation on the shaft so the screw sits to hold the collar nicely.
Yep, for sure! OTT should replace this under warranty on your 2024 hull. They used to make them to last 10+ years.
Edited by jd1923
We had the same thing happen.  I called service and got a spare but this was last year.  I would try asking again.
Sincerely, Clare
ALAZCACOFLGAHIIDKSLAMTNVNMNYNCOHOKPASCSD
  • 5 months later...
There is some concern that the steel rod threads will "eat" the aluminum  slot. A smooth rod of steel with collars or washers and cotter pins would likely serve you best.
Edited by Geronimo John
Typo
At the very worst, you temp use two bolts in each end. Available almost anywhere fine bolts are sold.
Cindy,  Russell and  "Harley dog" . Winchester TN
2027 EII on the board. "Ramble On"
3 hours ago, Geronimo John said:
A smooth rod of steel with colors or washers and cotter pins would likely serve you best.
"colors" ?
Let me guess.....   The person you spoke to has the initials MS...
On 10/31/2026 at 12:59 PM, topgun2 said:
"colors"
typo
Take both pieces to a muffler shop and have them weld them back together.
2023 Elite #1403--2019 Ford F150--2.7 Ecoboost V6--10 speed auto--without Max Tow
Cotter Pins and Washers would be a lot less expensive.
Likely. But as a retiree from within the auto repair business and specifically from a "Muffler Shop" I'm a bit prejudiced in that respect.  If someone had brought me the parts I would have probably done it for nothing.
