Boudicca908 Posted Monday at 02:43 PM Author Posted Monday at 02:43 PM 1 hour ago, Ronbrink said: Most U-Haul trailers have a 4-pin cable since they have surge brakes rather than electric brakes. Will that matter in the pull test you are suggesting And indeed — though I specifically requested confirmation of 7 pin they only have 4 pin and wiring seems to include no brakes. Of course they sell an adapter, but I don’t think this will tell me anything. I’m on hold… 1 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
Boudicca908 Posted Monday at 03:39 PM Author Posted Monday at 03:39 PM 14 hours ago, jd1923 said: Doesn't matter. Your mechanic thought this was the correct junction box and all the right colors are there for a trailer wire harness OTT told me the junction box was located here. Are you saying that this is not correct? Is there a second junction box not visible in this photo? (Reminder: I am checking in only periodically from my phone, as I don’t have WiFi in camp.) Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
jd1923 Posted Monday at 04:40 PM Posted Monday at 04:40 PM (edited) 2 hours ago, Boudicca908 said: Of course they sell an adapter, but I don’t think this will tell me anything. I’m on hold… Correct, 4-pin harness is for small trailers without brakes. 4 pins only connects turn signals and brakes lights. They’re wasting your time. You need a heavier trailer, large cargo trailer, car hauler, anything with 7-blade plug like your Oliver! Edited Monday at 04:53 PM by jd1923 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted Monday at 04:42 PM Posted Monday at 04:42 PM 1 hour ago, Boudicca908 said: Are you saying that this is not correct? No, I’m agreeing it is likely correct because all the right wire colors are there for a trailer wiring harness. Blue wire is power to brakes. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
ScottyGS Posted Tuesday at 06:01 PM Posted Tuesday at 06:01 PM Talking to JD1923 now and I was telling him about a "trailer disconnect" problem I had years back with my Ford F150. What solved it was the "Tow Ready 20142". https://www.reeseprod.com/product/20142_trailer-connector-adapter-7-to-7-way It "fools" the truck that there is enough electrical feedback to keep that message from happening. It's not that expensive, less than $30. You might try it. It solved a very vexxing problem for me. Good Luck, Scotty 1 Gregg & Donna Scott and Missy the Westie - The Flying Sea Turtle - 2016 Hull # 145 2024 Nissan Titan XD - Western NC
jd1923 Posted Tuesday at 06:30 PM Posted Tuesday at 06:30 PM 9 minutes ago, ScottyGS said: Talking to JD1923 now and I was telling him about a "trailer disconnect" problem I had years back with my Ford F150. What solved it was the "Tow Ready 20142". https://www.reeseprod.com/product/20142_trailer-connector-adapter-7-to-7-way It "fools" the truck that there is enough electrical feedback to keep that message from happening. It's not that expensive, less than $30. You might try it. It solved a very vexxing problem for me. Good Luck, Scotty Thanks Scotty, this is very helpful and adds a new twist! The Oliver has LED lights for brake, reverse and taillights. The low amp draw of LEDs may not register with the factory brake controllers, cause for the error codes. @Boudicca908's truck is GM vs. Ford but could still be the same issue. This is worth a try! If true in this case, there could be nothing wrong with the factory brake controller, nothing wrong with Oliver trailer wiring, just the factory controller not playing well with LED trailer lighting, wow! Learning this, the U-Haul trailer test I suggested would not be conclusive! If U-Haul trailers have standard automotive incandescent lights the factory controller would not show error with the U-Haul but only trailers like the Oliver with LED lighting. Yesterday U-Haul failed to rent a trailer with brakes and 7-blade connection. I would try this $30 device asap and scratch the U-Haul idea for now. At some point, if you're able to tow a second Oliver and the error messages go away, that would be a viable test showing issues with your Oliver trailer wiring. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Boudicca908 Posted Tuesday at 07:33 PM Author Posted Tuesday at 07:33 PM Well…. My Oliver and TV played well together for 3 1/2 years before this issue started. But I will keep this in mind. Thanks @ScottyGS for the additional input. 1 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
jd1923 Posted Tuesday at 08:10 PM Posted Tuesday at 08:10 PM 35 minutes ago, Boudicca908 said: Well…. My Oliver and TV played well together for 3 1/2 years before this issue started. But I will keep this in mind. Thanks @ScottyGS for the additional input. Yes good thought, but 3 1/2 years OK, not your issue. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Snackchaser Posted Tuesday at 09:30 PM Posted Tuesday at 09:30 PM I don’t want to offend anyone, but I have an entirely different view on this issue. It might be time to pull in the reins on the piece-meal fixes and take a fresh look. At lot of the advice provided is based on conventional auto electrics and trailer wiring. But things are much different with today's vehicles. There is changing technology with Pulse Width Modulation (PWM) switching, and the way it interfaces with modern LED lighting, and the low-to-ground switching of your Chevy that requires solid grounding. High resistance grounds and shorts can be hard to locate, and they can cause ultra low currents that will be detected by digital systems of new vehicles. These include grounds and shorts that might only appear under heavy loads, such as from your brakes. The heavy loads can cause insulation breakdown and arcing that might not be otherwise detected. The flickering lights you mentioned might be an artifact of your 2023 truck’s older PWM system and a separate issue, or it could be caused from a poor ground. It could also be caused from a failing brake controller for example. I agree that it’s most likely a trailer wiring issue, but I wouldn’t go rewiring the 7-pin or axle wiring just yet, or renting a u-haul with a 4-pin adapter because you will not get definitive answers. Unfortunately, new grommets will not help at this point either, the wires were already taped. The breakaway switch amperage will be ambiguous too. A direct short would smoke the wire, a high resistance short would be lost within the range of 9-12 amps for the 4 brake coils. But there are enough clues to point to a potential ground issue, so a ground check would a good start for most DIY folks. The trailer is grounded to the TV in 2-ways. Through the hitch ball, and via the 7-pin ground wire. The ball ground can be iffy, so the wire ground is important! You can see the black ground wires in your junction box picture, they are connected to studs that are grounded to the trailer chassis. A good place to start checking. Use a multimeter on ohm’s setting. Find a good ground on the TV for grounding one of the meter leads, and then start checking ground points on the trailer with the other lead while jiggling wires, including those on the axle. You will need two people, and maybe jumper cables to extend the test lead length. You should have fairly consistent low ohms readings. You might get lucky and find a loose connection. However, it sounds like various technicians have already checked for obvious problems, so at this point you are really in the territory of an Auto Electric specialist with proper logging instruments to test for intermittent problems and the ability to accurately trace circuit continuity. Auto electrics is a field of it’s own, and they are far more knowledgable that the dealers and regular mechanics. Just my two-cents. Good luck! Geoff 1 1
Boudicca908 Posted Wednesday at 12:34 AM Author Posted Wednesday at 12:34 AM 2 hours ago, Snackchaser said: You can see the black ground wires in your junction box picture, they are connected to studs that are grounded to the trailer chassis. A good place to start checking. Those two were LOOSE when the “last” diesel auto mechanic opened that access panel. He tightened them. And he taped the wires underneath, near the hole in the axle. And he connected the ground wire on one of the truck batteries (all mentioned in my original post). The issue resolved for 3 days. Then driving over aged highway macadam and it started again. My brother mentioned the potential for the slightest bit of low voltage to mess with computer components in the truck. Today I reopened the vanity access panel, looked around, took photos, buttoned it up again. Didn’t change anything. Noticed there are actually two junction boxes in there, street side one much harder to access; I opened the curbside junction box. Those two black ground wires still looked tight. Tomorrow morning I move to new location (more rural). 2 hours ago, Snackchaser said: various technicians Confidence level is low. Two mechanics looked at the ground bus bar under the dinette, after I pointed out where it is located, but I don’t know if anyone was certain about which wires on it were/are associated with the 7-pin cable and/or the brake wiring. And I shared the wiring diagrams (such as they are) in the manual. One tested the individual elements of the 7 pin head (trailer side) and said he didn’t think the issue was there, it was functioning. 3 hours ago, Snackchaser said: Use a multimeter on ohm’s setting. Find a good ground on the TV for grounding one of the meter leads, and then start checking ground points on the trailer with the other lead while jiggling wires, including those on the axle. You will need two people, and maybe jumper cables to extend the test lead length. You should have fairly consistent low ohms readings. You might get lucky and find a loose connection. Will do this in Cimarron, where my friend can help me. Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
jd1923 Posted Wednesday at 06:55 PM Posted Wednesday at 06:55 PM (edited) On 6/16/2026 at 2:30 PM, Snackchaser said: you are really in the territory of an Auto Electric specialist with proper logging instruments to test for intermittent problems and the ability to accurately trace circuit continuity. Auto electrics is a field of its own... Geoff, from what I've observed over the last couple years, you know more about electronics than most of us who posts on our Forum. There is electronics in brake controllers but NONE at all on the Oliver side brake wiring. I do not mean to offend either, but is there such a beast as an "Auto Electric Specialist?" Some believe in Bigfoot! 🤣 We don't have this kind of service in our area, so are you offering a solution? On 6/16/2026 at 2:30 PM, Snackchaser said: At lot of the advice provided is based on conventional auto electrics and trailer wiring. But things are much different with today's vehicles. There is changing technology with Pulse Width Modulation (PWM) switching, and the way it interfaces with modern LED lighting, and the low-to-ground switching of your Chevy that requires solid grounding. So, how does this point to a trailer wiring issue? Why not a bad ground or faulty controller on the truck side? Aren't you just guessing without at least touching the Oliver, running the most basic tests with multimeter or clamp ammeter in hand? The U-Haul rental idea was a simple binary test to see if the error would occur towing another trailer. If the error could be reproduced it would eliminate the Oliver wiring as cause. Of course, the rental trailer must have brakes and 7-blade connection. Only one U-Haul counter person thought the 7-to-4-pin adapter would fit the need! 🤣 Also, in trailer wiring the white wire is ground, the black is 12V+ which is why in the picture the black is fused in the junction box. Am I wrong on this? If there is a ground issue on the Oliver side and there very well could be but we just don't know that. If it was my issue, I certainly wouldn't spend more money on specialists, just replace the ground. Attach a new ground wire at the junction box, test for continuity to the ground on the 7-blade plug, then run the new wire directly to the main ground bus under the rear dinette seat. This would eliminate trailer ground as cause in an hour with 10 ft of new wire, a simple solution. There are only 3 places where a connections, positive or ground, could be bad on the Oliver: 1) the 7-blade plug and wire harness back to the junction box, 2) the connections in the junction box and Oliver brake (blue+) and ground (white-) wiring from the junction box back, and 3) the wiring to the streetside brakes and through the axles to the curbside brakes. I would do some current and ground testing in these 3 areas and replace the most likely culprit. The entire trailer brake wiring, on the Oliver side, could be replaced in a day with $200 in parts. However, simple current and ground testing would determine one of these 3 areas to be at fault. It could be determined the factory brake controller is defective or has wiring issues. Four (4) GM dealers already struck out in finding a solution here, too much money spent. If true, I would bypass the factory system and install a reliable Tekonsha P3. There are only 4 wires in this controller harness, install new wire with +/- connected directly to the battery. Yeah, it's "piece-meal" but simple. But I can hardwire all of this at home (or any trailer shop) with hand tools and when done count on its reliability for many miles to come! 😎 I don't expect we'll agree on this one and that's cool. When I do yardwork, the weed-whacker is my tool of choice. I'm not planting a new flower bed. It's just not me. I know you like electronic switching systems, and you have demonstrated some great ones! Very cool, but some are a bit too complex for my liking. When I restore a used vehicle, like our Oliver, with factory or prior-owner aftermarket additions, once again I reach for the weed-whacker! Love your work, Geoff. 🤗 Edited Wednesday at 09:35 PM by jd1923 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Snackchaser Posted Wednesday at 11:32 PM Posted Wednesday at 11:32 PM Jd, thanks for the complimentary words as always! I mentioned the Auto Electric Specialist option because many folks may not know it’s a thing. It’s an ASE recognized field and most areas have them. We actually have three exclusive Auto Electric businesses here in small town Eureka. I also remember at least a couple of them when I lived in the Phoenix area near you. I don’t rule out that the truck has a problem, but I believe it’s the trailer because the dealer cleared the truck, and there were no other trouble codes. Wiring issues were found in the trailer and the repairs made the issue go away temporarily, so odds are that’s the source. Electrical problems can be very elusive, and often beyond DYI electric testing skills. My mention of a possible brake controller problem, or PWM digital interfaces, was merely meant to show that the problem could be almost anywhere, and one must consider that in their repair decisions. After several mechanics failed to find the problem, it’s reasonable to assume it’s not a simple problem to find. That’s why it would be “lucky” to find it with simple tests. My suggested test might find a ground problem, which would explain both the brakes and the flickering lights. However, intermittent problems, high resistance connections and shorts, degraded brake controllers, etc., could all cause similar symptoms, and they can be very hard to find. You'r right about the black wire, I must of had a brain embolism on that one. And I should clarify that the junction box is a likely place for problems to occur, but I’d probably start testing from the main ground bus under the dinette, and work backwards to the truck — only if there was high resistance or an open… keeping in mind that the brake circuit probably branches out separately from the junction box which further complicates testing. Also I didn’t mean to shut-down your emergency brake breakaway switch amperage test idea. However, it’s fed directly from the battery and a completely separate circuit from the TV. In fact, your low amperage readings didn’t compute with expected amperage for 4 brakes, so perhaps the switch only controls the brakes for one axle. Regardless, it’s doubtful that a problem in that circuit would show-up as a TV brake issue. Also, the hot side of the TV brake wire could create similar symptoms if there was a short to ground. That could be even more tricky to find. Some might use a Megger to test the wire insulation… which is over kill for 12v circuits. A jiggle test with a multimeter is the way to go, but it’s hit and miss. Anyway, see how quickly it gets complicated. I don’t like to throw out too much detailed information to confuse people, but I re-iterate that there’s more to it than folks might realize, and that’s why there are so many auto electric specialist’s. Hope that clarifies things! Cheers! Geoff 3
Boudicca908 Posted Wednesday at 11:33 PM Author Posted Wednesday at 11:33 PM I have WiFi! But I am taking the evening off from the internet. I’m going to curl up with a good book and watch the Purple Martins and Scissor-tailed Flycatchers do their magic. 3 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
jd1923 Posted yesterday at 01:12 AM Posted yesterday at 01:12 AM 1 hour ago, Snackchaser said: Hope that clarifies things! Cheers! Geoff Yep, it does. I believe we're in sync now. Thanks, JD 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
