I am thinking of buiying a 2026 GMC Sierra 1500 Denali which comes standard with the Premium Suspension featuring Adaptive Ride Control (ARC)
Do people that have the GMC Denali find that it halls the Elite II without problems like no porpoising when going over bumps? Does the rear end of the truck squat a lot when conneccting to the Elite II.
I would appreciate any information you can share.
Edited by dewdev
Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 aH Lithonics batteries (390 total) and  Xantrex Freedom XC 3000 Pro Inverter in 2025
Maine
While this does not answer your specific question, many of us prefer to eliminate all those issues you list by simply going with a 3/4 ton truck.  Such a truck also eliminates the need for a weight distributing hitch and gives more payload capacity.  Its simple and provides more confidence on the road.
Edited by FloraFauna
5 hours ago, dewdev said:
I am thinking of buiying a 2026 GMC Sierra 1500 Denali…
I didn’t comment earlier, since I don’t follow new tech and models. But I’m with @FloraFauna 100%.
I used to buy used Cadillacs (one Lincoln Mark VII LSC) for my drivers back in the 90s, like the Seville STS, nice car to commute Chicago traffic! They’d come off a 2-year lease, with under 30K miles, and always with a dealer add-on 70K powertrain warranty! I’d keep them another 2 years and trade for another beauty for very little money. I’d spend 28K OTD, for what new would be 60K plus dealer fees and taxes!
In AZ if I buy from a private owner, there are NO sales taxes. From a dealer, the plus 8.6%! Think about total cost of ownership.
For what you’d be spending for new, you could get the same model but the HD 2500 series, low mileage 2-3 years old, for same or less $$$!
Our TV is 26 years old and pulls the Oliver NP!
I’ve purchased about 60 vehicles in my life. Only 4 of them were new. I have a little brother who won’t buy anything used to save his life! Maybe because when young he got all the used hand-me-down clothes I grew out of. He’s paid through the teeth and I’ve always had far better rides, way too many to park in our 3-car garage! 🤣
Edited by jd1923
Having done it before, I can say that having a marginal tow vehicle is no comparison to having a competent tow vehicle. A bigger truck is safer and more comfortable to tow with. No weight distribution hitch, no worrying about your weights, much more relaxing. If you're buying a new truck anyway, I suggest going for a 2500. You'll probably end up buying one later, anyway.
And nothing like the diesel engine with exhaust brake! 😎
I use it always, even around town, towing or not. Somebody cuts in front of you and you're slowing down as soon as you let your foot off the gas.
Drove recently Prescott to Phoenix to pickup Chris at the airport. It's a 4300 ft drop in elevation and I made it down the mountain without pressing the truck brake pedal once. Without it, I'd be on the brakes most of the way down. Towing the Oliver down I-17 does require braking a few times where the drop is 6-8%.
For sure! Note a couple Forum members recently posted they prefer when the TV weighs more than the TT. It provides balance which boosts confidence when towing in less than ideal conditions. Our truck loaded and hitched (with tongue weight) is 8K LBS with 8,800 GVWR, and the Oliver loaded is 6,400 LBS. Never will the tail wag our dog.
Given you're buying new, it's the right time to make it your last and best TV purchase. We're not getting any younger! 🤣
Edited by jd1923
JD beat me to it on this one.  I traveled a couple hundred miles in Wisconsin hill country today.  The steep downhills would have had me braking frequently to stay close to the speed limit.  Instead i flipped on the exhaust brake and didnt need to touch the brakes even once and i wasnt even towing this time.  When towing the benefit is even much more. I cant overstate how valuable this feature is in the hills and mountains.
Before making your decision spend some time test driving the Denali or AT4 EV. Seriously - just take some test drives, why not? GM is so gung-ho on EV’s because their data shows 4 out of 5 people, once you get them in an EV, never go back. As a tow vehicle you’ll find that it kills everything else. Uphill more torque/power than every other truck out there, and downhill you don’t use your brakes and it all regenerates into the battery.
As for squat it has independent rear coil suspension (one motor per axel no transmission) so it’s minimal, under an inch. Add a little bit of WD and there’s none.
Regarding adaptive ride, the Denali EV has airbag suspension which adapts height. It doesn’t have the adaptable shock absorbers, but with an entirely different suspension design (independent coils) I don’t think it needs it. You also get rear steer, it has the turning radius of a small compact like the Bolt. Parking lots are a breeze.
Not to mention the software and interior tech …
Sierra EV AT4 2026 (max range 530 mile pack)
I went with suggesting the diesel and exhaust brake, knowing full well Dan would chime in with the EV truck. 🤣
I imagine he’s right about power and downhill braking. Still not sure I’d want to be looking for charge stations while camping though.
The main issue may come down to cost. You can’t buy an older EV and they are quite costly compared to the 1500 series gas truck.
Glad I didn’t disappoint 😅
Quote
Not a problem anymore but we’ve been over that. But it’s all good, whatever rocks your boat.
Quote
Actually that too - 2024/25 Silverado EV’s (same platform different front end) are coming off lease and rentals, people are getting them at great prices. But yeah apples to apples you’ll pay an extra 4-6k or something. You’ll save in fuel/service total cost of ownership pretty quickly with gas prices as they are, but granted people tend to be more sensitive to sticker price.
From a different forum where I posted an estimation of towing costs, for the Oliver of EV versus Diesel, using today’s prices. The Unit Cost is the averaged national average for both, and of course while fuel costs are highly variable, charging base cost doesn’t change, except there are various discounts. For example GM keeps giving me $50 free charging credits, they run sales (Ionna ran a Labor Day sale of something like 20 cents/kWh), but AFAIK fuel never goes on sale.
Also this is just for towing trips, when at home of course you’ll charge off whatever your rate it, basically free for me with lots of solar.
Metric Diesel Truck Electric Truck
Baseline Efficiency (Unladen) ~18.0 MPG ~2.0 miles / kWh
Efficiency with 40% Loss 10.8 MPG 1.2 miles / kWh
Total Energy Required 370.4 gallons 3,333.3 kWh
Assigned Unit Cost $6.00 / gallon $0.40 / kWh
Total 4,000-Mile Cost $2,222.22 $1,333.33
Edited by DanielBoondock
I have posted several times that a F-150 TV (Crew cab and 3.5 EB engine) and OE2 loaded at 50% of the rated tow capacity is a great match for many of us.  Let me delve into this a bit deeper.
With the Ecoboost (IE:  False marketing by Ford as you get Economy (No Boost) or Boost (Power with no Economy) you have a great setup, especially for out west in the mountains.  It does however need a set of Bilstein 5100's and air bags to be that ideal daily driver and a great TV for an OE2 combo under 12,000 pounds (That's a 6K Ollie and a 6K F-150).
Unlike the Super Duty Team, I often take my truck off road , drive it daily. and accrew 60% of my miles with our OE2 in tow.  Such a use mix would work well with any Super Duty truck.  And such a statement does not even consider the fuel savings issue.
In summary, if you can afford having two or three vehicles (Daily Driver, Off road, and TV) great for you as you can have the best of your wonderful world.
But if you need to have a single vehicle for towing an OE2, occasional  4X4 off road(or winter snow use), and it is your daily driver..... then IMHO, the Super Duty is not going to be the optimal.
I hesitate jumping into vehicle discussion and what is best.  I will say our half tons were good TV’s and good daily drivers.  Our 3/4 ton is a great TV and a good daily driver.  It’s fine around town, hauling grandkids, and is our preferred vehicle for trips without the trailer.  So, it’s really just a matter of personal preference.  Mike
18 hours ago, Geronimo John said:
In summary, if you can afford having two or three vehicles (Daily Driver, Off road, and TV) great for you as you can have the best of your wonderful world... GJ
GJ, you make a good point and it is a wonderful world!
I need a fully adequate TV for the Oliver and for me that's the 3/4-ton truck with exhaust brake. The 1/2-ton means less payload and Andersen WDH and maybe airbags or Timbrens, etc. Once you're up in 3500-land, might as well get a dually and a 40' fifth-wheel trailer! 🤣
Like Mike, I'm fine with driving our 3/4-ton truck around town. It's also fun to drive at times, but we have two "daily drivers" that are better around town. My '92 Lexus SC400 get's me to pickleball 3 times a week, more quickly with less fuel costs. The 1/2-ton truck gets a little better MPG than the 3/4-ton. The 3/4-ton will be safer. I buy older vehicles in good condition, fix them up myself so we could afford them. For the last many years, a new truck costs a small fortune, so we're often in this same discussion, "Can I tow more with less?" 🤠
I've read here about towing an OE2 with so many odd choices, OMG! This thread started re the GMC Sierra 1500 which can be a fine TV for some. Maybe for those who pack light and tow more worry-free. Having the 2500 is reassuring, exhaust brake better yet! You have to do what's right for you and there's more than just the basics.
For example, I've learned that we must have a long-bed truck with 1500 LBS capacity just for stuff in the bed, including 35 gallons extra water. It's a must, for us. I drove a Quad-Cab Ram for 18 years. It was great when our son was young and we had two labs, but I will not own another 4-door truck. There's just two of us and I love the extended cab with the half-size suicide door. It's quick and easy and Charley loves his narrow bench seat back there!
It was also very important to us to have the rig, the truck & trailer that look good together, a matched set! 😎 Our truck fits us and our needs. Make the right choices for yourselves, with a lot here to think about.
Edited by jd1923
  • 3 weeks later...
To address your question specifically, yes the GMC Sierra 1500 will tow the Oliver trailers quiet nicely.  We towed our longest trips in a GMC Yukon Denali, which is a bit heavier than a 1500, but same platform and engines.  I had the 6.2 liter gas engine.  No problem towing with and without the weight distribution hitch.  I towed the trailer home from Nevada without the w.d.h. on it and had no wobble or sway.
I wouldn't tow it with anything less than a 1500.  It was too heavy for a Tacoma that I had briefly.  I've also tried a Cadi EV and that towed nicely and a Sierra HD.  The HD was obviously the best.  My next trip we're taking a Hummer EV, so we'll see how the range does on that EV.
Christian, Katie and Benny (our Maltese) | Cave Creek, AZ | 2019 LE II #448 | TV: GMC Sierra 2500
Note that I've never heard of an Oliver "swaying".
However, all of the manufacturers of current 1/2 ton trucks in one way or another "require" a weight distribution hitch.  Both legal and warranty issues should be considered before towing an Elite II without a WDH.
The 6.2L EcoTec3 V8 (L87 engine) used in the GMC Sierra 1500 (and its GM sister vehicles like the Chevrolet Silverado, Yukon, and Escalade) has been at the center of significant technical scrutiny and major recalls in recent years.
1. Major Safety Recall: Connecting Rod / Crankshaft Defects
  • The Issue: A critical manufacturing defect in connecting rods and main bearings/crankshafts resulted in severe internal engine damage, engine knocking, sudden stalling, or catastrophic engine failure.
  • Affected Vehicles: Broadly covers 2021 through May 2024 model year GM vehicles equipped with the 6.2L L87 V8 (affecting nearly 600,000 trucks and SUVs).
  • The Remedy: Dealerships inspect the engine for metallic debris or rod knock. If damage is present, a full engine replacement is authorized. Non-defective engines receive a specialized inspection, new oil cap/service guidance, and an extended 10-year / 150,000-mile engine powertrain warranty.
  • Federal Investigation: Federal safety regulators (NHTSA) opened and expanded investigations after reports of repeated failures, including on some engines replaced under the initial recall scope.
Note: Models built after May 2024 and 2025–2026 production units utilize updated engine components to address this manufacturing defect.
2. Dynamic Fuel Management (DFM) & Valve Lifter Failures
  • The Issue: The L87 engine features GM's Dynamic Fuel Management (DFM) system, which selectively deactivates individual cylinders to save fuel. The special collapsible hydraulic valve lifters associated with DFM are prone to sticking, bending, or collapsing.
  • Symptoms: Loud ticking or knocking noise from the valvetrain ("lifter tick"), engine misfires, rough idle, severe power loss, and Check Engine Light (CEL) illumination. If a lifter bends or fails completely, it can damage the camshaft, necessitating a top-end tear down or full engine replacement.
  • Prevalence: This issue affected many 2019–2023 models, prompting GM to issue technical service bulletins (TSBs) and updated lifter designs.
3. Valve Spring Breakage
  • The Issue: A batch of weak or improperly heat-treated valve springs in earlier L87 production runs caused sudden valve spring fractures.
  • Symptoms: Misfires, metallic clattering, drop in compression, and potential engine destruction if a broken valve drops into the cylinder.
4. High Oil Consumption
  • The Issue: Some owners report elevated oil consumption between routine service intervals.
  • Contributing Factors: DFM cylinder deactivation can draw small amounts of oil past piston rings during low-load operation. Owners are encouraged to check oil dipstick levels regularly, as low oil accelerates main bearing and lifter wear.
Summary for 2026 Model Year Buyers
If you are considering a 2026 Sierra 1500 Denali, GM implemented revised manufacturing processes and updated internal components to resolve the 2021–2024 crankshaft/connecting rod manufacturing defects. However, as with all high-displacement, pushrod V8s utilizing active fuel management systems, routine oil maintenance and monitoring are essential.
Edited by HDRider
