While camping this week I noticed a slight sidewall bulge on my streetside rear tire.  I just replaced all my tow vehicle tires so was not excited about buying more tires right now, but a sidewall bulge is never a good thing.  I have the Goodyear Endurance ST tires on my Oliver and with the trailer only 3 years old and less than 10,000 total miles on the trailer, I was disappointed in the tire longevity/durability.  I have been running about 55 psi in the tires as a compromise on ride quality vs tread wear/mileage.  I know some of you run even less pressure to save the springs, but lower pressures do stress the sidewalls more. I then looked closer and the date stamps on the tires are late 2021 so the tires are actually about 5 years old, not 3 and 5 years is about the life of a trailer tire.  So despite low miles and inside storage, I am leaning toward replacing all 5 tires (including the spare) and increasing my running tire pressure some.  I abhor the idea of changing a streetside tire along the road on a trip after a blow out.
What would you do?  And don't assume your tires are the same age as your trailer.
I would replace the one, put the spare on opposite side of the same axle. Put the other two best on the other axle. The most visible worn tire in as spare. Unless the tires have been in full sun, in the desert (say Phoenix), generally good until 6 - just inspect them regularly. Now the caveat - if I was headed out on a long-term trip - months, and headed up to AK, and beyond, different story. Do you run tire pressure monitors?
Cindy,  Russell and  "Harley dog" . Winchester TN
2027 EII on the production board. "Ramble On"
2026 Chevrolet 2500 ZR2, 6.6L L8T gas V8
I don't but I do check them regularly.  Thanks for your suggestions - they make sense to me.  Love your tag line by the way "die young - as late as possible".
Edited by FloraFauna
On 10/9/2026 at 4:24 AM, FloraFauna said:
I noticed a slight sidewall bulge on my streetside rear tire... What would you do?
Bummer!
I have seen brand new tires with a "slight sidewall bulge" due to the lesser manufacturing process of some brands. Though I just looked at my flat bed trailer that has the same Goodyear Endurance ST tires, just a size smaller. No bulges on mine and they look to be rather well made tires. They are 7 years old now with likely only 2500 miles on them! I'm not changing them yet since lately we only use the trailer to go dirt-biking once or twice a year. A 12 ft 7K dual axle trailer with 650 LBS of cargo a few miles at 35 MPH, I'll take my chances!
Now the Oliver is a different story! Our LT tires are near 5 years old. I never heard 5 years for ST, always seen 7 years. We have 19K miles on the Oliver in 3 years, prior owner had 2 years on the same tires with who knows how many miles, and there is no real treadwear.
Every time I talk maintenance, I recommend removing the wheels for inspection when doing anything else! Grease Zerks, torque bolts and spend a few minutes inspecting each tire. I always remove all the gravel, and often while doing so, I have found a screw or some kind of metal in the treads. Wash the tires on both sides. It's easier to see a defect or new damage on a clean tire!
Bulge just on one tire, make it the spare for now. Running at 55 PSI is a very good number for low sidewall stress.
Could you have any prorated warranty left? (3 years 10K miles) Or if it's truly a defect, Goodyear might cover it anyway. You could drive by a Discount Tire or other Goodyear dealer when you get a chance. They should help to communicate with Goodyear for coverage.
It's a shame that OTT installed tires already 1-2 years old, 6-8 months is more usual, less time with the large manufacturing volume of these ST tires. Why did OTT change to ST tires on 15" wheels? Do they make a 15" LT tire?
I'm not a TPMS guy either and our vehicles are all too old to have OEM TPMS. I check every time I take a break from driving. Do a full walk around and eyeball all 8 tires before going. I do it with all vehicles, whether towing or not.
Edited by jd1923
Here's a 2022 thread about Oliver changing to Goodyear Endurance ST tires:
Edited by rideandfly
Bill 2015 LE2 2024 F-350 6.8L
As I read through the replies my memory fades back to several tire foibles of the past. The Michelin's on my 2004 truck had similar bulges. and yet I got 45k out of them, my newer 2018, had one with a "dip" in it, and had no problems. The real issue for me has usually been nails, bolts, or some such road trash trespassing into my tire causing ruin and destruction - a flat.  I had great experience with the rubber on my former Ollie, no problems. Ran tire monitors, which actually resulted in more stress overall - "why is that left rear hotter than the left front, oh look, the left front is 2 psi diff, and on".  I know they are good for sudden blow out, otherwise, well, not so for me.  I don't recall what brand or size is on the 2027 LEII and I'm sure it will be just fine until that screwdriver jettisoned from the electrician's truck bed finds its way into the right front tire sidewall, ending the short life of a full tread left tire. My luck in a nutshell.
TPMS are nice but the batteries do die and then it one more thing to replace.  I have them on my tow vehicle and premptively replaced them because they are pain when they die. Been there with a different vehicle. Like you, a good, frequent visual check plus putting a pressure gage on once in awhile is my prefered method.  Like Russell explained, having 4 pressures in your face all the time can be an unwelcome mental distraction for many of us.
22 hours ago, FloraFauna said:
...having 4 pressures in your face all the time can be an unwelcome mental distraction for many of us.
Almost as bad as having a catastrophic blowout in the middle lanes of six on an interstate at 60mph. Use your own judgement. Your mileage may vary...
  • Haha 2
Having experienced a catastrophic blowout on a different trailer, I don't mess around with tires. Tire pressure monitor and replace trailer tires every 5 years, regardless of mileage. The problem with trailer tires is the lack of use. Flexing the rubber is actually good for it, so when a trailer sits, the rubber deteriorates faster. Worse, the problem can be on the inside of the tire, even if the outside looks fine. It's shocking how much damage a tire carcass can do to a trailer when it sheds at 65 MPH.
Prefer not to have that experience and thus lean toward the complete replacement route so share your cautious approach. But in all of this it is not obvious to me how the tire pressure monitor helps prevent a catastrophic blow out versus frequently visually checking inflation and watching for bulges or tire issues at every stop - only takes a minute.  Seems like tire temperature might be a more important indicator.  So do you see TPMS more as a convenient way to watch your tires or an actual safety feature?  Obviously before a blowout the pressure is a number and after a blowout its zero.
This makes alot of sense.  It is far easier to grease and visually observe how the chassis is functioning/wearing with wheels off.  But it is a royal pain as every time i take the wheels off the ez-flex inverts on me and then in addition to remounting, and retorquing, there is the jacking to correct the linkage inversion, once on each side.  I guess no pain, no gain.
With a tandem axle trailer and a heavy truck you can have a catastrophic trailer tire failure and not even know it. You won't feel it. With the TPMS you know right away and can start reacting, minimizing damage to your rim and trailer and reducing overloading of the remaining tire on that side. That's what happened to us. Our TPMS went off and we got away with only a broken mud flap and cosmetic damage because we stopped with most of the tire still on the rim.
You could also have a fast leak from road debris. It could go flat without you feeling it, then chew itself to bits on the rim before you knew you had a problem.
Our TPMS also alerted us to a catastrophic trailer brake failure. One wheel started running much hotter than normal. We pulled over and heard noise from that wheel. Turned out the brake assembly had come apart inside the drum.
So, yes, I consider TPMS a crucial safety feature.
All I had to see was a truck hauling a U-Haul trailer down the road with sparks flying from the driver side tire that had blown out. He was going down the road passing people having no idea he was tireless with rim grinding on the road. He kept going for miles down the road before we finally saw him pulled over. Convinced me to always have TPMS.
Todd & Kat
I can relate. Many years ago, we headed south I -40, I was asleep in the passenger seat, my wife driving. I wake up - "what is that thumping?" Oh it started a min or so back! We pulled over, the tire on the boat trailer was just about gone, and the fender was toast. Lessons learned. TPMS is invaluable.
RB
Well, I guess I jinked myself, or at least proved why having a TPMS is valuable. On the trip from Utah to Grand Junction (to get us some new leaf springs), our TPMS went off, and my wife said, "One of the tires is down to 35 psi... now 30... now 25," all in the matter of 30 seconds. We pulled over, and sure enough, the tire pressure was dropping fast. The valve stem had ripped and started leaking. We did enough of a patch-and-fill job to get off the side of the freeway so we could change the tire. Glad we had it, so this stayed just an inconvenience! Also, so glad I had done dry runs of changing tires at home so whenever this day did come I was confident we could get it addressed.
The next day I went to Les Schwab and got some nice steel stems put on all the tires!
Todd & Kat
Here is a good E-rated one that I am considering for my TV next year or so:
