I apologize for this redundant question, I know the answer is there somewhere, but I failed to find the answer in a search.  What is the height to the top of the ball on a EII when level. I seem to remember 19" or so, but saw 24" in a post. I need to purchase a drop hitch but can't figure the drop without this little piece of data. My new TV has a hitch mount height of approx. 25.5", so if the Ollie is about 19-20" I'm good at 6" drop, as the things are not cheap, I will wait for some expert answer to the question.
Thanks in advance.
RB
Cindy,  Russell and  "Harley dog" . Winchester TN
2027 EII on the production board. "Ramble On"
2026 Chevrolet 2500 ZR2, 6.6L L8T gas V8
No expert here - but - I seem to remember that the ball height is 23 inches.
For the REAL expert's opinion - simply email or call your Sales person at Oliver.
The top of my 2-5/16 inch ball is 21-5/8 inches with my 2500 truck bed empty.  By the time I load my extra 35 gallons of water and other stuff for camping plus add the tongue weight of the Oliver I am as close to dead level as you are going to get.  So it's not a simple question you ask. It depends alot on your TV and how you load.
Thanks all - My previous TV was just as some describe here - add a little to the TV bed, attach the Ollie, and it was about perfect. I have asked Oliver to give me a floor to top of ball measurement on a level Ollie.
RB
RB:
Would be nice if you would add your TV info to your signature.  If it's a 3/4 or 1 ton, skip the below.  But for the 1/2 ton trucks you may find some pearls.
For my 2019 OE2, the OTT target is 23.5" to 25" ball height.  Here are my heights  as I worked the issue of squat and bottoming out the rear springs with and especially without the Anderson in play.
ANDERSON BALL HEIGHT RANGE:  23.5” to 25”.
For my 2019 F-150 Crew Cab FX4, Max Tow Package:
               Truck loaded for tow travel Ball Height:   24 ¾”
               Ollie hitched without Anderson:                22 ¼”                   Way too much squat.
               Ollie hitched WITH Anderson Set              23 ½”                   Meets OTT recommended height range, but...
With the squat at 1 1/4 inch, I was bottoming out the springs way too often and the ride was not great as well.  Rear end of the truck was not well planted.
So I flipped the standard Anderson “Rack” and lowered the TV ball 1 7/8” height.  Then added air bags and Bilstein shocks (Rear).
Spent a bunch of time working different air bag PSI and found 30 to 40 PSI range worked depending on the road.  Normally travel at 30 PSI.  If the road requires more support I take it up via the on-board compressor.  Have used on a really bad road 50 PSI.  Squat was eliminated for the TV with the Anderson, Bilsteins and air bags in play.   The combined effect is that I have full factory spring deflection both up and down, and rarely bottom out.  The combination also resulted in the TV rear being much more planted and a great ride.
As FloraFauna stated, "So it's not a simple question you ask. It depends alot on your TV and how you load).
Thank You GJ:
I am aware of the variables involved in setting the final working height - I was just looking for the current Olliver at level setting. One never knows over the years if the tires, springs, etc have changed. From what I can gather, not much in this realm. Oliver confirmed today exactly what you quoted. And happily, for me, it looks like I can use the same hitch/ball from my previous setup.
Your pearls are indeed fine "organic" gemstones, interesting how changing a few things makes so much difference.
As for putting my TV in my Signature - I actually just purchased it and put it away in the barn. So, I will get right on that. The particulars: Chevrolet 2500 ZR2 6.6L L8T gas V8 , 401 hp and 464 lb‑ft of torque, but most importantly to me 3300lbs payload, towing GVWR more than I will ever need. White.
Thanks much, to you, and all the other wonderful forum members for the feedback.
RB
DONE -
Edited by BackofBeyond
RB….My 2021 EII is ~ 23.5” top of ball when level.   I’ve got stiffer springs, have not installed yet. waiting on new shocks which are back ordered.   In any case, I expect that might lift it a bit.  Keep in mind your previous trailer and  mine have 16” wheels, the new models have 15”, so slightly lower.
Edited by Hokieman
Format
This is so true! We started with the Andersen WDH which as you know can be bolted up or down about +/-5". I changed bolt positions on it 3 times over a 2-year period as our equipment/loads changed. Adding the 35-gal (+300 LB) water tank was one of the changes.
Our older truck, suspension a little softer after 25 years would drop 2" when adding the 580 LB tongue weight of the Oliver. We would tighten up the Andersen to get the two inches back. These pics are older, showing in the second pic how the Andersen would bring it up to level again. You want to keep your eye on your level over time. Something I do often when we find a wide-open level spot! They're hard to find in Arizona!
Adding Alcan Springs was another change. It's not like the tongue weight had changed any, but the Alcans hold the Oliver up so straight, the rear of our TV would drop <1" instead of 2". Modern 2500 trucks do not need WDH for a 7K trailer, but our TV was borderline. Since our Alcan Springs were installed, I ditched the Andersen for good, TG!
You may need something height-flexible in a hitch. I got lucky in the end. I had a HD 12K-rated ball with a 2" drop for another TV we had. Our current TV is 2WD so sits lower. I reversed the ball to make it a 2" rise and it's perfect, for how we load our TV and TT now. After 3 years we arrived at steady state! 🤣
Maybe this isn’t what you are asking for, but sitting level, on jack, on level concrete floor, 21.5 inches from floor to inside top of hitch. Length of the 2 dowels measured after adjusting as shown in the attached picture.
Bill 2018 hull 313
Bill and Martha
2019 Chevrolet 2500HD Duramax
One of the forum Masters, Mr. John Davies liked to run his rather heavy OTT on the low end of the range.  I believe he was trying to reduce drag a bit.
From reading multiple posts on this topic over the last ten seasons, and all of them above in this post, it appears that maintainnig the visual of parallel lines between the OE2 and the TV is also a consideration.  That's what I do with ours as well.
Bill 2018 hull 313
Yes, exactly. I may be a little high with my current plan - I pick up the new unit in March, I will know then - after the sag settles. I like to run it just a tad lower than "level". I am now thinking I will be a few inches high on this new TV. Thanks for the effort and the pics.
RB
That is a much better way to measure it.   I need  to double check mine next time I hook up, my Levelmate might not be set correctly.
