Camping recently in Colorado, our furnace would not fire. A search of this forum helped identify the problem as an insufficient air flow problem. I removed the outside panel, gently manipulated the ribbon sensor and all was fine - until the next day. Same issue. I called support and was told the furnace was not going to get enough air at above 5,000 ft. Simple solution seems to be to have a small space heater, but I'd rather have a safer solution. Has anyone else experienced this and is there a “high altitude “ solution?
We just got back from camping five nights at 8,700 in Mammoth Lakes, CA. Overnight temperatures were as low as 16 degrees. One night was 21 and windy enough to shake the trailer with the stabilizers down! The furnace worked just fine, other than eating up the propane. Sorry you had problems.
Andrew
Andrew
5,000 feet would eliminate most everywhere I'd want to camp. I'm not even sure that I'd call that "high altitude". Like Andrew, we've never had any problems - but then we have the Suburban furnace. Just curious, whose service told you that, Oliver's or Atwood's?
I've camped at just over 11,000 feet with no problems with the furnace. However, I do recall reading that anything above 6,500 to 7,000 might cause issues due to lack of O. Suburban for mine.
Just FYI:
I confirmed with Service at OTT and called support at Dometic (Atwood). Their furnaces are not rated above 5,000 ft., they do have high altitude kits for meduim size furnaces only. No upgrade for the Oliver.
I guess my options are: Stay low (not gonna happen); add a fireplace; replace with a furnace that works at altitude; use a space heater (most likely solution).
Just FYI:
Surprising. A lot of us routinely camp above 5,000 feet.
For what its worth - in addition to the Oliver furnace I always carry both a small 1500 watt electric heater (used only on the rare occasion I have shore power) and my "Mister Heater Buddy" propane heater. Both work great at any altitude with the Mister Heater Buddy not having an effect on electric usage since it has no fan.
p.s. I really do think that there is something amiss with the furnace not working above 5,000 feet and would have it "serviced" if I could not find the source of the problem.
What year is your Oliver. Are we talking the Dometic Furnace that comes on the 2019. Just picked ours up. If true I will not be a happy camper come March in Colorado.
Bill Thomas 2019 Elite II Hull # 534
2020 Chevrolet Silverado HD 2500
Bill, We have hull #468 that we picked up at the end of May.  The furnace works great and we have camped in temps down to 16 degrees at 8,700 feet.
I would not be concerned.
Andrew
Andrew
  • 9 months later...
Andrew
Seems 9600" is a concern. Mine doesn't like to ignite properly at this altitude. Really stupid I think. #359, 2018 build.
Ours is a 2019 and we had no issues with it camping above 10,700 feet, overnights in the high 30's, in WY last summer.
2019 Legacy Elite II #488 - Delivery July 24, 2019
2018 F150 Platinum SC SB EB - Leer canopy
