Moderators topgun2 Posted November 2, 2019 Moderators Posted November 2, 2019 The one that Oliver sells as an option is great - you simply never have to worry about it working or getting stolen. In the case of surge protectors - the more you spend almost certainly means the more protection and functions/features you get. 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted January 26, 2020 Posted January 26, 2020 (edited) We asked about a surge protector on the Oliver during our Jan 21 factory tour. We were told by Anita that the 2020 Oliver has a surge protector built in and is standard. Edited January 26, 2020 by Patriot 1 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
AndrewK Posted January 26, 2020 Posted January 26, 2020 (edited) There is not need to purchase a surge protector. All new Olivers trailer come with the following standard: "Progressive Industries EMS Surge Protector" (Cut and pasted directly from the standard features section of this website.) IMO, it is the best you can get and it is built-in so, no concerns of it being stolen. Andrew Edited January 26, 2020 by AndrewK Andrew 2019 Legacy Elite II 2018 BMW x5 35d
Mainiac Posted January 26, 2020 Posted January 26, 2020 We have the "portable" Progressive 30 EMS (electrical management system). We got our unit Hull #211 before built in became available or standard. We like it and that we can plug into a pedestal and see immediately that we do/or do not have clean power. And we know without having to go into the unit, and before even the unit is plugged in. However we do secure the unit to the electric box with a pistol cable lock. The moving lights on the box seems to make people curious about what is going on. Maybe the name Beretta on the lock makes them wonder too?
Moderators topgun2 Posted January 26, 2020 Moderators Posted January 26, 2020 With all the expensive electronic equipment onboard most Ollies it is good that the surge protector is now standard equipment. I'm not sure where the electronic readout for the protector is placed. But, if you are sensitive to light (flashing or otherwise) make sure that the readout is in a place that hides that flashing screen from view while still being easily accessible so you can read the codes that it displays. I'd have mine placed inside the first overhead cabinet right on the pantry wall. In this location all one has to do is lower the cabinet door and you can see the readout from the entrance door - assuming that you have not filled that cabinet so full as to block the view of the readout. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
AndrewK Posted January 26, 2020 Posted January 26, 2020 Bill, Ours came standard and it is attached to the right panel, inside the rear attic storage. Easy to see if you need to but unobtrusive. Andrew Andrew 2019 Legacy Elite II 2018 BMW x5 35d
John E Davies Posted January 26, 2020 Posted January 26, 2020 FYI the remote display is super easy to relocate, and it uses a regular Cat-5 ribbon style cable to power it. John Davies Spokane WA 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
DavidS Posted January 26, 2020 Posted January 26, 2020 HERE is a thread with various options for relocating the surge suppressor display. I followed @mountainoliver's suggestion HERE to move it under the dinette where it is visible from the door during campsite setup. You can snake the cable out through the electrical box, and no drilling is needed if you use command strips to attach the display to the trailer wall. 1 David Stillman, Salt Lake City, Utah 2016 Oliver Elite II Hull 164 | 2017 Audi Q7 tow vehicle. Travel and Photography Blog: http://davidstravels.net
Trainman Posted January 28, 2020 Posted January 28, 2020 Our 2019 came with the Progressive surge protector, you can turn it on and off, or Bypass mode located on the LED panel in the rear overhead. trainman 2019 RAM 1500, 5.7 Hemi, 4X4, Crew Cab, 5'7" bed, Towing Package, 3.92 Gears. Oliver was sold.
