Rivernerd Posted September 5, 2023 Posted September 5, 2023 1 hour ago, dewdev said: But, only the newer Olivers have the "Jack Point" decals! Good point. I was writing for John Welte, who I know has a 2022 Elite II, because his is one Hull # before mine! 3 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
MobileJoy Posted September 19, 2023 Posted September 19, 2023 LockNLube has three right angle adapters. The more expensive one at $16.99 is the one that was linked earlier in this thread. The one I'm considering is this "simple" one at $10.99. The former one is shorter at 0.8" while the latter is 2.15". Anyone have experience with it, or with both? The third one is the push-on adapter that looks like it will not work for the upper zerks. 2021 Elite II Twin #850 "Mojo", 2020 F250 Lariat 7.3L FX4 3.55
John and Debbie Posted September 19, 2023 Posted September 19, 2023 2 hours ago, MobileJoy said: LockNLube has three right angle adapters. The more expensive one at $16.99 is the one that was linked earlier in this thread. The one I'm considering is this "simple" one at $10.99. The former one is shorter at 0.8" while the latter is 2.15". Anyone have experience with it, or with both? The third one is the push-on adapter that looks like it will not work for the upper zerks. I used the $16.99 one that has a screw on piece and external spring. There are three pieces that are inside the housing. Don't make the mistake that I did and unscrew the piece fully. I lost those three little pieces and had to reorder the piece. I have to finish the job still now that the replacement adapter came. They should warn people to not unscrew that, or maybe everyone except me just knew not to. I don't have experience with the cheaper adapter that you reference. Good luck. John 1 1 John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022
Tom and Doreen Posted September 19, 2023 Posted September 19, 2023 I have the "simple one" at $10.99 and I was able to connect to the difficult zerks. 1 Tom & Doreen • 2023 Elite ll • Hull #1321 • 2023 Tundra Platinum Crew Max • Cheshire CT
MAX Burner Posted September 19, 2023 Posted September 19, 2023 7 hours ago, MobileJoy said: LockNLube has three right angle adapters. The more expensive one at $16.99 is the one that was linked earlier in this thread. The one I'm considering is this "simple" one at $10.99. The former one is shorter at 0.8" while the latter is 2.15". Anyone have experience with it, or with both? The third one is the push-on adapter that looks like it will not work for the upper zerks. We've been using the straight one that we bought from LockNLube, it hits all 16 zerks with ease and doesn't pop-off. Works as a great combo with the Lincoln grease gun: 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
John and Debbie Posted September 19, 2023 Posted September 19, 2023 29 minutes ago, MAX Burner said: We've been using the straight one that we bought from LockNLube, it hits all 16 zerks with ease and doesn't pop-off. Works as a great combo with the Lincoln grease gun: Did you have to remove the wheels? John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022
MAX Burner Posted September 19, 2023 Posted September 19, 2023 35 minutes ago, John Welte said: Did you have to remove the wheels? NOPE, I crawl under the trailer (and destroy a T-shirt) and hit the zerks from underneath. 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
dewdev Posted September 19, 2023 Posted September 19, 2023 On 9/19/2023 at 2:42 PM, MAX Burner said: NOPE, I crawl under the trailer (and destroy a T-shirt) and hit the zerks from underneath. You could aways use a crawler to lay on (and save the T-Shirt) , but you would want to park on pavement. 1 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension Maine
MAX Burner Posted September 19, 2023 Posted September 19, 2023 31 minutes ago, dewdev said: You could aways use a crawler to lay on (ande save the T-Shirt) , but you would want to park on pavement. With me on my Creepy Crawler - even on concrete - I can't manage to get my girth under the axles to reach the two center top zerks! Besides - I've got plenty of T's! HA! 1 2 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
MobileJoy Posted September 20, 2023 Posted September 20, 2023 I do have to remove the wheels which is why I will use a right angle adapter instead. If anyone has a preference, please tell me as I would rather not have to buy both. 1 2021 Elite II Twin #850 "Mojo", 2020 F250 Lariat 7.3L FX4 3.55
Moderators SeaDawg Posted September 20, 2023 Moderators Posted September 20, 2023 4 hours ago, MAX Burner said: With me on my Creepy Crawler - even on concrete - I can't manage to get my girth under the axles to reach the two center top zerks! Besides - I've got plenty of T's! HA! This makes me laugh. We have lots of t-shirts too. We have a big shelf of new ones. I sort used t-shirts at laundry time by work only, (folded really small), car wash rags (go to a bag), and "dressier" tee shirts, which get only a half fold. Work only shirts, pants, and socks go in one drawer. "Good" stuff, other drawers . 2 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
MAX Burner Posted September 20, 2023 Posted September 20, 2023 10 hours ago, SeaDawg said: Work only shirts, pants, and socks go in one drawer. "Good" stuff, other drawers . HA! Exactly what we do! Cracks me up! 1 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
