What’s everyone’s favorite product to get the splattered bugs off their Ollie?
looking for recommendations of products you use and links if you have it.
2021 Dodge Ram 1500
2021 Oliver Elite ll
Hull #732
Michigan
Elbow grease?😄
Used fabric softener dryer sheets with spray wax/detailer of your choice.
Edited by topgun2
spelling
A hose, a bucket of water with car wash soap, a soft carwash brush,  and microfiber cloths. And, topgun2's brand if elbow grease.
Good microfiber cloths actually make pretty quick work of bugs, without a lot of work. (Our trailer is waxed twice a year. Prevention is the best policy, imo.)
2 hours ago, topgun2 said:
Elbow grease?😄
Used fabric softener dryer sheets with spray was/detailer of your choice.
Interesting! Will give it a try. Thank you
2021 Dodge Ram 1500
Hull #732
Michigan
@SeaDawg We’ve had our Ollie custom detailed and we’ve also waxed it ourselves twice this season, we use Rockguard mud flaps and that helps but those bugs splat like paint and stick like glue!😬 Using elbow grease is an understatement. We do use microfiber cloths, I’m a big fan of microfiber cloths for inside and out.👍🏼
2021 Dodge Ram 1500
Hull #732
Michigan
I like the yellow microfiber from costco, and the yellow ones from restaurant depot. The ones from harbor freight and Walmart don't work as well, for some reason.
I know you have a lot more bugs up your way. But I  learned that trick in Alaska, where I was having trouble removing several weeks of bugs from an unwaxed rv.
A nice lady at Northern energy's free carwash in Tok gave me a microfiber cloth, and voila...well, elbow grease, and voila. Maybe we'd soaked it longer with the free cold water wash?
Good luck.
If you camp in humid areas where morning dews are common, wait until the trailer and your truck are wet - the bugs have soaked overnight (“hydrated”) and come off a lot more easily in the morning.
  • Like 7
@SeaDawg Thank you for the tip on favorite microfiber towels from Costco and restaurant depot. I will give them a try.
2021 Dodge Ram 1500
Hull #732
Michigan
try ceramic coating on front end of ollie washes off with a hose. so easy  bugs do not stick..  took me a whole day washing, wiping off with alcohol and  doing 2'squares at a time.  lasts a year.  incredible shine and so easy to clean
skip and cyd nielsen  hull #822 Elite     tow vehicle 2017 jeep trailhawk v6
We have ceramic coat the Ollie on our “to do” list. We do use a good wax but those bugs still stick like glue!
2021 Dodge Ram 1500
Hull #732
Michigan
You can also use Turtle Wax Graphene/Cermaic wax.  This stuff works great on the whole trailer and tow vehicle.  Best part is it isn't effected by the sun.  Won't melt like wax.
Will give it a try. Thank you!
2021 Dodge Ram 1500
Hull #732
Michigan
I have used this product for many years on trucks, motorcycles and campers. Take a look at BugSlide and decided for yourself.
You will be surprised and it is gentle on all surfaces.
Safe Travels,
Brian
Safe Travels,
Brian
Thank you so much Brian for the recommendation.
We recently tried Bugs Off and it works like a dream.
2021 Dodge Ram 1500
Hull #732
Michigan
Agree with John - soaked, wet bugs come off a lot easier.  I usually give our Ollie a hand wash in the driveway after a trip.  I soak the bugs with water/carwash soap solution then wash the whole trailer leaving the bug-covered front for last.  While washing and rinsing, I will hit the bugs with a stream of water and more soap from the soft car wash brush I use.  Finally, use the soft brush or microfiber cloth and they come off pretty easy after soaking.  Keeping the front polished with a good coat of wax twice a year helps too.
  • 3 weeks later...
14 hours ago, wolfdds said:
Spray nine.
Any idea of what that stuff does to your wax job?
I think using Spray 9 on vehicles is a VERY bad idea. I have no personal experience but I found a thread about it.
“It will strip anything he has for protection on the paint. It has a PH of around 13.5 and will melt tree sap. It is a good grease remover that does clean, and sanitize, a lot of surfaces. I use it around the house quite a bit because of it's germ, virus, odor and mold etc. killing effect. It is a very versatile product. He is cleaning his paint for sure but is leaving it with no sacrificial layer and open to attack from the elements.”
https://www.autogeekonline.net/forum/auto-detailing-101-a/71894-spray-nine.html
There are a lot of products that are effective, but some are really hard on your finish, for example Dawn dishwashing liquid. I will use it to intentionally strip off wax. Most detailing sprays contain carnauba wax, I use Griots Speed Shine which does not have any, so it is safe for use with a clay bar prior to applying Rejex (which must be applied to a WAX FREE base). It isn’t a super effective cleanser by itself, but it is completely harmless to your paint or gelcoat..
Always start with a mild cleaning product, then progress up to the more harsh ones if necessary. Leave the Spray 9 for crime scene cleanup….😬
My go to gear:
Microfiber towels, two buckets, Meguires 54 Gel Wash and an adjustable flow-thru brush.  Presoak while washing a side, return, wash side, return, wash back, return to the front and the bugs pretty much hose off.  Not a lot of elbow grease needed, except on me the next day as a liniment.
image.png.a2ab79f97f8ea177f3793ab8c2f1ed26.pngimage.png.be1b80357c75ac4d70801814b9fdae24.png
7 hours ago, Geronimo John said:
My go to gear:
We are big fans of Meguiars products but never tried this gel wash. Thank you for the recommendation.👍🏼
2021 Dodge Ram 1500
Hull #732
Michigan
I use a microfiber cloth with 3m Perfect-It Light Cutting Polish + Wax.  Takes any black streaks off very easily too as long as there's already a good coat of wax on the hull..
Before we head out, I apply a quick coat of ultima paint guard plus Ultima Paint Guard plus (pricey but is great and super easy to apply - wipe on, no need to buff or wipe off) - provides good UV protection and pollution protection for the gelcoat.
With recent wax, after pressure washing most all the splats come off.
For the remaining splats, we use Citrol spray.  We spray it on the remaining bugs, let is sit half a minute or so, then use a very mild white scrubby sponge if needed. (Warning - never use a "green" colored scrubby sponge on gelcoat it will scratch it horribly)
Finally, we ensure we wash off the Citrol spray with some mild soap.
Does the Citrol remove the Ultima Paint Guard?  I am sure it does somewhat.  However, the great hydrophobic properties of this paint sealant remain after one or two applications.
Does the sponge scratch the gel coat?  Not that one can see visually is bright sunlight.
Hope this helps!
image.png.7142eaf35efc1f3a3a69c99ebdc03590.png    image.png.1c784d21049ca9e8967f43a736d65e76.png  image.png.ad30279bbead027393074c6afae6c145.png
I'd be a bit careful using the "Citrol" product since most degreasers are not all that kind to a good wax job.
On 10/2/2022 at 7:56 AM, topgun2 said:
Elbow grease?😄
Bill, I bought Rejex, microfiber towels and dryer sheets.  I thought I would apply some Rejex to the front before leaving Tennessee.  It's warm now until we leave on Friday, at which point it drops into the teens at night on our route home.  Probably need to winterize before we go.  I was hoping the cold weather would hold off.
