Tom and Doreen Posted February 1, 2023 Posted February 1, 2023 On our return trip home from Oliver we noticed standing water in the shower pan. The "auto drain" valve had been closed as was evident by the standing water not draining from the pan and the light in the closet was not blinking. How is it possible that water from the grey tank can pass through the valve in one direction and not the other? Once I opened the valve the water drained out of the shower pan as expected. I didn't see any evidence of water entering the pan from any other source. Could hydraulic pressure be forcing water through the valve as the water sloshes around in the grey tank while driving? Tom & Doreen • 2023 Elite ll • Hull #1321 • 2023 Tundra Platinum Crew Max • Cheshire CT
AndrewK Posted February 1, 2023 Posted February 1, 2023 My guess would be, you ran water in the bathroom sink and didn’t realize it. That is the only thing I know of that would have caused what you described. We may have done that oneself or twice ourselves… Andrew Andrew 2019 Legacy Elite II 2018 BMW x5 35d
Steph and Dud B Posted February 1, 2023 Posted February 1, 2023 I put a REMOVE BEFORE FLIGHT keychain on the bathroom faucet handle when I close the valve before travel. Too many wet socks... 1x Remove Before Flight Red Key Chain by Apex Imports(1 Pack) https://a.co/d/2OxwnZE 2 6 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Moderators Mike and Carol Posted February 1, 2023 Moderators Posted February 1, 2023 If the gate won’t let water drain it won’t let water back up into the shower drain. I agree with Andrew, you may have run water in the sink after closing the gate. That’s the only source of water in the bath. Hydraulic pressure won’t do it. We’ve traveled thousands of miles with a nearly full gray tank, never any issues. Running water with the gate closed causes issues everytime, mostly wet socks and wet bath rug. Mike 3 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Moderators topgun2 Posted February 1, 2023 Moderators Posted February 1, 2023 There is one more possibility - If you were on rough roads and/or took turns too sharply - it is possible that water from the toilet came out of the bowl, particularly if you had the bowl full before you hit the road.🤢 Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Tom and Doreen Posted February 1, 2023 Author Posted February 1, 2023 I'm sure that there was no water in the sink before departure. After looking at the auto drain drawing, simply a typical gate valve with a motor and rack gear, I suspect that the gate was either not completely closed or there was some small amount of debris preventing it from sealing. What I should have done was to not open the valve immediately after finding the water in the shower pan and see if the water would seep back into the tank on it's own over time. I can certainly do that test but I won't be able to do a "slosh test" as the rig is now winterized ( and it's going to be -4 degrees soon ☹️). 4 Tom & Doreen • 2023 Elite ll • Hull #1321 • 2023 Tundra Platinum Crew Max • Cheshire CT
rideandfly Posted February 3, 2023 Posted February 3, 2023 We had a cracked bathroom exterior fan cap that that would drip water on the shower floor when raining. Did you drive through rain when the water appeared? 2 2015 LE2 #75 / 2024 F-150/STX/5.0L
Geronimo John Posted February 4, 2023 Posted February 4, 2023 On 2/1/2023 at 7:15 AM, Mike and Carol said: I agree with Andrew, you may have run water in the sink after closing the gate. That’s the only source of water in the bath. On my OE2 if I have closed the drain valve for travel, I and use the kitchen sink, it will fill the shower drain P-trap and overflow water into the shower drain pan. That resulted in my FIRST wet socks experience. 5 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Tom and Doreen Posted February 6, 2023 Author Posted February 6, 2023 Hello All - Thank you for your thoughts. We have a composting toilet so no water possible from that source and luckily we had mostly good weather for our ride back to CT (very lucky to avoid snow and ice storms!). For sure, the drain valve was closed as well. In thinking back, I don't believe we ran water in either sink after closing the valve, but I wouldn't bet on it as we did have rest and lunch stops along the way and we might have washed hands without thinking about it. I like the idea of signs near both sinks to remind us not to use them after the valve is closed! We will post some pictures and list the few issues we have had in the near future. Unfortunately, in the week we have been home I have been dealing with severe lower back and thigh pain - apparently from a pinched nerve. PT will hopefully have me ready for local weekend adventures in Olive in a few weeks. Tom retires 3/31 so we will be heading south soon thereafter - very exciting as we love our cozy home on wheels! Best, Doreen 6 Tom & Doreen • 2023 Elite ll • Hull #1321 • 2023 Tundra Platinum Crew Max • Cheshire CT
Steph and Dud B Posted February 6, 2023 Posted February 6, 2023 Hi, Doreen. You don't have to worry about the kitchen sink. Only the bathroom sink can back up into the shower pan. Hope you feel better soon. Maybe we'll see you guys at Hammonasset sometime! Dudley 2 3 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Moderators Mike and Carol Posted February 6, 2023 Moderators Posted February 6, 2023 I hope Tom will be feeling better soon! I don’t know of any Oliver owners who haven’t had wet socks or bath rug because they either forgot to close the gate or closed it and then ran water. After 7 years I just did it after we returned from Arizona a couple of weeks ago. DUH! Mike 1 3 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Moderator+ ScubaRx Posted February 7, 2023 Moderator+ Posted February 7, 2023 On 2/1/2023 at 9:40 AM, Tom and Doreen said: Could hydraulic pressure be forcing water through the valve as the water sloshes around in the grey tank while driving? No. The only way that clean fresh water can get into the shower pan is from above. Black water CAN find its way into the pan from below but that’s a whole ‘nother issue requiring a perfect storm of very specific circumstances. 2 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Tom and Doreen Posted February 8, 2023 Author Posted February 8, 2023 Thank you for the well wishes and it's good to know the "water in the shower pan" issue is likely because we ran water after closing the valve. Also nice to know that we aren't the first ones to do it! 😀 Dudley, it would be great to meet up at Hammonassett - it's an easy ride from home. The one limitation is that we will need to go when we can bring our four-legged girl Joy. As a bonus, there are large parking lots there where I can practice towing forwards and backwards! 🤞on that endeavor - 😳 3 Tom & Doreen • 2023 Elite ll • Hull #1321 • 2023 Tundra Platinum Crew Max • Cheshire CT
