AriesBarb Posted April 22, 2023 Posted April 22, 2023 Thoughts on towing a LEII with a Ram Promaster 3500 Van? The specs say the Promaster has a towing capacity of 6,410 lbs. I'm an ex trucker so the towing aspect in general I'd be fine with, but is this enough to safely tow the LEII? Thanks for your guidance!
Moderators topgun2 Posted April 22, 2023 Moderators Posted April 22, 2023 No. 1 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted April 22, 2023 Posted April 22, 2023 3 minutes ago, topgun2 said: No. X2 no. 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
AriesBarb Posted April 22, 2023 Author Posted April 22, 2023 Is it because the Promaster isnt high enough towing capacity? What about a Chevy Express with a 10,000 towing capacity?
Frank C Posted April 22, 2023 Posted April 22, 2023 Not a good choice. The empty dry weight of a bare bones no options Elite II is 4,900 lbs. That’s completely empty with no options at all. We have minimal options (no solar package, no second awning, no front storage basket) and our Elite II has a dry weight of 5,100 lbs on the factory sticker. Loaded up for camping we are close to 6,000 lbs with a full fresh water tank. Some owners are over 6,000 lbs. because of their options and accessories. That RAM towing capacity doesn’t give much of a safety margin. 1 2
Steph and Dud B Posted April 22, 2023 Posted April 22, 2023 If a Chevy Express does have a 10,000 pound tow rating it might be a good choice. That would probably be the cargo version. I think the passenger versions have much have much lower tow ratings, which is too bad. Years ago, we towed a trailer roughly LE2 size/weight cross country with a Ford E350 passenger van with the V10 engine. It was a great travel vehicle: tons of power, lots of interior cargo space, and captains chairs for all of us. Only got rid of it when we went to a fifth wheel. Wasn't there an Ollie owner on the forum towing with a full-size cargo van? 1 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Rivernerd Posted April 22, 2023 Posted April 22, 2023 According to a quick Google search, the Ram Promaster 3500 cargo van has 4330 lbs. of payload capacity, or more. If I am not mistaken, the 3500 level Dodge trucks and vans are in the "1 ton" category. I would say "no" to a 1500, but a 3500? We tow our LEII with a Tundra, which has 1465 lb. payload capacity. Granted, the Tundra requires a weight distribution hitch, and we are on the payload margin with 550-600 lbs. tongue weight, two of us plus gear, but with 4330 lbs. of payload capacity, and 6410 lbs. towing capacity, I would think the Ram 3500 cargo van would be in the "o.k." range. What am I missing? 1 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
AriesBarb Posted April 23, 2023 Author Posted April 23, 2023 That's what I was looking at. Specifically the Ram Promaster 3500 High Top Extended Van. I looked at the specs and it said 6,480 in one place, 6,410 in another. I was also thinking it was "on the edge" but maybe in the okay range, that's why I was trying to see what more experienced campers and towers thought. I appreciate everyone's input.
Moderator+ ScubaRx Posted April 23, 2023 Moderator+ Posted April 23, 2023 2 hours ago, AriesBarb said: Is it because the Promaster isnt high enough towing capacity? What about a Chevy Express with a 10,000 towing capacity? Much better from a towing capacity standpoint. Sixty four hundred pounds is "just getten' by..." 1 2 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Moderator+ ScubaRx Posted April 23, 2023 Moderator+ Posted April 23, 2023 The Ram Promaster 3500 Van only has a towing capacity of 6,410 lbs primarily because it has a 4,680-pound payload capacity. This would give it around a 12,000 pound GCVWR. Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
AlbertNTerri Posted April 23, 2023 Posted April 23, 2023 You won't have the braking capacity you would want during a panic stop down hill with a 6400 pound towing capacity. It will probably tow fine, it will be stopping in an emergency that will be the sketchy part. I forgot the exact number but our E2 loaded came in right around 6,700 pounds with the water tank filled and gray tank empty. If you found a van with 10,000# towing capacity then you're in line with an F250 which is a fine tow vehicle for an Elite 2. I'd go with that. 1 2 Albert & Terri Sterns Paonia, Colorado Elite II Hull #1125 Standard Floorplan / 2017 Ford F250 gas
MobileJoy Posted April 23, 2023 Posted April 23, 2023 I had been researching travel trailers since 2018 and eventually decided on a size class between 6-10K lbs and either an Airstream or an Elite II. Reducing the towed weight was important to me since our TT was to be used primarily as a roving hotel room while we toured the country. I decided that I did not want the concern of operating over spec and having to deal with liability in case of a bad accident. I also wanted a comfortable towing experience. My tow vehicle research (2019-2020) led me to conclude that anything under a 3/4 ton truck would eventually result in overloading some spec. We are not minimalists which is why I feared exceeding payload on a lighter vehicle. Not requiring the Andersen hitch was a nice benefit. Max tow/max payload packages on a 1/2 ton required accessory compromises we weren't willing to make. Having now taken some long towing trips in 2022 (about 7K miles total), I am glad that my vehicle choice exceeds all of the loading requirements. Having had a couple of panic stops, I'm very happy with how the TV/TT combo handled it. Passed and being passed by many semi trucks and not feeling the draft adds to my driving comfort. Given any particular TT, your use case matters. Had we decided to focus more on camping than traveling, we may have settled on something less capable than a 3/4 ton. An Expedition Max would have been a top consideration at 9K lbs towing capacity, or a 1/2 ton truck. With little (if any) gross trailer weight rating margin, a Promaster 3500 would not have been a candidate in either use case. 1 2 2021 Elite II Twin #850 "Mojo", 2020 F250 Lariat 7.3L FX4 3.55
AriesBarb Posted April 23, 2023 Author Posted April 23, 2023 I'm not a "minimalist" either, and we are planning on going full time hence I want to make sure we have what we need. I appreciate your input. I'll look into other options. I'm just not thinking a pick up will allow us enough space.
MobileJoy Posted April 24, 2023 Posted April 24, 2023 My F250 is my first truck and my OEII is my first RV. I have to admit that getting used to truck bed storage took quite a bit of time. At first it seemed daunting, but now it's second nature. Even so, access is not as convenient as I would like. I can only get to some items stored in the middle of the truck bed by climbing in and moving things out of the way. Your storage solution has to consider possible water penetration as well since truck beds are not weather sealed. A decent cap or tonneau cover mostly eliminates this problem, as well as providing security for your valuables. We have been through heavy rains, both moving and standing still, and have not had any water issues with our Diamondback cover. Our cover opens at the cab and tail ends of the bed, allowing me to get most items without gymnastics. Regarding space, the F250 has a coated 6'9" bed. We can easily store all that we want to bring with us with room to spare. We use plastic storage bins to contain and organize smaller items. However, we are not full-timers. If we were, I might have gone with a cap and possibly sliding storage racks. The cap would have had opening awning style flip-up windows allowing easier access to everything in the bed. A cap just about doubles contained storage volume over a tonneau cover, and relaxes the height restriction. I realize the difficulty in selecting a TV for your application. For me the (re-)search was fun and rewarding with the knowledge I gained. I hope the same is true for you, and am sure that you will find an excellent solution for your situation. 5 1 2021 Elite II Twin #850 "Mojo", 2020 F250 Lariat 7.3L FX4 3.55
Cort Posted April 24, 2023 Posted April 24, 2023 The Chevy Express/GMC Savana is fine but I suggest getting the 6.6L instead of the 4.3 I think it is V-6. I have the older 4.8L which has similar specs and while it does fine fully loaded by itself, going up hills with a 6000 lb trailer behind it would be a stretch. I checked out the other vans some time ago and the only one I would be comfortable with is the Chevy/GMC...dated but reliable, a good driver, and lots of payload and towing. 1 2 2023 Chevrolet Express 4x4 - 2019 Oliver Legacy Elite II - Hull 529 - Roaming the Western US with Skye (my dog) (and at times my Canadian partner).
Geronimo John Posted December 23, 2023 Posted December 23, 2023 NO. Not with one that has a tow rating under 10,000 pounds. TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
