Ty J Posted April 25, 2023 Posted April 25, 2023 I am a newbie with the Ollie but have done tons of modifications already. I am changing the Xantrex to a Victron 3000 Multiplus II Anyone know how to get from uppper cabinets to underneath by the inverter? I have tried following the path for the Xantrex display, but the cable will not budge. RJ telephone plug. Thanks
John E Davies Posted April 25, 2023 Posted April 25, 2023 Hi and welcome, you need to tell us at least your model and hull number. I tried unsuccessfully to drag wire through that area. I think the cables must be secured with gaffers tape in the cavity between the hulls. An electrician’s steel fish tape might do it, but it could also screw up the delicate insulation. Can you tell us what your plan is, are you going to add (much needed) fresh air ventilation to the compartment? I really wanted to have the display for my Smart Shunt up there, I settled for down below the pantry shelf. It really doesn’t matter because I use the app 98% of the time. John Davies Spokane WA SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
CnC Posted April 25, 2023 Posted April 25, 2023 53 minutes ago, Ty J said: changing the Xantrex to a Victron 3000 Multiplus II Good choice! I too would like access through that area if you can find it. Charlie. Arizona | 2020 Oliver Elite II Twin bed Hull #617 | 2021 Ram 1500 e-Hemi 4x4
Ty J Posted April 25, 2023 Author Posted April 25, 2023 Thanks John , I have a Elite II year 2021. I have taken out the xantrex controller and in the process of installing a victron LCD display , I have installed 4 x battleborn batteries, victron shunt, Victron Multiplus II 3000 and removed existing xantrex 2000 freedom, 6volt gel cells. The food cabinets has a access panel on upper right and cannot get from that cabinet to lower cabinet/battery box. The victron has a hdmi cable end that will go to the cerbo gx / "Brains of Victrons components , has wireless bluetooth and monitors whole system. i could go down the inside of the pantry cabinet and drill through but not sure what I may run into? Thanks!!!!!!!!!! Ill grab some pictures when I can.
John E Davies Posted April 25, 2023 Posted April 25, 2023 24 minutes ago, Ty J said: The victron has a hdmi cable end that will go to the cerbo gx / "Brains of Victrons components , has wireless bluetooth and monitors whole system. i could go down the inside of the pantry cabinet and drill through but not sure what I may run into? Not a problem, the pantry “floats” over the battery box with maybe three inches of space between the two parts. You can drill down at the rear inside corner (closest to you) and the bit will pop out at a location that lets a cable drop down right at the inverter area. Obviously you should think about protecting/ disguising the cable with a stick on “cord cover”. If you run it down the inside of the pantry nobody but you will ever see it. https://olivertraveltrailers.com/forums/topic/5301-how-to-lithium-battery-powered-vent-system/ Good luck, please start a thread about your mods. John Davies Spokane WA 2 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Ty J Posted April 25, 2023 Author Posted April 25, 2023 Thanks so much will give it a shot~ Pictures and mods to come. 2
Steve Morris Posted April 25, 2023 Posted April 25, 2023 I’ll be watching with great interest. My EII is just weeks old with the Victron charge controller and shunt/712 display. I understood there was’t room for the Multiplus II 3000, which is why the continued using the Xantrex. ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
Geronimo John Posted April 25, 2023 Posted April 25, 2023 2 hours ago, Ty J said: Anyone know how to get from upper cabinets to underneath by the inverter? I recall that there is a path that the A/C condensate uses. 3 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderator+ ScubaRx Posted April 25, 2023 Moderator+ Posted April 25, 2023 3 hours ago, Ty J said: …Anyone know how to get from uppper cabinets to underneath by the inverter?… The wire chase from the attic to the basement is in the aft port corner. I used a fiberglass rod to work from bottom to top. Once placed I pulled a piece of bulk weed eater cord down to the basement. I left enough cord rolled up at each end to pull from either direction. When finished, leave this pull line in place for future use. Additionally, using this technique, I have successfully placed pull lines from the inside of the closet through the ceiling to the inside of the cabinet over the microwave and side to side behind the pantry. 3 10 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Moderator+ ScubaRx Posted April 25, 2023 Moderator+ Posted April 25, 2023 If you’re going to be at either the Alabama or the Maine rally, come by and I can show you more. Site E-05 in Guntersville. Not sure about Maine. 1 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
CRM Posted April 25, 2023 Posted April 25, 2023 10 hours ago, John E Davies said: I tried unsuccessfully to drag wire through that area. I think the cables must be secured with gaffers tape in the cavity between the hulls. An electrician’s steel fish tape might do it, but it could also screw up the delicate insulation. A good way to fish a wire between the hulls without damaging the insulation is to use a "ball chain". It usually finds it's way down on the first attempt just by jiggling up and down while letting weight of the chain do the work. I use one like this but without the large ring attached which I found has a way of getting snagged on things in tight areas. Ball Chain 1 3 2010 Elite II, Hull #45. 2014 Toyota Sequoia Platinum 4WD 5.7 with tow package.
Moderators mossemi Posted April 25, 2023 Moderators Posted April 25, 2023 10 hours ago, Ty J said: The victron has a hdmi cable end that will go to the cerbo gx / "Brains of Victrons components , has wireless bluetooth and monitors whole system. Where do you intend to locate the Cerbo GX? Are going to use a GX Touch 50 or 70 display and if so, where are you going to place it? I am using a 15’ HDMI to get from the display down to the Cerbo GX through the rear port corner as ScubaRX mentioned above. Mossey 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Moderator+ ScubaRx Posted April 25, 2023 Moderator+ Posted April 25, 2023 8 hours ago, CRM said: A good way to fish a wire between the hulls without damaging the insulation is to use a "ball chain". It usually finds it's way down on the first attempt just by jiggling up and down while letting weight of the chain do the work. I use one like this but without the large ring attached which I found has a way of getting snagged on things in tight areas. Ball Chain I've successfully used this method from the attic down between studs on the interior of our house. I believe the wire chase in the rear of the Oliver is too tight with wires for this to work. 3 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
CRM Posted April 25, 2023 Posted April 25, 2023 6 minutes ago, ScubaRx said: I've successfully used this method from the attic down between studs on the interior of our house. I believe the wire chase in the rear of the Oliver is too tight with wires for this to work. Maybe I got lucky, but it worked for me the first try while installing new coax and an HDMI cable for an outside TV. I also only have the lizard skin insulation and not the Reflectix type which might have given me some extra space to work with? 1 2010 Elite II, Hull #45. 2014 Toyota Sequoia Platinum 4WD 5.7 with tow package.
Moderator+ ScubaRx Posted April 25, 2023 Moderator+ Posted April 25, 2023 9 minutes ago, CRM said: Maybe I got lucky, but it worked for me the first try while installing new coax and an HDMI cable for an outside TV. I also only have the lizard skin insulation and not the Reflectix type which might have given me some extra space to work with? Quite possibly. Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
