MnG KY Posted July 10, 2023 Posted July 10, 2023 1 On city water with plenty of pressure at spigot. A trickle of water at faucets and toilet but plenty of water at outside faucet. 2. Fresh water tank 100% . Water pump can't produce any flow at faucets or toilet. Both city water and fresh water tank worked fine yesterday. Any ideas?? Hull 1171 Ellite II George and Melinda Pierce 2022 EII hull 1171, 2021 Ford 150 Hybrid with Pro Power Onboard
AlbertNTerri Posted July 10, 2023 Posted July 10, 2023 Disconnect the hose from the outside (or at least shut off the water source), shut off the pump, get some towels and look under the curb side bed at the pump (where the valves are to change configuration for boondocking etc.) On the inlet side of the pump is a clear plastic cup-like structure that has a screen filter, unscrew the filter cap (clear plastic cup) and see if you have debris in the screen that need to be cleared. Put the towels down to catch the water that comes out when you unscrew the filter cover. Clean it and then put it back together, it doesn't need to be more than finger-tight. If that doesn't fix it then I'd call OTT in the morning. It may also be related to the back-flow valve which is on the inside of the line right after where you hook up the water hose (on the street side. If that's the issue than it should be under warranty and you'll want to open a service ticket. 3 Albert & Terri Sterns Paonia, Colorado Elite II Hull #1125 Standard Floorplan / 2017 Ford F250 gas
MnG KY Posted July 10, 2023 Author Posted July 10, 2023 8 hours ago, AlbertNTerri said: Disconnect the hose from the outside (or at least shut off the water source), shut off the pump, get some towels and look under the curb side bed at the pump (where the valves are to change configuration for boondocking etc.) On the inlet side of the pump is a clear plastic cup-like structure that has a screen filter, unscrew the filter cap (clear plastic cup) and see if you have debris in the screen that need to be cleared. Put the towels down to catch the water that comes out when you unscrew the filter cover. Clean it and then put it back together, it doesn't need to be more than finger-tight. If that doesn't fix it then I'd call OTT in the morning. It may also be related to the back-flow valve which is on the inside of the line right after where you hook up the water hose (on the street side. If that's the issue than it should be under warranty and you'll want to open a service ticket. When we have checked the filter ..no debris. Now no water even getting to the filter. Opened a ticket last night and waiting waterlessky to hear from OTT. It's a mystery! Thanks for the advice! 1 George and Melinda Pierce 2022 EII hull 1171, 2021 Ford 150 Hybrid with Pro Power Onboard
John E Davies Posted July 10, 2023 Posted July 10, 2023 Is the water pump running all the time when turned on? If so it is airlocked. You need to get water into its inlet hose. The easy fast way is to close the faucet valve and open the tank fill valve. This is from Hull 218, your arrangement may look different. This creates an open loop path for the water - tank to pump to tank. It allows the system to bleed out any air by releasing the bubbles into the tank. If that doesn’t do the trick, remove the inlet hose at the tee fitting and manually pour in some water and reconnect it. If that doesn’t do it, your pump has failed. Because the Ollie tank is so long, and the water is literally sucked out close the rear, it often gets air in that hose when traveling with a partially full tank (as the water sloshes around). This may not be related to your problem, but you need to know how to fix the airlock if it doesn’t correct itself by opening the sink faucets. Changing the pump is simple but does require making two crimped wire connections. John Davies Spokane WA 2 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Moderators mossemi Posted July 10, 2023 Moderators Posted July 10, 2023 Are your water supply valves under the curbside bed in the correct positions? Do you have cold water at the outside shower while connected to the City water inlet? Mossey The following is from the OTT LEII owners manual. 1 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
MAX Burner Posted July 10, 2023 Posted July 10, 2023 FYI: We had a similar condition where there was 35-40psi at the spigot, the water pump would run when a sink valve was open (so we knew it wasn't air locked), but flow was weak (if any) from the toilet, showers, bath/kitchen sinks. We went around to each point of usage and cleaned out debris which had accumulated at the mesh screens - including the one at the rear of the toilet. The debris appeared to be a white substance possibly calcification from a water line on the downstream side of the water pump. Don't know for sure. Anyhow, after removing the blockages - we no longer have "low-flow sadness." 3 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
BigTexas Posted July 10, 2023 Posted July 10, 2023 +1 to Max Burner's description. Had the same problem. One day is fine the next day all the faucets and toilet have barely a trickle. Had to clean out all the screens. Found a white calcified substance in all of them. After that all was well. Note: there is often a screen located at the connection to the flexible hose that feeds the shower head and kitchen faucet head. I never found any in the actual valve assembly. I assumed all this calcification came from the water heater but the mystery to me was how it got into all the cold water lines. 1 1 Big Texas – 2018 Elite II, Twin Bed, Hull #306 2024 RAM 2500 6.7L Cummins, Weigh Safe hitch
MAX Burner Posted July 10, 2023 Posted July 10, 2023 It might be caused by hard water drying out in the PEX after winterization - we don't winterize, but it could have been from a PO's efforts to winterize. 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
John E Davies Posted July 10, 2023 Posted July 10, 2023 If you use a water softener at home, and always fill the trailer tank from that source, especially for long term storage, those white hard water deposits will clear out on their own throughout the entire system, in a few months, and never return. When you are on the road, you must use whatever sources are available, just drain and refill the tank with the good stuff when you get back home, and flush out the pipes and water heater. Otherwise you need to do vinegar flushes every two years. This is a great reason to invest in a softener at home, it cleans out your home pipes and gets rid of spots in your shower, plus you can tee into that supply and wash the Ollie and your cars with it. It’s a win win win …. win situation. 😉 https://www.health.state.mn.us/communities/environment/water/factsheet/softening.html#:~:text=Advantages of home water softening,%2C bathtubs%2C and washing machines. John Davies Spokane WA 1 5 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
MAX Burner Posted July 10, 2023 Posted July 10, 2023 We've been filling our tanks with soft water from the house since we obtained the Oliver last March. As @John E Daviesmentioned, I'm thinking the soft water may have 43 minutes ago, John E Davies said: those white hard water deposits will clear out on their own throughout the entire system, in a few months, and never return. dislodged the hard water deposits (over the past months) down stream from the pump and clogged the faucet screens. Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
BBL Posted July 10, 2023 Posted July 10, 2023 4 hours ago, MAX Burner said: We went around to each point of usage and cleaned out debris which had accumulated at the mesh screens - including the one at the rear of the toilet. I learned this from having an AS! It works... BL 1
MnG KY Posted July 10, 2023 Author Posted July 10, 2023 5 hours ago, John E Davies said: Is the water pump running all the time when turned on? If so it is airlocked. You need to get water into its inlet hose. The easy fast way is to close the faucet valve and open the tank fill valve. This is from Hull 218, your arrangement may look different. This creates an open loop path for the water - tank to pump to tank. It allows the system to bleed out any air by releasing the bubbles into the tank. If that doesn’t do the trick, remove the inlet hose at the tee fitting and manually pour in some water and reconnect it. If that doesn’t do it, your pump has failed. Because the Ollie tank is so long, and the water is literally sucked out close the rear, it often gets air in that hose when traveling with a partially full tank (as the water sloshes around). This may not be related to your problem, but you need to know how to fix the airlock if it doesn’t correct itself by opening the sink faucets. Changing the pump is simple but does require making two crimped wire connections. John Davies Spokane WA Thanks will try to prime pump as you suggested. Not sure that will help the no flow on city water but the pump/fresh water tank needs to work too! 1 George and Melinda Pierce 2022 EII hull 1171, 2021 Ford 150 Hybrid with Pro Power Onboard
MnG KY Posted July 10, 2023 Author Posted July 10, 2023 5 hours ago, mossemi said: Are your water supply valves under the curbside bed in the correct positions? Do you have cold water at the outside shower while connected to the City water inlet? Mossey The following is from the OTT LEII owners manual. Yes..we checked and rechecked the water supply valves numerous times yesterday. And Yes we have cold water at the shower. Any ideas about what is happening? George and Melinda Pierce 2022 EII hull 1171, 2021 Ford 150 Hybrid with Pro Power Onboard
MnG KY Posted July 10, 2023 Author Posted July 10, 2023 6 hours ago, John E Davies said: Is the water pump running all the time when turned on? If so it is airlocked. You need to get water into its inlet hose. The easy fast way is to close the faucet valve and open the tank fill valve. This is from Hull 218, your arrangement may look different. This creates an open loop path for the water - tank to pump to tank. It allows the system to bleed out any air by releasing the bubbles into the tank. If that doesn’t do the trick, remove the inlet hose at the tee fitting and manually pour in some water and reconnect it. If that doesn’t do it, your pump has failed. Because the Ollie tank is so long, and the water is literally sucked out close the rear, it often gets air in that hose when traveling with a partially full tank (as the water sloshes around). This may not be related to your problem, but you need to know how to fix the airlock if it doesn’t correct itself by opening the sink faucets. Changing the pump is simple but does require making two crimped wire connections. John Davies Spokane WA Pump primed as suggested. Now we have water from the fresh water holding tank but still no pressure when city water is connected?? Waiting g to hear from PTT 1 George and Melinda Pierce 2022 EII hull 1171, 2021 Ford 150 Hybrid with Pro Power Onboard
MnG KY Posted July 10, 2023 Author Posted July 10, 2023 6 hours ago, MAX Burner said: FYI: We had a similar condition where there was 35-40psi at the spigot, the water pump would run when a sink valve was open (so we knew it wasn't air locked), but flow was weak (if any) from the toilet, showers, bath/kitchen sinks. We went around to each point of usage and cleaned out debris which had accumulated at the mesh screens - including the one at the rear of the toilet. The debris appeared to be a white substance possibly calcification from a water line on the downstream side of the water pump. Don't know for sure. Anyhow, after removing the blockages - we no longer have "low-flow sadness." Checked all points of usage and sorry to say, but no debris 1 1 George and Melinda Pierce 2022 EII hull 1171, 2021 Ford 150 Hybrid with Pro Power Onboard
Moderators SeaDawg Posted July 10, 2023 Moderators Posted July 10, 2023 You should not have the pump turned on with city water connection. (See @mossemi post.) When we get airlock in the cabin cold springwater system, we turn only one cold faucet at a time. It starts slow, then goes on. Trickle eventually turns to a stream. It may fill your greywater, so be careful there. You can leave grey water valve open, not black, if on full hookups, connected to septic. If you've truly checked screens, and have no debris, airlock is the most likely culprit. Especially if you've always used softened water, heretofore. 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
dewdev Posted July 10, 2023 Posted July 10, 2023 If you have been connecting to the City Water Connections at campgrounds that have hard water you may need to do a vinegar flush as john Davies mentioned to clear the water lines. FYI, I believe this is something that OTT does as part of their yearly maintance service. 3 Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
MnG KY Posted July 10, 2023 Author Posted July 10, 2023 2 minutes ago, MnG KY said: Pump primed as suggested. Now we have water from the fresh water holding tank but still no pressure when city water is connected?? Waiting g to hear from PTT 1 George and Melinda Pierce 2022 EII hull 1171, 2021 Ford 150 Hybrid with Pro Power Onboard
Moderators SeaDawg Posted July 10, 2023 Moderators Posted July 10, 2023 Are you sure you are connected to city connection, or filling the tank? City water supplies its own pressure, from the tap. From the tank, the pump must create the pressure. On city water, the pump should not be engaged, and should not run. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
MnG KY Posted July 10, 2023 Author Posted July 10, 2023 End of story... reprised the pump and have plenty of pressure at all outlets when using fresh water tank. City water still a trickle. OTT suggested getting a winterization hand pump and doing a vinegar flush thru city water inlet. This will have to wait until we get back to civilization (or find a hand pump to borrow). May try pouring vinegar into a hose hooked to city inlet then force it thru with city water pressure. We'll see. Thank all for suggestion! 1 George and Melinda Pierce 2022 EII hull 1171, 2021 Ford 150 Hybrid with Pro Power Onboard
Moderators SeaDawg Posted July 10, 2023 Moderators Posted July 10, 2023 If that is working, I suggest, til you "get back to civilization,: that you simply work from the tank, as we do. Change up the incoming source to tank fill. Can't leave it running 24/7, or you'll have a huge mud puddle under the trailer. Fill the tank til overflow starts, and turn off water supply. Good luck. 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Frank C Posted July 10, 2023 Posted July 10, 2023 1 hour ago, MnG KY said: End of story... reprised the pump and have plenty of pressure at all outlets when using fresh water tank. City water still a trickle. OTT suggested getting a winterization hand pump and doing a vinegar flush thru city water inlet. This will have to wait until we get back to civilization (or find a hand pump to borrow). May try pouring vinegar into a hose hooked to city inlet then force it thru with city water pressure. We'll see. Thank all for suggestion! There are one way check valves on each of the inlets (fresh tank fill inlet and city water inlet). That check valve on the city inlet may be bad, or it may be clogged from contaminants or calcium buildup. Unfortunately it’s only accessible by removing the floor in the basement storage area. 3
dewdev Posted July 14, 2023 Posted July 14, 2023 When I bought my Ollie used, it came with a winterizing hand pump but I am not sure if the previous owner bought it or Oliver provided it. Never-the-less, a hand pump is easy to buy at RV shop stores or on Amazon. 1 Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Moderators SeaDawg Posted July 14, 2023 Moderators Posted July 14, 2023 46 minutes ago, dewdev said: When I bought my Ollie, it came with a hand pump. Not sure if that is true for the 2022 year Olllies. A hand pump is easy to buy at any trailer repair shop store or on Amazon. What kind of hand pump? I'm curious. We have a manual foot pump in our sailboat, for the kitchen sink, only. Backup system. Only used it a few times, other than testing, annually. Nice feature, though. Oh, you probably mean a hand pump for winterizing? 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
dewdev Posted July 15, 2023 Posted July 15, 2023 16 hours ago, SeaDawg said: What kind of hand pump? I'm curious. We have a manual foot pump in our sailboat, for the kitchen sink, only. Backup system. Only used it a few times, other than testing, annually. Nice feature, though. Oh, you probably mean a hand pump for winterizing? Yes, I meant a winterizing hand pump. Mine is a Camco brand which can be found on Amazon. 3 Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
