MAX Burner Posted November 3, 2023 Posted November 3, 2023 (edited) After detailed discussions with @Geronimo John regarding a DC-DC Charger installation, we finally got around to making it happen. There's a ton of posts on this mod/upgrade, so we're not going down the rabbit hole to the end - just saying that it's a worth while mod to consider. Essentially, our concern was the 12AWG DC circuit from the 7-pin connector supplying an inadequate DC current to the OTT while towing, especially during the hours of darkness when there's no solar input to the battery bank. So, we decided to go with the Victron 12/12 30amp Bluetooth unit to be compatible with our other Victron devices (Smart Shunt, MPPT Solar charger, and the Cerbo S-GX multiplexer). We decided to upgrade from the OTT factory PWM solar module controller to the Victron MPPT unit. We also added the 7" Victron Touch to monitor all our AC and DC input/output activity which has been a game changer for us. Here's a series of pix that may satisfy the curiosity of those interested in efficiently charging the battery bank. FYI: We've got 3x BB's and ran 1/0 cables from the TV's smart alternator to an Anderson plug installed at the hitch, then 4 AWG cables from the Anderson through a Blue Sea Cable Clam to the Victron DC-DC charger installed under the aft dinette seat. The cables were snaked from the forward bulkhead under the toilet to the forward dinette seat, under the dinette table, to the aft dinette seat area: Below shows the location for the Victron Cerbo S-GX Touch Screen... This is the location where we mounted the new Victron MPPT Smart Solar Charger, upper street side compartment where the old PWM solar charge controller was mounted: We mounted the Victron remote solar controller monitor to the right of the Touch Screen... Building the Anderson plug for the OTT with 4AWG cables... Below shows the Blue Seas Cable Clam hull penetration adjacent to the 7-pin cable... Victron DC-DC Charger mounted on the street side wheel well/aft dinette seat next to the Progressive surge protector... Note the 50amp breaker between DC-DC Charger and the battery bank. We installed another 50amp breaker between the TV alternator and the Anderson connection: Pulling 4AWG cables from the hull penetration under the head sink thru the front of the toilet and to the aft dinette seat area... Thanks to @ScubaRx - Steve gave a great suggestion for snaking wires through challenging areas using a stiff plastic strap for securing pallet loads... One and done. I'm going for a cold one... Edited November 5, 2023 by MAX Burner Fixed a typo... 3 7 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Rivernerd Posted November 3, 2023 Posted November 3, 2023 Impressive. The documentation of your work is clear and easy to follow. It reminds me of similar posts from John Davies, which is high praise! 1 1 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
Ronbrink Posted November 4, 2023 Posted November 4, 2023 19 hours ago, MAX Burner said: we decided to go with the Vicron 12/24 350amp What is this referencing? Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Ronbrink Posted November 4, 2023 Posted November 4, 2023 20 hours ago, MAX Burner said: We installed another 50amp breaker between the TV alternator and the Anderson connection: I originally had a breaker at the battery on the cable leading the rear bumper Anderson, but excessive engine heat oftentimes would cause it to overheat and trip. Resorted to an ANL fuse, problem solved. 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
MAX Burner Posted November 4, 2023 Author Posted November 4, 2023 2 hours ago, Ronbrink said: excessive engine heat oftentimes would cause it to overheat and trip. FYI: We traveled 285 interstate miles yesterday, ambient temps ranged between 50 - 75F, the breaker didn't pop. We'll need to wait until next spring/summer for the higher temps to see if engine heat will cause it to trip. For now, we seem to be fine with the breaker as is... 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
MAX Burner Posted November 4, 2023 Author Posted November 4, 2023 3 hours ago, Ronbrink said: What is this referencing? Sorry, this was referencing the Victron DC-DC Charger model... 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Ronbrink Posted November 4, 2023 Posted November 4, 2023 12 minutes ago, MAX Burner said: ambient temps ranged between 50 - 75F, Right, the extreme summer heat here in Texas this summer was a bit too much! Just know the fuse option is a good fix. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
MAX Burner Posted November 4, 2023 Author Posted November 4, 2023 @Ronbrink: Good call, brother. The Blue Sea Systems ANL fuse is on our radar screen. TKX! 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Geronimo John Posted November 4, 2023 Posted November 4, 2023 8 hours ago, Ronbrink said: I originally had a breaker at the battery on the cable leading the rear bumper Anderson, but excessive engine heat oftentimes would cause it to overheat and trip. Resorted to an ANL fuse, problem solved. 6 hours ago, MAX Burner said: FYI: We traveled 285 interstate miles yesterday, ambient temps ranged between 50 - 75F, the breaker didn't pop. We'll need to wait until next spring/summer for the higher temps to see if engine heat will cause it to trip. For now, we seem to be fine with the breaker as is... This past summer, we traveled in temperatures exceeding 100F. Our breaker for the 4 AWG DC home run is located just aft of our F-150 engine bay battery. The breaker and system worked like a champ. GJ 1 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ronbrink Posted November 5, 2023 Posted November 5, 2023 3 hours ago, Geronimo John said: The breaker and system worked like a champ. All or part of the issue I experienced may have also been due to the quality, or lack thereof, of the breaker initially installed. To that point, I had another breaker tripping at the DC-DC after switching from a 20A to 40A charger. Upon research, I learned that this was a common occurrence with use of ‘cheap Chinese’ breakers and the remedy was installation of a ‘quality Blue Sea’ breaker, which resolved that problem. I should mention that with the 20A charger install, I took cable size into account to adequately accommodate any future upgrade in house battery amp hours and thus, a step-up in charger output. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Geronimo John Posted November 5, 2023 Posted November 5, 2023 15 hours ago, Ronbrink said: we decided to go with the Vicron 12/24 350amp I am not familiar with your unit. For our OE trailers, many of use the Victron Orion 12/12 DC to DC units. And NON of them can handle 350 amps. You must have a PeterBuilt to be working cables that size at 12 or even 24 volts. Just having fun. But it would be nice if you you would add your TV and Trailer info to your tag line. See above other posts for good examples. 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Geronimo John Posted November 5, 2023 Posted November 5, 2023 1 hour ago, Ronbrink said: I should mention that with the 20A charger install, I took cable size into account to adequately accommodate any future upgrade in house battery amp hours and thus, a step-up in charger output. Also interested in what size cables you used and what charger you would use to get beyond the Victron Orion 30 amp units on the market. BTW, great fuse unit. GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ronbrink Posted November 5, 2023 Posted November 5, 2023 10 hours ago, Geronimo John said: I am not familiar with your unit. Actually, this quote “we decided to go with the Victron 12/24 350 amp” was that of MAX Burner. I too questioned this, he replied it referenced the charger model. This was obviously a typo and edited to 12/12 350 amp, but his pic shows the charger as a 12/12-30. This should ease any concerns of a “PeterBuilt” signature OTT out there! As for the “tag line”, I need to figure out how to add that, but for now: 2012 Chevy 1500 Silverado 4x4; 2020 OLEll, 579, Twin. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Ronbrink Posted November 5, 2023 Posted November 5, 2023 10 hours ago, Geronimo John said: Also interested in what size cables you used and what charger you would use to get beyond the Victron Orion 30 amp units on the market. I recently replaced my Renogy 20A DC-DC charger with a Renogy 40A model to accommodate a new 460Ah LFP house battery bank upgrade. With the original install, the recommended 4AWG cable, specified for use of a 40A charger, was used in anticipation of this charger upgrade when a switch to lithiums occurred. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
MAX Burner Posted November 5, 2023 Author Posted November 5, 2023 47 minutes ago, Ronbrink said: we decided to go with the Victron 12/24 350 amp ...yup, yet another un-caught typo. Our's is a 30amp DC-DC charger, I'll fix it post haste... TKX! 2 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Geronimo John Posted November 5, 2023 Posted November 5, 2023 5 hours ago, Ronbrink said: I recently replaced my Renogy 20A DC-DC charger with a Renogy 40A model to accommodate a new 460Ah LFP house battery bank upgrade. With the original install, the recommended 4AWG cable, specified for use of a 40A charger, was used in anticipation of this charger upgrade when a switch to lithiums occurred. Impressive! What is the actual maximum amps are you seeing to the batters with the Renogy 40 amp DC to DC unit? GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ronbrink Posted November 5, 2023 Posted November 5, 2023 31 minutes ago, Geronimo John said: Impressive! What is the actual maximum amps are you seeing to the batters with the Renogy 40 amp DC to DC unit? GJ Here’s a screenshot of the Victron app showing 43.29A with the engine held slightly above idle, with some fluctuation to 40A. At idle the value settled down into a range of 33-36A. The next screenshot was taken 14 minutes later with a 1% increase in charge. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Geronimo John Posted November 5, 2023 Posted November 5, 2023 Getting the full capacity of the DC - DC charger flowing to the batteries is an indication that you nailed both the installation and set-up. I'm running #4 AWG copper welding cables full length both ways (To and From the TV and Ollie batteries. But not getting anywhere near the 30 amp rated output of the Victron Orion to our three 100 AH BB's. Suspecting my settings are the issue..... GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ronbrink Posted November 5, 2023 Posted November 5, 2023 1 hour ago, Geronimo John said: Suspecting my settings are the issue..... Agree, had to configure the five dip switches to charge lithiums with the Renogys, the Victron may have something similar to set in the Smart app. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Ty J Posted February 19, 2024 Posted February 19, 2024 I purchased also the Orion dc to dc charger 30 amp , but I charge from a spare power station I have. Victron has new DC to DC charger 50 amp that is scheduled to be released in us next month. Its 98 percent efficient compared to existing 82 percent. Lower temperature from high efficiency. I preordered it, of course they improve it. It also will tie into my victron components . Great Job on your install. 6 2021 Legacy II Hull #728 Pulled by 2015 Toyota Tundra 5.7 with 6.6 bed with Decked pullout. 300 Watt Bouge cigs flat solar. dual 30# propane tanks w/GasStop safety devices and Mopeka tank sensors, Victron Multiplus II 12volt., 400 x Battleborn Batteries ,Victron SmartShunt, Victron cerbo and screen. 2 x Victron Smart solar 100/30 and 1 x Smart solar 100 x 15. 800 watts ground panels. Mopeka tank sensors x 2 , Tempature sensors fridge battery compartment Ruuvi tags with fans. 12 volt Nova Kool refrigerator. Tosot A/C. Pecron E3600 + 2000 and 2000 Batteries with victron Orion 50amp dc to dc charger.Electric water valves and IRVWPC2 water pump controller. Truma on demand water heater. Added outdoor side Table. Bumper Toolbox, and Many more mods thank you contributors!
rideadeuce Posted May 19, 2024 Posted May 19, 2024 (edited) @MAX Burner I just noticed that you installed a non-isolated DC/DC charger. The newly released Orion XS 12/12 50amp charger is only available in non-isolated version and one of the requirements is that the starter battery and house battery share a common earth ground. Did you just run your black negative from the TV battery to the negative bus bar => charger negative to negative bus bar => then from bus bar to ground. I wasn't sure about the wiring. I have the new version that is non-isolated on order and was trying to figure how to wire. https://www.victronenergy.com/dc-dc-converters/orion-xs-12-12-50a-dc-dc-battery-charger Oh, and do you think it is possible to snake the 4 awg cables from the cable gland opening under the toilet to the aft dinette area without removing the bathroom shelf. Is it worth attempting? Or just remove it and proceed. Edited May 20, 2024 by rideadeuce 1 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
rideadeuce Posted May 20, 2024 Posted May 20, 2024 @Galway Girl Did you swap out your hot bus bar for better or more connections? Could you wire ORION XS Pos output directly to the post where the (2) 4 AWG wires are already connected. - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
Ronbrink Posted May 20, 2024 Posted May 20, 2024 (edited) 16 hours ago, rideadeuce said: Oh, and do you think it is possible to snake the 4 awg cables from the cable gland opening under the toilet to the aft dinette area without removing the bathroom shelf. Is it worth attempting? Or just remove it and proceed. I have successfully fished wires under the toilet; once through an existing gland for a an AC outlet at the front of the propane housing, and again when installing a double gland for the two cables leading to my DC-DC charger mounted within the aft dinette seat hatch. Using a light and mirror while leaning into the forward seat hatch, enabled viewing of the outer hull wall beneath the toilet platform to pinpoint where a hole needed to be drilled to avoid plumbing. View of AC outlet from inside housing. Exterior view. Double gland for DC-DC cable entry. Edited May 20, 2024 by Ronbrink 1 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Galway Girl Posted May 20, 2024 Posted May 20, 2024 @rideadeuce here’s how the wires looked after installation: The dc/dc charger output wire is the one with the red heat shrink on the end. The trick was to use the right size lug on the end to match buss bar bolts. The run was very short , < 2ft so a 6 x1/4” lug was used. 1 1 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine Aug 2024 on way to Nova Scotia.
jd1923 Posted May 20, 2024 Posted May 20, 2024 When I was first thinking about adding one of these, I assumed I needed an isolated converter to remove electrical interference between electronics in the TV (ECM, sensors, radio) and TT (solar charger, perhaps other). This article recommends the non-isolated merely based on cost. It does not address nor give example of possible interference. Isolated vs non Isolated DC to DC Charger - Which one to get (cleversolarpower.com) Then I installed a Pepwave router in the TV. I connected it directly to the TV battery. At first temporarily, thinking if there was interference with the router and ECM, I would just run the router when camped and eventually add an isolated AGM battery in the truck bed. I have not needed to do so. The TV with router on driving down the road has not shown any bleep of issue. We have received clean 5G while driving down the highway and no issue in the TV. BTW, I also have an Edge Juice w/ Attitude installed which is a supplemental ECM, with multiple sensors, gauges etc. and no interference between the Juice and Pepwave, of course all sharing the same TV ground The more I think about it, while towing/charging most everything is off in the TT (except solar charger), so what kind of interference could there be? Can anybody provide example(s) of probable relevant interference? If not, the Victron 50A non-isolated charger should be just fine, just as @MAX Burner's installation has proved. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
