Let us know how this lithium battery does for that price.. my AGMs are 4 years old now , might want to upgrade soon. Stay safe out there..
@skipster .. i have a Elite 1. Also. I cut a 6 inch opening, installed access hatch. Can get the bypass valve much easier. When i got our Oliver back in 2022 . I told them to move the hole they have back then closer to the valve.. dont know if was ever done. I know the pics i see of the LEII there is more room there, reaching from the top hatch panels under the bed.. i hope you get it fixed..
Scott_Kisling started following MaxxAir Fan Cleaning
I’ve noticed too.
water system leak at hotwater heater
Steph and Dud B replied to Skipster's topic in General Discussion
Glad you're getting it fixed. I have trouble reaching/turning the bypass valve, too. Very stiff. -
ScottyGS replied to Grizz000's topic in Ollie Modifications
Hey Everyone, I posed some questions about Alternator load with a DC/DC charger to Easton Ford at Inverter Services. Here is the info I got back from him: Q: When you install a DC/DC charger, what considerations should you have on the alternator in the Tow Vehicle? A: What I take into account is how much load you have on the alternator with all of your heavy electrical loads running, then I clamp the alternator wire to see how many amps it is pulling, I then Add 50 amps(DC/DC) and I see if that number is above 75% of the full capacity of the alternator. If its under everything is good. If it is over I would let you know that its over and if you didn’t want to do the DC/Dc I would take it off the ticket. If you still wanted the DC/DC it can be turned down to draw less from the alternator. Q: Can the Victron DC/DC charger be set to draw a certain amount of power. A: Yes, the Victron DC/DC charger can be turned down from 1 to 50 amps Q: My tow vehicle (2024 Nissan Titan XD) currently has a heavy duty 200 amp alternator. For me specifically, what would you recommend? A: For this vehicle I think one DC-DC would be fine no issues. If you want to have two DC-DCs I would want to clamp the alternator wire to make sure that we are not cutting it close. (2 dc/Dcs would equal up to 100Amps but it is highly programable to set it anywhere from 1-100) My plan going forward would be to have the alternator load tested and if it's within parameters, fine... if not, I will ask them to turn down the DC/DC charger to the appropriate number until I can arrange an alternator upgrade. Hope this helps to answer any Alternator questions anyone else may have. Happy Camping, Scotty - Yesterday
In Junei we enjoyed touring St. Elmo, Buena Vista, Leadville then up to Rifle CO. All were amazing. Oddly, the highlight was Rifle CO. For sure worth a few days to hike the Falls Trail and other smaller ones as well. Recommend staying at the Rifle City owned park for a couple of days. Not a bad drive to Grand Junction. Reservations recommend for weekends for sure. During the Monday to Thursday there are occasionally spaces. Primitive but nice camping for sure. It is full weekends by the rock climbers who call the area a meca for their sport. Be sure to hike down trail that follows the river to the Falls below. Explore the below falls areas for bear caves. Amazingly beautiful hike along the river. Takes about 90 minutes tops. GJ
so after consulting my chat ai. i decided fixing it myself would be a big problem for me so i am taking it to bish rv repair in bozeman montana . also having them make it easier for me to access the inline valve for bypassing the tank. I cant get my fingers on it to turn it on and off. very tight. also anther problem is the black tank shut off valve does not close all the way and the dump hose is always full so hope they can repair these issues. so thanks and I appreciate the help and advice
Skipster started following water system leak at hotwater heater
how do I access the fittings on tbe water heater. I can see a leak either the blue or red hose going into the insulated water heater. is there a utube video on how to get to those fittings. I have trouble turning the valve off for water going into water heater and now there is water spraying out of the blue hose connection.. how do I get to it to repair. my hands won't fit anywhere in there. do i take the styrofoam insulation off to get more room so I can repair the fitting. no idea. or should I take it to bish rv repair in bozeman,mt.. and let them repair it
I noticed that Oliver is getting active on X.
- 1 reply
- 1
Lost Mine trail was our favorite!
I got the Oliver into a tight spot on a rough road in this one...
Problem solved! I took the Oliver to a highly-rated solar installer in our area and he solved our problem. Galway girl was correct, the internal fuses (there were two) in the Xantrex inverter were blown. The service tech had another identical inverter on hand (he had replaced it with a Victron) and used those fuses, since he didn’t have new replacements in stock. We also had him replace our AGM batteries with a Vatrer 12V 300AH Bluetooth LiFePO4 Self Heating battery (only $599) and a shut off switch, so I don’t repeat my reverse-polarity blunder when it goes in storage. Thank you all for your help. Heading up to northern MN for some mountain biking next week.
- Last week
Haven't bought anything yet, just still in the beginning of the planning stage. And that King antenna was removed within days of buying #45... Ended up bringing it to @mossemiwho also lives here in Tampa. Have to get my son off to college and complete the move to our new place in Floral City Fl, but once that's done, upgrades will be priority #1!
The 3K model is enough, especially with your efficient Turbro inverter A/C (or your new Chill). I hope you bought one of the open box/used MP2s at half price! With the 4K model out, look for deals on the 3K models coming soon! I just looked again at the picture of your beautiful hull #45! Remove that king antenna and mount solar panels sideways. I'll bet today you can get near 800W up there! Install two drive motors so you can pitch the panels up on both left or righthand sides! Would be so cool. Consider my brain picked (just for now)! 😎
Not that we need this much power, but a new Victron Energy MultiPlus-II 12/4k/160-50 120V just came out for $1,105 (no tax or shipping cost with this vendor). It's at a good price, having paid $997 for the 3K model July of 2024. Also, very good customer service with InvertersRUs. They serviced a warranty replacement for me on a small Victron MPPT SC. All I had to do was to email the pic of the Victron Connect app screen. They shipped a new one out immediately with return label. It provides 4KVA (3.4 KW) inverted power and can charge up to 160A. It's 2" longer, the same width and 3/4" taller, plus 7 LBS heavier than the 3K model that several of us have installed, so it will just fit in the streetside basement. With a whole lot of LiFePO4 Ahs, you could use this kind of power, if you're still running an ol' school single-speed compressor A/C and don't want to worry about what else you power up! No Soft/Easy Start needed with this bad-boy and you won't ever get stuck with a Multiplus failing for low voltage cutout. With required input as low as 9.5V your batteries may cutout before the MP2 ever will! Wow, checking my thread above on page 1, it was two years ago to the day, when I finished my installation. We are rarely plugged in and never turn it off, so our MP2 has run 24x7 for a full 2 years now, always providing service without issue. 😎 https://invertersrus.com/product/ve-multiplus-ii-12-4k/
Congrats
Made in USA leaf springs
thompsonkd replied to Mountainman198's topic in Mechanical & Technical Tips
We also recently had Alcan upgrade our leaf springs and axles. Having a 2018 trailer we had the old 3000 lb axles and of course the 4 pack leaf springs installed by Oliver. It took us a while to decide to have the work done, but it was becoming obvious that we were due for a broken leaf spring or two without an upgrade. Upgrading the axles was an easy decision since the new axles provide better brakes and (hopefully) less maintenance. It’s a relatively quick process to have Alcan do the work; it takes about 2 hours. Lew told us his wife had worried about people driving to town to purchase a torque wrench and socket pulling a trailer so he now sells a decent torque wrench and the necessary socket to perform the required torquing for $50 dollars. He also provides a sheet with all the torque specs and is available for any questions. Tucker the technician who performed the work for us was available as well to answer any questions that we had. We did notice that the new running gear is much stiffer. We aired down our tires, and have done the preliminary torques. We would definitely recommend Alcan. Seems easier to have them do the work but as has been detailed by others, Alcan will ship so folks can do the work themselves or have a shop close to them do the work.Lew told us he is doing about 1 Oliver a week now, plus providing gear for the new Oliver Apex. I guess 38 pages of forum information pays off, for anyone who has the patience to read it all! Alcan suggested we go to Randy’s South Side Diner in Grand Junction while the work was being done. Decent local restaurant for breakfast! -
taylor.coyote replied to Mountainman198's topic in Mechanical & Technical Tips
I think it was Mountain man that discovered Alcan Springs and made the first post in the forum. some 36 pages later in the forum, seems the has provided a great service to Oliver owners and a real bump in sales for Alcan. Thank you Mountain man, for your contribution to all of us that have broken springs and now running on Alcan. Additionally, I think the folks at Alcan might consider some recognition and maybe a modest commission for purchases made by Oliver owners. Best to you and happy torquing Mountain Man -
That is a good A/B test right there. I have not yet pulled the trigger on this, but if/when I do, the "short gutter" looks like the winner.
Congrats on the new running gear. Best money we ever spent on labor was having Alcan professionally do the work on our Oliver. Good for you. The torquing is the easy part. Safe Travels!
Oliver Rally Registration Ends in Just 10 Days! Our Oliver Rally is coming up October 21–25 at Lake Guntersville, and we only have a few spots remaining! If you’d like to join us, be sure to register for the Oliver Rally here: https://olivertraveltrailers.com/events/oliver-owners-rally/registration/ You’ll also need to reserve your campsite directly with Lake Guntersville Campground. Registration closes Thursday, August 20. After that, we’ll be finalizing T-shirts, giveaways, activities, dinner plans, and all the fun details for the rally. Don’t miss your chance to camp, connect, and spend time with all of us. We’d love to see you there! ❤️ #OliverTravelTrailers #OliverRally #LakeGuntersville #OliverFamily
