We did the same thing years ago. Has worked great. So well I forget it was an issue.
Touch up for INTERIOR caulk filled holes
jd1923 replied to ScottyGS's topic in Mechanical & Technical Tips
Scotty is camping and he might not have a pic before he filled the holes. I filled mine too but have this picture from before. You can see two holes in front and look closer to see two more on either side. The Dometic P2 was twice as big inside and out. There are two more in back 6" beyond the much smaller Chill Cube. Notice the headroom too! Another reason it's quiet is the air handler/fan are not hanging down into the cabin interior like ALL the others! Scotty got his installed at summer end, and he was only able to test the A/C minimally. He got the newer Heat Pump version and we hope to hear about that function soon. The link below goes directly to page 2 of my Chill Cube post which shows the installation. Pages 3-4 have some of my reporting on its efficiency. We ran ours all summer (all of 2026) and we just LOVE it! -
Used Oliver advertisements Return to the Oliver Forum
jd1923 replied to dewdev's topic in General Discussion
There are number of brands in the market that refer to products as "extended season" campers. Lance is one of those but there are few others and this is where at most I would categorize the Oliver, although admittedly one can get by for a day or so in some rather cold temps if you can put up with the noisy furnace if not plugged into shore power with AC heat source which we have also done a few occasions.
thompsonkd replied to ScottyGS's topic in Mechanical & Technical Tips
Hey Scotty. Would you mind posting a few pictures of the air handler unit in the cabin after your new Chill Cube was installed, especially with holes you filled? As you mentioned above, there is a bit of difference between the Penguin and the Chill Cube inside. The Chill Cube is intriguing and seems potentially like a good choice, especially for energy management. And have you had much of a chance yet to try it out? I’d be interested in further reports. Thanks. -
We all use our Oliver's differently, in different environments, with differing expectations, and we all measure standards to those expectations. Four seasons does include "winter" and in this huge continent we can be in south Florida or North Slope Alaska and still be winter- with vastly opposite conditions. I would not expect any Oliver to adequately handle Ice fishing conditions unless modified to do so, nor a Montana winter on a daily basis. So, definitions matter, and four seasons means to me, in stock form, the Oliver (2027 models) will handle a few very cold days below zero, off grid. Late fall, at elevation, its 20 degrees at night - warms to low 50's in day - we get out hike, fish, whatever, and at night we are warm and secure. Snow, rain, ice, in moderation, not an issue. After a few days, we head out to the next spot, similar low temps and warming days. My expectations are met. If you need more - then a specialty product is needed. Yeah but 4 seasons? Ok, got it. I have enough experience in really cold weather - RV, tent, backpacking, - or otherwise to know matching equipment to the conditions is key. My two cents - Oliver within reason is more 4 season capable than most, but it is not a Montana winter home, nor an ice fishing platform in Wisconsin. Perhaps it is a 3.5 season RV? RB
I don't know how the newer models are designed, but our hull 45 is certainly not a 4 season camper. No ductwork at all to heat the basement and minimal insulation under the tanks. We have camped in the 20's and our heat pump kept the cabin as warm as we wanted but I'd be making some mods if we ever planned on camping in lower temps. I'd probably run one of those portable diesel heaters and install ductwork that branched to heat both the basement and the cabin.
Made it to Arches and Devils Garden Campground. First time here and this is a great campground and a stunning area.
Well, I guess I jinked myself, or at least proved why having a TPMS is valuable. On the trip from Utah to Grand Junction (to get us some new leaf springs), our TPMS went off, and my wife said, "One of the tires is down to 35 psi... now 30... now 25," all in the matter of 30 seconds. We pulled over, and sure enough, the tire pressure was dropping fast. The valve stem had ripped and started leaking. We did enough of a patch-and-fill job to get off the side of the freeway so we could change the tire. Glad we had it, so this stayed just an inconvenience! Also, so glad I had done dry runs of changing tires at home so whenever this day did come I was confident we could get it addressed. The next day I went to Les Schwab and got some nice steel stems put on all the tires!
Correct @BackofBeyond and just as importantly this thing is built like a tank ready to go anywhere. We have a local dealer nearby and they are the real deal. Their claims are not smoke and mirrors either based on the conversation I had with the dealer. While I don't doubt many have been sold to people with half ton trucks the reality is you need a much heavier duty vehicle to tow them safely and legally. Their frame, hitch and suspension does NOT allow for a WDH. Don't recall the specs on all of them but am fairly certain the tongue weight on all of their models exceeds 500lbs.
- Last week
Sorry you won't be there, and I hope you feel better soon. It seems to me this entire year has been full of false starts and changes in plans. I sent you a message.
@Olive2Roam and @topgun2 Krunch and I made it as far north as Murfreesboro on our 2026 OTTO Rally trip and while camping at Monte Sano SP in Huntsville, I had a recurrence of pseudogout effecting my hands, hips and shoulders. As a result of this, we headed back home and will miss the rally. Would you please find topgun2 at campsite E36 and handoff the Truma winterizing accessory and he will send it to me. Thank you for generous gift, Mossey
Dean and Mary changed their profile photo
Interesting that the Imperial RVs came out of the Ice Fishing market. Looking at the various models this is the design intent :"Four-season performance is standard. Nearly 3 inches of composite insulation, thermally broken windows, and heated water tanks keep the OB120 functional in extreme temperatures, with the cabin and systems engineered to perform down to -40°F. This cold-weather capability is no accident — it's the direct result of Imperial Outdoors' roots in building ice fishing structures designed to survive Wisconsin winters, applied to the most compact trailer in the lineup."
That is a splice connector, specifically a Wago brand lever nut splice connector. Considered a good easy to use connector joining two or more wires together.
No worries at all! Honestly, a loose battery connection is one of those things that's so simple it often gets overlooked. We've all chased complicated problems only to find out it was something basic in the end. I'm just glad you found the issue and got it sorted out. You definitely didn't waste my time. Troubleshooting is just a process of eliminating possibilities until the culprit shows itself. Great news that you're back up and running. Thanks for letting us know what the fix was!
Two weeks of feedback Apex #2 (Hull 1739)
Dennis and Melissa replied to Sentry62's topic in Getting Started
Living in Montana I do NOT think of the Oliver as a 4 season camper. Yes you can camp in moderately chilly weather as most of us have done at one time or the other but 4 season no way. If you want a true 4 season camper look at Imperial Outdoors and a few others built to similar standards. On our 2015 EII we have the suburban furnace installed which is only 16K BTU but runs at 40-50% efficiency cutting that value in half, and believe it is considerably undersized and noisy to boot. Not sure what they install on the newer models.
High Pointe Convection Oven Tripping CGFI Breaker
Thanks it does. It gives me some structure to start with. I will ohm on a cold baseline with several components before I try heating. I wish it would fail on the bench. It would make it easier to troubleshoot. Maybe decreasing the amount of airflow on the back and sides may simulate the Oliver environment and help to cause the failure. I can hold the cover and 2 shields in place with 4 screws. Try to induce the failure, and then remove the covers and have time to do the testing. Otherwise I will run it in Grill/convection mode for 20 minutes then remove the covers, and then use a heat gun on possible failure points. Question: If the cord was the failure point, would I feel more heat in the area in question on the cord? -
Snackchaser replied to 2008RN's topic in Mechanical & Technical Tips
We will be traveling overseas in a few days and I may not be able to respond for a while. Hopefully we'll be returning with our daughter who has been waiting 10 years to get through the legal immigration process🙏 Anyway, you're on the right track now, only remember that a current leak does not have to be on the specific component related to the mode. It also could be related to the neutral which is common in all 3 modes. Albeit, a neutral ground fault needs to be lower resistance for current to take the ground path. Think of it like this; 1 ohm or less is a direct short, under 1k on the neutral could cause a ground fault trip, anything under 25k on the hot side will cause a ground fault trip, anything up to a meg ohm is not great, but it might not trip the GFCI, and over a meg ohm is good insulation. Your right to relate the problem to heat, only the heat is just exposing an insulation weakness that is causing a ground fault enough to trip the GFCI. Do your testing after the breaker trips when it is still hot, or try a heat gun all over suspect insulation. Test hot and cold, and remember the resistance will change a little with temperature swings. Look for more significant changes. Since the power cord might have been pinched the first time you removed the oven, the heat could be softening the insulation at the pinch point causing current leakage there. It might not be easily seen, so It's worth examining very closely or just replacing the cord as a cheap first step. Hope that gives you something to start with. Good luck! -
We have a mixture in our home, with CFGI outlets, and a GFCI breaker. I added a pole barn for the cars and where I do most to the mechanical work. I have several 20Amp GFCI circuit breakers in the panel for outlets. -
Thanks I will get back with you. My electrical knowledge is very rudimentary. I saw the capacitor and the large transformer that feeds the microwave emitter. My spidy sense was turned on immediately. I remembered being warned years ago: use only one hand when working around capacitors, the other is behind my back. Thanks for reinforcing the safety. I spent a few years around ME, EE, and Electrical techs, and electricians, but that was 30-40 years ago. They help me with a couple of different projects. I built a timing comparitor circuit with relays to turn off a cleaning pump while an automated feeder was running on an 150 gallon tank. I also rigged up a bunch of heavy duty resistors in parallel to a motor and measure voltage drop (I think) across the resistors to calculate amperage of the motor under different loads. Since my microwave failures happened in 3 different modes grill, convection, and microwave. Heat and moisture would be involved in all 3. Although each has it's own separate heat source. ie: 2 different burners, the microwave emitter. The way I am doing testing only one heat source is on at a time, and the convection fan only operates in the convection mode. There is a main fan (below the electrical input PCB. that operates when any of the 3 modes are active. I haven't looked closely at this fan. It does have an external winding next to the fan in the fan assembly. I haven't seen this before. I will take a physical look at the burners, insulation, and closeness to the chassis. I will look for anything that could be close to shorting to ground. I will inspect the main fan assembly while I'm mucking around. After that I will contact you! it might be a couple weeks, I got some other stuff planned. -
OTT installed our microwave on an independent run to the 120VAC power panel, using white Romex (14-2 AWG). On a separate 14-2 run are the 110V outlets. OTT wired two (2) hot/black wires to one 15A breaker. In how they wired this, better not run the microwave and a blow dryer at the same time! 🤣 Wiring to the 20A breakers, for A/C, HWH and Fridge, is the yellow Romex (12-2 AWG). I understand OTT in later years used 12-2 Romex for all 120VAC wiring. The first outlet which is under the dinette is a GFCI outlet, so all other downstream outlets are hence GCFI protected. Our microwave was not wired by OTT to a GFCI circuit and therefore neither is our new air fryer. Since I disabled the PD converter when installing a new inverter/charger, I used the 15A circuit breaker for the converter now for our oven. Now we can run the oven and blow dryer at the same time on the two 15A breakers since the inverter can handle it. In our 1980 built home, we have one 15A GCFI breaker in the 200A panel. It protects 5 outlets in three bathrooms and 2 exterior outlets on the deck. There must be 150 ft of #14 wire connecting these 7 outlets. I guess that was local code 46 years ago. What I've read here is new homes now have GCFI outlets throughout the garage, bathrooms of course, and exterior walls, etc. -
It would be cool if you could troubleshoot your oven with Geoff's help! I'm sure we'll hear back on this. If you have to replace it, there should be several models that would fit. Now that you had it out, you know the internal dimensions. I was able to repurpose the OEM microwave grill to fit around our new oven (by merely cutting off the inside plastic tabs). I'm actually surprised OTT would install an oven in an uninsulated closed cabinet. I know some of the very early hulls had oven vents but they stopped that (history provided in the thread linked above). We had microwave only, so without the oven feature there is little external heat, no real need for proper insulation and venting. However, a convection oven is a different thing! I suggest any Oliver owner who has an oven and uses it for more than a few minutes at a time should add proper ventilation! Two 3" vents in the top-back corners truly allow the hot oven air to escape without needing a fan. Kiln insulation helps too. We use our oven regularly, running on inverter, 400F for 20 minutes or more and the cabinet surround and the kitchen cabinet above are just warm to the touch. 😎 Good luck with this, Bob! -
Most 30-40 degree nights when using the furnace we find that just cracking the Maxxair vent a tiny bit using the hand knob is sufficient venting to prevent humidity/condensation buildup. We never open it all the way with the furnace on.
