That’s great news! I hope your issues are resolved soon!
@DunnYet Open source - No, you should not leave the Truma winterization (bypass) filter or standard stainless steel filter installed all season long. [1] If you are actively using your RV during the camping season, you should be using the standard stainless steel filter (or the Truma Electric Antifreeze Kit if actively in use). The official winterization plug/filter is strictly designed to replace the standard filter for winter storage and is not meant to be run full-time. Keep these quick winterization rules in mind: For Winter Storage: Drain your Truma system and remove the filter cartridge entirely. Store the filter in a dry place inside your RV and leave the yellow Easy Drain Lever closed. Leaving any filter inside during freezing weather can trap water, expand, and permanently damage the unit. [1, 2, 3] For Active Winter Camping: If you plan to travel in freezing temperatures, you can use the Truma Electric Antifreeze Kit. This specific kit can be installed in place of your standard filter to keep the water heater from freezing without draining your propane. [1, 2] For Normal Summer Use: Remove the winterization plug and reinstall your standard stainless steel mesh filter before de-winterizing and turning your water system on for regular use.
Made in USA leaf springs
No worries, thanks yeah I did get clued into that trick. Worked great, the suspension quieted right down. Still a little creaky, suspecting the leaves are rubbing or maybe there’s a bit of grease missing somewhere. I noticed on the Alcan page they smartly put poly rub pads on the end of the leaves to avoid this. Well we’ll be in the neighborhood this summertime (roughly) so I set up an appointment to get fitted at Alcan. Full hog five leaf, who am I to argue with them? And I was thinking about when camping we’re going over weight anyhow with all the tanks and people in it. Plus I generally agree with having some extra margin and IIRC Alcan believes 20% is the right amount so OK. -
Thanks for sharing David, I just purchased a backup on Ebay for $25. If anyone needs a replacement or spare and can’t find one on the cheap, they are available on Amazon as well. https://a.co/d/00C38npm
Oliver's response has been outstanding. We are working together to address the issue. More to follow when I have a chance to provide a detailed update. Bob
jd1923 replied to Gliddenwoods's topic in Mechanical & Technical Tips
Just replaced the Blum slide on our nightstand drawer. This item is the OEM part replacement. Maybe I should have bought the 6-pack, LOL! The nightstand drawer and 5 kitchen drawers all use the 18" length, the short drawer uses the 12" Blum slide. https://www.amazon.com/dp/B0G7LQ3PQ4/?th=1 Lately, the drawer would open during travel so I suspected something was wrong. After removing the drawer (squeeze two orange levers underneath), I found the old slide was truly worn out. When fully extended the end would drop a couple inches. Not good! The new slide is in and now again it works great. But per the subject of this thread, OTT installed these slides with only three screws per slide! 😒 The slides are rated to carry 100 LBS, but three short #6 screws are certainly NOT! A couple year backs, working on a kitchen sink leak, I doubled all the screws on the kitchen drawers and went up one size. At the time, I forgot to do the nightstand drawer. The slides all wobbled a bit when unloaded with only 3 screws and I now contend it was the lazy installation that allowed this drawer to shake and eventually wear out the slides. These slides are substantial but need to be installed properly! BTW, Blum supplies 20 wood screws in these kits! 20 screws for 2 slides and 2 brackets not used for our application. I installed 8 screws on each slide! Why not? Blum certainly intends more than 3 should be used! I put 3 in the same holes to hold each slide in place and then drilled small pilot holes and screwed in 5 more (see pic)! Now this should last my lifetime. 😎 I suggest removing all your Oliver drawers, having at least 6 mounting screws per slide, 12 per drawer minimum. - Yesterday
Teaney Hull 292 started following Door window shutter
San Isabel National Forest , Cascade Campground near Buena Vista Colorado Gonna hit the nearby hiking trails, Ghost Town of Saint Elmo, Hot Springs Got the hang of the Ford 10 speed on mountain passes tow haul mode only , select M , 2nd gear off the top
Thanks a million for invite ! That is so kind of you ! we plan to stay in the Colorado High Country for most of the summer one of Therese days we will visit you in Prescott
Thanks very much @Patriot for this. It makes me wonder - I generally leave the “heater” filter in all the time regardless of season. Should I pull it for the “off season” and only put it in during the cold camping months? I only switch to the standard filter when running the decalcification cycle. Am I doing this wrong?
Thanks I will keep an eye on mine!
rideandfly replied to Snackchaser's topic in Ollie Modifications
Wired and tested the iRV62 today. Very easy to wire to Oliver wiring with AM/FM, DVD, and CD player working great with original Jensen TV and Jensen speakers! Great choice! -
Geronimo John replied to Gliddenwoods's topic in Mechanical & Technical Tips
Roger, thanks for the flowers... OH with small washers too! GJ -
Try unloading the fitting and likely you will get it to take grease. Sorry for speed reading this 36 page thread if you already tried this. GJ -
Part number of OEM Filter is AquaGo Replacement Filter # 77000-00251
Patriot started following Truma Aqua Go filter failed
This morning while doing a full systems ‘go’ inspection on Hull #634 XPLOR, I discovered when I configured the Truma water heater valve to the ON position, an impressive stream of water shot directly out of the Truma filter exterior housing. After a little troubleshooting, I removed the filter and discovered that inside the filter housing, a small black round piece of plastic had blown out of the filter housing. This rendered the filter useless. We have had 5.5 years of trouble-free service from our tankless Truma and this was a first. We like our Aqua Go. I am posting this in the event anyone should have the same issue with their Truma filter. I have the optional antifreeze filter which works in a pinch as a back up. If you do not have the optional antifreeze filter as a back up, you will be stuck like Chuck with no hot water. In order for the Aqua Go to work, it has to have the filter element. I contacted Oliver Service and ordered a OEM replacement and an extra back filter up of the exact one you see in the below pics. “Two is one and one is none.” 🫡🇺🇸 Replacement filters are $95.00 plus shipping. Thank you Mike Sharpe for getting my new filters shipped out. The tiny piece of plastic that broke loose. Here is the filter that failed. You should not be able to look through your filter. The arrow points to where this tiny piece blew out. There is no way to repair it. I pass this on, so that if you have this issue you can just replace the filter with a new one.
Tim, Oliver has gone to a newer Awning style window which opens at 90 degrees. It’s insulated and glass. I don’t have any additional info right now. I feel sure Oliver Service could provide you with more details. Cheers, Patriot
topgun2 replied to Lamar's topic in Mechanical & Technical Tips
Keep working with the folks at Oliver. It sounds like they understand where you are coming from and, in my experience, they will do everything that they can to get you to where you want to be. If for any reason this situation doesn't seem to be progressing towards your desired end, I would not hesitate to get Jason Essary involved. And, if that doesn't work then I'd write a note to Scott Oliver telling him (respectfully) the situation and request his help in getting your Ollie the way you want it. Be sure to let us know how this situation is resolved for you. Bill -
Not powering up is NOT the same thing as it taking too many watts overloading an inverter! Given it "does not come on" (at all), it's simply not wired to a circuit supplied by the inverter. If an appliance wired to the inverter pulls too much amperage, your inverter will start making noise and will shut down when overloaded, but it certainly will "come on." What were they thinking at OTT! And BTW, a 2000W inverter by definition will run an 1800W appliance! Given the True Induction cooktop is rated at 1800W, and it's a 2-burner cooktop, then each burner is rated at 900W. If OTT had wired the cooktop properly, you could certainly heat up water for coffee on one (1) burner and run the fridge at the same time! You will be well under 2000W! 🤣 Get OTT to wire this properly! I would just DIY, as I suggested in an earlier post, but you have to be concerned of warranty issues. We have the LP cooktop of course, but like Bill mentioned also have an induction cooktop that we plug in indoors or out. We also do not use our LP stove stove to heat coffee water (unless battery SOC is LOW). We love these products! 😎 https://www.amazon.com/dp/B07KSNTSVR/?th=1 https://www.amazon.com/Aigostar-Eve-Electric-Cordless-Boiling/dp/B07D3R7RZT/ https://www.amazon.com/Melitta-Pour-Over-Coffee-Stainless-Filters/dp/B0CSQLHFW9/ -
rideandfly started following True Induction Stove Top will not turn on
rideandfly replied to Lamar's topic in Mechanical & Technical Tips
I'm sure Oliver will resolve this cook-top issue, under warranty. We're like Mike & Carol, our propane cook-top has been very reliable. We use a portable 120V induction cook-top, too. -
Portable solar panel with legacy elite 2 platinum package
Dean and Mary replied to Brian H.'s topic in General Discussion
Thanks, Galway Girl, for the link to your solar panel kit and all the details. I found it very informative. Unfortunately, the cable is currently unavailable. -
Tom and Doreen replied to Brian H.'s topic in General Discussion
Yes, the cover has worked out very well. One of the nicest features is that there is a zipped door panel that allows access to the trailer when the cover is on which works great when checking on or working on the trailer during the winter. -
Mike and Carol replied to Lamar's topic in Mechanical & Technical Tips
The propane cook top has been very reliable and works well for us. -
DanielBoondock replied to Brian H.'s topic in General Discussion
Looks like you also got a branded cover add-on too. That’s nice, I need to get a cover -
It’s just a normal roller shade, nothing unique to Oliver, so doing a general web search on roller shades might help. Mine are working fine but I think (remembering to when I’ve used them before) if it’s kinda stuck just pull down to the bottom of the window to reset the mechanism. Regarding “the others retract to at least 3/4 of the way up” - I think you mean they leave 1/4 hanging when fully retracted? That’s not right, all of mine only leave an inch or two of the shade hanging. Anyhow so far been trouble free for me. The design has been around forever, seems like an early 20th century invention, anyhow should be easy to work with. No, interesting it has an even longer history
Thanks for all the replies. Sorry I haven’t updated sooner. We have been boondocking for several days. I have been in communication with support at Oliver. At first they didn’t understand why it wasn’t working. As they investigated they reported that it appears that the stovetop does pull 1800 w and overloads the 2000 w inverter. The only other major draw is the refrigerator. Even when I turn that off, the stovetop does not come on. I stopped at a Bass Pro the first day to pick up a small 2 burner propane stove so we could at least have coffee in the morning. Not what I was planning when camping. If I had known I would have asked for the propane stove instead of the induction stove. We have the Platinum pkg and I did ask sales at the dealer if people liked the induction stove and if I could use it boondocking. Answer was that it works. I noticed that the induction cooktop comes standard on the Legacy 2026. This isn’t working for us as designed. I have asked for this to be resolved…proper inverter set up or a propane stove retro fit. If you do much camping at Harvest Hosts, BLM, National Forrest, National Parks, etc. w/o hookups, it is a problem unless you run a generator. When we return from our travels we will see where Oliver lands on this. They are considering possible “upgrades” to our camper. I wouldn't see a resolution as upgrades, but will find out. When hooked up to shore power, the cooktop works great. But so far for us, most of our trip, was making coffee or cooking outside on a portable propane stove.
