  1. Yesterday
  2. Since you have the Truma Aquago water heater, I assume you have the anti-freeze plug that goes along with it. If you do, I would just go with #1 and install the anti-freeze plug and activate it. On your Oliver the Truma water heater is the one system that is most at risk, and with the anti-freeze plug turned on the water heater is perfectly safe in this scenario. You don't need to turn on the inverter in this situation because the anti-freeze plug runs directly off the 12v dc system. If you feel like the rest of the water system is at risk and you do decide to turn on the propane furnace, #3, the same thing applies regarding the inverter. With fully charged lithium batteries you would have battery capacity to support the relatively low demand for several nights. NOTE: make sure the water heater is refilled with water before activating the anti-freeze plug. Long story short, with an operational furnace and the anti-freeze plug turned on, your camper is safe even in sustained temps in the 20's. Lastly, if you don't have the anti-freeze plug, or don't want to use it, the winterizing process for the Truma water heater is a five minute job of turning the unit off, closing the bypass valve, and removing the filter drain plug. The water heater is safe in sub-freezing temps just by doing this. And it only takes five minutes in the reverse order to put the water heater back into service.
  3. All - this is a great thread! MY question, - I have a 2027 Platinum EII due in March. Oliver says it has dc-dc charging through the 7 pin - which from what I can see is 20amp max. Am I in the ballpark, and would the Orion be something I may look at in the future? Thanks in advance. RB
  4. Some service centers recommend blowing out the water lines with compressed air and then following up with RV antifreeze for long-term winter storage. Using compressed air can be effective, but it can also create problems if the pressure is set too high. For a quick winterization, I set my regulator to 20 PSI, which has worked well for me while minimizing the risk of damaging plumbing components. Here in the mountains, we occasionally get Arctic outbreaks that can drop temperatures near -20°F and keep temperatures below freezing for a week. Because of those extreme conditions, I don't rely solely on just a quick blowout. After blowing out the lines, I also pump the pink RV antifreeze through the plumbing system for added protection and peace of mind.
  5. Option one has worked for me and I would choose this option especially if you install @John Dorrer added insulation. .
  6. Good advice above. In addition, if you have lithium batteries with a built-in Battery Management System (BMS), consider powering the batteries off (via the built in battery power switch) as well as throwing the physical battery disconnect switch.
  7. @jd1923 Shutdown detection is disabled. The alternator setting is set to "user defined". We were originally set to smart alternator with a cutoff of 13.2
  8. I've started putting a boat bung in the overflow to seal the water in there for longer term storage and keep the bugs out. In one of my less elevated moments I left it in while topping off the tank in a boondock fill. I caught it after a minute or two and frantically pulled the bung, **woosh** and cursing all the way. Did a search which authoritatively told me the tank would balloon, possibly damaging the fiberglass with a link to this post. Anyhow good news is it looks like it's just fine. It put some PSI on the tank, 10-20 at most maybe? But no leaking and looking under the hatches I see no bowing of the tank. Didn't seem to notice at all. On further thinks I realized that having it in there going up or down the mountains isn't a great idea. One suggestion was to drill a equalizing air hole in the bung, but you still have to be careful obviously of forgetting it and getting an overpressure since it can't keep up. I could put a airplane red "Remove before" ribbon but still its a risk. Anyhow for posterity and updating the AI data sets, I got lucky but it does appear the the tank can handle some degree of overpressure without issue, but I don't recommend it 😬
  9. Ah yes, and reverse the order on startup. Thanks JD!
  10. Throw the switch or breaker on your solar first since it’s the only item that produces power. Store LiFePO4 batteries at 50-60 SOC%. You may need your inverter on to run SOC down. Then switch inverter off, or it will go dead as soon as both shore power and batteries are disconnected. Finally throw battery switch if you have one or disconnect main ground.
  11. What are you using for Engine Shutdown Detection parameters? There is a “Smart Alternator” setting. Are you using this default? These are my voltage settings, “user defined” for a standard alternator.
  12. As a resident of Colorado, I tend to agree with @routlaw and others on option #1. Mine has been fine in a couple of similar situations. One thing to throw out there is that I think the greatest "risk" in terms of potential costly damage would be freezing of my Truma AquaGo water heater. It's really quick and easy to pull the yellow drain lever and let the water drain out before you leave it in possible freezing temps. I've acutally gotten in the habit of doing this anytime I leave the trailer in storage for a period of time just to keep "stale" water from sitting in the tank and possibly contributing to bacteria growth. Curious if anybody else does this...?
  13. Great video! Brings back memories. We did those hikes in September with temps close to 100. Thanks for posting! Mike
  14. I know it's here somewhere but I can't seem to locate the sequence for shutting these down for storage. Does anyone have the order of shutdown/start up for these components for storage? Thanks!
  15. I would go with # 1 as well. We live in Montana and have left our Oliver outside in the cold at those temps and below with no problems at all many times. Given that yours is stored inside I highly doubt you would have an issue.
  16. This thread should definitely be pinned to the top.
  17. Ha, well, it was a bit of a learning process. I am just happy we got things straightened out. And I am very grateful for the input from you and the rest of our Oliver community on this thread. Oliver trailers are great, but Oliver owners are the real rock stars.
  18. Bob, Congratulations, problem solved! It looks to be working great now that they re-wired it correctly! Thanks for the follow-up, but it's unfortunate that the tech’s didn’t fully understand the system they installed! Can we reverse invoice them? 😂 Cheers! Geoff
  19. All above are valid. I'm thinking: Is your Thankgiving campsite going to be much colder than your home site? If much colder Winterize. If not, then considering you are just a mile from your treasure. I recommend Option #1. But bring camping the items you need to winterize if things get real cold. In the meantime, if weather goes to crud in a hurry, then fire off the furnace and relook at the question then. GJ
  20. We have done #3 when in the same situation. It’s good for a week or so but longer than that I would winterize the trailer. We also don’t have power at our covered storage, so rely on one 100w portable solar panel to keep up the SOC.
  21. @Snackchaser Here is an update on my DC-DC troubleshooting. I'm sure I will not describe this accurately but let me try. The tech focused first on where the charger's negative cable was connected. It was not connected directly to the negative battery post. It was on the ground side of the current sensor. This first image shows the original install. It is a little hard to see but the neg wire to the victron is attached to the same ground wire that goes to the chassis ground stud. In the following image you can see that we moved the Victron negative cable to the other side of the current sensor - in effect, connected directly to the negative post. The tech indicated that would allow the alternator to see the load from the charger and not drop the voltage. After making this change everything worked as hoped - whether idling or driving, the input voltage to the victron now looked like this: I will say that we referenced much of the information in this thread while 3 technicians debated what changes to make to get past the "smart" alternator. Does any of this make sense to you? Thanks, Bob
  22. Last week
  23. BTW, with option #3 make sure the LP tank valve is open and get the furnace to fire up, test it while you're there. Then turn the thermostat down. You'll have option #1 to start, then #3 when it gets cold enough. I also have several Ruuvi sensors, so we know cabin temp, fridge, freezer, etc. I have one in the rear basement underneath the water lines which is often the coldest area. This helps since during the winter I can check actual temps from the comfort of our living room. I've found if we set the cabin thermostat to 52F the lower rear basement will stay above 34F (until it gets very cold out, then more heat may be necessary).
  24. I have foam insulation around the outside shower knobs. I have Reflectix that fits outside the outside shower and covering the the floor and entrance to the basement. Two layers on the basement floor at the entrance. Pipe insulation caps for the 4 exterior connections. Soft foam in the ends and tape. 3/4" pipe insulation, cut and a piece added to allow a snug fit on the connector.
  25. I would choose #3 as long as there's nothing right up against the furnace exhaust. No guarantee the forecast is right. Miscalculated once with a different trailer and ended up replacing a split fitting on my water heater.
  26. Smart move. Wish i had thought of this when i was working on mine.
  27. My advice would be 3. Keep in mind, forecasts are often wrong and it could go colder than expected. And I agree with @jd1923 that 2 is the worst option for several reasons, the main one being nonuniform heating where a cold spot could cause a plumbing freeze.
