Wheel bearing maintenance and replacement
jd1923 replied to Frank C's topic in Mechanical & Technical Tips
Every Timken part also has a QR code on the packaging. I purchased hubs for my truck on Amazon. The QR codes wouldn’t read. Called Timken and the rep said no Amazon seller is authorized. I returned them. Then I looked on their dealer locator and found an auto parts supplier in Phoenix. Anything but Amazon for auto parts. -
Dean and Mary started following Geronimo John
CRM replied to Frank C's topic in Mechanical & Technical Tips
If you have a decent digital scale, one way to verify authenticity is by weight. Timken provides the exact weight of each part number in their catalogue. -
Calculators in schools have left generations without the ability to do simple arithmetic. i spent 55 years learning to write well. AI will write for the idiots of the next generation! People quoting AI is annoying, let alone plagiarism! I always read the Roman numerals on movie credits to know the year, never before adding. Let me give it a try! MDIV + MDIV = MMMVIII 🤣
BackofBeyond replied to Frank C's topic in Mechanical & Technical Tips
Almost all standard wheel bearings have an industry-standard part number stamped or laser-etched directly onto the metal. You just have to clean off the grease first and know where to look depending on the bearing style. I fondly remember my bearing search back in the day. Amazon was/is sketchy. Chinese knockoffs go to great lengths to try and fool the buyer into thinking they are Timkin bearings - some even try to capture the perfect box graphics. Honestly - as important as bearings are - a few extra $$ spent at the Timkin authorized dealer is just insurance. Provided you install them correctly. My 50cents. RB -
Geronimo John started following Dean and Mary
A Roman calculator? 🥴
ADKCamper replied to Frank C's topic in Mechanical & Technical Tips
Bearing #'s will likely be different depending on the particular axle model installed. As detailed elsewhere on the forum... capture a photo of the sticker on your axle (axle serial #, model #, date of mfg, etc.) and send that information to Dexter customer service. Upon request they can provide a copy of your axle's "build sheet" detailing the specs on your axle, including the inner/outer bearings and seal part numbers. These Dexter P/N's can then be cross-referenced to Timken or other brand products. -
What kind of calculator figures MDIV +MDIV? According to my wife the HS teacher, the vast majority of students can't figure 1+4-7..... Don't ask them to write a paragraph.
- Last week
Very nice to note the owner of Hull #112! -
dharmardr replied to Frank C's topic in Mechanical & Technical Tips
What is the bearing #? -
The Romans were on to something?
MDIV - I had to look it up. Nice.
Robert Byrne joined the community
Marianne5777 joined the community
I’m still in the campground at Key Largo. But my son headed north today and passed 2 separate Ollie’s.
Happy Thanksgiving to everyone
Tim Brooks joined the community
Happy Thanksgiving!
Happy Turkey Day 🦃
Removed from 2018 OEII hull 313. Good condition. Includes mounting hardware. Reason for removal: replaced with MaxxFan Dome. Sometime in the past I replaced the impeller and installed an EPDM foam seal in place of the open cell foam seal. I will include the wooden dowel that we used to keep it closed when traveling. You pay shipping. I will ship from 38261 when I find a suitable box. Bill
- 1
Removed from 2018 OEII hull 313. Perfect condition. Includes mounting hardware. Reason for removal: replaced with a marine hatch. You pay shipping. I will ship from 38261 when I find a suitable box. Bill
- 1
Happy Thanksgiving
Happy Thanksgiving fellow travelers and campers! Mike
Handle behind the Truma water heater fell off
FloraFauna replied to John and Debbie's topic in General Discussion
My valve handle fell off a couple of years ago. Finally and with a mirror, I found it. It cant go far! I fished it out, put it back on, and tighten the hex screw nice and tight. Havent had the problem since but i keep an eye on it. -
And it makes great conversation topic around a campfire.
Townesw replied to John and Debbie's topic in General Discussion
90 degrees CCW is CLOSED in 2018 hull number 313 I meant to respond to your question early this morning but got busy doing other stuff. -
You speak the truth. The reason I went with this was primarily because I already had most of the gear lying around not being used and also because I am a technology guy and enjoy it. But I'm not poring over graphs when I'm out camping! This is part fun / part diagnostic tool.
