Tim Brooks joined the community
Happy Thanksgiving!
Happy Turkey Day š¦
Removed from 2018 OEII hull 313. Good condition. Includes mounting hardware. Reason for removal: replaced with MaxxFan Dome. Sometime in the past I replaced the impeller and installed an EPDM foam seal in place of the open cell foam seal. I will include the wooden dowel that we used to keep it closed when traveling. You pay shipping. I will ship from 38261 when I find a suitable box. Bill
- 1
Removed from 2018 OEII hull 313. Perfect condition. Includes mounting hardware. Reason for removal: replaced with a marine hatch. You pay shipping. I will ship from 38261 when I find a suitable box. Bill
- 1
Happy Thanksgiving
Happy Thanksgiving fellow travelers and campers! Mike
Handle behind the Truma water heater fell off
FloraFauna replied to John and Debbie's topic in General Discussion
My valve handle fell off a couple of years ago. Finally and with a mirror, I found it. It cant go far! I fished it out, put it back on, and tighten the hex screw nice and tight. Havent had the problem since but i keep an eye on it. - Last week
And it makes great conversation topic around a campfire.
Townesw replied to John and Debbie's topic in General Discussion
90 degrees CCW is CLOSED in 2018 hull number 313 I meant to respond to your question early this morning but got busy doing other stuff. -
You speak the truth. The reason I went with this was primarily because I already had most of the gear lying around not being used and also because I am a technology guy and enjoy it. But I'm not poring over graphs when I'm out camping! This is part fun / part diagnostic tool.
Golfnut replied to John and Debbie's topic in General Discussion
I had the valve handle fall off my water heater.. it was still in warrenty they sent me the whole valve, it had to take the handle off it had a small set screw.. it was a PITA.. Because of the 6 gal is so close to the inner wall on a Elite 1.. I would try what Tony said..Good luck.. p.s. why wouldnāt OTT sell you a valve?.. -
Our batteries self-heat to approximately 40° and we maintain the battery charge with external panels during the winter when the cover is on. We do monitor the state of charge periodically in case of prolonged cloudy weather or extended severe cold but have never needed anything other than the external panels in the past three winters to maintain the batteries.
Happy Turkey Day to all. And Thanks Bill and Debbie. We just got back from a very wet "Thanksgiving in the Woods" rally at Paynes Prairie State Park in Florida. Was a good trip though. Deciding where to go in December, maybe back to Paynes Prairie, but we will see.
A.R.E topper or a Diamondback HD bed cover
Wayfinder replied to BackofBeyond's topic in General Discussion
I'm going to get a Cap for the new-to-me F250 soon. Likely an A.R.E like fiberglass. I keep going back and forth between Smartcap too. I may add a half slide-out top to go on my Decked drawer system. I think that will provide a nice balance for me instead of a full-size slider. Now weather to get a partially raised or fully raised cap (extra head room). Maybe not, since I also want a rack system on the cap. I'm also thinking of someday having Alcan replace my rear truck springs. Lew, the owner, was at the Oliver rally this year. He said Alcan does provide a stronger, yet softer ride due to thinner and more springs in the pack. Heck, maybe I will have them do the truck springs and the Oliver axles (custom size). Good road trip, then keep going West. -
dewdev replied to John and Debbie's topic in General Discussion
I did not know the valve handle could fall off. Having a 90 degree valve in that location is easier to operate -
Tony and Rhonda replied to John and Debbie's topic in General Discussion
Can't tell from your photos but if the valve has a "stump" sticking up and if you can access the stump with plyers, turning it 90 degrees away from the perpendicular water line should close the valve. If there is no stump you could try needle nose plyers to grab whatever the brass handle attached to. I think you can test to make sure it's closed by running water into the trailer line. Drain the water heater by moving the yellow latch down and removing the filter/antifreeze filter. Leave the water heater's yellow latch down with the filter/antifreeze filter removed. Turn on the water. If the valve is closed, water should not flow out. If you already have antifreeze in the water lines you will have to re-winterize the lines if you test the water heater like this. Tony -
Impressive technological effort folks. I am continually amazed at the ingenuity displayed by Oliver owners. What's really interesting are the types of the upgrades posted on the forum. Ten years ago, they tended to focus on best ways to alter this or that mechanical system, physical leveling products, how to's, AGM's v lead acid, the "hard" goods of an Oliver. Today we have folks automating the systems - as seen in this thread- routers, custom electronics, interfaces and programming we never thought about in 2017. (Some didn't exist back then) I also believe - to some extent- why we become Oliver owners - RV-people- has also migrated towards a more modern - less get back to the wilds of nature- kind of experience. Honestly, I sometimes experience a little cognitive dissonance. I spend a good deal of effort towards escaping the "modern" world, only to arrive in the backcountry hoping my modern conveniences have a signal... ????? The cool factor is off the charts, to be sure, but I push back, my inclination is to reduce, eliminate, if possible, all connection with this culture, and simply exist in the "natural" analog world. I dip my toes- back and forth- some trips are to the back country of Dinosaur National Monument- and others in a parking lot RV park- with full hookups - in Yellowstone, or perhaps, just outside some POI. Confused - but grateful. The Oliver allows us to experience almost any level of comfort - in as many locations we can reach. While many are tickled to know every data point, of all systems on board, some prefer the simplicity of the basics. Stuff is working as designed, leaving me to enjoy that backcounrty trail. Happy Thanksgiving to all. RB
When provoked enough, I can eventually go there. When it comes time for retribution, my Grandpa taught me well. Folks should not mess around with us Grandpa's. Why? We have a lot more experience, and a LOT more time than they do to mess with them. In my case, I probably too much enjoyed "Home Alone (the original), and "Bad Grandpa". Then there was the really old 1950's Lucille Ball and Desi Arnaz classic movie "The Long Long Trailer". The more current short videos about dealing with residential package thiefs also warrants a mention. All of them should be in or OTT's as an emergency kit for when we get totally rained in and feel in the need for an uplifting story that for sure will get laugh's. GJ
John and Debbie started following Handle behind the Truma water heater fell off
Hi all, the brass handle for the waterline turnoff fell off. I used an endoscope and wasn't successful in finding it. Oliver parts recommended an Amazon three way waterline valve that has the brass handle. It's currently in the normal configuration. I need to shut off water to the water heater. When I put the handle on, do I turn to the left or right one quarter turn. Thanks, John
Ohh youāve got an evil mind! š
Thanks everyone for the advice. I have been maintaining 41F battery temps on mid-teen nights with the camper plugged in and covered. I have decided to remove the cover and turn on the solar. I will take John from Prescottās advice of monthly SOC draw downs and solar rechargeā¦..and will not touch the 320s for ten years. š Steve
rideandfly started following Have a Great Thanksgiving
We Hope Everyone and their Family has a Great Thanksgiving! Best Regards, Bill and Debbie
- 7 replies
- 11
Geronimo John started following Home Assistant in the Oliver
Impressive effort and post. Another benefit is that one could also think of your system as a theft recovery tool. Sort of like "Home Alone". Whoever has stolen, or you just don't like if they borrowed your rig, you could make their life miserable! Full Heat, Full Cold, Lead Zepplin at 2:00 A, Rap at 3:00 AM, strobe lighting every 13.5 minutes randomly, drain the freshwater tank when they are 50 miles from a refill, lock up the brakes when in front of a police station... Oh, the fun that could be. Maybe turn it into a Home Alone #4! Rabbit Hole Society: You are getting close for sure...... GJ
