ScubaRx
Moderator+
ScubaRx last won the day on March 16
ScubaRx had the most liked content!
    Tupelo
    #026 (2008 Elite) and #050 (2014 Elite II)
    2014
12,972 profile views
ScubaRx's Achievements
Grand Master
Grand Master (14/14)
  • Great Support Rare
  • Great Content Rare
  • Helpful Rare
  • Superstar Rare
  • Well Followed Rare
5.4k
  1. For those of us who have been around for a few decades or so, probably have a collection of USB cords numbering anywhere from the hundreds to perhaps the thousands. I know I do. I decided to go through all of mine and sort them by type. For anyone that's not been paying attention there are currently three types of USB cables: A-B-C. Within these types there are at least five sub-types. Within all of these there are many versions of capabilities and speeds. Some will only carry data, some will only carry power. Some will carry both. Before I started sorting I wrote a little document to help me understand the differences. All this information was copied from multiple sites on the internet so I know it is all accurate. 🤪 I have included a PDF for anyone that has nothing better or more interesting to do. Enjoy... USB Cable Types.pdf
  2. I have a friend in town that owns Tupelo Trophy, a shop that does all sorts of engraving. A well as hundreds of other things, she made all the custom switch plates for us that we have installed in The Outlaw Oliver. I showed her my plate and she said she could duplicate it. I may let her duplicate mine just to see how it turns out. I'll post a before and after picture when its done.
  3. With lithium batteries and adequate solar, you should be able to last essentially for years.
  4. The price is what it is. The factory sets the price and the dealer’s sell based on the set price. I suppose some dealers might negotiate, but I suspect there’s not much wiggle room.
  5. I, for one, was thrilled to see this trailer resurrected and restored to its original beautiful self. Personally, I thought that the prior owner made a terrible mistake and created something akin to a mud fence. No disappointment here, good work...
  6. We do use them for leveling and have done so since our first Oliver bought back I early 2008. Advice: Chock the tires fore and aft, then unhook the trailer and move the truck. Raise/Lower the front jack first to get the trailer level front to rear. If the trailer is not level side to side, use the jack to raise the low side to level. Then lower the opposite side to stabilize it. Make sure you place a block between the jack foot and the ground. That way when you forget to raise them before driving away, you won’t ruin $1200 worth of jacks. Routinely check the bolt that holds the foot plate to the inner jack tube. If this bolt works loose, you will lose the foot plate that will cost you close to $40 to replace.
  7. We are still on our yearly western sojourn but I have 2 x 300Ah Epoch’s waiting for me at home. If you are using BB’s, I certainly can’t promise you they will fail. But if they do, I can promise you it won’t be in a convenient place.
  8. Our Oliver has outside rear jack switches located on the port and starboard sides as well as duplicate switches for each jack located on the inside of the cabin.
  9. I can pump 35 gallons of diesel and go pee inside the trailer while Tali walks the dog, goes inside the station for a snack and uses the bathroom and be back up to speed on the interstate in under 15 minutes. I’m then good for at least another 400 miles or until one of the three onboard bladders gets full again. I have no idea how long this would take with an EV and no desire to find out.
  10. Then fill your freshwater tank with clean water and either pump it into the gray tank and then dump or just drain it out onto the ground. That will wash out what small amount of AF that ended up in the fresh water tank. If you want to kill two birds with one stone, add some bleach to the first flush, let it sit for a few hours and then empty the fresh tank. That will sanitize it as well. I’d then flush it again.
  11. I only have one owner registered in my database as living in Prescott, AZ. What is their last name?
  12. A broken or loose connection anywhere in the entire plumbing system will cause a loss of pressure. Begin at the pump. Check connections there and make sure the filter bowl is tight. Work outward from there. If you have an accumulator tank you may need to pressurize it also.
  13. We have traditionally camped at or near these coordinates off Dome Rock Road west of Quartzsite. N 33.642439 W 114.307646 If you're coming into Quartzsite on Interstate 10 from the East (headed West) do not take any of the exits marked Quartzsite. If you do you will likely become snarled in traffic. Instead, continue West on I-10 until you see the Exit 11 - Dome Rock Road sign. Exit to your right and follow the road turning left to go back under the Interstate. Continue on a few hundred feet and turn left onto Dome rock road. You will begin to see folks camped along either side of the road but within 2-3 miles you will be nearing the coordinates I've provided. From there we will be off the right side of the road and you'll just have to look for a group of Oliver's. We should not be too hard to spot. Most of us will be there around the 2nd to 3rd week in January and will likely stay for a couple of weeks. This time frame will allow you to visit the Big Tent show. Hope to see you there. Contact me directly if you need more information.
  14. We will be there with possibly another Oliver Owner in tow. Leaving here 2nd week in January. Expecting arrival to coincide with the opening of the big tent.
  15. The NTSB (National Transportation Safety Board) investigates transportation accidents to find causes and makes safety recommendations, while the NHTSA (National Highway Traffic Safety Administration) sets and enforces vehicle safety standards, conducts recalls, and creates regulations, essentially acting as the rule-maker and enforcer to the NTSB's investigator/advisor role, though both focus on U.S. transportation safety. NTSB looks backward at incidents (planes, trains, cars) to prevent future ones, whereas NHTSA looks forward, setting rules for cars on the road today, including new tech like automated driving systems (ADS).
