Townesw Posted March 20, 2024 Posted March 20, 2024 (edited) If you see water dripping from this bolt under the front center of your trailer look for a leak under the bathroom sink In my case it was a split in the sink tailpiece. The split was on the side not visible so I didn’t find it until I removed the tailpiece. I couldn’t find this style of tailpiece at any of my local hardware places including Lowe’s because most tailpieces are made for sinks with built in overflows. I finally found a tailpiece that would work at a place that had an old supply of mobile home parts. It was plastic instead of metal but it worked great. I will order another tailpiece, either this one or a metal one, to put in my parts box. Installed pictures. The stopper is better than the rubber plug used before I cannot understand why the factory puts that fixed caddy under the bathroom sink. Sure, it’s no problem to remove and replace, but the fiberglass won’t stand the removal and reinsertion of the screws many more times. And when you remove, replace, and recaulk the caddy you have to wait until the caulk cures enough before you can use the shower. I will be installing a marine deck hatch in its place. Edited March 21, 2024 by Townesw 7 1 Bill and Martha 2018 LEII Hull 313 Original owners 3/14/2018 2019 Chevrolet 2500HD Duramax
Patriot Posted March 20, 2024 Posted March 20, 2024 1 hour ago, Townesw said: If you see water dripping from this bolt under the front center of your trailer look for a leak under the bathroom sink In my case it was a split in the sink tailpiece. The split was on the side not visible so I didn’t find it until I removed the tailpiece. I couldn’t find this style of tailpiece at any of my local hardware places including Lowe’s because most tailpieces are made for sinks with built in overflows. I finally found a tailpiece that would work at a place that had an old supply of mobile home parts. It was plastic instead of metal but it worked great. I will order another tailpiece, either this one or a metal one, to put in my parts box. I cannot understand why the factory puts that fixed caddy under the bathroom sink. Sure, it’s no problem to remove and replace, but the fiberglass won’t stand the removal and reinsertion of the screws many more times. And when you remove, replace, and recaulk the caddy you have to wait until the caulk cures enough before you can use the shower. I will be installing a marine deck hatch in its place. Super helpful post! Thank you! 3 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Townesw Posted March 20, 2024 Author Posted March 20, 2024 (edited) I forgot to mention that while you have the caddy off take a few seconds and straighten out your faucet head hose. Edited March 20, 2024 by Townesw 4 Bill and Martha 2018 LEII Hull 313 Original owners 3/14/2018 2019 Chevrolet 2500HD Duramax
Moderators topgun2 Posted March 20, 2024 Moderators Posted March 20, 2024 And - while you are under there - it might be a good idea to put some insulation on those water lines. Insulation on the hot line will help keep the water hotter and insulation on the cold line ( and hot) will help prevent freezing of the lines in below 30 degree weather. Bill 4 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
rich.dev Posted March 20, 2024 Posted March 20, 2024 1 hour ago, topgun2 said: And - while you are under there - it might be a good idea to put some insulation on those water lines. Insulation on the hot line will help keep the water hotter and insulation on the cold line ( and hot) will help prevent freezing of the lines in below 30 degree weather. Bill Agree….exactly what I did, using 3M Thinsulate SM600L and 1/2” foam pipe insulation!😊 6 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Townesw Posted March 21, 2024 Author Posted March 21, 2024 @rich.dev is this the bathroom heat duct? Is the factory using this now or is this something that you have used to replace what the factory used? Bill and Martha 2018 LEII Hull 313 Original owners 3/14/2018 2019 Chevrolet 2500HD Duramax
rich.dev Posted March 21, 2024 Posted March 21, 2024 32 minutes ago, Townesw said: @rich.dev is this the bathroom heat duct? Is the factory using this now or is this something that you have used to replace what the factory used? Yup that’s the factory heat duct, comes std with the truma varioheat furnace/heater. 1 3 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Geronimo John Posted March 22, 2024 Posted March 22, 2024 Wow, new Ollies have insulate water lines. Also, a lot more stuff in the way of the Bathroom Vanity door mod. 😞 Is the shape of the door "teardrop" or is that just camera parallax? GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators topgun2 Posted March 22, 2024 Moderators Posted March 22, 2024 24 minutes ago, Geronimo John said: Is the shape of the door "teardrop" or is that just camera parallax? The shape of the door has not changed - it must be whatever a "parallax" is 😁. And, the lines are still not insulated at Oliver. A number of owners (to include the provider of the pic) have insulated their lines like this. Bill 4 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Geronimo John Posted March 22, 2024 Posted March 22, 2024 Thanks Bill. I really suggest that OTT consider upgrading the bathroom vanity area as MaxBurner documented last year. With a little bit of engineering, the cabinet space could be provided without much cost and with great benefit to future owners! Art: Would be worth sending in your Mod info to OTT in the form of a Service Ticket. That way it for sure will be discussed and consided by their Leadership Team. I'll be packing a door this summer! 🙂 GJ 1 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
rich.dev Posted March 22, 2024 Posted March 22, 2024 1 hour ago, Geronimo John said: Wow, new Ollies have insulate water lines. Also, a lot more stuff in the way of the Bathroom Vanity door mod. 😞 Is the shape of the door "teardrop" or is that just camera parallax? GJ @Geronimo John like @topgun2 said, the shape of the door has not changed, and I added the 3M Thinsulate 600 and 1/2” foam pipe insulation. As far as I’m concerned the reflectix on the inside of the bottom outside hull is pretty much useless as a good insulator, so I have added Thinsulate pretty much everywhere within reach on the inside of the bottom outside hull, including the well documented cold area behind the garage and battery and garage doors. See this post….. 2 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Moderators mossemi Posted March 23, 2024 Moderators Posted March 23, 2024 (edited) I wonder when they started using PVC instead of ABS for the drain pipe? Mossey Edited April 4, 2024 by mossemi Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
MAX Burner Posted March 25, 2024 Posted March 25, 2024 On 3/22/2024 at 12:31 PM, Geronimo John said: Art: Would be worth sending in your Mod info to OTT in the form of a Service Ticket. Will do, John. Might generate OTT Factory-level interest... The pic might look like this: Any suggestions for pic content, @Geronimo John? 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Geronimo John Posted March 25, 2024 Posted March 25, 2024 Art: I think using the pic shown is perfect. Shows the space that we can gain very clearly. I'll be packing the "Hatch Door" with me this summer! GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
MAX Burner Posted March 25, 2024 Posted March 25, 2024 19 minutes ago, Geronimo John said: Art: I think using the pic shown is perfect. Shows the space that we can gain very clearly. I'll be packing the "Hatch Door" with me this summer! GJ Solid copy. RT! Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Moderators topgun2 Posted March 26, 2024 Moderators Posted March 26, 2024 Sure - but - I still don't know what a "parralax" is! And that door is still shaped oddly! 😁 Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderator+ ScubaRx Posted March 26, 2024 Moderator+ Posted March 26, 2024 52 minutes ago, topgun2 said: Sure - but - I still don't know what a "parralax" is! And that door is still shaped oddly! 😁 Bill I believe the GJ was referring to the keystone effect rather than parallax. Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Moderators Mike and Carol Posted March 26, 2024 Moderators Posted March 26, 2024 1 hour ago, ScubaRx said: I believe the GJ was referring to the keystone effect rather than parallax. Is that like the Miralax effect? 4 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Joe and Janet Childers Posted March 26, 2024 Posted March 26, 2024 Under sink storage is really nice. We just purchased a 2020 LEII. Making a list of modifications for Joe to complete. This will be near the top. 1 LEII 2020 Hull #588 Egg-Stream 2022 GMC Sierra 2500 Crew Cab
Moderators topgun2 Posted March 26, 2024 Moderators Posted March 26, 2024 30 minutes ago, Joe and Janet Childers said: Making a list of modifications for Joe to complete. Whatever happened to "Rosie the Riveter"? 😇 Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
MAX Burner Posted March 26, 2024 Posted March 26, 2024 17 minutes ago, topgun2 said: Whatever happened to "Rosie the Riveter"? 😇 The Airstream Mothership hired her many decades ago... 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Geronimo John Posted March 26, 2024 Posted March 26, 2024 (edited) 7 hours ago, ScubaRx said: I believe the GJ was referring to the keystone effect rather than parallax. Wow you must be photography buff. You are correct. I try to keep them "simplized" (Yea that is another GJ concocted new word) as: The Keystone effect is when lines converge with distance. Parallax on the other hand is when an object appears differently when viewed from two different points when in motion. The picture of the cabinet door has a bit of the former as you astutely observed. But, if I am inside Ollie, and my wife is driving down the highway, would Parallasium, not to be confused with paralaxium, end up being Keystoning when viewed from an infinite distance? Think on that one for a while. GJ: PS: I can't as it gives me a brain circuit trip. Edited March 26, 2024 by Geronimo John 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Townesw Posted March 27, 2024 Author Posted March 27, 2024 (edited) I realize this post has nothing to do with the direction this thread has taken, but I think this part is what was originally used for the bathroom sink drain. I submitted a service request asking for the correct part but the factory was unable to provide that information. You won’t find this in most hardware stores. https://www.lasallebristol.com/product/metal-c-o-plug-without-overflow/ Edited March 27, 2024 by Townesw 4 Bill and Martha 2018 LEII Hull 313 Original owners 3/14/2018 2019 Chevrolet 2500HD Duramax
Geronimo John Posted April 3, 2024 Posted April 3, 2024 On 3/27/2024 at 7:03 AM, Townesw said: You won’t find this in most hardware stores. That's a keeper. Thank you! GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Golfnut Posted April 3, 2024 Posted April 3, 2024 I just had to post this, when i seen leaking under bolt.. last year coming back from Banff,AL. It was leaking at the bolt.. stopped using bath sink. It stopped.. when i got home , i removed the bath vanity. To my regard the leak was at the faucet hose. Just needed to tighten the nut.. lesson leraned ..check that first!!! I might do that mod with the hatch , cinch i took it off already.. Very Senior moment.. 1 3 1 2022 Elite I # 1179 | 2024 Tundra SR5 4x4 Crewmax. 5.5 ft. Bed. 3.31gears 10 spd.trans
