Snackchaser Posted August 11, 2025 Author Posted August 11, 2025 David that's very cool and clever! Sounds like you know the maker! Do you think you could get the slicer file from him, or have him put it on Thingiverse? Is it made from PLA filament? BTW, I never mentioned it, but the rubber weather cap that comes with the Rj45 socket can be used under Furrion cap. Mine has disappeared though! Thanks, Geoff
Coddiwomple Posted August 11, 2025 Posted August 11, 2025 Hey Geoff, I don't know him personally. You should contact him about the file. ABS?? Not sure what it is made of but seems to be really solid. David & Martha from North Plains, Oregon. 2023 Elite 1 Hull 1382 "Coddiwomple" with full Truma & Lithium Pro packages. 2002 Toyota Tundra 4.7L. DC-DC Victron Orion XS 50 amp. Truma soft start.
Tideline77 Posted November 20, 2025 Posted November 20, 2025 I didn’t want to start a new thread with this simple question , so I apologize for piggyback riding on your install thread We are ordering the starlink mini while it’s on sale at $229 what other accessories do we need to order from starlink when we enter our order ? need to get it done with one order if possible Robert E 2022 LE II , LIthium Pro, 2018 F150 XLT 4WD 2.7 EcoBoost , 355 gears, tow package,36 gallon fuel, factory brake controller, transmission cooler
Ronbrink Posted November 20, 2025 Posted November 20, 2025 1 hour ago, Tideline77 said: what other accessories do we need to order from starlink when we enter our order ? You will pay a premium for any Starlink accessory, Amazon offers a lot of quality aftermarket products. At minimum: The SLM comes with a 15 meter cable, a shorter 5 meter will come in handy. The supplied power box is a 110 to 12V converter, you will likely want a setup to utilize 12V type outlets. 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Geronimo John Posted November 22, 2025 Posted November 22, 2025 With our lithium battery voltage ranging up to 14.4 volts (when equalizing) would inclusion of a 12V voltage regulator be advised? Something like was recently posted for the Max Fan by RidenFly? It is rated at 60 watts as well. TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Snackchaser Posted November 23, 2025 Author Posted November 23, 2025 23 hours ago, Geronimo John said: With our lithium battery voltage ranging up to 14.4 volts (when equalizing) would inclusion of a 12V voltage regulator be advised? No, a voltage regulator is not advised for the Starlink mini because it already operates from 12 to 48 volts DC. As was the jest of this thread, it's actually necessary to boost the voltage if using the supplied long cord in a 12 volt system due to the voltage drop. When I started this thread, I had one of the first Minis and there were no accessories or aftermarket options to allow it to work on 12 volts without either boosting the voltage, or shortening the cord. So I utilized a robust Vctron voltage booster that's wired to turn-on whenever the Mini is plugged in. I still use that system and, IMHO, it's still the best and simplist way to go. Of course, you can always use the supplied AC adapter that puts out 48 volts DC if you have an inverter, but that will suck down your battery a lot faster. These days there are more options and shorter cords if your mini is going to be mounted close by. However, it's often necessary to move the Mini further away for it to have a clear sky view, and in such case you need to boost the voltage to account for voltage drop from the longer cord. Some people use a POE injector (Power Over Ethernet) that can supply power through an ethernet cable that is plugged into the auxiliary ethernet port. Others use portable battery packs. I make snap-in re-chargeable battery packs for taking my mini to other campsites and such, but they have limited battery life. Because the Mini has a built in Router, it looses WiFi signal, and thus internet speed, the farther away it is. Mine is hopelessly slow if I use the entire cord length. So a great accessory is the Starlink Mini Router. They are inexpensive, and you won't often need it. But when you have a situation where your Mini is placed farther away for a clear sky view, then the router will save your day! See my post "The New Starlink Mii Router, for what ails you." So you will need to decide how you want to power your Mini based on how you plan to mount it and use it. Then you can make an informed decision on how to power it. Hope that helps! Geoff 1 3 1
Rarebear.nm Posted March 6 Posted March 6 I love your article. Can you please provide links for the bluetooth programmer and the 5mm 3 pin connector? Thanks Fred
Snackchaser Posted March 6 Author Posted March 6 Hey Fred! Even with all the other options now availible, this Starlink Mini power supply is a great way to go! I provided Amazon links to the Victron, timer, and programmer to someone else above, and the links are still good. As far as the 3-pin connector, there are several choices on Amazon. Search for 5.5mm 3-pin DC power connector. Go to timers.shop website for programming instructions. Iv'e provided a screen shot of the settings above. The programer is powered by USB, and the settings are flashed to the timer via WiFi by a cell phone or computer, No Apps are required, just open the URL address and plug in the settings. Have Fun! Geoff 3
jd1923 Posted March 7 Posted March 7 (edited) Yep, to everything Geoff wrote. He is THE electronics/wiring expert on our, The Forum! I wired the DC-2-DC 12/24 charger as he wired, tuned it up to 30V, but so far have not used it. It's an amazing upgrade which I have installed and will use someday. If you look very closely at my picture, the harness going up to the rooftop cellular antenna, the cable tied down in a loop has Ethernet and 30V power supply for our Starlink Mini! There is only time for so much in life, and once I realized a simple battery is all we need for BASIC functionality... I've been using this day-to-day! 😎 Edited March 7 by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Geronimo John Posted March 7 Posted March 7 Just for grins question as most of my miles are solo: But, could a passanger successfully use the internet while traveling in the flatlands? GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
jd1923 Posted March 7 Posted March 7 1 hour ago, Geronimo John said: Could a passenger successfully use the internet while traveling in the flatlands? I remember long ago watching a YouTube, where they had a Starlink dish in the car propped up to the moon-roof and somehow it worked! Maybe they had the larger dish. After using our Mini for a year, I cannot see how that is possible. It's a bit touchy, requiring proper alignment pointing to the northern sky. That's why we have our Pepwave router with Parsec Husky cellular antenna installed in our TV. Chris uses her tablet often while I'm towing. We have our own Wi-Fi connection wherever we drive and on many "flatlands" and most all Interstate Highways, we are connected. No campground or coffee shop Wi-Fi connections for us! Then we use our Starlink only when cell reception is weak, like for example, Burro Creek Campground sitting at the bottom of a DEEP canyon! There's no cell signal, no TV reception, no radio at all, and that's where Starlink truly shines! 😎 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
CRM Posted March 7 Posted March 7 5 hours ago, Geronimo John said: Just for grins question as most of my miles are solo: But, could a passanger successfully use the internet while traveling in the flatlands? GJ These days, yes... I think they used to block transmission on anything over 10mph with the roam plan and you also needed a special dish. I have a friend with a mini mounted on top of his van and it works perfectly at highway speeds. 1 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
Geronimo John Posted March 7 Posted March 7 (edited) 5 hours ago, jd1923 said: That's why we have our Pepwave router with Parsec Husky cellular antenna installed in our TV. I assume those are these.... From their web sigte: "Ground planes are not required for this antenna to function properly making it ideal for fiberglass roof installations." And also F-150's with aluminum bodies I may add . GJ Edited March 8 by Geronimo John 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
CRM Posted March 8 Posted March 8 15 minutes ago, Geronimo John said: I assume those are these.... Yep. 1 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
Zodd Posted Wednesday at 02:28 PM Posted Wednesday at 02:28 PM On 3/7/2026 at 9:30 AM, Geronimo John said: But, could a passanger successfully use the internet while traveling in the flatlands? It depends on your plan. Starlink recently changed its roaming plans, now you can't use it while in motion. I love Starlink, but when will their plans stabilize? They still change them every six months. 1 1 Todd & Kat 2023 LE ll twin, hull # 1305, Truma AC & WH, Platinum solar, Natures Head 2024 Ford F250 Lariat 7.3L gasser / 3.75, FX4
Steve Morris Posted Wednesday at 02:38 PM Posted Wednesday at 02:38 PM 7 minutes ago, Zodd said: It depends on your plan. Starlink recently changed its roaming plans, now you can't use it while in motion. This newest change only applies to the $5/month Standby plan. The $50 and $165 plans still allow roaming at speeds under 100 MPH (down from speeds up to 450 MPH, which has angered private aviation. Now there are new $350/month or $1000/month aviation plans.) 2 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
Zodd Posted Wednesday at 03:07 PM Posted Wednesday at 03:07 PM 28 minutes ago, Steve Morris said: This newest change only applies to the $5/month Standby plan. The $50 and $165 plans still allow roaming at speeds under 100 MPH (down from speeds up to 450 MPH, which has angered private aviation. Now there are new $350/month or $1000/month aviation plans.) Ah nice. Thanks for the clarification. I missed that part. Todd & Kat 2023 LE ll twin, hull # 1305, Truma AC & WH, Platinum solar, Natures Head 2024 Ford F250 Lariat 7.3L gasser / 3.75, FX4
Moderators topgun2 Posted Wednesday at 06:08 PM Moderators Posted Wednesday at 06:08 PM 3 hours ago, Steve Morris said: Now there are new $350/month or $1000/month aviation plans.) OUCH! 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Steve Morris Posted Wednesday at 08:30 PM Posted Wednesday at 08:30 PM 5 hours ago, Zodd said: Ah nice. Thanks for the clarification. I missed that part. Here’s the latest as of this week. Probably gonna change any day again… BTW, these guys are a wealth of information, and owned an Oliver several years ago. 2 1 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
Moderators mossemi Posted Thursday at 02:35 PM Moderators Posted Thursday at 02:35 PM 23 hours ago, Zodd said: I love Starlink, but when will their plans stabilize? They still change them every six months. I’ve always wondered if Starlink pricing is tied to the Tesla stock price. 17 hours ago, Steve Morris said: BTW, these guys are a wealth of information, and owned an Oliver several years ago. Chris and Cherie, the Technomadia/Mobile Internet Resource Center folks moved from a Tab trailer to an Oliver LE in 2008 and sold it in 2011. Mossey 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
jd1923 Posted Friday at 01:24 AM Posted Friday at 01:24 AM 10 hours ago, mossemi said: I’ve always wondered if Starlink pricing is tied to the Tesla stock price. Maybe? Love our Tesla stock! I bought a bunch when the paid-protester crazies were fire-bombing the dealerships and the stock dropped down to near $200. I’ve never been one for sound investing, yet we sure won on this one, monies doubled! BTW, after our last trip, I forgot to pause our account, from the $50 to the $5 standby plan. Got the email re monthly renewal charges, but it was too late to change plans (even though it was the day before the new billing month). I entered a CS ticket. It took 3 days and after a second request, then Starlink CS wrote back. They wrote the next month is still live on the $50 plan, but they apologized for the inconvenience and put a $50 credit in our account for future charges. In our family, we Love Elon, his genius and ALL of his great companies!!! 😎 4 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
CRM Posted Sunday at 06:53 PM Posted Sunday at 06:53 PM On 3/11/2026 at 10:38 AM, Steve Morris said: This newest change only applies to the $5/month Standby plan. The $50 and $165 plans still allow roaming at speeds under 100 MPH (down from speeds up to 450 MPH, which has angered private aviation. Now there are new $350/month or $1000/month aviation plans.) I can understand private aviation being angry with the change, but crying over the 10mph limit on standby plans just doesn't make sense to me. You can have connectivity virtually anywhere in the US for $5 per month and you're going to complain because you have to be stationary to do so? 2 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
jd1923 Posted Sunday at 11:22 PM Posted Sunday at 11:22 PM 3 hours ago, CRM said: You can have connectivity virtually anywhere in the US for $5 per month and you're going to complain because you have to be stationary to do so? Really! Who would use the Standby plan anyway, for more than its intended purpose? Just enough bandwidth to remote connect via the Starlink app, then upgrade to the $50 mobile plan or better ASAP! For on the road, mount a cell antenna and router which these days provides good service in 90% of roads out west and 99% when traveling east. On our summer trip to Northern Minnesota, we only used Starlink at our first campsite in New Mexico. Then all the way there and back, we did not need it again until we entered Wyoming. Then we used Starlink at each camp coming home. Though when towing, even in these remote areas, our cell antenna kept us connected more often than not. 😎 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
CRM Posted Sunday at 11:44 PM Posted Sunday at 11:44 PM 4 minutes ago, jd1923 said: Really! Who would use the Standby plan anyway, for more than its intended purpose? Just enough bandwidth to remote connect via the Starlink app, then upgrade to the $50 mobile plan or better ASAP! I tested it one month when I knew we wouldn't be traveling and It actually works pretty good for making WIFI phone calls and for doing some lite web surfing. Did several speed tests and was getting around 500Kbps. I think $5 per month to have the ability to do this anywhere in the US with a clear view of the sky is a crazy good deal. We've been using the residential $50/100 Mbps plan and have just been changing our "home address" to every place we camp. Works great (so far) and it's the only reason we haven't switched to the mini dish yet since they won't let you subscribe to a residential plan with a mini. I'll have no issue moving over to a roam plan and mini if they take this feature away, though. 2 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
Tideline77 Posted 3 hours ago Posted 3 hours ago our Ollie has the 390 AH lithionics system and we often camp without power connections Power usage onboard using the inverter is mostly a coffeee pot and and water kettle every morning , we think we are light power users When the mini is deployed away from the camper to get clear sky , Is it a reasonable idea to power our mini with two Milwaukee Forge tool batteries ? we have the batteries in our tool box with a few Milwaukee M18 tools , inflator, impact wrench for tire emergencies rolling out and rolling up a power cord seems like a burden "………….after doing it for 45 years our internet use while traveling is just web surfing and maybe an hour of movie streaming here and there. Robert E 2022 LE II , LIthium Pro, 2018 F150 XLT 4WD 2.7 EcoBoost , 355 gears, tow package,36 gallon fuel, factory brake controller, transmission cooler
