David that's very cool and clever!  Sounds like you know the maker!  Do you think you could get the slicer file from him, or have him put it on Thingiverse?  Is it made from PLA filament?
BTW, I never mentioned it, but the rubber weather cap that comes with the Rj45 socket can be used under Furrion cap.  Mine has disappeared though!
Thanks, Geoff
Hey Geoff, I don't know him personally. You should contact him about the file.
ABS?? Not sure what it is made of but seems to be really solid.
David & Martha from North Plains, Oregon.
2023 Elite 1 Hull 1382 "Coddiwomple" with full Truma & Lithium Pro packages.
2002 Toyota Tundra 4.7L.  DC-DC Victron Orion XS 50 amp.  Truma soft start.
States Visited Map
  • 3 months later...
I didn’t want to start a new thread with this simple question , so I apologize for piggyback riding on your install thread
We are ordering the starlink mini while it’s on sale at $229
what other accessories do we need to order  from starlink when we enter our order ?
need to get it done with one order if possible
Robert E
2022 LE II , LIthium Pro, 2018 F150 XLT 4WD 2.7 EcoBoost , 355 gears, tow package,36 gallon fuel, factory brake controller, transmission cooler
You will pay a premium for any Starlink accessory, Amazon offers a lot of quality aftermarket products. At minimum: The SLM comes with a 15 meter cable, a shorter 5 meter will come in handy. The supplied power box is a 110 to 12V converter, you will likely want a setup to utilize 12V type outlets.
With our lithium battery voltage ranging up to 14.4 volts (when equalizing) would inclusion of a 12V voltage regulator be advised?  Something like was recently posted for the Max Fan by RidenFly?   It is rated at 60 watts as well.
No, a voltage regulator is not advised for the Starlink mini because it already operates from 12 to 48 volts DC.  As was the jest of this thread, it's actually necessary to boost the voltage if using the supplied long cord in a 12 volt system due to the voltage drop.
When I started this thread, I had one of the first Minis and there were no accessories or aftermarket options to allow it to work on 12 volts without either boosting the voltage, or shortening the cord.  So I utilized a robust Vctron voltage booster that's wired to turn-on whenever the Mini is plugged in.  I still use that system and, IMHO, it's still the best and simplist way to go.
Of course, you can always use the supplied AC adapter that puts out 48 volts DC if you have an inverter, but that will suck down your battery a lot faster.
These days there are more options and shorter cords if your mini is going to be mounted close by.  However, it's often necessary to move the Mini further away for it to have a clear sky view, and in such case you need to boost the voltage to account for voltage drop from the longer cord.  Some people use a POE injector (Power Over Ethernet) that can supply power through an ethernet cable that is plugged into the auxiliary ethernet  port.   Others use portable battery packs.  I make snap-in re-chargeable battery packs for taking my mini to other campsites and such, but they have limited battery life.
Because the Mini has a built in Router, it looses WiFi signal, and thus internet speed, the farther away it is.  Mine is hopelessly slow if I use the entire cord length.  So a great accessory is the Starlink Mini Router.  They are inexpensive, and you won't often need it.  But when you have a situation where your Mini is placed farther away for a clear sky view, then the router will save your day!  See my post  "The New Starlink Mii Router, for what ails you."
So you will need to decide how you want to power your Mini based on how you plan to mount it and use it.  Then you can make an informed decision on how to power it.
Hope that helps!  Geoff
  • 3 months later...
Hey Fred!  Even with all the other options now availible, this Starlink Mini power supply is a great way to go!  I provided Amazon links to the Victron, timer, and programmer to someone else above, and the links are still good.  As far as the 3-pin connector, there are several choices on Amazon.  Search for 5.5mm 3-pin DC power connector.  Go to timers.shop website for programming instructions.  Iv'e provided a screen shot of the settings above.  The programer is powered by USB, and the settings are flashed to the timer via WiFi by a cell phone or computer,  No Apps are required, just open the URL address and plug in the settings.  Have Fun!   Geoff
Yep, to everything Geoff wrote. He is THE electronics/wiring expert on our, The Forum!
I wired the DC-2-DC 12/24 charger as he wired, tuned it up to 30V, but so far have not used it. It's an amazing upgrade which I have installed and will use someday.
If you look very closely at my picture, the harness going up to the rooftop cellular antenna, the cable tied down in a loop has Ethernet and 30V power supply for our Starlink Mini!
There is only time for so much in life, and once I realized a simple battery is all we need for BASIC functionality... I've been using this day-to-day! 😎
Edited by jd1923
Just for grins question as most of my miles are solo:
But, could a passanger successfully use the internet while traveling in the flatlands?
Could a passenger successfully use the internet while traveling in the flatlands?
I remember long ago watching a YouTube, where they had a Starlink dish in the car propped up to the moon-roof and somehow it worked! Maybe they had the larger dish. After using our Mini for a year, I cannot see how that is possible. It's a bit touchy, requiring proper alignment pointing to the northern sky.
That's why we have our Pepwave router with Parsec Husky cellular antenna installed in our TV. Chris uses her tablet often while I'm towing. We have our own Wi-Fi connection wherever we drive and on many "flatlands" and most all Interstate Highways, we are connected. No campground or coffee shop Wi-Fi connections for us! Then we use our Starlink only when cell reception is weak, like for example, Burro Creek Campground sitting at the bottom of a DEEP canyon! There's no cell signal, no TV reception, no radio at all, and that's where Starlink truly shines! 😎
These days, yes... I think they used to block transmission on anything over 10mph with the roam plan and you also needed a special dish. I have a friend with a mini mounted on top of his van and it works perfectly at highway speeds.
I assume those are these....
From their web sigte: "Ground planes are not required for this antenna to function properly making it ideal for fiberglass roof installations."
And also F-150's with aluminum bodies I may add .
Edited by Geronimo John
Yep.
It depends on your plan. Starlink recently changed its roaming plans, now you can't use it while in motion. I love Starlink, but when will their plans stabilize? They still change them every six months.
Todd & Kat
This newest change only applies to the $5/month Standby plan. The $50 and $165 plans still allow roaming at speeds under 100 MPH (down from speeds up to 450 MPH, which has angered private aviation. Now there are new $350/month or $1000/month aviation plans.)
Steve - Northern Ohio, USA
Facebook - Instagram
Ah nice. Thanks for the clarification. I missed that part.
Todd & Kat
