HDRider Posted August 20, 2024 Posted August 20, 2024 Help! What is the default code? I am locked out. Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
DunnYet Posted August 21, 2024 Posted August 21, 2024 (edited) I’m not aware of a default code for the lock. Do you have the override key? If its a LE II twin bed and (1) your basement door is not locked (2) you are agile and small and (3) you have the pass through door under the nightstand I have heard of people getting back in from there. We keep our physical key in the tow vehicle for this very reason. (Plus I am NOT agile and small….) Edited August 21, 2024 by DunnYet More about spare key 1 3 Current: 2023 Oliver Elite II - Hull #1364 "Reset 2.0" (Second Owner) Tow Vehicle: 2023 Ford F-150 XLT 3.5L EcoBoost /w 3.55 axle and Max Tow Package "SIlver" Original: 2022 Oliver Elite I - Hull #1030 "Reset" (Sold) Original Tow Vehicle: 2022 Subaru Ascent "Blue Moose" Home Base: Duncanville, TX
Moderators SeaDawg Posted August 21, 2024 Moderators Posted August 21, 2024 The key. 1 1 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
HDRider Posted August 21, 2024 Author Posted August 21, 2024 (edited) Oliver Service, named Jason, came to our rescue. I called and left a message with service at 8:30 Eastern. Jason called me back within a few minutes. He suggested the basement route. Lucky my son was here to crawl where no man has crawled before, and hopefully never again. It appears the default code would not work because the lock battery is low. LESSON LEARNED, and a huge shout out of appreciation to @JEssary at the mothership. BTW - What is "the override key"? 10 hours ago, DunnYet said: I’m not aware of a default code for the lock. Do you have the override key? If its a LE II twin bed and (1) your basement door is not locked (2) you are agile and small and (3) you have the pass through door under the nightstand I have heard of people getting back in from there. We keep our physical key in the tow vehicle for this very reason. (Plus I am NOT agile and small….) Edited August 21, 2024 by HDRider 1 Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
DunnYet Posted August 21, 2024 Posted August 21, 2024 (edited) 34 minutes ago, HDRider said: BTW - What is "the override key"? Ours looks like this - Keyway is blurred because with AI these days you never know. It is a two-sided keyway - notches on the top and bottom of the key. If you did not get one with your lock contact service and there should be a serial number on the lock that would allow you to order a backup. Note that the key number is the blur where the grey box is. Edited August 21, 2024 by DunnYet Forgot to erase the key number Current: 2023 Oliver Elite II - Hull #1364 "Reset 2.0" (Second Owner) Tow Vehicle: 2023 Ford F-150 XLT 3.5L EcoBoost /w 3.55 axle and Max Tow Package "SIlver" Original: 2022 Oliver Elite I - Hull #1030 "Reset" (Sold) Original Tow Vehicle: 2022 Subaru Ascent "Blue Moose" Home Base: Duncanville, TX
HDRider Posted August 21, 2024 Author Posted August 21, 2024 10 minutes ago, DunnYet said: Ours looks like this I got you. That was my problem. They key was locked in the truck and the truck key was locked in the Ollie. I had two things happen that broke my routine. My driver door auto lock on my truck just stopped working. Then, the battery on the Ollie keypad went low. Being on autopilot, like I sometime do, I messed up. We are on a 3,000+ mile trip and my head is not quite on straight. Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
rich.dev Posted August 21, 2024 Posted August 21, 2024 36 minutes ago, DunnYet said: Ours looks like this - Keyway is blurred because with AI these days you never know. It is a two-sided keyway - notches on the top and bottom of the key. If you did not get one with your lock contact service and there should be a serial number on the lock that would allow you to order a backup. Note that the key number is the blur where the I might be wrong but this key is for the deadbolt not the electric lock? 1 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Patriot Posted August 21, 2024 Posted August 21, 2024 (edited) 3 hours ago, rich.dev said: I might be wrong but this key is for the deadbolt not the electric lock? Ours works for both. Edited August 21, 2024 by Patriot 3 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina
Frank C Posted August 21, 2024 Posted August 21, 2024 (edited) I always had that concern about getting locked out of the trailer and truck if I lost my keys while on the road, so I mounted a small mechanical (no battery) combination lockbox from Lowe’s inside the rear bumper storage area on one frame rail and kept an Ollie door key in there, and then kept a spare truck key hidden inside the Ollie so I could always get access to everything if I ever lost my primary keys while out away from the trailer. Edited August 21, 2024 by Frank C 2
John Dorrer Posted August 21, 2024 Posted August 21, 2024 (edited) My suggestion is to carry your keys. We do, and you will be glad in the future. If your batteries run too low you will need the key. We have to replace the batteries 1-2 times a year. I just replaced the remote battery. You should have received 2 keys and a remote. Edited August 21, 2024 by John Dorrer Typo John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
rich.dev Posted August 21, 2024 Posted August 21, 2024 55 minutes ago, Patriot said: Ours works for both. You are correct, just checked mine and sure enough it works on both! 😊 2 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Patriot Posted August 21, 2024 Posted August 21, 2024 (edited) “Two is one and one is none” We always keep an extra set of “all things keys” locked up inside a locked center console vault in our TV. The helpful option allows for coded keyless entry into our TV. Edited August 21, 2024 by Patriot 1 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina
MAX Burner Posted August 21, 2024 Posted August 21, 2024 5 hours ago, Patriot said: Ours works for both. Same here... Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
DunnYet Posted August 21, 2024 Posted August 21, 2024 2 hours ago, Patriot said: “Two is one and one is none” Takes me back to my datacenter days. 🙂 "Why do you spin five generators when you can run the whole place on three?" "N + 1 and one to not spin up properly and get sent down." 1 Current: 2023 Oliver Elite II - Hull #1364 "Reset 2.0" (Second Owner) Tow Vehicle: 2023 Ford F-150 XLT 3.5L EcoBoost /w 3.55 axle and Max Tow Package "SIlver" Original: 2022 Oliver Elite I - Hull #1030 "Reset" (Sold) Original Tow Vehicle: 2022 Subaru Ascent "Blue Moose" Home Base: Duncanville, TX
Ronbrink Posted August 22, 2024 Posted August 22, 2024 20 hours ago, Frank C said: I mounted a small mechanical (no battery) combination lockbox from Lowe’s inside the rear bumper storage area on one frame rail and kept an Ollie door key in there, and then kept a spare truck key hidden inside the Ollie so I could always get access to everything if I ever lost my primary keys while out away from the trailer. I would be inclined to keep any spare keys/Fobs hidden on the TV rather than the OTT. In doing so, one will always have the backup sets available, especially if lost when away from the trailer. Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
srthomsen Posted August 22, 2024 Posted August 22, 2024 On 8/21/2024 at 7:58 AM, rich.dev said: I might be wrong but this key is for the deadbolt not the electric lock? It does work for both. I always keep our truck keys with me when leaving the trailer but never carry the trailer key with me. Guess I need to get into the habit of doing that. Hint to self: Hit up Home Depot for some spare batteries too! 2023 Elite #1403--2019 Ford F150--2.7 Ecoboost V6--10 speed auto--without Max Tow
MAX Burner Posted August 29, 2024 Posted August 29, 2024 We keep two exact sets of TV/OTT keys on respective caribiners. One set stays in the TV - one in the OTT. We use Casablanca's main hatch combo lock exclusively when boondocking - so if one of us gets back to the trailer before the other, no biggie getting inside. Full Disclosure of a Lesson Learned: Magnus (knucklehead #1) locked us out of our TV during a roadside stop enroute to Pagosa Springs several years ago with the truck still running. Had we stashed another set of keys in the TT, we wouldn't have had to break the rear window to get access to the TV.... That was not a cheap date! 2 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Geronimo John Posted August 29, 2024 Posted August 29, 2024 2 hours ago, MAX Burner said: We keep two exact sets of TV/OTT keys on respective caribiners. One set stays in the TV - one in the OTT. We use Casablanca's main hatch combo lock exclusively when boondocking - so if one of us gets back to the trailer before the other, no biggie getting inside. Full Disclosure of a Lesson Learned: Magnus (knucklehead #1) locked us out of our TV during a roadside stop enroute to Pagosa Springs several years ago with the truck still running. Had we stashed another set of keys in the TT, we wouldn't have had to break the rear window to get access to the TV.... That was not a cheap date! Ditto on the first part. Be sure to wrap it in heavy aluminum foil for the RF raiders. In addition to the above, the following for us works well for the Lesson Learned. (Snipped from Partiot's post above) GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
