On 8/27/2026 at 12:23 PM, Wayfinder said:
I am just starting my research on a new fridge.  I also have the old Dometic 3-way fridge in Hull #110. It still works, for the most part, but cannot get it to go to level 5, only runs up to level-4.  Have not search on that yet. Works great until cabin gets warm.
I would think the Nova kohl R5810  or similar fridge really should be powered by Lithium batteries.  I'm not yet ready to upgrade to Lithium as my Lifeline AGMs are still quite new and great shape (2024).
Not sure if I could just live with a portable Lithium box for the fridge, when needed on drive days.
Thoughts?
Do you actually use a freezer compartment? The Dometic they're installing now (or the '26's at least) have a removable one, and its much better as now I have room for taller stuff. Annoying that jams, pasta sauce and the like doesn't fit anywhere except on their side otherwise. I also have a Dometic CFX5 75 in the truck for when we need more stuff. The compartments are individually settable via Bluetooth or front panel, to freezer/fridge. Being an EV there's lots of power in the bed, I have a portable battery plugged into that which tops off when we drive, and powers the cooler otherwise. I got this on sale but there's equivalent cheaper ones
Anyhow the other advantage is no more ice buildup since its just a fridge now. On the downside, their design is for moisture to collect on the top area (former freezer) and it drips down which is annoying. This is actually their design ... anyhow easy to 3D print a collection tray and funnel it to the drain hose which I'll do at some point.
I believe (can check if you're interested) a Dometic NRX 130C with dark stainless front. Freezer compartment is removeable as mentioned, it has a latch which props it open when unpowered to keep airflow going through it. Really a nice fridge I like it
Edited by DanielBoondock
Sierra EV AT4 2026 (max range 530 mile pack)
Better stay with a 3-way fridge, unless you're plugged in. Running on DC overnight takes too much power for AGM batteries.
We do, and it must stay below 10F to keep my Qt of ice cream cold! Glampin' right?! 😎
We also make ice! Two of these fit in one corner of the Dometic freezer, taking very little room. I refill one each night so we always have ice available for those adult beverages!
https://www.amazon.com/Molds-Silicone-Trays-Large-Square/dp/B0771YDNCY/
@Ronbrink was first to have one of these in his TV. Like you, he has the dual-zone CFX which is great!
At first, I didn't want to use the space, but I went with the single compartment CFX5 45L which just fits in this space by the passenger door. It's so nice always having cold water with us, and not only in the cabin.
Often when traveling, we buy a load of meat from a local farm or butcher shop. I'll remove the drinking water, set the CFX5 down to freezer temps to carry the box full of frozen meats, yum!
Some people go to museums. That's not us. We shop the great local food markets. Leaving to SW Colorado this Wednesday! With both fridges half empty, our first stop is always the Delores Market! 😍
@mossemi
I just tried running my (original 2018) 3-way Dometic Refigerator on DC batteries.
When I did, the charger/inverter ran the entire time. Made for too much noise when trying to sleep.
Do you notice that as a problem in your installation and/or how did you eliminate that issue?
Edited by dewdev
Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 aH Lithonics batteries (390 total) and  Xantrex Freedom XC 3000 Pro Inverter in 2025
Maine
6 hours ago, dewdev said:
@mossemi
Mossey replaced his over a year ago, so these days he could let you know how noisy the new Nova Kool is on DC.
Given you have the 3-way Dometic (we have the same model), if you have it truly set on DC the inverter does not need to run. First push it to AUTO and then sensing 120VAC from the inverter it will automatically switch to AC. Then push the other button to switch from AC to DC. The DC light should then be ON.
I have very good hearing and the Dometic fridge on AC or DC barely makes a sound, most people would not hear it. When running on LP you can hear a slight clicking sound when it's lighting the gas and then it too should run awfully quiet. The absorption fridge should be quiet in all three modes. Low noise is the only benefit of having absorption vs. a compressor fridge (and LP of course).
Running the fridge on inverted AC is such a small load, about 1A on 120VAC (10A on DC), you should not hear the inverter unless your sleeping above it there would be a very light hum. The only time I turn off our inverter because of noise is if our LiFePO4 batteries are very low and the inverter is in full charge mode, producing full out 120A DC. Full out charge should be easy to hear, but when merely running the fridge, not.
Noisy inverter, or a noisy 3-way fridge? It could mean there is an issue creating the noise.
Is the sound coming from the fridge, your inverter, or both? Make sure your fridge is actually on DC, turn your inverter OFF if you have to and see if the noise is still present in DC mode.
Edited by jd1923
Oh that’s a good idea, don’t know why I didn’t think of it. The one thing I miss about the freezer is having ice cubes, I’ll keep ‘em in the cooler. I need a bigger buffer battery, the small Jackery runs out overnight. I can tell the truck to stay on and power it for however long but its overkill
Quote
I got a small dedicated drink cooler behind the drivers seat with soft drinks for the road, but my full sized Montague folding bike has been going there now.
We eat a lot of veg and good stuff isn’t always available. Four of these store in the fridge part of the cooler, two in the Oliver and eight of the smaller ones also in the Oliver. They have little packets that capture - I think it’s C02, which wilts vegetables. Cut cabbage for example will literally keep for weeks without wilting or browning, its amazing. Anyhow great way to organize the veg
https://www.amazon.com/OXO-Grips-GreenSaver-Produce-Keeper/dp/B00TO8X0BA
We need my good friend, our friend @Geronimo John to chime in!
He showed us an ice maker he travels with and I purchased a larger unit which we now use everyday at home (use distilled water to minimize cleaning).
Still planning on the Oliver Rally this year, though I missed registration (have a campsite). 😎
We're bringing the icemaker with us for sure, for campground wanderers that need hydration!
https://www.amazon.com/dp/B09133YZL4/
Edited by jd1923
Glamping, who said glamping? 😄
My camper is stuffed, explaining the 700 lb tongue, because I want it 'always ready' to go. Partly because if we get a wildfire or other emergency we can leave in 10 minutes. Also so that I don't have to bother packing for each trip, so we've got cold weather, hot, mountains, coastal, desert gear. Anyhow there's definately no room for an icemaker, though when I took my ice trays out I did toy with the idea 😄
The one appliance I did compromise on is this
Both a toaster and a small oven, gotta have toast. Fits in the electrical cabinet above the stove, on the side don't have to take it out. Unfortunately not available anymore ..
Yeah, I like having a freezer for ice and a good ice pack for the back & neck.
Looks like the Nova fridge uses a lot less power at about 4.5A on 12v.  My old 3-way burns at least 10amps on DC, but my 4 good AGMs sustain that all day, with Solar coming in.  I'm estimating that the Nova, without a freezer, might run on a Jackery 1000 for approximately 30 to 35 hours.
I always travel with at least one of my Jackery 1000s portable power units, for among other things, running my 12v Truma Cooler that I either carry in the cab of the truck or in the camper itself. The Truma cooler runs at least two days on that portable power unit, and I seldom charge past 85%, depending how hold I want things and the ambient temps.
I'm estimating that the Nova, without a freezer, might run on a Jackery 1000 for approximately 30 to 35 hours. But that remains to be seen, and weather dependent.
In theory, and if I put my money where my mouth has been, I'll be retired in 122 days.  (Fine, yes, I'm counting)
Chris
o-o  2016 Legacy Elite II (demo) - Hull #110 -"Rock'in 110"
o-o  2024 Ford F-250 Lariat, 7.3L Godzilla gasser
o-o  Augusta, Georgia
@dewdev
Krunch says that I am deaf, so I’m not a good judge of noise.  The Dometic Penguin AC does not bother my sleeping either!
I don’t know which inverter you have, but I never ran our OEM Dometic refrigerator on our OEM Xantrex inverter and I have never run the Nova Kool on inverted 12v DC.  I always thought it was a waste of battery power to invert the 12v DC to AC, to power anything that was capable running on 12v DC.  The microwave was one of the few appliances that we run with the inverter.
jd1923 brought up an very good point, verify that you are actually powering the refrigerator from you 12v batteries without running the inverter.
I am currently working on a Victron MultiPlus II installation and so I can’t test your scenario in 'the dog house'.
Edited by mossemi
Add additional info
1 hour ago, mossemi said:
I am currently working on a Victron MultiPlus II installation...
😍 Love it! The Dog House is certainly getting high-tech. Love to see your take on this one with all of your great Mods!
Mike/Mossey, I hope to meet you at The Rally!
(Your hull graphic should be easy to find.)
189 here 😅
If you have an Apple watch there’s an app that puts it up as a widget (complication?) At this point fun to watch it count down, very soothing …
I am looking forward to meeting you as well and 'the dog house' graphic may be gone by then.  I need to get a replacement.
Pulled our Oliver into the driveway yesterday, since we're leaving for SW Colorado tomorrow.
Like Dewdev, I started our Dometic 3-way fridge on DC. It did not seem to work. On the Epoch and Victron apps you could see it was only pulling -4A total and our system pulls -2.5A with almost nothing ON! I think I had the Maxxfan on too, so the fridge switched on DC was not actually pulling any DC power from the batteries!
Switched it to AC and the readings changed to -16A which is a good number showing the fridge is drawing amperage so should be running. Two hours later the freezer had cooled down to 26F, the fridge at 62F, ambient cabin temp was 79F. This was going nowhere fast!
Later last night, I switched the cooling to LP and started the Beech Lane fan at 50%. I sat at the dinette for 5 minutes to hear the LP ignite. It took two tries because on the first try I had forgotten to first light a cooktop burner to bleed the LP lines. After the bleed, I could hear it go through the click pattern twice to ignite and then I could hear it burning, a soft smooth sound. This should be working now.
Got up this morning to read the freezer at 8F and the fridge at 36F (Ruuvi sensors and app). We always keep the fridge cooling setting at #4 out of 5.
So our fridge is hardly a 3-way anymore! I will try running on A/C (Victron inverter always ON) while we are towing. Maybe now that it's cool it can sustain running on electric. Last trip we were at 7600 ft elevation north of Flagstaff and the fridge had issues staying lit overnight at altitude. This trip we will always be above 7K+ ft.
After all I've done to our Oliver, I'd hate to think fridge upgrade now, but it looks like it's coming soon. At least we have the 45L CFX5 fridge in the truck if all else fails. We're packing light on food with good local markets on the route!
Edited by jd1923
JD1923:
I should clarify my issue. We have a Dometic 3 way RM2454 refigerator. Out charger/inverter is a Xantrex Freedom XC 3000 Pro Inverter.
So the situation was: After the 3rd day of camping, we left the campground to go to the fair and was gone 4 hours.
Upon getting back to the trailer, the refigerator was off completely. I tried turning the unit on and it would not start up on AC. I then switched it on DC and the Xantrex started up (likely to charge the batteries) and did ot turn off. Since it is under my wife's bed, I know the noise would be too much for her. I then switched it to propane and it ran fine. The next day after I thought about it for awhile, I pushed the auto switch in and out for a few times, as it would not activate the first time and only run on propane. After working the Auto switch a couple of time it finally worked and switched to AC.
So the moral of the story is.:
1. I think that one of us had accidently hit the on/off switch before leaving the trailer. The auto swtich had not been pushed for a couple of years, so the contacts may have been dirty.
2. I have always found the button operation to be difficult to get it to ingage, maybe due to dirty contacts. That would explain difficulity in getting the refig started again and switching to AC.
3. After discussing the siuation with a knowledgable friend, he suggested buying a new eyebrow board from Dinosaur Electronics who make a better board the Dometic, which I have ordered. I also ordered a new Dometic board (which includes the face plate) since the cost was less than $5.00. I will now have 2 back up boards when needed.
Other explalination would be appreciated.
Maine
4 hours ago, dewdev said:
We have a Dometic 3 way RM2454 refrigerator. Out charger/inverter is a Xantrex Freedom XC 3000 Pro Inverter.
We have the same model RM2454, and we've done the same thing! Chris says I hit the switch with my butt when making a drink. 🤣 I use the shelf above the fridge as a bar top. I've gotten up in the middle of the night and it's dark up that way with no lights on!
If all the lights are off, then it got turned off accidently.
Our fridge has been holding today on AC power, after it needed LP to cool it down at first. I also realized it was nowhere near level. Checked the LevelMate this morning and the front was almost 6" low! That's the way it is in my driveway, hitched with the truck parked in the garage. I raised the front about 3" this morning but can't get it higher because it has to stay hitched.
Richard, I'm glad you are working on getting yours to perform again! I was looking at replacement fridges and they're either too small or too big and too much money. Thanks for the heads up on Dinosaur boards.
Yeah, if the Xantrex is keeping Marianna up at night, just shut it down. I sleep above our Victron and if it's charging when I want to go to sleep, I'll turn it off. Lucky I can switch it off by the phone app.
At some point I'll figure out how the AC/DC circuits work on our model and how to test them myself. This guy may be worth following.
@jd1923 I too love watching "My RV Works".
I also still have the  Dometic RM2454. My fridge will not stay on left 5. The light usually goes out after a while or immediately depending on ambient temps (so it seems). Not sure it's the eyebrow or board.
I've been wanting to delve into it more, but I'm a bit afraid I will break something worse.  I'm such a scaredy cat.  I don't mind breaking it with someone with me or if it doesn't work at all.  LOL. I'm so complex.
Chris
@dewdev and @jd1923
littlehousecustoms.com
sells the button guard below, which we found totally eliminated the accidental RM2454 button push.
FRIDGE BUTTON GUARD
86e1e435.fridge_guard_t.jpgWho hasn’t bumped the fridge control, switched to DC and run their battery down? This new version is made for us by Charlie Young. It's clear, fits the fridge well and doesn't require removal to operate the buttons. It attaches with clear VHB tape to the control panel.
6f692ed4.fridge_guard2_t.jpgThe red color in the photo is the release film on the guard and peels off prior to installation revealing the clear VHB tape.
Button Guard $14.95 Add to Cart
3 hours ago, mossemi said:
@dewdev and @jd1923
FRIDGE BUTTON GUARD
We got one of these right after our pick up trip in 2016 because someone leaned against the fridge and turned it off.  A few years later, I called Charlie and told him I was giving a presentation about modifications at our Oliver rally and he sent me some that I could hand out at Lake Guntersville. That was before COVID, so probably 2019.  Glad to see they are still available.  Mike
Charlie "used to be" a member of the Forum.  I say "used to be" because I've not seen him on the Forum for several years now.
After just getting back from a bit over two months on the road it might take me a couple of days to see if I can find his Forum name.
@tractors1 is Charlie Young’s forum name.  Mike
Thanks Mike - I couldn't remember his Forum name for the life of me.
