Trailblazers Posted August 3, 2025 Posted August 3, 2025 My 110 outlets are not working with my solar. Everything else works fine; lights, refrigerator, water pump, etc, but no 110 outlets. The outlets work while plugged into shore power or with the generator. This started when I was boondocking and did not notice my refrigerator was still set on DC, from traveling. When I went to make coffee in the morning, the electricity started struggling and eventually went out. I've checked all the possible fuses, breakers and GFCI plug, and all seem to be good. Is there a fuse for the inverter that is located somewhere else in the trailer, or could I have maybe fried the transfer switch? Thoughts? My trailer is an 2018 Elite II. 1 Franklin, TN 2018 Elite II #315 Tow Vehicle: 2020 Ram 1500
John Dorrer Posted August 3, 2025 Posted August 3, 2025 16 minutes ago, Trailblazers said: My 110 outlets are not working with my solar. Everything else works fine; lights, refrigerator, water pump, etc, but no 110 outlets. The outlets work while plugged into shore power or with the generator. This started when I was boondocking and did not notice my refrigerator was still set on DC, from traveling. When I went to make coffee in the morning, the electricity started struggling and eventually went out. I've checked all the possible fuses, breakers and GFCI plug, and all seem to be good. Is there a fuse for the inverter that is located somewhere else in the trailer, or could I have maybe fried the transfer switch? Thoughts? My trailer is an 2018 Elite II. Your outlets will only work with shore power, a generator, or with an inverter turned on if you have one. More information is required. What batteries do you have 2 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Trailblazers Posted August 3, 2025 Author Posted August 3, 2025 I have four AGM batteries and the inverter is always turned on when using the solar. 1 Franklin, TN 2018 Elite II #315 Tow Vehicle: 2020 Ram 1500
Galway Girl Posted August 3, 2025 Posted August 3, 2025 (edited) If your batteries are too low of voltage < 10.5v the 2000 watt inverter shuts down. the inverter should alarm on low voltage or give an E01 code. when you are in solar if the batteries drop too low the inverter will not turn on again until the batteries are charged When we boondock we leave the inverter off unless we need 110 as it draws down the batteries just being turned on. if you fully charge your batteries the inverter should begin working. Edited August 3, 2025 by Galway Girl 1 3 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
Trailblazers Posted August 3, 2025 Author Posted August 3, 2025 The batteries are back to fully charged. They went to down to around 50%, when this happened, but back to 100% now. 1 2 Franklin, TN 2018 Elite II #315 Tow Vehicle: 2020 Ram 1500
Moderators Mike and Carol Posted August 3, 2025 Moderators Posted August 3, 2025 I recommend you leave your inverter off until you need to use 110, especially with AGM’s. As mentioned above, just having your inverter on and not being used draws down battery capacity. We rarely turn our inverter on. 5 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
John Dorrer Posted August 4, 2025 Posted August 4, 2025 2 hours ago, Trailblazers said: I have four AGM batteries and the inverter is always turned on when using the solar. Inverter should be off unless using microwave, outlets, or watching TV 3 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
jd1923 Posted August 4, 2025 Posted August 4, 2025 44 minutes ago, John Dorrer said: Inverter should be off unless using microwave, outlets, or watching TV Yes, in an OTT installed system, yet we keep our Victron system on always, 24x7x365! It’s ON now, as we sit on our deck with A/C set to 85F to keep things nice! Solar on/off has nothing to do with 110VAC outlets working, PERIOD! We could only guess, not knowing battery, inverter or any other particulars. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Snackchaser Posted August 4, 2025 Posted August 4, 2025 7 hours ago, Trailblazers said: Thoughts? All the comments are right on the money. But for a little more perspective of why you fell short of power, consider this: My guess is that you have about 400 Amp Hours with your 4 AGM batteries, which gives you about 200 AH usable power without going below 50%. You stated that your inverter stays on. A Xantrex Freedom inverter uses 72 AH per 24 hours of standby power (turned on without a load.) The Victron Multiplus is better at 40 AH a day with standard factory settings, and as low as 16 amp hours a day with power saving settings. These are both zero AH when turned off. The batteries are being supplemented with an assumed 320 watt solar system, which is under 30 AH a day in sunny conditions. You mentioned a coffee maker which burns a lot of power, typically about 20 AH to brew coffee, and more if your keeping it warm. That could cancel out the solar contribution. Now add in the AH values for whatever else you're using, and you can figure out how long you can last when boondocking. Hope that helps! Cheers, Geoff 3
Trailblazers Posted August 4, 2025 Author Posted August 4, 2025 I'm sorry we got off track here. The first reply after my post said "Your outlets will only work with shore power, a generator, or with an inverter turned on if you have one." I replied our inventer is always on when using the inverter. I should have said my inverter is always on when using the outlets. But then the discussion turned to why not to use the inverter full time and away from the original post. We were out on a long camping trip, when this happened and it was the last BLM spot we camped in. I am home now and want to start working on the problem. The batteries are fully charged and my 110 outlets will not work with the solar. I am wondering if there is a fuse somewhere else in the trailer, other than the fuse/breaker panel or if I have a problem with the transfer switch, maybe? I'm asuming the problem is inverter-related, but not sure. I have the 320 solar watt package, with the Xantrex 2000 watt inverter. Looking for any ideas. Thank you! Franklin, TN 2018 Elite II #315 Tow Vehicle: 2020 Ram 1500
Guest Posted August 4, 2025 Posted August 4, 2025 (edited) Solar can charge the batteries (12 volts DC). Batteries can run the inverter (12 volts DC converted to 120 volts AC). Inverter is a pass through of 120 VAC when on generator or shore power. Inverter is also a converter and will provide 12 VDC to charge the batteries if AC load allows. Solar cells do not provide AC! If the batteries are charged, the inverter is turned on, the GFCI on the inverter is not tripped and the CB in the main panel is not tripped - the AC outlets in the trailer should operate. If the outlets aren’t working, check the GFCI on the inverter and the CB on the main panel under the dinette. Wire plugged into the GFCI feeds the AC outlets through the CB. Edited August 4, 2025 by katanapilot Added clarifying text
Ronbrink Posted August 4, 2025 Posted August 4, 2025 (edited) 1 hour ago, Trailblazers said: I'm asuming the problem is inverter-related, but not sure. A good way to check if the GFCI on the inverter is working is to see if the microwave has power, since it plugs directly into the GFCI outlet on the inverter. If the microwave has power then your inverter is working. If not, the GFCI has tripped and needs to be reset. For reasons unknown my GFCI has tripped, wherein the microwave and outlet receptacles have no power. There have been times when it took a few presses of the reset button on the GFCI to get it to work again. Once power is confirmed at the microwave, all is good. This may not be your remedy, but a good place to start. Edited August 4, 2025 by Ronbrink 2 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Trailblazers Posted August 4, 2025 Author Posted August 4, 2025 Thank you katanapilot and Ronbrink. There doesn't appear to be any CB tripped, but I could see it being the CFCI breaker. Where is the breaker for the inverter located? I don't see a CFCI breaker specifically for the inverter. Also, unforturnately we don't have a microwave. 1 Franklin, TN 2018 Elite II #315 Tow Vehicle: 2020 Ram 1500
Snackchaser Posted August 4, 2025 Posted August 4, 2025 Typically it's a GFIC receptacle (outlet) with a reset and test button, not a breaker. It will be the first receptacle closest to the breaker panel that daisy chains to feed the others, mine is the one under the dinette. 2 1
Galway Girl Posted August 4, 2025 Posted August 4, 2025 "The batteries are fully charged and my 110 outlets will not work with the solar. I am wondering if there is a fuse somewhere else in the trailer, other than the fuse/breaker panel or if I have a problem with the transfer switch, maybe? I'm asuming the problem is inverter-related, but not sure. I have the 320 solar watt package, with the Xantrex 2000 watt inverter. The batteries are fully charged and my 110 outlets will not work with the solar." is this statement true...batteries at 100%, you are not connected to shore power and your 110 outlets don't work....but your inverter is ON? Here's a checklist to help: Battery Charged (YES) Connected to shore power (Yes) (No) Inverter On (Yes) (No) Fridge Breaker Tripped (Yes) (No) = ours has a 20amp breaker in the panel for the fridge Inverter Built In GFCI Tripped (Yes) (No) = There is a plug in on the actual inverter that has a GFCI on it...see below GFCI In Outlet Tripped (Yes) (No) = Our hull has a second gfci outlet on the front of the dinette seat. 2 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
Trailblazers Posted August 4, 2025 Author Posted August 4, 2025 Thanks, yes I have the GFCI outlet under the dinette. I tested that when I was plugged into shore power and it tested fine, so I ruled that out. But just double-checked it now, with only the inverter on (not on shore power) and it will not trip, when I test it. I plugged back into shore power and the GFCI outlet tests and resets fine. Looks like that might be it. I'll replace it today. Thanks to all! 1 1 Franklin, TN 2018 Elite II #315 Tow Vehicle: 2020 Ram 1500
Guest Posted August 4, 2025 Posted August 4, 2025 Before you do that please check the GFCI outlet on the inverter itself. You said you have the Xantrex 2000 watt inverter and if it’s like the one I used to have in our Oliver, there is a duplex GFCI outlet on the inverter with a romex cable plugged into that outlet that then feeds a CB on the panel. Your wiring may be different than mine but I hope this helps.
Trailblazers Posted August 4, 2025 Author Posted August 4, 2025 Correction, it was the GFCI outlet that the inverter plugged into. I did not notice that was a GFCI plug, until I was going through Galloway Girls post again. Went back to double-check that outlet and walla! The circuit was tripped. Thanks for the help! 2 Franklin, TN 2018 Elite II #315 Tow Vehicle: 2020 Ram 1500
Ronbrink Posted August 4, 2025 Posted August 4, 2025 1 hour ago, Trailblazers said: Correction, it was the GFCI outlet that the inverter plugged into. I did not notice that was a GFCI plug, until I was going through Galloway Girls post again. Went back to double-check that outlet and walla! The circuit was tripped. Thanks for the help! It is hard to see and get to, thus I unplug from the GFCI to better access the reset button. Like I mentioned, if it doesn’t reset first try I repeat until it stays in meaning it is properly reset and functional. 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Moderator+ ScubaRx Posted August 5, 2025 Moderator+ Posted August 5, 2025 On 8/3/2025 at 5:55 PM, Trailblazers said: I have four AGM batteries and the inverter is always turned on when using the solar. The inverter has a standby power consumption constantly while it is turned on. This is true whether you are using 110vac or not. Personally, we keep the inverter off unless we are using something like a hair dryer or the microwave. Our camping style is 90% boondocking but we use the inverter very sparingly. This is even more important since you have the AGM's and have to watch them carefully to prevent them from getting to 50% SOC. 5 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Olive2Roam Posted August 12, 2025 Posted August 12, 2025 On 8/4/2025 at 1:27 AM, Snackchaser said: You stated that your inverter stays on. A Xantrex Freedom inverter uses 72 AH per 24 hours of standby power (turned on without a load.) The Victron Multiplus is better at 40 AH a day with standard factory settings, and as low as 16 amp hours a day with power saving settings. These are both zero AH when turned off. Trailblazer: Glad you got the issue sorted out! Geoff: We have a 260AH lithium batteries and a 2000 Watt Pro inverter. I assume the above applies to lithium batteries as well. True? I was not aware of that and we boondock a lot so 72AH is a big deal with our system. Bob https://www.instagram.com/campbells_olive2roam 2024 Legacy Elite Platinum, Hull #1465 2024 Nissan Pathfinder, Rock Creek Edition Lithium Batteries (260AH), 240 Watt Solar with Charge Controller, and a 2000 Watt Pro Inverter. Victron Orion XS 50A DC-DC Battery Charger
Snackchaser Posted August 12, 2025 Posted August 12, 2025 2 hours ago, Olive2Roam said: Trailblazer: Glad you got the issue sorted out! Geoff: We have a 260AH lithium batteries and a 2000 Watt Pro inverter. I assume the above applies to lithium batteries as well. True? I was not aware of that and we boondock a lot so 72AH is a big deal with our system. Bob Bob, I was using the specs of my Xantrex Freedom 2000 model to make a point about power consumption in standby mode, without any AC load. Different models will vary. The newer Xantrex models have a "No-load detection" feature that reduces the standby current by 25%, or to about 60 AH. This is similar to the Victron's power saving modes. Be sure to check your settings, because this feature is usually turned off in the default settings. However, I don't know the minimum current for the No-load detection off-hand, so it's possible that ghost loads like the microwave LED clock could defeat its value. And your assumption is right, this applies to any type of batteries. Hope that helps! Cheers! Geoff
jd1923 Posted August 12, 2025 Posted August 12, 2025 (edited) We keep our Victron Multiplus II on ALWAYS because we use AC appliances all the time! Also, with the MP2 full OFF does not allow for shore-power pass-through. There are 4 states as seen in the menu which can be changed via the VictronConnect Bluetooth App (see picture). The MP2 is more efficient than the original Multiplus as follows with power saving modes: - Zero load power 13W - In AES mode 9W - In Search mode 3W 13W is about 1A or 24Ah used per day (I don't bother with the power savings Modes). Since our Oliver is always outdoors, it takes about 3 hours of sun or 6 hours of clouds to replenish the 36Ah in 24 hours, the 24Ah for the inverter and another 0.5Ah x 24 for DC usage, Exterior Courtesy Lights ON and DC parasitic draw. I will on occasion turn the inverter off overnight, for example when charging is creating noise under my bed or when boondocking and SOC is low from use (<50%) and we need to be off-grid more overnights. On the rare occasion when the inverter is turned OFF overnight, Chris will try to start the electric kettle for coffee in the morning and when she gets no power she knows. So, I turn it back on using the app while still in bed! Our batteries have to be really low to use LP. The 1100W electric kettle (usually draws 900W) boils water in half the time. When SOC% gets low we have DC-2-DC charging and an extra 400W in suitcase solar. Our Epoch and Victron upgrades are GREAT and we use them to the fullest! Edited August 12, 2025 by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Snackchaser Posted August 12, 2025 Posted August 12, 2025 (edited) 1 hour ago, jd1923 said: We keep our Victron Multiplus II on ALWAYS because we use AC appliances all the time! Also, with the MP2 full OFF does not allow for shore-power pass-through. JD, This is unfortunately one of the drawbacks to the Victron inverters, but supposedly you can switch it to charger only mode to allow shore-power pass-through with the inverter off, with less standby power used. Bit of a pain though! However, a clever and handy guy such as yourself could install an external by-pass switch that would be easier than the App. Victron makes an inexpensive 30 amp beauty for switching between a generator and shore-power. I've seen them for $45. This can be wired so that you can switch the inverter off and still have shore-power. It's a great solution that might get you some extra sleep! 🥱 Cheers! Geoff Edited August 12, 2025 by Snackchaser grammar 2
jd1923 Posted August 12, 2025 Posted August 12, 2025 1 hour ago, Snackchaser said: supposedly you can switch it to charger only mode to allow shore-power pass-through with the inverter This is correct, I have tested it. The same for "Inverter Only." I've never seen the need to turn the inverter off when connected to shore power. When connected to shore power the Victron MP2 ON acts as an UPS, backup power for brown or blackouts and 1Ah drain is negligible when on the cord. My only issue with no pass-through power is if the MP2 was to fail the 120VAC could be left in an open state. I have a few wire nuts for this small likelihood and your switch idea would also gaurd against inverter failure. Thanks 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
