Trailblazers Posted 3 hours ago Posted 3 hours ago My 110 outlets are not working with my solar. Everything else works fine; lights, refrigerator, water pump, etc, but no 110 outlets. The outlets work while plugged into shore power or with the generator. This started when I was boondocking and did not notice my refrigerator was still set on DC, from traveling. When I went to make coffee in the morning, the electricity started struggling and eventually went out. I've checked all the possible fuses, breakers and GFCI plug, and all seem to be good. Is there a fuse for the inverter that is located somewhere else in the trailer, or could I have maybe fried the transfer switch? Thoughts? My trailer is an 2018 Elite II. Franklin, TN 2018 Elite II #315 Tow Vehicle: 2020 Ram 1500
John Dorrer Posted 2 hours ago Posted 2 hours ago 16 minutes ago, Trailblazers said: My 110 outlets are not working with my solar. Everything else works fine; lights, refrigerator, water pump, etc, but no 110 outlets. The outlets work while plugged into shore power or with the generator. This started when I was boondocking and did not notice my refrigerator was still set on DC, from traveling. When I went to make coffee in the morning, the electricity started struggling and eventually went out. I've checked all the possible fuses, breakers and GFCI plug, and all seem to be good. Is there a fuse for the inverter that is located somewhere else in the trailer, or could I have maybe fried the transfer switch? Thoughts? My trailer is an 2018 Elite II. Your outlets will only work with shore power, a generator, or with an inverter turned on if you have one. More information is required. What batteries do you have 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Trailblazers Posted 2 hours ago Author Posted 2 hours ago I have four AGM batteries and the inverter is always turned on when using the solar. Franklin, TN 2018 Elite II #315 Tow Vehicle: 2020 Ram 1500
Galway Girl Posted 2 hours ago Posted 2 hours ago (edited) If your batteries are too low of voltage < 10.5v the 2000 watt inverter shuts down. the inverter should alarm on low voltage or give an E01 code. when you are in solar if the batteries drop too low the inverter will not turn on again until the batteries are charged When we boondock we leave the inverter off unless we need 110 as it draws down the batteries just being turned on. if you fully charge your batteries the inverter should begin working. Edited 2 hours ago by Galway Girl 3 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine Aug 2024 on way to Nova Scotia.
Trailblazers Posted 2 hours ago Author Posted 2 hours ago The batteries are back to fully charged. They went to down to around 50%, when this happened, but back to 100% now. 2 Franklin, TN 2018 Elite II #315 Tow Vehicle: 2020 Ram 1500
Moderators Mike and Carol Posted 2 hours ago Moderators Posted 2 hours ago I recommend you leave your inverter off until you need to use 110, especially with AGM’s. As mentioned above, just having your inverter on and not being used draws down battery capacity. We rarely turn our inverter on. 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
John Dorrer Posted 1 minute ago Posted 1 minute ago 2 hours ago, Trailblazers said: I have four AGM batteries and the inverter is always turned on when using the solar. Inverter should be off unless using microwave, outlets, or watching TV John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
