Snackchaser Posted 17 hours ago Posted 17 hours ago Sounds like click bait, but it’s true! During a recent trip, the master switch on the main panel started flickering on and off, and that caused the blue LED indicator lights for other switches to flash.  It turns out that one of the spade terminals for the switch had loosened from the strain of the tangled mass of wires that were tightly stuffed in behind the switches. Many of the wires were individual grounds for the LED switch indicators, and there just isn’t enough room for all of them. The wires are oversized and stiff, and they used bulky splices to connect them all together. So I cut the mass of yellow wires out and replaced them with a single smaller wire that was daisy chained to each switch.  That space is much less tangled now, and there is more room and less strain on the switches. Now I have room for a new switch for a future project. While I was in there, I decided to address another peeve. I’ve always thought that those blue LED’s were too bright, so I soldered a 47K ohm resistor on the termination end of the new LED ground jumper. This dimmed the LEDs by about 50%. . . so much better! If anyone’s interested in doing this, Amazon carries a 525 piece resistor assortment for $8 so you can experiment with various levels of dimness. Only one resistor is needed for all the switches, so you could do a little twisted resistor art with the leftovers. I hope that someone finds this useful. Cheers! Geoff 1 1
Boudicca908 Posted 15 hours ago Posted 15 hours ago Not feeling very confident to do any rewiring, I live with blue painters tape on a lot of the little lights inside my Oliver. Maybe one day I will find someone to help me do this project for reducing the glow. 1 Oliver Elite II Twin (delivered 3/28/2022)  Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here    Â
Dave and Kimberly Posted 15 hours ago Posted 15 hours ago (edited)   See now I must just be different?  I like all the little lights inside at night... the way they reflect in multiple places, bouncing from curve to curve around the interior.  I think of them as my Ollies star-lights! 🙂   That said... I really appreciate the nice neat daisy chained ground wires! Good job! Edited 15 hours ago by Dave and Kimberly 3 2022 Elite II, Hull #1097 Elli Rose 🌹 and she has the solar panels with the 390Ah lithium batteries. Our tow vehicle is a 2019 Ford Lariat F-150 4wd, 3.5L Eco-boost, 3.55 rear end, with the Max tow package. Elli Rose also has the street side awning and several walnut and cherry mods on the inside.     Â
Mountainman198 Posted 14 hours ago Posted 14 hours ago 54 minutes ago, Dave and Kimberly said:   See now I must just be different?  I like all the little lights inside at night... the way they reflect in multiple places, bouncing from curve to curve around the interior.  I think of them as my Ollies star-lights! 🙂   That said... I really appreciate the nice neat daisy chained ground wires! Good job! You are not alone in enjoying the way light bounces across the Oliver interior. 2 1 2021 Elite II, Hull# 898 2018 Toyota Tundra, 2003 Dodge Ram 3500 5.9l SRW
jd1923 Posted 12 hours ago Posted 12 hours ago 2 hours ago, Boudicca908 said: Not feeling very confident to do any rewiring, I live with blue painters tape on a lot of the little lights inside my Oliver. Maybe one day I will find someone to help me do this project for reducing the glow. Nice work Geoff! Not sure I would like all those night lights! No blue LEDs on switches in this old hull! @Snackchaser, as an answer to this, could the yellow wires be disconnected at the ground to kill the blue LEDs? This could be the simple answer for @Boudicca908. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Boudicca908 Posted 11 hours ago Posted 11 hours ago 1 hour ago, jd1923 said: to kill the blue LEDs? Maybe to be more specific .... I have painters tape on the control panels of the Microwave, SeaLevel2 control panel, and the Norcold fridge; I close up the usb ports, and then I put a jacket on the floor near front dinette seat (to cover the bright light at the CO2 monitor) and I have thought about taping paper over the Solar Charge Controller! I haven't had the flashing blue lights occur. :) Oliver Elite II Twin (delivered 3/28/2022)  Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here    Â
Snackchaser Posted 9 hours ago Author Posted 9 hours ago 2 hours ago, jd1923 said: Nice work Geoff! Not sure I would like all those night lights! No blue LEDs on switches in this old hull! @Snackchaser, as an answer to this, could the yellow wires be disconnected at the ground to kill the blue LEDs? This could be the simple answer for @Boudicca908. Thanks JD.  Yes, if you disconnect the grounds the LEDs won’t work, but switches will still work.  Also, if you want the blue lights, then you can replace your switches with LED types available at AZ. i like the blue lights, just not so bright! Geoff 1 1
Patriot Posted 8 hours ago Posted 8 hours ago When my eyes are closed, I see no lights and sleep well. 🤣 So no issues here. 3 1 2020 OLEII - Hull #634 aka-  “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina 🇺🇸
Moderators SeaDawg Posted 8 hours ago Moderators Posted 8 hours ago 3 minutes ago, Patriot said: When my eyes are closed, I see no lights and sleep well. 🤣 So no issues here. My eyelids must be thin, according to my husband.  I'm another one who blocks out little lights at night. Fortunately, very few in a 2008. 1 2008 Ram 1500 4 Ă— 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.        Â
