Buddhabelly Posted August 13, 2025 Posted August 13, 2025 (edited) Since the front of our glass trailer is exposed to road debris from our tow vehicle, I went and had the lower front end of the trailer and front of the frame PPF'd. A good quality one will protect the trailer pretty good. So far is has worked pretty well. I also added mud guards front and back. The PPF can be replaced anytime if it starts to look bad. Edited August 13, 2025 by Buddhabelly 5 Hiroshi 2023 Oliver Elite #1299 2024 Lexus GX550 Overtrail
Patriot Posted August 13, 2025 Posted August 13, 2025 (edited) I had 10 mil XPEL PPF installed on our Oliver a few years ago, it’s holding up great. It’s worth the money spent if you want to protect the gelcoat. Also a good set of rear flaps is worth the investment. Here is a link to a thread on my PPF install. I also had my entire tow vehicle covered in 8 mil XPEL PPF. Edited August 13, 2025 by Patriot 4 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
FloraFauna Posted August 14, 2025 Posted August 14, 2025 Here is my solution. If CGI would come to my area I would add a ceramic coating. 5 2023 Legacy Elite II - Twin Bed - Hull #1394 TV - 2020 Silverado 2500 Duramax 4x4
taylor.coyote Posted November 13, 2025 Posted November 13, 2025 (edited) We spend a great deal of time "off road" and have struggled with a reliable solution to protect the trailer from road rock damage. In our case with many miles using only mud flaps, the glass/ gelcoat at close inspection had the effect of a mild sandblasting. The PPF installers did not recommend installation due the surface being porous and not super smooth due to "road wear". We have been pleased with a somewhat radical solution; shooting the nose of our trailer with Vortex. We learned of the Vortext process from "Bugeyed driver". Our Vortext coating was applied recently but so far amazingly "bomb tough". We are now traveling on nasty fractured rocked/graveled roads stress free. This solution may not be for everyone but is a valid consideration if you spend a lot of time on gravel or your gelcoat is "road worn" and not longer super smooth. A further note on gravel protection: John Davies has a post on an under trailer mid flap to protect the under side and trailer running gear (socket, springs, axles and other) from gravel damage. We have found this to be effective and recommended if you spend time on gravel. Edited December 11, 2025 by taylor.coyote typo 8 2016 Legacy Elite II, Twin Beds, Hull #124 Tow Vehicle: 2019 Ford F250 4x4 / Short Bed / Crew Cab / 6.7 Diesel Fieldbrook, Ca
jd1923 Posted December 5, 2025 Posted December 5, 2025 On 11/13/2025 at 3:16 AM, taylor.coyote said: Our Vortex coating was applied recently... Did you coat this yourself or did you have a local dealer service the coating? Looks like it requires special equipment. We just got our Oliver polished and ceramic coated and it looks better than ever up front and all over. However, we off-road with a Lexus GX470. Had it painted a couple years ago and it looks great except the LARGE plastic front bumper has gotten scratched up, paint pealing only on the plastic from off-road use and pressure-washing. A black vortex coating may be the answer! I would remove the bumper to get it sanded and coated properly. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Jason Foster Posted December 10, 2025 Posted December 10, 2025 On 11/13/2025 at 4:16 AM, taylor.coyote said: We spend a great deal of time "off road" and have struggled with a reliable solution to protect the trailer from road rock damage. In our case with many miles using only mud flaps, the glass/ gelcoat at close inspection had the effect of a mild sandblasting. The PPF installers did not recommend installation due the surface being porous and not super smooth due to "road wear". We have been pleased with a somewhat radical solution; shooting the nose of our trailer with Vortex. We learned of the Vortext process from "Bugeyed driver". Our Vortext coating was applied recently but so far amazingly "bomb tough". We are now traveling on nasty fractured rocked/graveled roads stress free. This solution may not be for everyone but is a valid consideration if you spend a lot of time on gravel or your gelcoat is "road worn" and not longer super smooth. A further note on gravel protection: John Davies has a post on an under trailer mud flap to protect the under side and trailer running gear (socket, springs, axles and other) from gravel damage. We have found this to be effective and recommended if you spend time on gravel. That looks good. How much weight does it add the the trailer? Is it soft or hard? 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
taylor.coyote Posted December 11, 2025 Posted December 11, 2025 (edited) JD and Jason, Vortex must be applied with special equipment by an experienced shop. I got my inspiration from Bugeyed Driver. Vortex is similar to Line-X spray on pick-up bed liner in texture and feel (a firm rubber like finish) I chose Vortex because it is applied at a much lower temperture than Line-X (best not to heat fiberglass too much) and can be painted with automotive paint to match your hull. Bugeyed Driver estimates it increased his tongue weight by 40lbs. The coating is substantial and tough. We have been on the road five 5 week since the application and are pleased to date.. I feel Vortex is a very good solution to protect your trailer nose. Bugeyed Driver has years of experiences with his Vortex.. Edited December 11, 2025 by taylor.coyote was not done writing 1 2 2016 Legacy Elite II, Twin Beds, Hull #124 Tow Vehicle: 2019 Ford F250 4x4 / Short Bed / Crew Cab / 6.7 Diesel Fieldbrook, Ca
Douglas Rink Posted yesterday at 02:18 PM Posted yesterday at 02:18 PM I was wondering if anyone had put a Vortex or LineX type of covering on their Oliver and what kind of results they had. I’m taking delivery of an Apex 23 in October and have made an appointment with the folks who do the ceramic coatings to do a PPL on the front and lower undersides of my trailer to provide some additional protection against debris being thrown up. Seems like a good idea to do right off the bat vs after taking damage though the thought of spraying my brad new trailer gives me a huge “eak”!!!!
Galileo Posted yesterday at 05:33 PM Posted yesterday at 05:33 PM I purchased a “Rock Tamer” mudflap setup to use on our two vehicles, assembled it part way and essentially abandoned the project because of not having the right tools handy to trim the mudflap height/length and “drill” the holes through the gummy “rubber” material. After towing the Ollie for a season, I checked and found so little evidence - much less “damage” to the lower front area of the trailer that I decided that the added weight and fooling with the RockTamer (that fits over the ball carrier shaft) really isn’t necessary. If anything, weathering of the gel coat and nicks from rocks kicked up by -other- vehicles that strike the sides of the trailer are at least as big of a concern as gravel thrown up by our tires. We primarily travel paved roads, and find the few times that we’re on gravel that the roads are SO rough that slowing to walking speed is required to keep dental work and trailer contents where we last stowed them. That said - if anybody is looking for a Rock Tamer setup - I’ll make you a helluva deal on the one I have in storage. It’s in Hammond, LA, but I could arrange to have it in Winnsboro, TX this winter/Spring. https://a.co/d/01fojEhk 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Moderators Mike and Carol Posted yesterday at 05:58 PM Moderators Posted yesterday at 05:58 PM 20 minutes ago, Galileo said: After towing the Ollie for a season, I checked and found so little evidence - much less “damage” to the lower front area of the trailer… We’ve towed now for 10 seasons, 100K+ miles. We have quite a few nicks and chips on the lower front of the trailer. When the CGI guys refresh my ceramic coating next time I’m going to have them put their film on the front. Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Galileo Posted yesterday at 06:09 PM Posted yesterday at 06:09 PM Just now, Mike and Carol said: We’ve towed now for 10 seasons, 100K+ miles. We have quite a few nicks and chips on the lower front of the trailer. When the CGI guys refresh my ceramic coating next time I’m going to have them put their film on the front. Mike We’ve got half as many years and maybe a third of the miles, so I’d expect you have more wear and tear. I do all my own cleaning and polishing - so I’m intimately familiar with the whole front end of the trailer. The upper half gets WAY more abuse from bugs - especially in the Southern states. I’ve only spotted one tiny nick of any significance and it doesn’t even penetrate the gelcoat. I’d guess our “paved roads” mission combined with our low-slung tow vehicles (and not doing burn-outs on gravel) keep the nicks to a minimum. Just from a drivability standpoint, I avoid the jacked-up, high ground clearance vehicles like the AT-4 (or is it ATX?) trim level on our GMC Sierra. Just keeping the truck body close to the ground keeps the amount, trajectory, and velocity of road debris mitigated adequately. I like a vehicle that my wife can enter and exit without a rope ladder - and also at least a bit of ability to see objects close to me when maneuvering in tight parking lots. 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Moderators topgun2 Posted 23 hours ago Moderators Posted 23 hours ago 5 hours ago, Douglas Rink said: Seems like a good idea to do right off the bat vs after taking damage though the thought of spraying my brad new trailer gives me a huge “eak”!!!! There IS an Oliver that has black truck bed liner spray on it and I believe that at least at one time this Oliver actually belonged to one of the Oliver's. I'm sure that Jason Essary would remember it and might even have a pic or two. I was surprised that it didn't look as bad as I thought it would. However, why get a new trailer sprayed right off the bat? Let it get dinged up a bit and then spray it or get PPF applied initially to reduce the dings (assuming that you intend to do some gravel roads and the like). Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators Mike and Carol Posted 23 hours ago Moderators Posted 23 hours ago 1 hour ago, Galileo said: We’ve got half as many years and maybe a third of the miles, so I’d expect you have more wear and tear. My point wasn’t to question your wear or towing technique. I was attempting to let the OP know that a film covering on the lower front of his trailer might be a good investment based on our experience. Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Moderators Mike and Carol Posted 23 hours ago Moderators Posted 23 hours ago 2 minutes ago, topgun2 said: There IS an Oliver that has black truck bed liner spray on it and I believe that at least at one time this Oliver actually belonged to one of the Oliver's. @bugeyedriver has a similar coating on the front of his trailer. It is white and provides great protection. Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
taylor.coyote Posted 18 hours ago Posted 18 hours ago We applied Vortex 8 months ago and have been very pleased. Forest Service / Blm roads rocked with 3/4 to 1.5" fractured rock is the worst. Even with full mud flaps this stuff finds your trailer. Vortex is primarily used as a truck bed liner and is very tough. The guy that sprayed our trailer estimated the weight of the coatings about 40lbs . The material has thickness and some flex to absorb "rock impacts". We tool a 7week trip through the SW and southern UT with a lot of off road in places like Bears Ear / valley of the Gods with no sign of damage. The worst road we know for throwing rock is over Hart Mt in SW oregon, 60 miles of well maintained BLM with large fractured rock. We are still mindful of modest speeds but will travel up to 35mph with no concerns. Before vortex, we became gun-shy and would just crawl along , still taking on some damage. Over time, we had lots of micro chips (like sand blasting) with a few significant chips here and there. 3 2016 Legacy Elite II, Twin Beds, Hull #124 Tow Vehicle: 2019 Ford F250 4x4 / Short Bed / Crew Cab / 6.7 Diesel Fieldbrook, Ca
taylor.coyote Posted 18 hours ago Posted 18 hours ago I have posted this image before but thought it may be useful here because of questions about the cosmetics of Vortex coating. 1 2 2016 Legacy Elite II, Twin Beds, Hull #124 Tow Vehicle: 2019 Ford F250 4x4 / Short Bed / Crew Cab / 6.7 Diesel Fieldbrook, Ca
Moderators topgun2 Posted 6 hours ago Moderators Posted 6 hours ago I assume that to clean the Vortex - all you have to do is powerwash it? Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
taylor.coyote Posted 1 hour ago Posted 1 hour ago So far, warm water, auto soap and a sponge have done the trick to clean the vortex 2016 Legacy Elite II, Twin Beds, Hull #124 Tow Vehicle: 2019 Ford F250 4x4 / Short Bed / Crew Cab / 6.7 Diesel Fieldbrook, Ca
Moderators bugeyedriver Posted 1 hour ago Moderators Posted 1 hour ago The Wonder Egg has had Vortex over the lower front, just like taylor.coyote's picture for about 8 years now. Yes, it added 40 lbs to the weight, but is impervious to rocks. I hesitated to take a trip to Alaska until it was applied. Now, I'll go anywhere, (within reason). 1 Pete & "Bosker". TV - '18 F150 Super-cab Fx4; RV - "The Wonder Egg"; '08 Elite, Hull Number 014. Travel blog of 1st 10 years' wanderings - http://www.peteandthewonderegg.blogspot.com
