While helping my girlfriend with her 2002 Casita to down-size her propane tanks to new 20 lbs tanks, we found that the propane regulator bracket and the hold-down/tank retainer bar were flipped and allowed the regulator, and hence hose/lines, to drop too far down. This can easily happen to any camper with a dual propane tank system like this.
After anyone works on your rig, or you purchase a used travel trailer, ensure things are in order in the propane area.
Hope this helps.
UPDATE: If you look close at her picture, you can also see that the right-angle LP connector off the regulator has now rubbed into the passenger-side tank.  That's not good in any way shape or form - truly bad.  I'm sure these have very strict rules by the DOT. Also, in some rare cases, having certain regulators lower than the tops of the LP tanks, may cause certain LP appliances to fail to operate properly.
Edited by Chris Scarff
Improved image with "Bad" indicator, and UPDATE
  • Like 8
Chris
2016 Legacy Elite II  o-o  Hull #110  o-o  "Rock'in 110"  o-o  Wayfinder (old) o-o  Twin Bed
2020 RAM 1500 Limited 5.7L
Augusta, Georgia
Chris:
Many of us fully remove the tank hold down bar when filling our propane tanks.  I would prefer not to have the regulator support angle above the tank hold down bar.  Doing so would subject the hoses to additional stress at every tank fill.
That said, I appreciate your warning.  I think that I will add two jamb nuts below the tank hold down bar (One on each side of the regulator support angle) to "fix" the location of the regulator thereby reducing stress on the hoses during survice.
Do you think that would solve the concern?
PS:  It appears that one of your hoses is relatively new and the other is likely a 2016 OEM.  May want to update the older one.
The key is to have enough slack in the hoses to enable lifting the regulator off the threaded stock when removing the propane tanks. This is my preferred setup, as the tank valves and changeover switch are all easily reachable via the housing screw port; and the regulator can be moved out of the way for more clearance when handling the tanks. Note the cable routed through the cross bar, around each tank handle the loop ends on the threaded stock seen behind the regulator, as well as the padlock for securement.
Edited by Ronbrink
4 hours ago, Geronimo John said:
Chris:
I actually love your idea. It seems that in some cases that would be a bit less work.  However, as @Ollie-Haus recently found out with his current regulator, he ended up having to raise up his regulator on the bracket to be a bit higher compared to the top of his tanks. We had an exhaustive conversation about it. This was because his Truma (I think) was having issues igniting, he can verify.
I then read through a bunch of different regulator instructions while at a local hardware store, and found out that some regulators (few) did mention the height/elevation recommendation compared to the tanks.  That was a surprise to me, but I'm a computer guy and have never gotten out of the house much.  LOL
Since I received only this one picture from my girlfriend, I had also noted that it's time to replace both hoses so she has good data on age.
I still love the idea of an easier removal process, no matter what.  Some of you guys are really good with metal-work.  So get to work on ideas.  🫠
PS: If you look close at her picture, you can also see that the right-angle LP connector off the regulator has now rubbed into the passenger-side tank.  That's not good in any way shape or form - truly bad.  I'm sure these have very strict rules by the DOT and other agencies.
Chris
Augusta, Georgia
I believe it’s designed to sit above. Works for me. It drops down when detached/filling tanks and lift up and it sits nice and close when mounted and locked.
I renewed the regulator and lines a couple months ago. 😎 I used your idea of using street elbows so 12” lines would fit nicely!
Also, the new regulator came with a mounting bracket exactly like Ron’s (single mount). I reused the original bracket that mounts to the threaded post above and below for better support (can’t be seen in photo).
Edited by jd1923
As @Chris Scarff mentioned above, I experienced a regulator failure on our 2023 LE2 and it was not allowing  gas to flow at a high enough rate for the Truma furnace to run properly. Rather than making an appointment and going to the trouble of hauling the camper to a local dealer for troubleshooting, I decided to just replace the regulator with an identical model. Currently Oliver is using the Fairview GR-9984. Long story short, the regulator was the problem.
When I received the regulator it came with very specific installation instructions, which clearly indicated that the regulator was not installed correctly from the factory. I have no way of knowing if this had anything to do with the failure, and I doubt that it did or you would likely hear about others experiencing this same problem.
Nevertheless I chose to install the new regulator according to the instructions. I do believe this is an important detail or Fairview would not explicitly detail these instructions.
Below is the instruction sheet that came with my replacement regulator. Notice at the bottom of the page are the highlighted instructions for correct installation and incorrect installation. The next two pictures are my as found installation, followed by my updated installation with the new regulator.
Note: I have ordered a set street 90 fittings to reduce stress on the hoses as others have mentioned in their comments
As found
Updated installation required mounting the bracket to the lower set of holes in the regulator, effectively raising it ~3-4 inches.
There is still about 4 inches of clearance between the top of the regulator and the propane cover and the valve selector is still easily accessible for switching.
Edited by Ollie-Haus
Very well done Ron! Gotta love a neat and clean install! 👍🏻
Now that's a good understatement.   Your post has generated several concepts that frankly need a relook:
  • The need to have the regulator higher than we had envisionated.  (A Geronimo John word)
  • Having enough hose to reduce hose stress especially during tank removal for refill.
  • Using street elbows to get the hose traveling in the right direction from the regulator.
  • Knowing that there is a second set of holes on the regulator.
  • Creative security for our propane gear.
  • Part of the service PITA is that the regulator itself is in the way as the tank installation centerlines are a bit too close.  We have room to spare, but all the "OEM Purchased" components are set up for the "standard" set up where space is very critical.  We have space to spare.
  • Mount the regulator away from the threaded rod sufficient so as to allow the tightening of the rod handle without hitting or being close to the regulator!
And now I'm thinking that the geometry of our OE2 dog house propane hoses and regulators may be space efficient, but it sure does not do us any favors when changing tanks when we have to do a Up and Over maneuver with the tanks.  IMO, doing so always is a small PITA.
I think we can concoct a better design as we are blessed with space under the hood of the dog house.  My assumption is to reuse the tank base, rod, and horizontal tank tie-downbar.  Then to focus on the regulator support. From almost 4,000 miles from our Ollie, I'm going to plant a seed to attract some flamng arrows.  What if we:
A.  Modified the regulator bracket to attach to the verticle threaded rod to have two attachment points on the rod and a regulator bracket so as to put the regulator out of the way for service and high enough to be above the liquid level. Double nut one set of the attachment points on the threaded rod to do so.  In effect the regulator's location would be fixed.
B.  Incorporate into the design a simple way to keep the tanks locked down that can be easily removed for service, light and uses a pad lock.
C. Increase the hose lengths to facilitate service.
D. Use street brass fittings to align the hoses to the direction needed to increase hose bend radius.
image.thumb.png.9f16db063bd35a10e04d26fcb6f1fe6d.pngT
Fromthe picture, the 30 pound tanks diameter has reduced a more restricted space for the regulator.
Edited by Geronimo John
Yes I did encounter interference between the wing nut tabs and the regulator in the upper mounted position. This was quickly and easily remedied with a 12-14 inch adjustable wrench. With the wing nut screwed down tight, use the adjustable wrench to bend the tabs up to a vertical enough angle to clear the back side of the regulator. Problem solved.
Me too on our new unit. Just hold the regulator up with on hand as you spin the wing-nut with the other! All’s good! 😎
I found my pic from 2023 where I turned both tanks 45 degrees making the hoses fit like a glove with nearly no strain on the hoses. Works fantastic, but I do like those 90 degree connectors.  Things to add to my future work truck for common parts.
PS: It looks like I could add those safety gauges and have penty of room for the cover. Sweet!
more bla bla bla
Chris
Augusta, Georgia
i tried that, and did't like the results.  So I just added several inches of  1/2" cpvc pipe under the nut to get it up over the obstructions.  Either way easy fix.
Ok, we have two solutions for the wing nut.
If we were to use the Gas-Gear 90 degree hoses we could use these longer ones:
 Which would allow us to move the regulator forward well out of the way of swinging tanks as we change them.  With the regulator moved out of the way (Forward), using one of these for security makes sense now as getting the lock on it would be eazy.
Just need a simple bracket to move this forward out of the way:
This is sort of turning into a cherry pick the best so far!
Here's one more thing to add to your growing list of annually inspectable items. Use a mirror tool or smart phone to visually inspect the diaphragm air vent on your propane regulators.
Ensure bugs and road debris have not clogged the air vent.  Boy, if going to Alaska, this will need to be inspected often, and carry a spare regular, just to be sure. No propane, no heat while boon-docking. 😵‍💫
Chris
Augusta, Georgia
Ok, I can assume mine is dirty. How do you clean it?
Got an update from Jason Essary today on the installation instructions from Fairview on their automatic regulator. According to Fairview, the instruction sheet that was included in the regulator that I received was an obsolete version and that the high mounting position was no longer applicable. Fairview confirmed with photos from the Oliver factory that their method of installation was acceptable.
Just wanted to pass this along so folks didn’t get unduly concerned with their regulator installation from the factory.
Maybe a soft brush that can get up I. There. Maybe a mini vacuum with LP off, just to be sure.  Inspect first. Assume nothing.
Chris
Augusta, Georgia
My new regulator makes a  whistle or high-pitch tone at times. Like tonight, while we have the fire ring burning.
If I close the tank it stops and when I reopen the tank the sound changes or it may go away for a while which just happened.
I do not remember any sound coming from the older original regulator. I have very good ears and many people may not hear it. Is a high-pitch sound coming from the LP regulator normal?
I’ve never noticed a high=pitch sound from my regulator.
57 minutes ago, Mike and Carol said:
I’ve never noticed a high-pitch sound from my regulator.
Agreed, I believe my new regulator is failing!
It can happen more often in colder weather.  Try turning off gas, unscrew side you were using to release gas and reattach and turN back on.   See if sound goes away.  If not consider another regulator.
ai answer:
Common "Normal" Causes
  • Diaphragm Vibration: The most common cause is the rubber diaphragm inside the regulator vibrating as it moves to maintain steady gas pressure. This is generally harmless if there is no gas odor.
  • Environmental Factors: Outside temperature, humidity, and barometric pressure can cause internal components to resonate or vibrate more than usual.
  • High Gas Flow: If you are running multiple burners or a high-output appliance, the increased volume of gas rushing through the small internal orifice can create a high-pitched noise.
  • Low Tank Level: In some cases, a tank that is nearly empty can cause the regulator to hum as it struggles to maintain pressure.
When to Take Action
  • If You Smell Gas: A high-pitched "hissing" accompanied by a rotten egg smell indicates a gas leak. Shut off the tank valve immediately and evacuate the area.
  • Poor Performance: If the noise is paired with weak, yellow, or flickering flames, the regulator may be failing and need replacement.
  • Overfilled Tank: If the sound started immediately after a refill and is accompanied by a gurgling noise, the tank may be overfilled, putting excess strain on the regulator.
Edited by Galway Girl
Added ai
Like Mike T I've never heard any noise from my regulator.
However, even though the temps do go below freezing when at altitude during my summer fishing trips, the temps rise quickly with the sun and I rarely use the furnace for these time due to the fact that mid to high 20's is about as low as it gets and that is only for short duration.
JD:
Your regulator may be undersized for the load.  Past posts indicate that the gas regulator size likely should be in this range:
·       The OEM Hull 505:   GR-9984XF with 345,000 BTU
·       Possible Smaller Replacement Part if above is not available:  GR-9994XF has 262,500 BTU
If you are using a high demand outside stove, grill or fire ring especially with the furnace running; then for sure go the larger regulation.
Hope this helps with the moonlight harmony you are getting from your regulatior.
PS:  The Fairview gas regulators are designed in USA and made in North America.  I have purchased them from American Copper and Brass for a lot less than most posted prices on the net.  Worth checking them out.
added PS
I checked AC out yesterday, the version they sell is the 262K BTU version (bottom in data sheet)GR-9994.
Amazon has the GR-9984 with 345,000 BTU version (top of data sheet) for about $95 and E-Trailer $125 or so...
