My wife and I are traveling to look at a new 2026 Oliver and reading this thread got me curious. Are the suspension parts being replaced due to wearing out or are the OEII factory suspension underrated?
thanks!
I'm sure that you will receive a bunch of differing views on this subject and your question.
As is covered in the many posts related to this subject, there are those members that believe that the stock suspension is underrated and there are those members that believe that at least some of the issues you might read about are due to things wearing out.  There are other opinions that Dexter (the main suspension parts supplier to Oliver) had a run of "bad" or "defective" or "weak" or .... parts from China that caused at least some of the issues.  And, of course, there is the manner in which and individual trailer was used - a bunch of rough off-road activity, hitting curbs, etc.
Happy reading!
Edited by topgun2
The stock suspension is fine.  We replaced everything after 9 years and a lot of miles (100K+).  There have been some cases of leaf spring failure, but when I had ours replaced they looked fine.  I’m just a believer in preventive maintenance (too many years in the Army).  There was no reason to replace my axles, except to upgrade from the 3500 lb axles and also get bigger brakes and never lube bearings.  Our camping is a combination of nice roads and not so nice roads.  Mike
2 hours ago, xdr said:
My wife and I are traveling to look at a new 2026 Oliver and reading this thread got me curious. Are the suspension parts being replaced due to wearing out or are the OEII factory suspension underrated? thanks!
Lot's of good replies here already! Am I correct in thinking new Oliver TTs now come with the Dexter D52 (5200 LB) Nev-R Lube axles? Some of us with older hulls had D35 axles installed and like Mike mentioned, have upgraded. So, you should be good here.
Either way, OTT installs Dexter Chinese made leaf springs rated at 1750 LBS each. Although, we've heard rumors OTT is talking with Alcan Springs for USA made springs. Given you're buying new in 2026, you could ask them about this!
Search for keyword 'Alcan' for more information. Many of us think 1750 LB springs are under-sprung (200 Oliver owners have installed Alcan Springs rated at 2750 LBS each), and there have been several failures of these springs documented.
Our Oliver used to waddle like a duck when crossing bridge seams, gas station entrances, or speed bumps on an angle. Not anymore, and since our Oliver suspension is now handling itself, the truck tows better and I was able to remove the Andersen WDH. The Alcan Spring upgrade is a little over $1K plus labor.
On Ollie Elite II. D35 bad. D52 good, with Alcan springs even better. 🙂
thanks!
Welcome to the forum and at some point if you can, try take advantage of the Oliver TT factory tour in Hohenwald, Tenn. You will see why Olivers are the best fiberglass TT made. There is a ton of great information that Oliver provides in Oliver University, digital manuals and their great online DYI videos. There are lots of mods and great information here  as well as the Oliver Owners FB fourm.
As far as the suspension being underrated, this has been a subject debated by many on this forum to the point of ad nauseam. This said, we never had any issues with our stock OEM dexter running gear. We like many others decided to have the 5200# never lube axle upgrade installed and also the Alcan 5 leaf pack, HD wet-bolts and HD shackles. There have been a few leaf spring failures. It’s my understanding not enough failures for a recall.
All the best should you decide to purchase a new Oliver.
We could not be happier with XPLOR Hull# 634!
Welcome!
Edited by Patriot
Thanks for all the replies. We are looking at one right now.
BTW, it does have the Dexter D52 nevrlube axles.
Edited by xdr
Axles manufactured in July 2025! Looks like you have a good opportunity in a Like New Oliver! 😂
XDR:
This axle is rated at 5200 pounds.  It is an excellent axle that well over 200 OE2 owners have upgraded to in the past couple of years.  We specifically like it's 12" brakes and the long life maintenance free bearings.  Better stopping power, especially in mountains and way easier maintenance!
The only down side is that with a lot of miles (And typically 6+ years of sevice), we have had some of the 1750-pound springs flaten out.  Those owners, myself included, were looking at spring replacement and the cost of upgrading to your 5200 Dexter axles to 100% renew our entire suspension system.  The huge discussion was to go with the Dexter 2400-pound rated or the American made Alcon heavier duty rated springs.  The vast majority of the cost to do so is the axle, not the springs.  By comparison the springs are cheap.
Should that happen down the road to your trailer, the good news is that you would already have the higher rated axles.
So I echo Patriot's thoughts, and that OTT is moving in the right direction by exclusively using the higher rated axles on all their trailers, and that the Oliver Trailers are the best on the road.
Geronimo John
Edited by Geronimo John
Thank you all for the information, it’s really good to know the axles are highly recommended and what the potential weak points are down the road. The pic I took above is on a brand new 2026. Hopefully we will be taking it home.
Welcome to our OTT Family!
As questions arise, do your homework as mentioned by Patriot in his post above.  Do down load the new search tool by Wayfinder below.  And always be encouraged to ask questions here on the forum.
I am just starting to poke around Wayfinder's search tool and all I can say is WOW!
I would phrase this D35 good, upgrade to heavier springs better; D52 better, Allan springs even better!
Very kind of you @Geronimo John, thanks!
@xdr I'm not sure how the previous postings have been interpreted by you, but well I hope. Personally, as someone who JUST upgraded his ancient 2016 original lesser springs with Alcan springs, I don't think you will have to worry about leaf springs for several years to come - if you purchase a new trailer.  Those newer heavy springs and axles will do very well for you with, "hopefully", worry-free travels.  And please do travel. There's really no better travel trailer on the market.  Is it perfect?  No, it's a rolling earthquake.  Things will break.  This is the place to get help & answers when needed, and Oliver Support of course.  😉
For those folks purchasing used trailers, like I did in 2021, there were some upgrades to be done.
Good luck and let this awesome group of enthusiasts know if you have any further questions.
Cheers,
Edited by Wayfinder
Chris
o-o  2016 Legacy Elite II (demo) - Hull #110 -"Rock'in 110"
o-o  2024 Ford F-250 Lariat, 7.3L Godzilla gasser
o-o  Augusta, Georgia
Yes with a minor edit.  I copied this axle below:
It IS the desired D52 axle which is designed for 5200 or 6,000 pounds of load depending on use.
But it is also showing that it was derated for this use with the Dextre 3500 spring rating.  With two per axle that tells us that it has the Dexter 1750 springs on each end.
@xdr I'm not sure how the previous postings have been interpreted by you, but well I hope. Personally, as someone who JUST upgraded his ancient 2016 original lesser springs with Alcan springs, I don't think you will have to worry about leaf springs for several years to come - if you purchase a new trailer.  Those newer heavy springs and axles will do very well for you with, "hopefully", worry-free travels.  And please to travel. There's really no better travel trailer on the market.  Is it perfect?  No, it's a rolling earthquake.  Things will break.  This is the place to get help & answers when needed, and Oliver Support of course.  😉
Cheers,
Actually, this whole thread has been very helpful and we are very grateful for all the information.  Thank you all!
We just got home late last night with Hull#1665 right behind us. Lots of learning to do but we are enjoying g the resources here and on YouTube.
@xdr Welcome to the Oliver owners family!  Enjoy your new trailer!  The quality is second to none.  I've had mine for 5 years now and buying it was one of the best decisions I've made. As you've already experienced, the folks on this forum are an amazing, collective wealth of knowledge and experience --- and always interested to help others.  It's another true benefit of owning an Oliver!
Congrats and Welcome !
Dan
2020 Elite II #627, 2026 Toyota Tundra Platinum Hybrid, Colorado
Thank you all! We are so pleased with our purchase and are looking forward to many years of enjoying it.
Time to add a Forum Signature and update your location! 😎
Happy reading!
Spot on Bill. Couldn't have been laid out any clearer.👍
And for sure this is the place to get the best options on how to do them.  Especially now that we have a great search engine at our fingertips!  YEA!
  • Care 1
Camped just outside of Grand Junction awaiting our Tuesday appointment with Alcan for an axle upgrade.  Already did the 5200# spring upgrade as we were treated to the sight of a broken spring last fall.  As these things generally go, our breakdown was nearly 40 miles off the nearest highway.  The tow, springs, labor and expenses related to this adventure reached well over $4000, of which $1800 was thankfully covered by insurance.
When one of these cheap 3500# spring breaks in the usual spot, the trailer will not be able to be moved to any serious degree as the remaining spring will contact the wheel well if a bump of any consequence is experienced and the fibreglass wheelwell will be badly damaged.  This would not be an easy or cheap fix.
My advice to any considering an axle and spring upgrade is to do it and sleep easy.
Edited by Jim and Chris Neuman
Chris:
So sad to read about your spring failure 40 miles in the boondocks with your 5 year old Ollie.  Your situtation was very close to a discussion in early 2024 on how to deal with two flats.  In April 2024 I posted a DIY for a simular situtation and over time reposted that a two flat situtation and a spring failure.  Both likely could be handled by the process discussed in the attachment below.  I would love to hear you thoughts on probability of success it would have had in your out-back situtaiton.  Also any suggested edits would be greatly appreciated.
Now back to whimpy springs......No matter how an Oliver is used, springs should not be an issue for at least a decade or two of use. Certainly not in a trailer less than ten years old.  At this point well over 200 owners have gone with the Alcan springs, and about ten with the Dexter 2400's.  Regardless of which higher rated spring replacement one uses, they are a problem that can not be ignored.
We are now aware that well over 200 OE2 owners have replaced their undersprung 1750's with either the Dexter 2400 or the Alcan's, I am thrilled that OTT is now using the larger braked D52 axles, but disappointed that they are still using those 1750 # rated springs.
I strongly suggest that OTT provide an option for the Dexter 2400 and/or the Alcan equivalent springs.  They would well compliment the D52 axles.
Geronimo John
