Jason Foster Posted February 16, 2025 Posted February 16, 2025 Mine is on there. It fills up with crap. I clean it and I move on. Don't give it much thought really. 2 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
MAX Burner Posted February 16, 2025 Posted February 16, 2025 We removed ours a couple years back - mainly because it was badly oxidized and looked like crap. We bought a replacement strip, but never saw the need to install it - Casablanca doesn't see the light of day unless behind the Tundra rolling to the next OTT adventure. That said, anyone interested in a new awning strip can have ours for the cost of shipping... Just say'n. 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Galileo Posted February 16, 2025 Posted February 16, 2025 20 hours ago, topgun2 said: If/when you replace it, be sure to clean, clean, clean the surface of the Oliver before going any further. Also, a nice low humidity, and warm to hot day when you can hold the new gasket in place for at least 24 hours would be advisable. Always good advice and best practice! One of my first jobs was programming binary load lifters, er, I mean installing body side molding at a car dealership. Cleaning was half the job. (Getting it on straight was the other - and more difficult task!) I made a bit of a science of it - using a heat gun or even a Rube Goldbergesque “oven” to warm the coiled self-adhesive molding to help straighten and soften it. I expect that a lot of cleaning will be required just to remove the old adhesive and stains that are sure to be there. 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Galileo Posted February 16, 2025 Posted February 16, 2025 (edited) 15 hours ago, SeaDawg said: I will interject that we love the awning seal. We have replaced it once.. I guess it depends in how you store and canp Though I can see the argument for both “camps”, I like to keep things as stock as possible. I guess I’ll pull off the existing seal and see if it’s still in decent shape. If so, I’ll find a premium automotive trim adhesive tape and reinstall it. If it’s falling apart, then I’ll get that replacement from Amazon. Or, if we like it without the seal - then job completed. (After the cleaning!) Edited February 16, 2025 by Galileo Autocorrect strikes again! 1 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
jd1923 Posted February 16, 2025 Posted February 16, 2025 2 hours ago, MAX Burner said: We bought a replacement strip, but never saw the need to install it... Prior owner had removed the OEM seal and replaced it with a rain gutter below the awning. Normally, I would be in the same camp as Art, but... Our Oliver has many rain stripes down the streetside body and windows that I do not see on the curbside. Since our Oliver has not had wax or anything since a ceramic job 3-4 years ago, these do not come off with a wash. I would say install none or on both sides. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators topgun2 Posted February 16, 2025 Moderators Posted February 16, 2025 4 hours ago, MAX Burner said: That said, anyone interested in a new awning strip can have ours for the cost of shipping. Dibs! At the Rally? 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted February 17, 2025 Posted February 17, 2025 (edited) On 2/15/2025 at 8:15 PM, Rolind said: I think I remember that if the Truma is a retrofit install, the Truma doesn’t use the existing condensate drains. We had the Truma retro fit install and it does use the OEM condensate drain line and works great. We have never had any ponding of water on the roof, but we always level during set up. If your Truma ponds up you may have a kink in one of your condensate lines. I remember actually speaking with the Oliver tech “Tucker” about this prior to install and he assured me he would take extra care making sure this was a non issue and that the lines/drain tubes were not kinked during the retrofit. Oh those little details. Edited May 12, 2025 by Patriot content 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
MAX Burner Posted February 17, 2025 Posted February 17, 2025 18 hours ago, topgun2 said: Dibs! At the Rally? It's all yours, Bill -- I'll bring it to the rally. 1 2 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Geronimo John Posted February 20, 2025 Posted February 20, 2025 On 10/10/2024 at 2:05 PM, rich.dev said: Yup unfortunately only available in 40’ from what I could find, so that’s what I ordered 40’! Actually that's great as you can do your windows, door, and still have enough for over the windows adjacent to the awning and still have a few feet left over. GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
rich.dev Posted February 20, 2025 Posted February 20, 2025 8 minutes ago, Geronimo John said: Actually that's great as you can do your windows, door, and still have enough for over the windows adjacent to the awning and still have a few feet left over I already have the 1/2” trim lok drip rail above the windows and door! 😊 2 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
John and Debbie Posted February 21, 2025 Posted February 21, 2025 On 2/15/2025 at 9:12 PM, Jason Foster said: Mine is on there. It fills up with crap. I clean it and I move on. Don't give it much thought really. I have awnings on both sides and the seal does collect stuff, but I just take a brush to it and water pressure and clean the area. I don't think much about it either. John 3 John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
Jason Foster Posted May 12, 2025 Posted May 12, 2025 On 2/15/2025 at 11:12 PM, Jason Foster said: Mine is on there. It fills up with crap. I clean it and I move on. Don't give it much thought really. I gave it some more thought this weekend: 3 1 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Moderators Mike and Carol Posted May 12, 2025 Moderators Posted May 12, 2025 9 hours ago, Jason Foster said: I gave it some more thought this weekend: We’re 6 or 7 years without ours and don’t miss it a bit. 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Jason Foster Posted May 12, 2025 Posted May 12, 2025 53 minutes ago, Mike and Carol said: We’re 6 or 7 years without ours and don’t miss it a bit. I think I will be thinking the same. It rained yesterday and the water coming down the side didn’t bother me. The junk that collected on top and was almost permanently imbedded into the seal, brackets and fiberglass concerned me more. 2 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Galileo Posted June 4, 2025 Posted June 4, 2025 On 5/11/2025 at 9:55 PM, Jason Foster said: I gave it some more thought this weekend: Looks like what’s in my basket as of yesterday afternoon! 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Galileo Posted June 4, 2025 Posted June 4, 2025 Well Ollie folks, I got tired of the brown trickles that were coming down over the fridge vent panels and rearward edge of the door from where the rubber seal had detached from the camper body and leaked the brown water from behind the awning. I purchased a new 20’ seal through Amazon - looks like the same exact thing. Pulled the old one off yesterday. Peeled and “rolled” off 99.5% of the old double-sided tape that held it on. (Got a blister on my fingertip from the technique I found to be effective. And then, took my soapy water and assorted brushes to clean the residue an dirt from the former dam created. It came cleaner than I expected. No staining from crud that had built up. All that remains are a few small traces of adhesive that I planned to attack with 79% isopropyl alcohol today. ”Today” decides it’s gonna be a rain day. Bummer. Went outside to do some unrelated chores and was surprised/horrified by what I saw. Multicolor streaks down the side of the trailer! Really surprising as there was really nothing left to run down the side. That, and I had rinsed the whole area and whole side of the camper yesterday. This sucker was CLEAN yesterday and there was no crud left to drip down the side. There was a speck or two of leaf/tree litter, but no streaks of stains or anything. The masks don’t easily wipe or rub off. I am under some trees right now. I’m probably gonna have to use something with a little polishing ability to get it off. Anybody else seen this appear on an otherwise clean camper during/after a rain? I typically use blue Coral cad wash to do regular washing. Though I haven’t used it on the rest of the trailer, I’m using a product on the bug-prone “nose” of the trailer (and front of my TV) that is recommended to make bugs less likely to stick. That stuff seems to work. Im gonna try some StarBrite and Maguires wash and cleaner/wax products to attack these new stripes. Any other suggestions? BTW - I had decided to pass on installing the new rubber seal - but if this is what I have to look forward to - I’ll likely reverse that decision. 1 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Moderators Mike and Carol Posted June 4, 2025 Moderators Posted June 4, 2025 I’ve had mine off for years and the only time I get streaks after a rain is when the top of the trailer isn’t clean. If addressed quickly the streaks come off fairly easily. I still find it a better situation than the debris collected with the seal. Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Galileo Posted June 4, 2025 Posted June 4, 2025 24 minutes ago, Mike and Carol said: I’ve had mine off for years and the only time I get streaks after a rain is when the top of the trailer isn’t clean. If addressed quickly the streaks come off fairly easily. I still find it a better situation than the debris collected with the seal. I cleaned the top of the trailer just this past weekend, so not sure what would be running down onto the side. The street side of the trailer actually looks quite a bit better. Not pristine, but not as dramatic as this. The marks aren’t coming off with just “soap” so I guess I’m gonna have to use something with some polishing capabilities. It’s strange that it looks worse after it’s been cleaned. That makes zero sense. 1 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Moderators topgun2 Posted June 4, 2025 Moderators Posted June 4, 2025 There are a number of products on the market that specifically deal with "black streak" removal. Amazon has a bunch LIKE THESE. I've used a couple of these products on both the Ollie and other campers with good results. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
John Dorrer Posted June 4, 2025 Posted June 4, 2025 18 minutes ago, topgun2 said: There are a number of products on the market that specifically deal with "black streak" removal. Amazon has a bunch LIKE THESE. I've used a couple of these products on both the Ollie and other campers with good results. Bill I have used 303 products for years and have their streak remover. I have been washing on a regular basis after a trip and have not had the issue for a couple of years😊 2 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Patriot Posted June 4, 2025 Posted June 4, 2025 18 minutes ago, topgun2 said: There are a number of products on the market that specifically deal with "black streak" removal. Amazon has a bunch LIKE THESE. I've used a couple of these products on both the Ollie and other campers with good results. Bill It’s also good to be aware these products will not play well with wax and especially ceramic coatings. 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Galileo Posted June 4, 2025 Posted June 4, 2025 37 minutes ago, Patriot said: It’s also good to be aware these products will not play well with wax and especially ceramic coatings. I’m guessing that a ceramic coating would have either prevented the streaks, or made them easy to wipe away. Guessing also that my waxing job or wax product isn’t cutting the mustard. 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Moderators Mike and Carol Posted June 4, 2025 Moderators Posted June 4, 2025 37 minutes ago, Galileo said: I’m guessing that a ceramic coating would have either prevented the streaks, or made them easy to wipe away. Ceramic coating won’t prevent streaking but it does make it easier to clean. 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
John Dorrer Posted June 5, 2025 Posted June 5, 2025 1 hour ago, Patriot said: It’s also good to be aware these products will not play well with wax and especially ceramic coatings. Definitely have to be careful, thoroughly wash with soap and water and then apply a spray of ceramic coating. Haven't had any that wouldn't come off with soap and water. 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Patriot Posted June 5, 2025 Posted June 5, 2025 (edited) 2 hours ago, Galileo said: I’m guessing that a ceramic coating would have either prevented the streaks, or made them easy to wipe away. Yes, it’s much easier to remove the streaks for sure. When not on the road, I park our Oliver in our “Ollie Hangar” here at home. It has really helped keep it clean and streak free and out of the UV. Edited June 5, 2025 by Patriot 2 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
